Hi, I just installed Manjaro GNOME on my Legion 5. For one boot I think the touchpad worked fine, and now no matter how many times I reboot its not working. Suspending the laptop also didnt help. Please help
My inixi:
System: Host: john-legion Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 40.4
tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 82B1 v: Lenovo Legion 5 15ARH05H serial: <superuser required> Chassis:
type: 10 v: Lenovo Legion 5 15ARH05H serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required> UEFI: LENOVO v: FSCN14WW date: 08/26/2020
Battery: ID-1: BAT0 charge: 60.5 Wh (98.1%) condition: 61.7/60.0 Wh (102.9%) volts: 17.6 min: 15.4 model: SMP L19M4PC0
type: Li-poly serial: 4613 status: Charging cycles: 16
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 rev: 1 cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92663
Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1390 3: 1397 4: 1387 5: 1397
6: 1388 7: 1397 8: 1387 9: 1397 10: 1396 11: 1397 12: 1471 13: 1575 14: 1643 15: 1397 16: 1387
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Lenovo driver: nvidia v: 470.63.01 bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-3:5 chip-ID: 174f:244c class-ID: 0e02
serial: 0001
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver: loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: GN Netcom Jabra EVOLVE Link MS type: USB driver: jabra,snd-usb-audio,usbhid bus-ID: 3-2:3
chip-ID: 0b0e:0305 class-ID: 0300 serial: 00004487139A08
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 1000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 38:f3:ab:15:ae:22
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 1000 bus-ID: 04:00.0 chip-ID: 8086:2723
class-ID: 0280
IF: wlp4s0 state: down mac: 56:0b:22:ea:e7:e5
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-3:3 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 1.38 TiB used: 24.76 GiB (1.8%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM512GDHTNI-87A0B size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: NJ12N513411502B79 rev: 11020C00 temp: 34.9 C scheme: GPT
ID-2: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s type: SSD
serial: 1919E20206DF rev: 023 scheme: GPT
Partition: ID-1: / size: 881.71 GiB used: 24.76 GiB (2.8%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 34.35 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
Sensors: System Temperatures: cpu: 49.5 C mobo: N/A gpu: nvidia temp: 44 C
Info: Processes: 365 Uptime: 19m wakeups: 1 Memory: 31.29 GiB used: 3.49 GiB (11.1%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1321 pacman: 1314 snap: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.06
