Hi All,
after connecting a second screen, my main screen’s touch input is offset by a huge amount in the x-axis. How can I fix it?
Wrong category?
Nope, your question is just unclear…
- You have 2 monitors of which one is a touchscreen and the other is not and the touch is offset by exactly half of the second screen?
- If yes: did you extend desktops over 2 screens?
- All applications or just Google Chrome?
- If all applications: an
inxi --admin --verbosity=7 --filter --no-host
,xrandr
andxinput list
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command) - If only Google Chrome: Use FireFox!
Sorry for the late reply.
The laptop has a touchscreen and I am connecting a second monitor without one.
Global Scale is at 225%, but setting it to 100% (and rebooting) did not solve the issue.
- Yes, but I can’t say if it is exactly half of the screen, lets say it is 1 KCalc in StatisticMode
- I used extend
- all applications
(removed some irrelevant stuff)
System: Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=.... rw quiet
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 13 9350 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 07TYC2 v: A01 serial: <filter> UEFI: Dell v: 1.12.2 date: 12/15/2019
CPU: Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake family: 6 model-id: 4E (78)
stepping: 3 microcode: D6 L2 cache: 3072 KiB bogomips: 19204
Speed: 467 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:1916
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo bus ID: 1-5:4 chip ID: 0c45:670c
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1800 s-dpi: 96 s-size: 1353x475mm (53.3x18.7") s-diag: 1434mm (56.5")
Monitor-1: eDP1 res: 3200x1800 hz: 60 dpi: 280 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
Monitor-2: DP1 res: 1920x1200 hz: 60 dpi: 83 size: 590x370mm (23.2x14.6") diag: 696mm (27.4")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-2: 1-4:3 info: Elan Micro Touchscreen type: HID driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s chip ID: 04f3:20d0
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 3-1:2 info: NXP s PTN5002 [Startech VGA/DVI-D adapter] type: N/A driver: N/A interfaces: 1 rev: 2.0
speed: 12 Mb/s chip ID: 1fc9:5002 serial: <filter>
xrandr
output:
Screen 0: minimum 8 x 8, current 5120 x 1800, maximum 32767 x 32767
eDP1 connected primary 3200x1800+0+0 (normal left inverted right x axis y axis) 290mm x 170mm
3200x1800 59.98*+ 59.94
2880x1620 59.97
2560x1600 59.99 59.97
2560x1440 59.96 60.00 59.95
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
2048x1152 60.00 59.90 59.91
1920x1200 59.88 59.95
1920x1080 59.96 60.00 59.93
1600x1200 60.00
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 60.00 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 60.00 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
640x360 59.84 59.32 60.00
DP1 connected 1920x1200+3200+0 (normal left inverted right x axis y axis) 590mm x 370mm
1920x1200 59.95*+
1600x1200 60.00
1280x1024 75.02 60.02
1440x900 74.98 59.89
1280x960 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
640x480 75.00 72.81 66.67 59.94
720x400 70.08
DP2 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
xinput list
output:
Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ DLL0704:01 06CB:76AE Mouse id=11 [slave pointer (2)]
⎜ ↳ DLL0704:01 06CB:76AE Touchpad id=12 [slave pointer (2)]
⎜ ↳ ELAN Touchscreen id=10 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
↳ Intel HID events id=13 [slave keyboard (3)]
↳ Dell WMI hotkeys id=14 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=15 [slave keyboard (3)]
↳ Integrated_Webcam_HD: Integrate id=16 [slave keyboard (3)]```
It’s probably not exactly half but 3/5 of the screen looking at your resolutions and confirms my suspicion: the X screen is 5120 pixels wide and the touchscreen only 3200.
That’s what I suspected.
Kernel 5.7 is EOL please upgrade to an LTS or a higher version.
Test 1: try setting the resolution of the first screen to 1280x800 (from 3200x1800 and see if that makes the touch screen available over the entire width, please?)
For the next test, I’ll need the output of
xinput list-props 10
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
(as that makes our life much easier so you get helped more quickly and efficiently)
P.S. Nothing to do for you this time as I’m an editor on this site and have done that for you already…
Thanks for the heads-up, I’ll upgrade my kernel.
Setting the main screen resolution to 1280x800 did not solve it, unfortunately (also tested it with global scale 100%)
Device 'ELAN Touchscreen':
Device Enabled (174): 1
Coordinate Transformation Matrix (176): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Calibration Matrix (314): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Calibration Matrix Default (315): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Send Events Modes Available (297): 1, 0
libinput Send Events Mode Enabled (298): 0, 0
libinput Send Events Mode Enabled Default (299): 0, 0
Device Node (300): "/dev/input/event5"
Device Product ID (301): 1267, 8400```
Unfortunately your touch screen doesn’t seem to have a scaling option neither, so the only thing I can tell you now is:
- In dual-monitor mode, use the mouse and stay away from the touchscreen
OR - Ensure the second monitor is a touch screen too…
Well, too bad…
Do you happen to know how ubuntu handles this - it seems to work there (I really don’t want to go back).
Urgh… I migrated away from Ubuntu 9 months ago… Can you boot an Ubuntu Live USB and provide xrandr
and xinput
output from there???
Sure!
xrandr
Screen 0: minimum 320 x 200, current 5120 x 1800, maximum 16384 x 16384
eDP-1 connected primary 3200x1800+0+0 (normal left inverted right x axis y axis) 294mm x 165mm
3200x1800 59.98*+ 59.96 59.94
2880x1620 59.96 59.97
2560x1440 59.99 59.99 59.96 59.95
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1080 60.01 59.97 59.96 59.93
1600x1200 60.00
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 connected 1920x1200+3200+0 (normal left inverted right x axis y axis) 593mm x 371mm
1920x1200 59.95*+
1600x1200 60.00
1280x960 60.00
1152x864 75.00
832x624 74.55
720x400 70.08
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ DLL0704:01 06CB:76AE Mouse id=12 [slave pointer (2)]
⎜ ↳ DLL0704:01 06CB:76AE Touchpad id=13 [slave pointer (2)]
⎜ ↳ PS/2 Generic Mouse id=17 [slave pointer (2)]
↳ Integrated_Webcam_HD: Integrate id=11 [slave keyboard (3)]
↳ Intel HID events id=14 [slave keyboard (3)]
↳ Dell WMI hotkeys id=15 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=16 [slave keyboard (3)]
No difference. I wouldn’t know where to look now…
Ok, thank you!
Calibrating Touchscreen
