I just installed Manjaro 21.3.1 (with gnome 42) on my laptop and 3 and 4 finger gestures don’t work.
I tried reinstalling Touchegg from the official repository as well as Touché (the UI app).
I also tried those command lines from the Touchegg repository :
$ sudo systemctl enable touchegg.service
$ sudo systemctl start touchegg
And the service is active and running :
● touchegg.service - Touchégg Daemon
Loaded: loaded (/usr/lib/systemd/system/touchegg.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2022-07-03 12:42:52 CEST; 6min ago
Docs: https://github.com/JoseExposito/touchegg/tree/master/installation#readme
Main PID: 508 (touchegg)
Tasks: 4 (limit: 9176)
Memory: 13.8M
CPU: 2.763s
CGroup: /system.slice/touchegg.service
└─508 /usr/bin/touchegg --daemon
I also verified if my track-pad could handle gestures.
Device: MSFT0001:02 06CB:7F8F Touchpad
Kernel: /dev/input/event7
Group: 6
Seat: seat0, default
Capabilities: pointer gesture
Finally, I tried to install x11 gestures from gnome extensions but still nothing.
Is there any way to solve this issue?
Thanks in advance.
(I also posted on stackoverflow)
https://stackoverflow.com/questions/72846063/touche-global-gestures-grayed-out-and-says-used-by-gnome
