Hi,
torbrowser does not start
sudo pacman -Qi torbrowser-launcher
Version : 0.3.7-3
Description : Securely and easily download, verify, install, and launch Tor Browser in Linux
Architecture : any
URL : https://github.com/torproject/torbrowser-launcher
Licenses : MIT
Groups : None
Provides : None
Depends On : dbus-glib gnupg hicolor-icon-theme python python-gpgme python-packaging python-pyqt5 python-pysocks python-requests tor
Optional Deps : apparmor: support for apparmor profiles [installed]
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 267.29 KiB
Packager : Jelle van der Waa <jelle@archlinux.org>
Build Date : Fri 29 Nov 2024 05:00:55 PM CET
Install Date : Fri 23 May 2025 11:04:11 AM CEST
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
torbrowser-launcher
Tor Browser Launcher
By Micah Lee & Tor Project, licensed under MIT
version 0.3.7
https://gitlab.torproject.org/tpo/applications/torbrowser-launcher/
Launching Tor Browser.
Running /home/marco/.local/share/torbrowser/tbb/x86_64/tor-browser/start-tor-browser.desktop
File "/usr/bin/torbrowser-launcher", line 31, in <module>
torbrowser_launcher.main()
File "/usr/lib/python3.13/site-packages/torbrowser_launcher/__init__.py", line 92, in main
gui = Launcher(common, app, url_list)
File "/usr/lib/python3.13/site-packages/torbrowser_launcher/launcher.py", line 168, in __init__
self.update()
File "/usr/lib/python3.13/site-packages/torbrowser_launcher/launcher.py", line 215, in update
self.start(None)
File "/usr/lib/python3.13/site-packages/torbrowser_launcher/launcher.py", line 232, in start
self.run_task()
File "/usr/lib/python3.13/site-packages/torbrowser_launcher/launcher.py", line 300, in run_task
self.run()
File "/usr/lib/python3.13/site-packages/torbrowser_launcher/launcher.py", line 480, in run
subprocess.call(
[self.common.paths["tbb"]["start"]], cwd=self.common.paths["tbb"]["dir_tbb"]
File "/usr/lib/python3.13/subprocess.py", line 395, in call
with Popen(*popenargs, **kwargs) as p:
File "/usr/lib/python3.13/subprocess.py", line 1039, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
pass_fds, cwd, env,
...<5 lines>...
gid, gids, uid, umask,
start_new_session, process_group)
File "/usr/lib/python3.13/subprocess.py", line 1969, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: '/home/marco/.local/share/torbrowser/tbb/x86_64/tor-browser/start-tor-browser.desktop'
Best
