[Update: Reinstalling manually eventually resolved the inability to load the browser, I don’t have much more in the way of details as to how it resolved. Again, uninstall reinstall pacmac didn’t work, doing this here: is what did it. (- Is changing the /etc/tor/torrc configuration file ever necessary in your book?)
Related question: Is it really bad to use ublock or other add ons with Tor Browser? I don’t understand what about an adblocker destroys the OpSec.
- [warn] Tor was compiled with zstd 1.5.0, but is running with zstd 1.5.2. For safety, we’ll avoid using advanced zstd functionality.
*** [notice] Read configuration file “/etc/tor/torrc”.** - [warn] Error setting groups to gid 43: “Operation not permitted”.
- [warn] If you set the “User” option, you must start Tor as root. *( I don’t remember settings a “user” and if I type “sudo Tor” it still doesn’t work. )
- [warn] Failed to parse/validate config: Problem with User value. See logs for details.
*** [err] Reading config failed–see warnings above.**
Note: xpost Reddit
