Touchpad doesn't work
Hi, my touchpad doesn’t work
i almost use my dell laptop 7450 with mouse and now i want to use the touchpad. Touchpad is activated in settings and it seems to “be there” because after some time, the key leds dimm and hitting the touchpad, the leds were on.
Any idea were i could check this?
Please post inxi -zv8 so we can learn a little more about your system.
💡 Legibility Tip pasting code
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
inxi -zv8        ─╯
  Kernel: 7.0.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
    root=UUID=a127c97f-3dcb-4e33-a5c8-00969309cc25 rw quiet splash
    resume=UUID=17bc1f4b-88ee-4355-bfc4-cb8ebb18655a udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.27.0
    wm: kwin_wayland with: krunner vt: 3 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: Latitude 7450 v: N/A
  Mobo: Dell model: 00329X v: A00 serial: <superuser required> part-nu: 0CC1
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.15.1
    date: 07/01/2025
  ID-1: BAT0 charge: 57 Wh (100%) condition: 57/57 Wh (100%) health: good
    temp: 28.5 C volts: 12.79 min: 11.4 model: SMP DELL V0W55489
    made: 2024-08-09 type: Li-poly serial: <filter> charging:
    status: not charging control: start: 50% end: 90% type: fast
    avail: adaptive,custom,fast,standard,trickle cycles: 25
  System RAM: total: 32 GiB available: 30.8 GiB used: 7.33 GiB (23.8%)
  Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
    spec: 7467 MT/s actual: 6400 MT/s volts: curr: 0.5 width (bits): data: 16
    total: 16 manufacturer: N/A part-no: N/A serial: N/A
  Device-2: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
  Device-3: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
  Device-4: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
  Device-5: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
  Device-6: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
  Device-7: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
  Device-8: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
  Info: model: Intel Core Ultra 7 165U bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 5 cores: 12 threads: 14 mt: 2 tpc: 2
    st: 10 smt: enabled cache: L1: 1.2 MiB desc: d-10x32 KiB, 2x48 KiB; i-12x64
    KiB L2: 10 MiB desc: 5x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4900:3800:2100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    bogomips: 75264
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
    smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Graphics] vendor: Dell driver: i915
    v: kernel arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+ ports:
    active: DP-5,eDP-1 off: DP-9 empty: DP-1, DP-2, DP-3, DP-6, DP-8, HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:7d45 class-ID: 0300
  Device-2: Creative Live! Cam Chat HD [VF0700]
    driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 3-1.1.3.1.1.4:31 chip-ID: 041e:4088 class-ID: 0102
    serial: <filter>
  Display: wayland server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-5 model: Dell P3223DE serial: <filter> built: 2022 res:
    mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red:
    x: 0.686 y: 0.310 green: x: 0.255 y: 0.643 blue: x: 0.141 y: 0.055 white:
    x: 0.314 y: 0.329 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
    ratio: 16:9 modes: 2560x1440, 1920x1080, 1600x1200, 1280x1024, 1152x864,
    1024x768, 800x600, 640x480, 720x400
  Monitor-2: DP-9 model: BenQ M2700HD serial: <filter> built: 2010
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green:
    x: 0.282 y: 0.604 blue: x: 0.141 y: 0.071 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1152x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  Monitor-3: eDP-1 model: ChiMei InnoLux 0x143b built: 2021 res:
    mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 162 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.349 green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white:
    x: 0.314 y: 0.329 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: 1920x1200
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.2-arch1.2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Graphics (MTL) device-ID: 8086:7d45
    memory: 30.08 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu
    name: Intel Graphics (MTL) driver: mesa intel v: 26.1.2-arch1.2
    device-ID: 8086:7d45 surfaces: N/A
    de: kscreen-console,kscreen-doctor wl: kanshi,wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Meteor Lake IPU vendor: Dell driver: intel-ipu6
    bus-ID: 0000:00:05.0 chip-ID: 8086:7d19 class-ID: 0480
  Device-2: Intel Meteor Lake-P HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 0000:00:1f.3 chip-ID: 8086:7e28 class-ID: 0403
  Device-3: Creative Live! Cam Chat HD [VF0700]
    serial: <filter>
  Device-4: GN Netcom Jabra Link 390 driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.2:12
    chip-ID: 0b0e:2e51 class-ID: 0300 serial: <filter>
  Device-5: Dell MH3021P driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.3:15
    chip-ID: 413c:81e3 class-ID: 0300 serial: <filter>
  API: ALSA v: k7.0.10-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
    driver: iwlwifi v: kernel bus-ID: 0000:71:00.0 chip-ID: 8086:272b
    class-ID: 0280
  IF: wlp113s0f0 state: up mac: <filter>
  IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4.4:13
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s13f0u3u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wwp0s20f0u2 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: Intel BE200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:11 chip-ID: 8087:0036
    class-ID: e001
  Report: rfkill ID: hci1 rfk-id: 1 state: up address: see --recommends
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
    class-ID: 0104
  Local Storage: total: 1.43 TiB used: 301.05 GiB (20.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PVC10 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 61001171 temp: 34.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: RVT0 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Corsair model: Voyager SliderX1
    size: 56.64 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1100 scheme: GPT
  ID-1: / raw-size: 442.75 GiB size: 434.73 GiB (98.19%)
    used: 300.96 GiB (69.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: a127c97f-3dcb-4e33-a5c8-00969309cc25
    used: 86.7 MiB (29.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 831C-63E8
  ID-1: swap-1 type: partition size: 33.89 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 17bc1f4b-88ee-4355-bfc4-cb8ebb18655a
  ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: N/A
    uuid: 5da82338-c907-4cf4-98ea-92bcf2a30c9b
  ID-2: /dev/sdb1 maj-min: 8:17 size: 226 KiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sdb2 maj-min: 8:18 size: 5 MiB fs: vfat label: N/A
    uuid: 6750-B94D
  ID-4: /dev/sdb3 maj-min: 8:19 size: 661.5 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 2-3:10 info: Intel USB3.0 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 8087:0b40
  Hub-4: 2-3.4:11 info: Realtek Dell dock ports: 4 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 0bda:0487
  Hub-5: 2-3.4.3:12 info: Realtek Dell dock ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0413
  Hub-6: 2-3.4.3.1:14 info: Hitachi ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210
  Hub-7: 2-3.4.3.1.1:16 info: Hitachi ports: 4 rev: 3.0
  Device-1: 2-3.4.3.1.1.1:17 info: Corsair Voyager Slider Flash Drive
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
    chip-ID: 1b1c:1a15 class-ID: 0806 serial: <filter>
  Device-2: 2-3.4.3.1.1.3:18 info: VIA Labs VLI Product String
    type: mass storage driver: uas interfaces: 1 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 2109:0716 class-ID: 0806 serial: <filter>
  Device-3: 2-3.4.4:13 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-9: 3-1:20 info: Fresco Logic USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d5c:5801
  Hub-10: 3-1.1:21 info: Realtek Dell dock ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5487
  Hub-11: 3-1.1.3:22 info: Realtek Dell dock ports: 6 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5413
  Hub-12: 3-1.1.3.1:24 info: Hitachi ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
  Hub-13: 3-1.1.3.1.1:27 info: Hitachi ports: 4 rev: 2.1
  Device-1: 3-1.1.3.1.1.2:29 info: Elgato Systems GmbH Stream Deck XL
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 0fd9:008f class-ID: 0300 serial: <filter>
  Device-2: 3-1.1.3.1.1.4:31 info: Creative Live! Cam Chat HD [VF0700]
    type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
    chip-ID: 041e:4088 class-ID: 0102 serial: <filter>
  Device-3: 3-1.1.3.2:25 info: Logitech M-U0007 [Corded Mouse M500]
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 046d:c069 class-ID: 0301
  Device-4: 3-1.1.3.5:26 info: Dell dock type: HID
    chip-ID: 413c:b06f class-ID: 0300 serial: <filter>
  Device-5: 3-1.1.5:23 info: Dell Thunderbolt Dock WD22TB4
    type: HID,billboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 413c:b06e class-ID: 1100 serial: <filter>
  Hub-14: 3-3:3 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
  Device-1: 3-3.2:12 info: GN Netcom Jabra Link 390 type: audio,HID
    driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Device-2: 3-3.3:15 info: Dell MH3021P type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-3: 3-3.5:18 info: VIA Labs Dell MH3021P type: billboard driver: N/A
    power: 100mA chip-ID: 2109:8884 class-ID: 1100 serial: <filter>
  Device-4: 3-5:5 info: SLS Lattice AI USB 2.0 type: <vendor specific>
    driver: gpio_usbio.usbio-gpio,i2c_usbio.usbio-i2c,usbio-bridge interfaces: 1
    rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 2ac1:20c9 class-ID: ff00
  Device-5: 3-8:7 info: Broadcom 58200 type: smart card driver: N/A
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 100mA chip-ID: 0a5c:5865 class-ID: 0b00 serial: <filter>
  Device-6: 3-10:11 info: Intel BE200 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0036 class-ID: e001
  Hub-15: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Device-1: 4-2:2 info: Dell Fibocom FM101R-GL Module
    type: communication,CDC-data driver: cdc_mbim,option,option1 interfaces: 3
    rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    power: 896mA chip-ID: 413c:8213 class-ID: 0a00 serial: <filter>
  System Temperatures: cpu: 63.0 C mobo: 46.0 C sodimm: 37.0 C
  Fan Speeds (rpm): cpu: 1686
  Packages: 2437 pm: pacman pkgs: 2367 libs: 573 tools: octopi,pamac,yay
    pm: flatpak pkgs: 70
    1: https://mirror.23m.com/manjaro/stable/$repo/$arch
    2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    6: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    8: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 408
  1: cpu: 34.8% command: chrome pid: 56553 mem: 750.9 MiB (2.3%)
  2: cpu: 14.5% command: chrome pid: 57299 mem: 327.0 MiB (1.0%)
  3: cpu: 13.8% command: chrome pid: 56745 mem: 213.4 MiB (0.6%)
  4: cpu: 12.2% command: chrome pid: 56788 mem: 352.1 MiB (1.1%)
  5: cpu: 12.1% command: chrome pid: 57336 mem: 359.6 MiB (1.1%)
  Memory top: 5 of 408
  1: mem: 750.9 MiB (2.3%) command: chrome pid: 56553 cpu: 34.8%
  2: mem: 439.0 MiB (1.3%) command: plasmashell pid: 1557 cpu: 0.5%
  3: mem: 419.3 MiB (1.3%) command: DiscoverNotifier pid: 1850 cpu: 0.1%
  4: mem: 359.6 MiB (1.1%) command: chrome pid: 57336 cpu: 12.1%
  5: mem: 352.1 MiB (1.1%) command: chrome pid: 56788 cpu: 12.2%
  Processes: 408 Power: uptime: 49m states: freeze,mem,disk suspend: s2idle
    image: 12.26 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 260
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Zsh v: 5.9.1
    running-in: konsole inxi: 3.3.40
I have no idea if this will work. I don’t have, or care for, a laptop, so this advice might be useless, but ensure/check that you don’t have both the mouse and the touchpad enabled at the same time.
  • Does the touchpad appear in /proc/bus/input/devices?
  • lsmod | grep -E "i2c|multitouch|hid" might also provide some good clues as to whether the necessary modules are loaded at all.
  • If multitouch isn’t listed there, try running sudo modprobe hid_multitouch.
  • Then run sudo dmesg -T | tail -50 and check to see if anything was loaded.
I would make sure it isn’t disabled by a hardware button Fn+<F-key>
In the system settings “Mouse & Touchpad”. I have a Latitude E7470. Perhaps the device isn’t enabled?
This isn’t any issue. You can use both devices together.
I have enable touch an mouse.
But what i do and now it works:
Update (around 600 Packages) were installed and do a firmware upgrade.
I don’t know exactly why it’s working again, but i didn’t changed a setting, only update…
Thanks to all.
This isn’t shouldn’t be.
But, as we all should know, thing aren’t always as they should be…
