TOR Browser not launching following 2025-06-23 update
Everything went well and in good order. I just have one issue: I can’t launch Tor Browser anymore.
Doesn’t launch from taskbar, so I tried from the terminal but the application launch command “completes” rather than running until I close it. See below output:
user@host:~/home$ torbrowser-launcher
Tor Browser Launcher
By Micah Lee & Tor Project, licensed under MIT
version 0.3.7
https://gitlab.torproject.org/tpo/applications/torbrowser-launcher/
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
qt.qpa.qgnomeplatform.theme: The desktop style for QtQuick Controls 2 applications is not available on the system (qqc2-desktop-style). The application may look broken.
Launching Tor Browser.
Running /home/johndoe/.local/share/torbrowser/tbb/x86_64/tor-browser/start-tor-browser.desktop
Launching './Browser/start-tor-browser --detach'...
…and the process ends right there.
Here’s also some system info:
  Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=ed025dba-939e-4bf2-aaef-2acc1bb7d828 rw
    cryptdevice=UUID=243adbf7-1101-43ce-a40f-9559f05bd5e2:luks-243adbf7-1101-43ce-a40f-9559f05bd5e2
    root=/dev/mapper/luks-243adbf7-1101-43ce-a40f-9559f05bd5e2 apparmor=1
    security=apparmor sysrq_always_enabled=1
  Desktop: GNOME v: 48.2 tk: GTK v: 3.24.49 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: lxlock dm: GDM v: 48.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: Latitude 5480 v: N/A
  Mobo: Dell model: 0R75NX v: A00 serial: <superuser required> part-nu: 07A7
    uuid: <superuser required> UEFI: Dell v: 1.31.0 date: 07/03/2023
  ID-1: BAT0 charge: 55.6 Wh (100.0%) condition: 55.6/68.0 Wh (81.7%)
    volts: 8.1 min: 7.6 model: LGC-LGC8.820 DELL DV9NT84 type: Li-ion
    serial: <filter> status: full
  System RAM: total: 16 GiB available: 15.37 GiB used: 2.5 GiB (16.3%)
  Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: 80AD000080AD part-no: HMA81GS6AFR8N-UH serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous unbuffered (unregistered)
    manufacturer: 094900000000 part-no: V01D4S88GB52F52F2400 serial: N/A
  Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 3500 min/max: 400/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3500 2: 3500 3: 3500 4: 3500 bogomips: 21607
    sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
    vulnerable
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:5916 class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
    chip-ID: 1bcf:2b96 class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: ASUS VY279 serial: <filter> built: 2022
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.643 y: 0.333 green:
    x: 0.306 y: 0.620 blue: x: 0.153 y: 0.075 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1152x864,
    1280x720, 1440x576, 1024x768, 1440x480, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x14c3 built: 2016 res: 1366x768
    dpi: 112 gamma: 1.2 chroma: red: x: 0.576 y: 0.333 green: x: 0.325 y: 0.580
    blue: x: 0.157 y: 0.137 white: x: 0.314 y: 0.329
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1366x768
  API: EGL Message: EGL data requires eglinfo. Check --recommends.
  Info: Tools: x11: xprop,xrandr
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
    class-ID: 0403
  API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  Device-1: luks-243adbf7-1101-43ce-a40f-9559f05bd5e2 maj-min: 254:0
    type: LUKS dm: dm-0 size: 238.17 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 238.17 GiB
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 238.47 GiB used: 144.01 GiB (60.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD PM871b M.2 2280
    256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2D0Q scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.37 GiB (97.99%)
    used: 143.98 GiB (61.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-243adbf7-1101-43ce-a40f-9559f05bd5e2 label: N/A
    uuid: ed025dba-939e-4bf2-aaef-2acc1bb7d828
    used: 32.5 MiB (10.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: E6F3-AB15
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Sunplus Innovation Integrated_Webcam_HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:2b96 class-ID: 0e02
  Device-2: 1-10:3 info: Broadcom BCM5880 Secure Applications Processor
    Smartcard reader type: smart card driver: N/A interfaces: 2 rev: 1.1
    chip-ID: 0a5c:5832 class-ID: 0b00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 0.0 C pch: 42.5 C mobo: 37.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1547 libs: 456 tools: gnome-software,pamac
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    8: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 229
  1: cpu: 12.0% command: brave pid: 3877 mem: 248.1 MiB (1.5%)
  2: cpu: 8.2% command: brave pid: 3847 mem: 224.1 MiB (1.4%)
  3: cpu: 4.9% command: gnome-shell pid: 1500 mem: 315.7 MiB (2.0%)
  4: cpu: 4.7% command: gnome-terminal-server pid: 3910 mem: 58.0 MiB (0.3%)
  5: cpu: 4.4% command: brave pid: 3094 mem: 282.6 MiB (1.7%)
  Memory top: 5 of 229
  1: mem: 401.4 MiB (2.5%) command: brave pid: 3004 cpu: 2.2%
  2: mem: 315.7 MiB (2.0%) command: gnome-shell pid: 1500 cpu: 4.9%
  3: mem: 282.6 MiB (1.7%) command: brave pid: 3094 cpu: 4.4%
  4: mem: 248.1 MiB (1.5%) command: brave pid: 3877 cpu: 12.0%
  5: mem: 224.1 MiB (1.4%) command: brave pid: 3847 cpu: 8.2%
  Processes: 229 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.13 GiB services: gsd-power,
    tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
    inxi: 3.3.38
Thoughts?
I’ve moved your post to its own dedicated topic as it may get better attention. :wink:
Does the journal output anything usefull?
eg run journalctl --follow in a seperate tab/window
example as provided recreated: Tor works here on gnome altho unstable branch system, same startup output.
An option is to reset the cache/settings, start with a fresh profile.
1. Save (backup) your bookmarks.
2. Uninstall TorBrowser and nuke the entire directory from orbit.
3. Install a fresh copy, and restore your bookmarks.
Disclaimer: This may or may not solve the problem.
While running journalctl --follow, I’m getting this when launching Tor browser from the terminal (torbrowser-launcher):
Jun 29 12:51:59 host kernel: audit: type=1400 audit(1751215919.699:182): apparmor="DENIED" operation="mknod" class="file" profile="torbrowser_firefox" name="/run/user/1000/wayland-proxy-3589" pid=3589 comm="firefox.real" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
Jun 29 12:51:59 host kernel: audit: type=1400 audit(1751215919.729:183): apparmor="DENIED" operation="open" class="file" profile="torbrowser_firefox" name="/usr/share/xkeyboard-config-2/rules/evdev" pid=3589 comm="firefox.real" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Jun 29 12:51:59 host kernel: firefox.real[3589]: segfault at 8 ip 00007408e328b9d4 sp 00007ffda5138e58 error 6 in libxkbcommon.so.0.10.0[229d4,7408e326c000+29000] likely on CPU 0 (core 0, socket 0)
Jun 29 12:51:59 host kernel: Code: f9 12 00 00 49 29 c1 46 0f b7 0c 4b e9 a4 fb ff ff ff 15 57 14 03 00 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00 f3 0f 1e fa <83> 47 08 01 48 89 f8 c3 0f 1f 40 00 f3 0f 1e fa 48 85 ff 0f 84 3b
And I get this when launching from the taskbar:
Jun 29 12:54:00 host systemd[1390]: Started Application launched by gnome-shell.
Jun 29 12:54:00 host python[3673]: Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
Jun 29 12:54:00 host python[3673]: qt.qpa.qgnomeplatform.theme: The desktop style for QtQuick Controls 2 applications is not available on the system (qqc2-desktop-style). The application may look broken.
Jun 29 12:54:00 host torbrowser.desktop[3693]: Launching './Browser/start-tor-browser --detach'...
Jun 29 12:54:00 host torbrowser.desktop[3673]: Tor Browser Launcher
Jun 29 12:54:00 host torbrowser.desktop[3673]: By Micah Lee & Tor Project, licensed under MIT
Jun 29 12:54:00 host torbrowser.desktop[3673]: version 0.3.7
Jun 29 12:54:00 host torbrowser.desktop[3673]: https://gitlab.torproject.org/tpo/applications/torbrowser-launcher/
Jun 29 12:54:00 host torbrowser.desktop[3673]: Launching Tor Browser.
Jun 29 12:54:00 host torbrowser.desktop[3673]: Running /home/johndoe/.local/share/torbrowser/tbb/x86_64/tor-browser/start-tor-browser.desktop
Jun 29 12:54:00 host kernel: audit: type=1400 audit(1751216040.865:184): apparmor="DENIED" operation="mknod" class="file" profile="torbrowser_firefox" name="/run/user/1000/wayland-proxy-3712" pid=3712 comm="firefox.real" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
Jun 29 12:54:00 host kernel: audit: type=1400 audit(1751216040.895:185): apparmor="DENIED" operation="open" class="file" profile="torbrowser_firefox" name="/usr/share/xkeyboard-config-2/rules/evdev" pid=3712 comm="firefox.real" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Jun 29 12:54:00 host kernel: firefox.real[3712]: segfault at 8 ip 00007f939a9ba9d4 sp 00007ffde4daff28 error 6 in libxkbcommon.so.0.10.0[229d4,7f939a99b000+29000] likely on CPU 0 (core 0, socket 0)
Jun 29 12:54:00 host kernel: Code: f9 12 00 00 49 29 c1 46 0f b7 0c 4b e9 a4 fb ff ff ff 15 57 14 03 00 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00 f3 0f 1e fa <83> 47 08 01 48 89 f8 c3 0f 1f 40 00 f3 0f 1e fa 48 85 ff 0f 84 3b
Tiny bit confused now; is it an issue with Gnome? AppArmor? Also getting a segfault?
As far as I know, an AppArmor profile for Tor Browser comes with the Tor Browser package in the repos. I haven’t ever had an issue with Tor Browser’s AppArmor profile so I’m not too sure if it’s that. But I’m a bit perplexed what created this issue since this began right after the recent Manjaro update.
In fact, it might be my first ever issue after an update :slightly_smiling_face:
What do you think? Is your output any different?
Where are the bookmarks located? Would it be in a format that could be imported?
/home/user/.local/share/torbrowser? I see there is a directory under there called gnupg_homedir… is it safe having that deleted in the process?
Being based on Firefox, the method is identical;
Bookmarks (toolbar) → Manage BookmarksImport and BackupBackup
This exports all bookmarks to a bookmarks-YYY-MM-DD.json by default. Take note of where it’s exported to so you can easily find it again.
To restore; it’s the same procedure, only selecting Restore instead. You will be presented with a list of recent backups, but the most recent might not be as current as desired, so choose Choose file from that dropdown and navigate to the .json file you exported, instead.
If you don’t have the toolbar showing, you’ll need to find the dialog via TorBrowser’s menu system.
Yes.
Yes, it’s fine, TorBrowser will recreate it during install. The same applies if you use the downloaded version, as the package is effectively portable on all platforms; whatever is in the package is what you get.
I should note that after seeing the additional information posted, the issue is likely elsewhere, but at least you now know how to backup/restore your bookmarks.
Thank you for explaining, but how would I do that when the browser refuses to launch :slightly_smiling_face:
As for the issue at hand, do you have any thoughts as to what might be going on?
tor browser is based on Firefox.
The same methods to save and restore files apply.
Inside that directory are more folders.
~/.local/share/torbrowser/tbb/x86_64/tor-browser/Browser/TorBrowser/Data/Browser/profile.default
Within it, there are the files that hold bookmarks, passwords etc. - just like in a regular Firefox profile.
places.sqlite
key4.db
etc ...
ls -l ~/.local/share/torbrowser/tbb/x86_64/tor-browser/Browser/TorBrowser/Data/Browser/profile.default
will show them all
Move ~/.local/share/torbrowser to somewhere else to save it
or copy it to somewhere else and then remove the directory
recursively.
A new one will be created.
Also remove
~/.config/torbrowser
and
~/.cache/torbrowser
as well
I just installed it:
sudo pacman -Syu torbrowser-launcher
and then started it via the menu.
It downloaded torbrowser (creating this directory structure) and launched it and it worked …
Thank you, I see my bookmarks there :slightly_smiling_face:. But are these in an importable format?
Also a quick update: I disabled the following AppArmor profiles:
torbrowser.Browser.firefox
torbrowser.Tor.tor
…and lo and behold, Tor Browser is launching and running normally again.
So the question is, what changed in the recent Manjaro update (2025-06-23) that prevents Tor Browser from launching with its AppArmor profile :thinking:? Bear in mind this AppArmor profile came with the Tor Browser package.
And it’s even stranger that (it appears) I’m the only one who has reported this issue as of now.
That is the way Mozilla describes the process of migrating a profile to somewhere else without losing anything.
Look it up.
I have done it dozens of times.
… importable format?
you literally copy the file, to overwrite one with the other of the same name …
function/result corresponds with file name
AppArmor:
I would not know.
Disabled and uninstalled as one of the first things after installing a fresh system.
I have never even tried to deal with it.
I like to keep things simple. :nerd_face:
Hey, you wanted to know, and now you do. :wink:
Bookmarks are backed up fairly regularly; maybe twice a day (guessing) and a .json file is saved each time. They are listed in the dialog, as previously mentioned.
However, if you can’t launch the browser (even in safe mode) then you can still look through the directories manually till you find the one that contains many bookmarks-YYY-MM-DD.json files - the file with the latest date is the latest backup (in case it isn’t obvious).
Copy that somewhere safe to restore later, and nuke away.
Anecdotal:- TorBrowser launches without issue (for me).
What is that? :eyes:
I really only want AppArmor for Tor so disabling it isn’t quite the solution. I won’t mark it as resolved just yet in case there are answers or an explanation as to why the profile suddenly won’t work following the 2025-06-23 system update.
I’ll try to figure this problem out first but if to no avail, nuke away I will :slightly_smiling_face:.
Probably a typo - but he will know better.
Same for me.
And I didn’t explicitly disable AppArmor in my recent installation.
Manjaro minimal version - AppArmor at whatever was the default setting.
I think not active by default.
I’d never actively use Tor or the browser - this was just for the sake of trying and seeing …
A special startup mode that virtually every web browser has to allow starting without potentially troublesome elements, such as themes and extensions, for example. The actual branded feature name may vary from browser to browser, but it still achieves the same result. See whatever help system is offerred by individual browsers for specifics.
3 posts were split to a new topic: My tor browser is not launching
@yoel
Did you manage to solve your issue?
If so, please let us know with a brief summary of how you solved it; the topic will otherwise be closed.
Unfortunately I haven’t found out why this happened or how to solve it; just the temporary workaround by disabling the AppArmor profile.
I’ll enable it back once I access my machine and see if the new releases might have fixed it.
OK. Make sure to keep us updated in the meantime. There’s no problem to leave it open a few more weeks, if needed.
Cheers.
I had same issue of tor updater crashing because of apparmor, it only happens on wayland, so i swapped to xorg to update as temporary workaround.
