Ok, I followed through with all the package removals. I had to remove hplip, pulseaudio-equalizer, system-config-printer.
Then I was able to remove dbus-python, command line worked.
Then I tried applying the all the updates again and everything seemed good, it all downloaded, integrity checks all good, and then…:
invalid or corrupted package (PGP signature):
Forgot to mention, when I issued the command from earlier (before removing hplip, pulseaudio-equalizer, system-config-printer):
sudo pacman -Syu
It asked to proceed with installation and I said yes.
Then it said:
(323/323) checking keys in keyring [########################################] 100%
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: keyring is not writable
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
So, then I issued the command:
sudo pacman-key --init
gpg: Generating pacman keyring master key...
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.[d/fksdfjsklfslkjf-I replaced this just in case].rev'
gpg: Done
==> Updating trust database...
gpg: public key of ultimately trusted key [sdlkjada08-I replaced this just in case] not found
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 2 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 2u
==> ERROR: Trust database could not be updated.
I realized, I should have dealt with this first. Doing too many other things at once
Any idea how to fix this?
