Sometimes the bluetooth enabled checkbox gets unchecked (usually when switching between user sessions)
I can’t recheck it because my mouse is bluetooth.
Any way to toggle it from cli?
I believe the command you’re looking for is:
sudo systemctl restart bluetooth
bluetoothctl ?
(this will of course not work if the service is stopped)
Behind mask this check execute rfkill, so for enable you need:
rfkill unblock bluetooth
and disable:
rfkill block bluetooth
