Touchegg Not Installing
I have a 2-1 laptop and my touchscreen is working fine for scrolling and typing (onboard) but I’m trying to install Touchegg and it is giving me this back.
could not satisfy dependencies:
- unable to satisfy dependency ‘inputproto’ required by grail
- unable to satisfy dependency ‘grail’ required by geis
- unable to satisfy dependency ‘geis’ required by touchegg-qt5
I’ve never tried it on Manjaro Plasma but surely it should work on it too. The reason I want it is because touch-to-click with finger it not working on my desktop so I can’t click onto any shortcuts or icons in the launcher. Is there a way to get past this without installing touchegg (which proved it’s worth in Kubuntu with the same problem). I use latte dock so perhaps the problem is with that?
Many Thanks
I will create a seperate topic for this but I have a bug where unless I select it all it will not format as code so I will have to send my system information seperately
  Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  parameters: root=UUID=9ec2e85d-3d12-49e5-9df8-f5a7476ed01d rw quiet
  udev.log_priority=3 initrd=boot\initramfs-5.7-x86_64.img
  Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Manjaro Linux
  Type: Convertible System: LENOVO product: 80X8 v: Lenovo YOGA 520-14IKB
  serial: <filter> Chassis: type: 31 v: Lenovo YOGA 520-14IKB serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
  UEFI: LENOVO v: 4QCN51WW(V2.15) date: 11/19/2019
  ID-1: BAT1 charge: 14.5 Wh condition: 33.1/35.0 Wh (95%) volts: 7.4/7.5
  model: SIMPLO PABAS0241231 type: Li-ion serial: <filter> status: Discharging
  Topology: Dual Core model: Intel Pentium 4415U bits: 64 type: MT MCP
  arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: C6
  L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18406
  Speed: 900 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
  4: 901
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:5906
  Device-2: Realtek EasyCamera type: USB driver: uvcvideo bus ID: 1-5:2
  chip ID: 0bda:58ea serial: <filter>
  Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  OpenGL: renderer: Mesa Intel HD Graphics 610 (KBL GT1) v: 4.6 Mesa 20.1.5
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71
  Sound Server: ALSA v: k5.7.15-1-MANJARO
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lenovo driver: ath10k_pci v: kernel port: 3040 bus ID: 02:00.0
  chip ID: 168c:0042
  Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-7:4
  chip ID: 0cf3:e500
  Local Storage: total: 119.24 GiB used: 22.45 GiB (18.8%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW128HEGR-000L2
  size: 119.24 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: 4L1QCXB7 scheme: GPT
  ID-1: / raw size: 43.95 GiB size: 43.01 GiB (97.86%) used: 21.80 GiB (50.7%)
  fs: ext4 dev: /dev/nvme0n1p5
  System Temperatures: cpu: 37.5 C mobo: N/A
  Processes: 203 Uptime: 1h 07m Memory: 3.71 GiB used: 1.74 GiB (46.9%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1076 lib: 291
  Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
  L2 cache: 2048 KiB
  4: 901
  Type: l1tf
  chip ID: 8086:5906
  direct render: Yes
  chip ID: 8086:9d71
  chip ID: 168c:0042
  chip ID: 0cf3:e500
You’ll have to replace inputproto with xorgproto in the grail PKGBUILD.
