I’m using Manjaro/KDE Plasma/Stable and I’ve had some issues with Tor Browser since the latest Manjaro updates which rolled out about a week ago.Also, I use the Tor Browser bundle downloaded directly from the Tor Project website rather than the one from the repos. It’s been working fine for years until just recently.
Problem 1: I use an addon called ‘The Dark Reader’ which converts all webpages into a dark theme. For some reason this addon no longer works. I’ve tried reinstalling the addon and even did a fresh install of TB but it doesn’t work still. And by the way, I’m not looking to discuss whether or not you should use addons with TB so please leave that out thanks
Problem 2: Github does not display correctly now. All the content is sparsely spread out all over the place and some things seem to be sized incorrectly. It’s a mess to look at. There seems to be a serious formatting issue. Again, I’ve tried a clean version of TB and it makes no difference. There may be other websites with the same issue but I haven’t noticed any so far.
Problem 3: I can’t get videos to play on Invidious instances. The player says “No compatible source was found for this media”.
So yeh, it seems there is some kind of problem with the visual rendering in TB since the latest system updates. If I roll back to a Timeshift backup from before these updates then these problems go away. I don’t know what could’ve caused it.
Any ideas? I hope to fix this soon as all the bright websites are killing my eyes @_@
Thanks!
Update 1: I tried installing TB from the repos and it still has the same problem so I can rule that out too.
