Touchpad frozen, does not work
my touchpad suddenly stopped working
I looked at libinput list-devices and it gives me this:
libinput list-devices  :heavy_check_mark:
Failed to open /dev/input/event6 (Permission denied
Failed to open /dev/input/event5 (Permission denied)
Failed to open /dev/input/event0 (Permission denied)
Failed to open /dev/input/event2 (Permission denied)
Failed to open /dev/input/event1 (Permission denied)
Failed to open /dev/input/event4 (Permission denied)
Failed to open /dev/input/event11 (Permission denied)
Failed to open /dev/input/event12 (Permission denied)
Failed to open /dev/input/event13 (Permission denied)
Failed to open /dev/input/event14 (Permission denied)
Failed to open /dev/input/event15 (Permission denied)
Failed to open /dev/input/event16 (Permission denied)
Failed to open /dev/input/event17 (Permission denied)
Failed to open /dev/input/event7 (Permission denied)
Failed to open /dev/input/event8 (Permission denied)
what can I do?? Thank You
It wouldnt have, but it appears some parts of it were removed/edited.
So now part of those comments are visible along with the arrow before your post.
Usually the idea is to not touch it at all … or remove it entirely.
The following should work for that command;
sudo libinput list-devices
but using sudo it says:
sudo libinput list-devices  :heavy_check_mark:
[sudo] Passwort für euki:
Device: Acer Wireless Radio Control
Kernel: /dev/input/event6
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Accel profiles: n/a
Rotation: 0.0
Device: Video Bus
Kernel: /dev/input/event5
Group: 2
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Lid Switch
Kernel: /dev/input/event0
Group: 3
Capabilities: switch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Power Button
Kernel: /dev/input/event2
Group: 4
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Sleep Button
Kernel: /dev/input/event1
Group: 5
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Logitech USB Optical Mouse
Kernel: /dev/input/event4
Group: 6
Capabilities: pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: button
Click methods: none
Accel profiles: flat *adaptive custom
Rotation: 0.0
Device: ELAN0515:01 04F3:3142 Mouse
Kernel: /dev/input/event11
Group: 7
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Calibration: n/a
Scroll methods: *button
Click methods: none
Rotation: n/a
Device: ELAN0515:01 04F3:3142 Touchpad
Kernel: /dev/input/event12
Group: 7
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: *button-areas clickfinger
Disable-w-typing: enabled
Disable-w-trackpointing: enabled
Rotation: n/a
Device: Intel HID events
Kernel: /dev/input/event7
Group: 8
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Intel HID 5 button array
Kernel: /dev/input/event8
Group: 9
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: AT Translated Set 2 keyboard
Kernel: /dev/input/event3
Group: 10
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
Device: Acer WMI hotkeys
Kernel: /dev/input/event10
Group: 11
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: 0.0
One thing to try:
sudo modprobe -r psmouse && sudo modprobe -a psmouse
This happens to me after a sleep cycle, typically just the first one following a reboot.
If the above command works, I’ll find the post where someone detailed a script to run on resume.
Thank You. unfortunately it didn’t work.
It happened suddenly.It was working and then it stopped… I had done a reboot, that 's right, but this event happened long after it.
What could it be? It has worked fine so far.
