TLP works only after suspension
Hello everyone!
After several years of Debian and Red Hat based distros, I’m happily trying Manjaro for the first time!
I’ve insalled Manjaro XFCE 21.0.7, Kernel 5.10.42-1 on my secondary laptop (Acer Aspire 1, Celeron N4120) and tuned TLP a little bit, managing to get an amazing battery life of 8-9 hours. Unfortunately I’m facing a quite annoying issue: when I turn on or reboot the laptop, TLP seems that it’s not working: the CPU is stuck at >2GHz: I’ve tried to restarting tlp wth sudo tlp start, but nothing changes. But if I suspend and wake up the system, TLP starts working properly.
What could it be?
Here’s my tlp.conf file.
Thanks :slight_smile:
# /etc/tlp.conf - TLP user configuration
# See full explanation: https://linrunner.de/en/tlp/docs/tlp-configuration.html
# New configuration scheme (TLP 1.3). Settings are read in the following order:
# 1. Intrinsic defaults
# 2. /etc/tlp.d/*.conf - Drop-in customization snippets
# 3. /etc/tlp.conf     - User configuration (this file)
# Notes:
# - In case of identical parameters, the last occurence has precedence
# - This also means, parameters enabled here will override anything else
# - IMPORTANT: all parameters here are disabled, remove the leading '#'
#   to enable them; shown values may be suggestions rather than defaults
# - Default *: intrinsic default that is effective when the parameter is missing
#     or disabled by a leading '#'; use PARAM="" to disable an intrinsic default
# - Default <none>: do nothing or use kernel/hardware defaults
# tlp - Parameters for power saving
# Set to 0 to disable, 1 to enable TLP.
# Default: 1
#TLP_ENABLE=1
# Operation mode when no power supply can be detected: AC, BAT.
# Concerns some desktop and embedded hardware only.
# Default: <none>
TLP_DEFAULT_MODE=BAT
# Operation mode select: 0=depend on power source, 1=always use TLP_DEFAULT_MODE
# Note: use in conjunction with TLP_DEFAULT_MODE=BAT for BAT settings on AC.
# Default: 0
#TLP_PERSISTENT_DEFAULT=0
# Power supply class to ignore when determining operation mode: AC, BAT.
# Note: try on laptops where operation mode AC/BAT is incorrectly detected.
# Default: <none>
#TLP_PS_IGNORE=BAT
# Seconds laptop mode has to wait after the disk goes idle before doing a sync.
# Non-zero value enables, zero disables laptop mode.
# Default: 0 (AC), 2 (BAT)
#DISK_IDLE_SECS_ON_AC=0
#DISK_IDLE_SECS_ON_BAT=2
# Dirty page values (timeouts in secs).
# Default: 15 (AC), 60 (BAT)
#MAX_LOST_WORK_SECS_ON_AC=15
#MAX_LOST_WORK_SECS_ON_BAT=60
# Note: CPU parameters below are disabled by default, remove the leading #
# to enable them, otherwise kernel defaults will be used.
# Select a CPU frequency scaling governor.
# Intel Core i processor with intel_pstate driver:
#   powersave(*), performance.
# Other hardware with acpi-cpufreq driver:
#   ondemand(*), powersave, performance, conservative, schedutil.
# (*) is recommended.
# Use tlp-stat -p to show the active driver and available governors.
# Important:
#   powersave for intel_pstate and ondemand for acpi-cpufreq are power
#   efficient for *almost all* workloads and therefore kernel and most
#   distributions have chosen them as defaults. If you still want to change,
#   you should know what you're doing!
# Default: <none>
CPU_SCALING_GOVERNOR_ON_AC=ondemand
CPU_SCALING_GOVERNOR_ON_BAT=ondemand
# Set the min/max frequency available for the scaling governor.
# Possible values depend on your CPU. For available frequencies see
# the output of tlp-stat -p.
# Default: <none>
CPU_SCALING_MIN_FREQ_ON_AC=800000
CPU_SCALING_MAX_FREQ_ON_AC=2600000
CPU_SCALING_MIN_FREQ_ON_BAT=800000
CPU_SCALING_MAX_FREQ_ON_BAT=2600000
# Set Intel CPU energy/performance policies HWP.EPP and EPB:
#   performance, balance_performance, default, balance_power, power
# Values are given in order of increasing power saving.
# Notes:
# - Requires an Intel Core i processor
# - HWP.EPP requires kernel 4.10 and intel_pstate driver
# - EPB requires kernel 5.2 or module msr and x86_energy_perf_policy
#   from linux-tools
# - When HWP.EPP is available, EPB is not set
# Default: balance_performance (AC), balance_power (BAT)
#CPU_ENERGY_PERF_POLICY_ON_AC=balance_performance
#CPU_ENERGY_PERF_POLICY_ON_BAT=balance_power
# Set Intel CPU P-state performance: 0..100 (%).
# Limit the max/min P-state to control the power dissipation of the CPU.
# Values are stated as a percentage of the available performance.
# Requires an Intel Core i processor with intel_pstate driver.
# Default: <none>
CPU_MIN_PERF_ON_AC=0
CPU_MAX_PERF_ON_AC=100
CPU_MIN_PERF_ON_BAT=0
CPU_MAX_PERF_ON_BAT=100
# Set the CPU "turbo boost" feature: 0=disable, 1=allow
# Requires an Intel Core i processor.
# Important:
# - This may conflict with your distribution's governor settings
# - A value of 1 does *not* activate boosting, it just allows it
# Default: <none>
CPU_BOOST_ON_AC=1
CPU_BOOST_ON_BAT=1
# Minimize number of used CPU cores/hyper-threads under light load conditions:
#   0=disable, 1=enable.
# Default: 0 (AC), 1 (BAT)
#SCHED_POWERSAVE_ON_AC=0
#SCHED_POWERSAVE_ON_BAT=1
# Kernel NMI Watchdog:
#   0=disable (default, saves power), 1=enable (for kernel debugging only).
# Default: 0
#NMI_WATCHDOG=0
# Change CPU voltages aka "undervolting" - Kernel with PHC patch required.
# Frequency voltage pairs are written to:
#   /sys/devices/system/cpu/cpu0/cpufreq/phc_controls
# CAUTION: only use this, if you thoroughly understand what you are doing!
# Default: <none>.
#PHC_CONTROLS="F:V F:V F:V F:V"
# Disk devices; separate multiple devices with spaces.
# Devices can be specified by disk ID also (lookup with: tlp diskid).
# Note: DISK parameters below are effective only when this option is configured.
# Default: "nvme0n1 sda"
#DISK_DEVICES="nvme0n1 sda"
# Disk advanced power management level: 1..254, 255 (max saving, min, off).
# Levels 1..127 may spin down the disk; 255 allowable on most drives.
# Separate values for multiple disks with spaces. Use the special value 'keep'
# to keep the hardware default for the particular disk.
# Default: 254 (AC), 128 (BAT)
#DISK_APM_LEVEL_ON_AC="254 254"
#DISK_APM_LEVEL_ON_BAT="128 128"
# Hard disk spin down timeout:
#   0:        spin down disabled
#   1..240:   timeouts from 5s to 20min (in units of 5s)
#   241..251: timeouts from 30min to 5.5 hours (in units of 30min)
# See 'man hdparm' for details.
# Default: <none>
#DISK_SPINDOWN_TIMEOUT_ON_AC="0 0"
#DISK_SPINDOWN_TIMEOUT_ON_BAT="0 0"
# Select I/O scheduler for the disk devices.
# Multi queue (blk-mq) schedulers:
#   mq-deadline(*), none, kyber, bfq
# Single queue schedulers:
#   deadline(*), cfq, bfq, noop
# (*) recommended.
# to keep the kernel default scheduler for the particular disk.
# Notes:
# - Multi queue (blk-mq) may need kernel boot option 'scsi_mod.use_blk_mq=1'
#   and 'modprobe mq-deadline-iosched|kyber|bfq' on kernels < 5.0
# - Single queue schedulers are legacy now and were removed together with
#   the old block layer in kernel 5.0
# Default: keep
#DISK_IOSCHED="mq-deadline mq-deadline"
# AHCI link power management (ALPM) for disk devices:
#   min_power, med_power_with_dipm(*), medium_power, max_performance.
# (*) Kernel >= 4.15 required, then recommended.
# Multiple values separated with spaces are tried sequentially until success.
# Default:
#  - "med_power_with_dipm max_performance" (AC)
#  - "med_power_with_dipm min_power" (BAT)
#SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
#SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
# Exclude host devices from AHCI link power management.
# Separate multiple hosts with spaces.
# Default: <none>
#SATA_LINKPWR_BLACKLIST="host1"
# Runtime Power Management for AHCI host and disks devices:
#   on=disable, auto=enable.
# EXPERIMENTAL ** WARNING: auto may cause system lockups/data loss.
# Default: <none>
#AHCI_RUNTIME_PM_ON_AC=on
#AHCI_RUNTIME_PM_ON_BAT=on
# Seconds of inactivity before disk is suspended.
# Note: effective only when AHCI_RUNTIME_PM_ON_AC/BAT is activated.
# Default: 15
#AHCI_RUNTIME_PM_TIMEOUT=15
# PCI Express Active State Power Management (PCIe ASPM):
#   default(*), performance, powersave, powersupersave.
# (*) keeps BIOS ASPM defaults (recommended)
# Default: <none>
#PCIE_ASPM_ON_AC=default
#PCIE_ASPM_ON_BAT=default
# Set the min/max/turbo frequency for the Intel GPU.
# Possible values depend on your hardware. For available frequencies see
# the output of tlp-stat -g.
# Default: <none>
#INTEL_GPU_MIN_FREQ_ON_AC=0
#INTEL_GPU_MIN_FREQ_ON_BAT=0
#INTEL_GPU_MAX_FREQ_ON_AC=0
#INTEL_GPU_MAX_FREQ_ON_BAT=0
#INTEL_GPU_BOOST_FREQ_ON_AC=0
#INTEL_GPU_BOOST_FREQ_ON_BAT=0
# Radeon graphics clock speed (profile method): low, mid, high, auto, default;
# auto = mid on BAT, high on AC.
# Default: default
#RADEON_POWER_PROFILE_ON_AC=default
#RADEON_POWER_PROFILE_ON_BAT=default
# Radeon dynamic power management method (DPM): battery, performance.
# Default: <none>
#RADEON_DPM_STATE_ON_AC=performance
#RADEON_DPM_STATE_ON_BAT=battery
# Radeon DPM performance level: auto, low, high; auto is recommended.
# Note: effective only when RADEON_DPM_STATE_ON_AC/BAT is activated.
# Default: auto
#RADEON_DPM_PERF_LEVEL_ON_AC=auto
#RADEON_DPM_PERF_LEVEL_ON_BAT=auto
# WiFi power saving mode: on=enable, off=disable; not supported by all adapters.
# Default: off (AC), on (BAT)
#WIFI_PWR_ON_AC=off
#WIFI_PWR_ON_BAT=on
# Disable wake on LAN: Y/N.
# Default: Y
#WOL_DISABLE=Y
# Enable audio power saving for Intel HDA, AC97 devices (timeout in secs).
# A value of 0 disables, >=1 enables power saving (recommended: 1).
#SOUND_POWER_SAVE_ON_AC=0
#SOUND_POWER_SAVE_ON_BAT=1
# Disable controller too (HDA only): Y/N.
# Note: effective only when SOUND_POWER_SAVE_ON_AC/BAT is activated.
# Default: Y
#SOUND_POWER_SAVE_CONTROLLER=Y
# Power off optical drive in UltraBay/MediaBay: 0=disable, 1=enable.
# Drive can be powered on again by releasing (and reinserting) the eject lever
# or by pressing the disc eject button on newer models.
# Note: an UltraBay/MediaBay hard disk is never powered off.
# Default: 0
#BAY_POWEROFF_ON_AC=0
#BAY_POWEROFF_ON_BAT=0
# Optical drive device to power off
# Default: sr0
#BAY_DEVICE="sr0"
# Runtime Power Management for PCI(e) bus devices: on=disable, auto=enable.
# Default: on (AC), auto (BAT)
#RUNTIME_PM_ON_AC=on
#RUNTIME_PM_ON_BAT=auto
# Exclude PCI(e) device adresses the following list from Runtime PM
# (separate with spaces). Use lspci to get the adresses (1st column).
# Default: <none>
#RUNTIME_PM_BLACKLIST="bb:dd.f 11:22.3 44:55.6"
# Exclude PCI(e) devices assigned to the listed drivers from Runtime PM.
# Default when unconfigured is "amdgpu nouveau nvidia radeon" which
# prevents accidential power-on of dGPU in hybrid graphics setups.
# Separate multiple drivers with spaces.
# Default: "amdgpu mei_me nouveau nvidia pcieport radeon", use "" to disable
# completely.
#RUNTIME_PM_DRIVER_BLACKLIST="amdgpu mei_me nouveau nvidia pcieport radeon"
# Set to 0 to disable, 1 to enable USB autosuspend feature.
# Default: 1
#USB_AUTOSUSPEND=1
# Exclude listed devices from USB autosuspend (separate with spaces).
# Use lsusb to get the ids.
# Note: input devices (usbhid) are excluded automatically
# Default: <none>
#USB_BLACKLIST="1111:2222 3333:4444"
# Bluetooth devices are excluded from USB autosuspend:
#   0=do not exclude, 1=exclude.
# Default: 0
#USB_BLACKLIST_BTUSB=0
# Phone devices are excluded from USB autosuspend:
#   0=do not exclude, 1=exclude (enable charging).
# Default: 0
#USB_BLACKLIST_PHONE=0
# Printers are excluded from USB autosuspend:
# Default: 1
#USB_BLACKLIST_PRINTER=1
# WWAN devices are excluded from USB autosuspend:
# Default: 0
#USB_BLACKLIST_WWAN=0
# Include listed devices into USB autosuspend even if already excluded
# by the blacklists above (separate with spaces). Use lsusb to get the ids.
# Default: <none>
#USB_WHITELIST="1111:2222 3333:4444"
# Set to 1 to disable autosuspend before shutdown, 0 to do nothing
# Note: use as a workaround for USB devices that cause shutdown problems.
# Default: 0
#USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=0
# Restore radio device state (Bluetooth, WiFi, WWAN) from previous shutdown
# on system startup: 0=disable, 1=enable.
# Note: the parameters DEVICES_TO_DISABLE/ENABLE_ON_STARTUP/SHUTDOWN below
#   are ignored when this is enabled.
# Default: 0
#RESTORE_DEVICE_STATE_ON_STARTUP=0
# Radio devices to disable on startup: bluetooth, wifi, wwan.
# Separate multiple devices with spaces.
# Default: <none>
#DEVICES_TO_DISABLE_ON_STARTUP="bluetooth wifi wwan"
# Radio devices to enable on startup: bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_STARTUP="wifi"
# Radio devices to disable on shutdown: bluetooth, wifi, wwan.
# Note: use as a workaround for devices that are blocking shutdown.
# Default: <none>
#DEVICES_TO_DISABLE_ON_SHUTDOWN="bluetooth wifi wwan"
# Radio devices to enable on shutdown: bluetooth, wifi, wwan.
# (to prevent other operating systems from missing radios).
# Default: <none>
#DEVICES_TO_ENABLE_ON_SHUTDOWN="wwan"
# Radio devices to enable on AC: bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_AC="bluetooth wifi wwan"
# Radio devices to disable on battery: bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT="bluetooth wifi wwan"
# Radio devices to disable on battery when not in use (not connected):
#   bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth wifi wwan"
# Battery charge thresholds (ThinkPad only).
# May require external kernel module(s), refer to the output of tlp-stat -b.
# Charging starts when the remaining capacity falls below the
# START_CHARGE_THRESH value and stops when exceeding the STOP_CHARGE_THRESH
# value.
# Main / Internal battery (values in %)
# Default: <none>
#START_CHARGE_THRESH_BAT0=75
#STOP_CHARGE_THRESH_BAT0=80
# Ultrabay / Slice / Replaceable battery (values in %)
# Default: <none>
#START_CHARGE_THRESH_BAT1=75
#STOP_CHARGE_THRESH_BAT1=80
# Restore charge thresholds when AC is unplugged: 0=disable, 1=enable.
# Default: 0
#RESTORE_THRESHOLDS_ON_BAT=1
# Battery feature drivers: 0=disable, 1=enable
# Default: 1 (all)
#NATACPI_ENABLE=1
#TPACPI_ENABLE=1
#TPSMAPI_ENABLE=1
# tlp-rdw - Parameters for the radio device wizard
# Possible devices: bluetooth, wifi, wwan.
# Separate multiple radio devices with spaces.
# Default: <none> (for all parameters below)
# Radio devices to disable on connect.
#DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
#DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
#DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
# Radio devices to enable on disconnect.
#DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
#DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT=""
#DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT=""
# Radio devices to enable/disable when docked.
#DEVICES_TO_ENABLE_ON_DOCK=""
#DEVICES_TO_DISABLE_ON_DOCK=""
# Radio devices to enable/disable when undocked.
#DEVICES_TO_ENABLE_ON_UNDOCK="wifi"
#DEVICES_TO_DISABLE_ON_UNDOCK=""
I would bet your specific settings are not compatible with your CPU. Get back to default values and report if the issues persist.
I’ve tried to load the default config file, but nothing changed.
Even if I think that if the settings weren’t compatible it shoulnd’t work neither after the suspension
That won’t do anything if it’s already started. It has a systemd service already enabled. Restart it instead:
systemctl restart tlp
Your changes aren’t helping anything. Restore the file to defaults as suggested. the - lines are default, the + lines are your changes.
@@ -29,7 +29,7 @@
 # Default: <none>
-#TLP_DEFAULT_MODE=AC
+TLP_DEFAULT_MODE=BAT
@@ -73,18 +73,18 @@
 # Default: <none>
-#CPU_SCALING_GOVERNOR_ON_AC=powersave
-#CPU_SCALING_GOVERNOR_ON_BAT=powersave
+CPU_SCALING_GOVERNOR_ON_AC=ondemand
+CPU_SCALING_GOVERNOR_ON_BAT=ondemand
 # Default: <none>
-#CPU_SCALING_MIN_FREQ_ON_AC=0
-#CPU_SCALING_MAX_FREQ_ON_AC=0
-#CPU_SCALING_MIN_FREQ_ON_BAT=0
-#CPU_SCALING_MAX_FREQ_ON_BAT=0
+CPU_SCALING_MIN_FREQ_ON_AC=800000
+CPU_SCALING_MAX_FREQ_ON_AC=2600000
+CPU_SCALING_MIN_FREQ_ON_BAT=800000
+CPU_SCALING_MAX_FREQ_ON_BAT=2600000
@@ -106,10 +106,10 @@
 # Default: <none>
-#CPU_MIN_PERF_ON_AC=0
-#CPU_MAX_PERF_ON_AC=100
-#CPU_MIN_PERF_ON_BAT=0
-#CPU_MAX_PERF_ON_BAT=30
+CPU_MIN_PERF_ON_AC=0
+CPU_MAX_PERF_ON_AC=100
+CPU_MIN_PERF_ON_BAT=0
+CPU_MAX_PERF_ON_BAT=100
@@ -118,8 +118,8 @@
 # Default: <none>
-#CPU_BOOST_ON_AC=1
-#CPU_BOOST_ON_BAT=0
+CPU_BOOST_ON_AC=1
+CPU_BOOST_ON_BAT=1
Hello!
Currently I’m already running the original configuration file as suggested by Wollie, but the result is the same. Also, the problem is not that tlp is not working at all, but that it start working only after waking up from a suspension…
I’ve also tried to restart the tlp service with systemctl as you suggested, but it changed nothing
What is the output of
systemctl status tlp
a) after boot
b) after supspend/wake up
Also, please post
sudo tlp-stat
What you also could try:
systemctl mask systemd-rfkill.service
systemctl mask systemd-rfkill.socket
These services should be masked when tlp is used.
Are you running other power management tools?
After boot:
● tlp.service - TLP system startup/shutdown
     Loaded: loaded (/usr/lib/systemd/system/tlp.service; enabled; vendor preset: disabled)
     Active: active (exited) since Sat 2021-07-03 20:25:30 CEST; 2min 1s ago
       Docs: https://linrunner.de/tlp
    Process: 401 ExecStart=/usr/bin/tlp init start (code=exited, status=0/SUCCESS)
   Main PID: 401 (code=exited, status=0/SUCCESS)
        CPU: 278ms
lug 03 20:25:29 gianluca-aspirea11432 systemd[1]: Starting TLP system startup/shutdown...
lug 03 20:25:30 gianluca-aspirea11432 tlp[401]: Applying power save settings...done.
lug 03 20:25:30 gianluca-aspirea11432 tlp[401]: Setting battery charge thresholds...done.
lug 03 20:25:30 gianluca-aspirea11432 systemd[1]: Finished TLP system startup/shutdown.
sudo tlp-stat
--- TLP 1.3.1 --------------------------------------------
+++ Configured Settings:
defaults.conf L0004: TLP_ENABLE="1"
defaults.conf L0005: TLP_PERSISTENT_DEFAULT="0"
defaults.conf L0006: DISK_IDLE_SECS_ON_AC="0"
defaults.conf L0007: DISK_IDLE_SECS_ON_BAT="2"
defaults.conf L0008: MAX_LOST_WORK_SECS_ON_AC="15"
defaults.conf L0009: MAX_LOST_WORK_SECS_ON_BAT="60"
defaults.conf L0010: CPU_ENERGY_PERF_POLICY_ON_AC="balance_performance"
defaults.conf L0011: CPU_ENERGY_PERF_POLICY_ON_BAT="balance_power"
defaults.conf L0012: SCHED_POWERSAVE_ON_AC="0"
defaults.conf L0013: SCHED_POWERSAVE_ON_BAT="1"
defaults.conf L0014: NMI_WATCHDOG="0"
defaults.conf L0015: DISK_DEVICES="nvme0n1 sda"
defaults.conf L0016: DISK_APM_LEVEL_ON_AC="254 254"
defaults.conf L0017: DISK_APM_LEVEL_ON_BAT="128 128"
defaults.conf L0018: DISK_IOSCHED="keep keep"
defaults.conf L0019: SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
defaults.conf L0020: SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
defaults.conf L0021: AHCI_RUNTIME_PM_TIMEOUT="15"
defaults.conf L0022: PCIE_ASPM_ON_AC="default"
defaults.conf L0023: PCIE_ASPM_ON_BAT="default"
defaults.conf L0024: RADEON_POWER_PROFILE_ON_AC="default"
defaults.conf L0025: RADEON_POWER_PROFILE_ON_BAT="default"
defaults.conf L0026: RADEON_DPM_PERF_LEVEL_ON_AC="auto"
defaults.conf L0027: RADEON_DPM_PERF_LEVEL_ON_BAT="auto"
defaults.conf L0028: WIFI_PWR_ON_AC="off"
defaults.conf L0029: WIFI_PWR_ON_BAT="on"
defaults.conf L0030: WOL_DISABLE="Y"
defaults.conf L0031: SOUND_POWER_SAVE_ON_AC="0"
defaults.conf L0032: SOUND_POWER_SAVE_ON_BAT="1"
defaults.conf L0033: SOUND_POWER_SAVE_CONTROLLER="Y"
defaults.conf L0034: BAY_POWEROFF_ON_AC="0"
defaults.conf L0035: BAY_POWEROFF_ON_BAT="0"
defaults.conf L0036: BAY_DEVICE="sr0"
defaults.conf L0037: RUNTIME_PM_ON_AC="on"
defaults.conf L0038: RUNTIME_PM_ON_BAT="auto"
defaults.conf L0039: RUNTIME_PM_DRIVER_BLACKLIST="amdgpu mei_me nouveau nvidia pcieport radeon"
defaults.conf L0040: USB_AUTOSUSPEND="1"
defaults.conf L0041: USB_BLACKLIST_BTUSB="0"
defaults.conf L0042: USB_BLACKLIST_PHONE="0"
defaults.conf L0043: USB_BLACKLIST_PRINTER="1"
defaults.conf L0044: USB_BLACKLIST_WWAN="0"
defaults.conf L0045: USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN="0"
defaults.conf L0046: RESTORE_DEVICE_STATE_ON_STARTUP="0"
defaults.conf L0047: RESTORE_THRESHOLDS_ON_BAT="0"
defaults.conf L0048: NATACPI_ENABLE="1"
defaults.conf L0049: TPACPI_ENABLE="1"
defaults.conf L0050: TPSMAPI_ENABLE="1"
+++ System Info
System         = Acer V1.24 Aspire A114-32
BIOS           = V1.24
Release        = "Manjaro Linux"
Kernel         = 5.10.42-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:37:11 UTC 2021 x86_64
/proc/cmdline  = BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=c075e4ce-5d3b-4342-9f61-89cbabe5c67e rw quiet apparmor=1 security=apparmor udev.log_priority=3
Init system    = systemd
Boot mode      = UEFI
+++ TLP Status
State          = enabled
RDW state      = enabled
Last run       = 20:27:28,    100 sec(s) ago
Mode           = battery
Power source   = battery
+++ Processor
CPU model      = Intel(R) Celeron(R) N4120 CPU @ 1.10GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver    = intel_cpufreq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = ondemand
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = conservative ondemand userspace powersave performance schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq  =  2600000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver    = intel_cpufreq
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor  = ondemand
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_governors = conservative ondemand userspace powersave performance schedutil
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq  =  2600000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver    = intel_cpufreq
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor  = ondemand
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_governors = conservative ondemand userspace powersave performance schedutil
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq  =  2600000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver    = intel_cpufreq
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor  = ondemand
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_governors = conservative ondemand userspace powersave performance schedutil
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq  =  2600000 [kHz]
/sys/devices/system/cpu/intel_pstate/min_perf_pct      =  30 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct      = 100 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo          =   0
/sys/devices/system/cpu/intel_pstate/turbo_pct         =  80 [%]
/sys/devices/system/cpu/intel_pstate/num_pstates       =  19
Intel EPB: unsupported CPU.
/sys/module/workqueue/parameters/power_efficient       = Y
/proc/sys/kernel/nmi_watchdog                          = 0
+++ Temperatures
CPU temp               =    47 [°C]
Fan speed              = (not available)
+++ File System
/proc/sys/vm/laptop_mode               =     2
/proc/sys/vm/dirty_writeback_centisecs =  6000
/proc/sys/vm/dirty_expire_centisecs    =  6000
/proc/sys/vm/dirty_ratio               =    20
/proc/sys/vm/dirty_background_ratio    =    10
+++ Storage Devices
Devices = nvme0n1 sda
/dev/nvme0n1: not present.
/dev/sda: not present.
+++ AHCI Link Power Management (ALPM)
/sys/class/scsi_host/host0/link_power_management_policy  = med_power_with_dipm
/sys/class/scsi_host/host1/link_power_management_policy  = med_power_with_dipm
+++ AHCI Host Controller Runtime Power Management
/sys/bus/pci/devices/0000:00:12.0/ata1/power/control = on
/sys/bus/pci/devices/0000:00:12.0/ata2/power/control = on
+++ Intel Graphics
/sys/module/i915/parameters/enable_dc        = -1 (use per-chip default)
/sys/module/i915/parameters/enable_fbc       = -1 (use per-chip default)
/sys/module/i915/parameters/enable_psr       = -1 (use per-chip default)
/sys/module/i915/parameters/modeset          = -1 (use per-chip default)
/sys/class/drm/card0/gt_min_freq_mhz         =   100 [MHz]
/sys/class/drm/card0/gt_max_freq_mhz         =   700 [MHz]
/sys/class/drm/card0/gt_boost_freq_mhz       =   700 [MHz]
+++ Wireless
bluetooth = off (software)
wifi      = on
wwan      = none (no device)
hci0(btusb)                   : bluetooth, not connected
wlp3s0(ath10k_pci)            : wifi, connected, power management = on
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save            = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = [default] performance powersave powersupersave (using BIOS preferences)
+++ Runtime Power Management
Device blacklist = (not configured)
Driver blacklist = amdgpu mei_me nouveau nvidia pcieport radeon
/sys/bus/pci/devices/0000:00:00.0/power/control = auto (0x060000, Host bridge, no driver)
/sys/bus/pci/devices/0000:00:00.1/power/control = auto (0x118000, Signal processing controller, proc_thermal)
/sys/bus/pci/devices/0000:00:00.3/power/control = auto (0x088000, System peripheral, no driver)
/sys/bus/pci/devices/0000:00:02.0/power/control = auto (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:0e.0/power/control = auto (0x040380, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:0f.0/power/control = auto (0x078000, Communication controller, mei_me)
/sys/bus/pci/devices/0000:00:12.0/power/control = auto (0x010601, SATA controller, ahci)
/sys/bus/pci/devices/0000:00:13.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:13.2/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:13.3/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:15.0/power/control = auto (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:17.0/power/control = auto (0x118000, Signal processing controller, intel-lpss)
/sys/bus/pci/devices/0000:00:1c.0/power/control = auto (0x080501, SD Host controller, sdhci-pci)
/sys/bus/pci/devices/0000:00:1f.0/power/control = auto (0x060100, ISA bridge, no driver)
/sys/bus/pci/devices/0000:00:1f.1/power/control = auto (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:02:00.0/power/control = auto (0xff0000, Unassigned class [ff00], rtsx_pci)
/sys/bus/pci/devices/0000:02:00.1/power/control = auto (0x020000, Ethernet controller, r8169)
/sys/bus/pci/devices/0000:03:00.0/power/control = auto (0x028000, Network controller, ath10k_pci)
+++ USB
Autosuspend         = enabled
Device whitelist    = (not configured)
Bluetooth blacklist = disabled
Phone blacklist     = disabled
WWAN blacklist      = disabled
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms =    0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 003 ID 0408:a031 control = auto, autosuspend_delay_ms = 2000 -- Quanta Computer, Inc. VGA WebCam (uvcvideo)
Bus 001 Device 002 ID 04ca:3015 control = auto, autosuspend_delay_ms = 2000 -- Lite-On Technology Corp. Qualcomm Atheros QCA9377 Bluetooth (btusb)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms =    0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Features: Charge Thresholds and Recalibrate
natacpi    = inactive (laptop not supported)
tpacpi-bat = inactive (laptop not supported)
tp-smapi   = inactive (laptop not supported)
+++ Battery Status: BAT1
/sys/class/power_supply/BAT1/manufacturer                   = PANASONIC
/sys/class/power_supply/BAT1/model_name                     = AP16M5J
/sys/class/power_supply/BAT1/cycle_count                    = (not supported)
/sys/class/power_supply/BAT1/charge_full_design             =   4810 [mAh]
/sys/class/power_supply/BAT1/charge_full                    =   4152 [mAh]
/sys/class/power_supply/BAT1/charge_now                     =   3240 [mAh]
/sys/class/power_supply/BAT1/current_now                    =    865 [mA]
/sys/class/power_supply/BAT1/status                         = Discharging
Charge                                                      =   78.0 [%]
Capacity                                                    =   86.3 [%]
After suspended/wake up:
     Active: active (exited) since Sat 2021-07-03 20:25:30 CEST; 6min ago
      Tasks: 0 (limit: 4462)
     Memory: 0B
        CPU: 0
     CGroup: /system.slice/tlp.service
sudo tlp-stat
+++ System Info
BIOS           = V1.24
Boot mode      = UEFI
+++ TLP Status
State          = enabled
RDW state      = enabled
Last run       = 20:31:14,    182 sec(s) ago
Mode           = battery
+++ Processor
+++ Temperatures
CPU temp               =    48 [°C]
+++ File System
+++ Storage Devices
+++ Intel Graphics
+++ Wireless
wifi      = on
+++ Audio
+++ USB
Bus 001 Device 004 ID 046d:c542 control = on,   autosuspend_delay_ms = 2000 -- Logitech, Inc. Wireless Receiver (usbhid)
/sys/class/power_supply/BAT1/charge_now                     =   3183 [mAh]
/sys/class/power_supply/BAT1/current_now                    =    410 [mA]
Charge                                                      =   76.7 [%]
Capacity                                                    =   86.3 [%]
I’ve tried to mask those two services as you suggested, but apparently nothing changed :pensive: And I use only tlp, tlp-rdw and powertop (I use this one only to monitor the battery discharge rate)
And thank you very much for your help :slight_smile:
To be fair, I’m trying other live distros (Fedora, KDE Neon, various *buntu) and TLP shows the same exact issue. Am I missing something?
Then maybe it’s hardware or firmware related.
