error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: manjaro-pulse and pipewire-v4l2 are in conflict
-> error installing repo packages
On all four systems, so far
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
If you’re using pulseaudio
, there is no need for pipewire-v4l2
Remove pipewire-v4l2
then update.
Moderator
The </> & Ctrl+E failed when I made this post
Palemoon v31.3.0.1 (2022-09-28)
Removed pipewire-v4l2
pacman -R pipewire-v4l2
checking dependencies...
:: pipewire optionally requires pipewire-v4l2: V4L2 interceptor
Packages (1) pipewire-v4l2-1:0.3.57-1
Total Removed Size: 0.08 MiB
:: Do you want to remove these packages? [Y/n]
(1/1) removing pipewire-v4l2 [#####################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
then
:: manjaro-pulse and pipewire-x11-bell are in conflict
remove pipewire-x11-bell and proceed
pamac remove pipewire-x11-bell
Moderator edit: DO NOT use sudo
with pamac
Update now proceeding, very slow, two systems crashed updating, restarted.
Unhappy that such long upgrades are happening especially for rolling update system…
Then don’t use Pale Moon. Either way, you can use your keyboard and type the character instead: `
system
Closed
8
