Greetings,
I have Manjaro Plasma minimal installation running on a Desktop.
Things I have disable at current state;
- Disable Baloo
- Disable TLP
- Disable Touchpad
What else can I disable without crippling the system? What about bluetooth? Though I don’t know if my wireless keyboard and mouse is that category.
[storm@universe ~]$ inxi -Fza
Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=0d88a501-bfd0-432e-934e-91ef0f380bbe rw quiet
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X370-A v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 5222 date: 10/15/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
serial: <filter> charge: 61% rechargeable: yes status: Charging
Device-2: hidpp_battery_1
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Topology: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP
arch: Zen family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138
L2 cache: 4096 KiB
bogomips: 108626
Speed: 2943 MHz min/max: 2200/3400 MHz boost: enabled
Core speeds (MHz): 1: 2871 2: 1744 3: 1741 4: 1741 5: 1878 6: 1884
7: 1879 8: 1880 9: 1745 10: 1745 11: 1879 12: 1882 13: 1881 14: 1885
15: 3488 16: 1743
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK
driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 09:00.0
chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5")
s-diag: 590mm (23.2")
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 10de:10f0
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0b:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.7.14-1-MANJARO
Device-1: Qualcomm Atheros AR9227 Wireless Network Adapter
driver: ath9k v: kernel bus ID: 06:01.0 chip ID: 168c:002d
IF: wlp6s1 state: up mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 07:00.0
chip ID: 10ec:8168
IF: enp7s0 state: down mac: <filter>
Local Storage: total: 1.14 TiB used: 8.94 GiB (0.8%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: A750 scheme: GPT
ID-1: / raw size: 232.38 GiB size: 227.74 GiB (98.00%)
used: 7.65 GiB (3.4%) fs: ext4 dev: /dev/sda2
ID-2: /home raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 1.29 GiB (0.1%) fs: ext4 dev: /dev/sdb1
System Temperatures: cpu: 45.1 C mobo: N/A gpu: nvidia temp: 45 C
Processes: 338 Uptime: 21m Memory: 31.36 GiB used: 2.43 GiB (7.8%)
Init: systemd v: 245 Compilers: gcc: N/A Packages: pacman: 1016
lib: 278 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
[storm@universe ~]$
regards,
Storm
