Can we use the pinephone’s modem 4G or Wifi to create nodes similar to short wave radio systems to communicate without the internet? Nodes would relay bandwidth between each other and thus provide totally decentralized long distance communication. Some nodes would be super nodes with internet connection sharing. This would be great in local communities without good internet access or no internet at all or even states with deep internet censorship. The more people would connect, the further we would be able to reach each other by relaying connections from node to node to node. Please feel free to discuss and share ideas.
Please read this:
Especially the section What’s this Upstream/Downstream business and then file a feature request upstream…
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
