Tor browser can't connect
I downloaded tor from official website, started it, requested bridges, got them.
But tor can’t connect at all, it even can’t check for updates
I tried rebooting system, changing bridges and turning firewall off
Still not working
endless connecting
Hi,
we need more information. log would be great.
start tor-browser from the terminal and give us the output of the terminal, please. (format output with </> button)
I can confirm that the tor-browser-bin from the AUR works.
(pamac build tor-browser-bin)
(I hardly use the browser, i only use the tor.service in my network)
regards
When i’m trying to run it from term, it detaches for some reason
Here are logs from app itelf tho (stacking at 2%)
2024-08-04 15:46:44.732 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
2024-08-04 15:46:47.005 [NOTICE] Opening Socks listener on 127.0.0.1:9150
2024-08-04 15:46:47.005 [NOTICE] Opened Socks listener connection (ready) on 127.0.0.1:9150
2024-08-04 15:46:47.725 [NOTICE] Bootstrapped 1% (conn_pt): Connecting to pluggable transport
2024-08-04 15:46:47.728 [NOTICE] Bootstrapped 2% (conn_done_pt): Connected to pluggable transport
I find in google that it can be related to wrong system time settings
Honestly, could be the problem, as my pc refuses to work with my timezone, and i changed time by force
If you have time releated issues be sure to set the system time using ntp
sudo systemctl enable --now systemd-timesyncd
Yeah… time errors…
Now i need to create another post to fix my time zone lol xd
I use a little networkmanager script for setting timezone automatically.
That (and some other stuff) can be found here:
