Salve, ho installato Manjaro gnome 21.2.4 e il touchpad non funziona.
Al momento sto usando un mouse usb
Chassis: laptop
Kernel: Linux 5.15.25-1-MANJARO
Architecture: x86-64
Hardware Vendor: Lenovo
Hardware Model: IdeaPad 5 15IIL05
Come dovrei risolvere?
Ho provato le soluzioni proposte nelle altre discussioni ma non ha funzionato nulla.
Grazie
Salve,
Sorry i will continue in english. You might have to add pci=nocrs
as kernel boot parameter inside /etc/default/grub
to the GRUB_CMDLINE_LINUX_DEFAULT
line … also, bios needs to have Load system defaults
disabled in some cases …
Potresti spiegarmi la procedura?
grazie tante
Either from terminal:
pkexec gedit /etc/default/grub
or Edit the file as Root from Files
Look for the line
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
or whatever is on your file and make it like this
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs udev.log_priority=3"
Save it and open up terminal again, and run:
sudo update-grub
Reboot the system. If that does not help you can remove the pci=nocrs
and update-grub again. and look into BIOS (that i can’t explain) and look for options like Load system defaults
and disable it.
if its a recent install im guessing you took the option of proprietary drivers? worked fine while installing but after no joy.Reinstall taking non proprietary drivers and will be fine. I tried everything after making the same mistake nothing worked except reinstall.
No ho installato due volte l’open source
Ho provato tutto, niente da fare
