Hello everyone.
Noob-ish here. I just upgraded Manjaro, and now my entire display is hanging whenever I try to startx or something similar. Even if I type clear I get a big hang. The computer is almost unusable, except I can log in to tty as root and do whatever I like. This all leads me to believe that it is a graphics/display issue, but I could be wrong. Regular commands work just fine.
Package versions are:
linux510-nvidia 520.56.06-2
linux510 5.10.148-1
I tried monitoring with systemd-analyze, but nothing seems to be amiss. Any suggestions on how I might debug this, or if this is a known issue?
Olli
23 October 2022 17:51
2
can you post the output of
from console TTY you could do it by sending the output to a file
inxi --admin --verbosity=7 --filter --no-host --width > myinxi.txt
and edit/copy it for more easier transfer from this file
Here you go!
Kernel: 5.10.148-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=680a8b70-06b3-49ca-b358-16d20d41d4ba rw quiet
acpi_backlight=vendor apparmor=1 security=apparmor udev.log_priority=3
Console: tty 1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401IV_GA401IV
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA401IV v: 1.0 serial: <filter>
UEFI: American Megatrends v: GA401IV.214 date: 08/03/2020
ID-1: BAT0 charge: 45.4 Wh (72.2%) condition: 62.9/76.0 Wh (82.7%)
volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging
RAM: total: 15.12 GiB used: 799.3 MiB (5.2%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1K43CB1-CWE serial: N/A
Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
part-no: M471A1K43DB1-CWE serial: <filter>
Info: model: AMD Ryzen 9 4900HS with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1500 high: 3000 min/max: 1400/3000 boost: enabled
base/boost: 3000/4400 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 3000 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 95859
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106M [GeForce RTX 2060 Max-Q] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: speed: Unknown lanes: 63 link-max:
gen: 5 speed: 32 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f12 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 30.0 C
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: amdgpu,modesetting,nouveau,nvidia,vesa alternate: fbdev,nv
gpu: amdgpu tty: 240x67
Monitor-1: eDP-1 model: Sharp LQ140M1JW46 built: 2020 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
Message: GL data unavailable in console for root.
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.10.148-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-887f3061c41a state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-4:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.84 TiB used: 357.62 GiB (19.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
rev: 21106000 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 357.62 GiB
(38.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 680a8b70-06b3-49ca-b358-16d20d41d4ba
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: EAD2-14B7
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: N/A
uuid: 0f0e3232-5006-43c5-98d8-a401fe71d8dc
Hub-1: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: ASUSTek N-KEY Device type: Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:1866 class-ID: 0301
Hub-2: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:521d class-ID: ff00
Device-2: 5-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 6-2:2 info: Samsung PSSD T7 type: Mass Storage driver: uas
interfaces: 1 rev: 3.2 speed: 10 Gb/s power: 896mA chip-ID: 04e8:4001
class-ID: 0806 serial: <filter>
System Temperatures: cpu: 31.6 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
GPU: device: nvidia screen: :0.0 temp: 32 C device: amdgpu temp: 30.0 C
Processes: 339 Uptime: 15m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11
clang: 14.0.6 Packages: 1626 pm: pacman pkgs: 1620 libs: 465 tools: pamac
pm: flatpak pkgs: 6 Shell: Bash (login) v: 5.1.16 running-in: tty 1
inxi: 3.3.22
Olli
23 October 2022 18:01
4
one question, what gui did you use ?
plasma/kde or gnome or cinnamon etc. ? that would help a little bit.
I am using i3 as my desktop environment.
I should also mention that if I run startx at all, I will get:
waiting for X server to begin accepting connections ..
for a really long time.
The funny part is that even the initial boot will take more time than usual, so it might be going deeper than the gui itself?
Olli
23 October 2022 18:13
6
a backup would be priceless now…
Hahaha I do have a backup if need be ! (I’m a week behind, but it’s not killer for me). I was just wondering if there were a nicer way out of this. And I like to learn how to fix my system for future’s sake too.
Olli
23 October 2022 18:23
8
i hope so, but i cannot help on i3 but it’s good to know that you do have plan b.
brahma
23 October 2022 18:39
9
you can try switching kernels and see if it helps
also rerun update again, to see if there are any errors
@brahma @Olli I have no understanding why, but upgrading my kernel from 510 to 515 fixed my issue. If it works, it works Thank you for the help! Wish I knew why though
For those who might have the same issue one day:
mhwd-kernel -li // Figure out which kernel you have
pacman -S linux515 // Install the new kernel
shutdown now
can you also update your UEFI motherboard ?
I just finished fixing a Dell 15-5575. It seemed that X was crapping out. I thought as well it was Video related… but just like you I updated to linux515 and it was magical.
I am also running an AMD CPU chipset (Ryzen3). but I’m running Amd Radeon Vega for Videocard.
Devs, we need to REMOVE 510. Troubleshooting/Upgrading to 510 was the worst experience I’ve had in 10 years.
system
Closed
28 October 2022 11:42
13
