Hi!
Today’s upgrade annoyingly broke my system. Now when desktop after some idle period dims the display, the display stays black but the mouse pointer is visible and functional. I have to log in the other tty to pass reboot to get rid off that black screen.
My work around it to turn off all energy saving features. I hope there will be fix.
Some info about my system:
Host: rinssi Kernel: 6.10.11-2-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.1.5 Distro: Manjaro Linux
Type: Mini-pc System: Intel Client Systems product: NUC11TNHv7 v: K87768-405
serial: <superuser required>
Mobo: Intel model: NUC11TNBv7 v: K87766-405 serial: <superuser required>
UEFI: Intel v: TNTGLV57.0064.2022.0217.1533 date: 02/17/2022
Info: quad core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
cache: L2: 5 MiB
Speed (MHz): avg: 917 min/max: 400/4800 cores: 1: 917 2: 917 3: 917 4: 917
5: 917 6: 917 7: 917 8: 917
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2 driver: X:
loaded: modesetting dri: iris gpu: i915 s-res: 1920x1080
resolution: 1920x1080
API: EGL v: 1.5 drivers: iris,swrast platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
renderer: Mesa Intel Xe Graphics (TGL GT2)
API: Vulkan v: 1.3.295 drivers: intel surfaces: xcb,xlib
Please read the Stable Update 2024-10-01 announcement; in particular, the section found here with the following headings:
System freeze on suspend
KDE Plasma hangs on Shutdown, Restart and Logout
Either of which might be related to your issue.
Cheers.
I have observed something similar. But I found that as a (hopefully temporary) workaround, if I switch to TTY3 (no need to actually log in or anything), and then back to TTY2, the unlock screen then displays normally.
I tried this:
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
At first it looked that it helped but later on it appears it did not. So, no help for me. Neither switching from tty2 to tty3 does not make any difference.
The mouse pointer is visible and functional. If I move the pointer to upper left corner, I will see all my desktops as supposed. As soon I choose one, display blackens again.
I guess no easy solution available. So far the only thing I can do is to turn off all energy saving features.
Well, then, all I can offer is
cscs
3 October 2024 19:19
6
kernel? tried others?
Also your system info is missing a lot.
inxi -Farz
Also … your BIOS is old.
Some more tests. Updated BIOS to the newest (077). No help. I also tried different kernels; 6.11, 6.10, 6.6 and no any difference. The more detailed info of my system:
inxi -Farz ✔
Kernel: 6.6.52-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=8557f3a3-7af5-4e3c-8c68-d473aeb2e923 rw nowatchdog splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
serial: <superuser required> Chassis: Intel Corporation type: 35 v: 2.0
part-nu: BNUC11TNHv70000/1/2 uuid: <superuser required> UEFI: Intel
v: TNTGLV57.0077.2024.0508.1835 date: 05/08/2024
Device-1: hidpp_battery_1 model: Logitech Signature M650 Mouse
serial: <filter> charge: 25% rechargeable: yes status: discharging
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 747 min/max: 400/4800 scaling: driver: intel_pstate
governor: powersave cores: 1: 747 2: 747 3: 747 4: 747 5: 747 6: 747 7: 747
8: 747 bogomips: 47936
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: DP-1
empty: DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: DP-1 model: BenQ RL2455 serial: <filter> built: 2015
res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 30.49 GiB unified: yes
API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
name: Intel Xe Graphics (TGL GT2) driver: mesa intel v: 24.2.2-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.6.52-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I225-LM driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 58:00.0 chip-ID: 8086:15f2
class-ID: 0200
IF: enp88s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 931.51 GiB used: 575.35 GiB (61.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QJXD7 temp: 41.9 C
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 575.32 GiB (62.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 35.4 MiB (11.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1614 libs: 442 tools: pamac pm: flatpak pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Memory: total: 64 GiB note: est. available: 62.44 GiB used: 3.94 GiB (6.3%)
Processes: 238 Power: uptime: 8h 16m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 24.96 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.32 running-in: yakuake inxi: 3.3.36
