Touchpad freezes and comes back only after hardware reset
Hello guys,
For the last weeks, my touchpad stopped working while using it to browse. This DOES NOT happen when I use a mouse (Logitech MX Master 2S) and typically occurs when making gestures with more than one finger (scrolling for example). When it freezes, I simply need to close the lid of my notebook (Dell XPS 9310) and it comes back working. An important note is that my settings allow the Linux to go to sleep mode while with the lid closed.
Here some more information:
~ > inxi --admin --verbosity=7 --filter --width
  Kernel: 5.10.105-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=41eb5b89-c0e9-4e31-b9e8-f8b1b5d4e418 rw i915.enable_psr=0 quiet
    udev.log_priority=3
  Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
  Type: Laptop System: Dell product: XPS 13 9310 v: N/A
  Mobo: Dell model: 022T4X v: A02 serial: <superuser required> UEFI: Dell
    v: 3.3.0 date: 11/12/2021
  ID-1: BAT0 charge: 36.5 Wh (74.8%) condition: 48.8/51.0 Wh (95.8%)
    volts: 8.1 min: 7.6 model: LGC-LGC6.5 DELL 2XXFW15 type: Li-poly
    serial: <filter> status: discharging
  RAM: total: 15.35 GiB used: 7.02 GiB (45.7%)
  RAM Report:
  Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
    arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 728 high: 921 min/max: 400/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 482 2: 652 3: 532 4: 896
    5: 921 6: 890 7: 590 8: 865 bogomips: 47936
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
    driver: i915 v: kernel ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
    class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 3-6:3 chip-ID: 0c45:672a class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Sharp 0x14f9 built: 2020 res: 1920x1200 dpi: 169
    gamma: 1.2 size: 288x180mm (11.34x7.09") diag: 340mm (13.4") ratio: 16:10
    modes: 1920x1200
  Message: Wayland GBM/EGL data currently not available.
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
    driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.10.105-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: no
  Device-1: Intel Wi-Fi 6 AX201 vendor: Rivet Networks driver: iwlwifi
    v: kernel bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
    bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 953.87 GiB used: 59.63 GiB (6.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA
    model: KXG60ZNV1T02 NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B
    rev: 10604107 temp: 43.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
    used: 59.63 GiB (6.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 41eb5b89-c0e9-4e31-b9e8-f8b1b5d4e418
    label: NO_LABEL uuid: 9304-5775
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 27c6:533c class-ID: ff00
  Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: Video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 44.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 278 Uptime: 8d 19h 43m wakeups: 11849 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.2.0 Packages: pacman: 1193 lib: 406
  Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.14
~ > xinput -list
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ xwayland-pointer:17                     	id=6	[slave  pointer  (2)]
⎜   ↳ xwayland-relative-pointer:17            	id=7	[slave  pointer  (2)]
⎜   ↳ xwayland-pointer-gestures:17            	id=8	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ xwayland-keyboard:17                    	id=9	[slave  keyboard (3)]
~ > sudo dmesg | grep i2c_hid        3s
[599003.399780] i2c_hid i2c-DLL0945:00: supply vdd not found, using dummy regulator
[599003.399839] i2c_hid i2c-DLL0945:00: supply vddl not found, using dummy regulator
[694924.087318] i2c_hid i2c-DLL0945:00: supply vdd not found, using dummy regulator
[694924.087373] i2c_hid i2c-DLL0945:00: supply vddl not found, using dummy regulator
[760904.342527] i2c_hid i2c-DLL0945:00: supply vdd not found, using dummy regulator
[760904.342581] i2c_hid i2c-DLL0945:00: supply vddl not found, using dummy regulator
Any ideas? What should I do to stop this behavior?
You might also want to add i915.enable_fbc=1 too …
https://wiki.archlinux.org/title/Dell_XPS_13_(9310)#Random_Hangs_on_i915_with_kernel
Test also on X11 session, does it happen also?
@anon89812132 Tried adding i915.enable_fbc=1 and on X11 session and no luck, same problem. :confused:
