Hello, I today after quite a while not mobile noticed that TLP isn’t working as expected.
When on BAT it stays in AC mode and thus does not apply the powersavings.
The change in powersource AC->BAT and BAT->AC is detected though.
+++ System Info
System = LENOVO ThinkPad T490 20N2004AGE
BIOS = N2IET95W (1.73 )
Release = "Manjaro Linux"
Kernel = 5.12.14-1-MANJARO #1 SMP PREEMPT Wed Jun 30 18:26:07 UTC 2021 x86_64
/proc/cmdline = BOOT_IMAGE=/@/boot/vmlinuz-5.12-x86_64 root=UUID=fb1e1c51-e430-416f-8573-881f7f647606 rw rootflags=subvol=@ cryptdevice=UUID=d4973d9c-da0c-45f3-b451-d4988f86921c:crypt_nvme0n1p2 i915.modeset=1 udev.log_priority=3 resume=/dev/disk/by-uuid/fb1e1c51-e430-416f-8573-881f7f647606 resume_offset=25171200
Init system = systemd
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = enabled
Last run = 08:06:16, 730 sec(s) ago
Mode = AC
Power source = battery
/etc/tlp.conf
# /etc/tlp.conf - TLP user configuration
# See full explanation: https://linrunner.de/en/tlp/docs/tlp-configuration.html
# New configuration scheme (TLP 1.3). Settings are read in the following order:
# 1. Intrinsic defaults
# 2. /etc/tlp.d/*.conf - Drop-in customization snippets
# 3. /etc/tlp.conf - User configuration (this file)
# Notes:
# - In case of identical parameters, the last occurence has precedence
# - This also means, parameters enabled here will override anything else
# - IMPORTANT: all parameters here are disabled, remove the leading '#'
# to enable them; shown values may be suggestions rather than defaults
# - Default *: intrinsic default that is effective when the parameter is missing
# or disabled by a leading '#'; use PARAM="" to disable an intrinsic default
# - Default <none>: do nothing or use kernel/hardware defaults
# tlp - Parameters for power saving
# Set to 0 to disable, 1 to enable TLP.
# Default: 1
TLP_ENABLE=1
# Operation mode when no power supply can be detected: AC, BAT.
# Concerns some desktop and embedded hardware only.
# Default: <none>
# TLP_DEFAULT_MODE=BAT
# Operation mode select: 0=depend on power source, 1=always use TLP_DEFAULT_MODE
# Note: use in conjunction with TLP_DEFAULT_MODE=BAT for BAT settings on AC.
# Default: 0
# TLP_PERSISTENT_DEFAULT=0
# Power supply class to ignore when determining operation mode: AC, BAT.
# Note: try on laptops where operation mode AC/BAT is incorrectly detected.
# Default: <none>
#TLP_PS_IGNORE="BAT"
# Seconds laptop mode has to wait after the disk goes idle before doing a sync.
# Non-zero value enables, zero disables laptop mode.
# Default: 0 (AC), 2 (BAT)
#DISK_IDLE_SECS_ON_AC=0
#DISK_IDLE_SECS_ON_BAT=2
# Dirty page values (timeouts in secs).
# Default: 15 (AC), 60 (BAT)
#MAX_LOST_WORK_SECS_ON_AC=15
#MAX_LOST_WORK_SECS_ON_BAT=60
# Note: CPU parameters below are disabled by default, remove the leading #
# to enable them, otherwise kernel defaults will be used.
# Select a CPU frequency scaling governor.
# Intel Core i processor with intel_pstate driver:
# powersave(*), performance.
# Other hardware with acpi-cpufreq driver:
# ondemand(*), powersave, performance, conservative, schedutil.
# (*) is recommended.
# Use tlp-stat -p to show the active driver and available governors.
# Important:
# powersave for intel_pstate and ondemand for acpi-cpufreq are power
# efficient for *almost all* workloads and therefore kernel and most
# distributions have chosen them as defaults. If you still want to change,
# you should know what you're doing!
# Default: <none>
#CPU_SCALING_GOVERNOR_ON_AC=powersave
#CPU_SCALING_GOVERNOR_ON_BAT=powersave
# Set the min/max frequency available for the scaling governor.
# Possible values depend on your CPU. For available frequencies see
# the output of tlp-stat -p.
# Default: <none>
#CPU_SCALING_MIN_FREQ_ON_AC=0
#CPU_SCALING_MAX_FREQ_ON_AC=0
#CPU_SCALING_MIN_FREQ_ON_BAT=0
#CPU_SCALING_MAX_FREQ_ON_BAT=0
# Set Intel CPU energy/performance policies HWP.EPP and EPB:
# performance, balance_performance, default, balance_power, power
# Values are given in order of increasing power saving.
# Notes:
# - Requires an Intel Core i processor
# - HWP.EPP requires kernel 4.10 and intel_pstate driver
# - EPB requires kernel 5.2 or module msr and x86_energy_perf_policy
# from linux-tools
# - When HWP.EPP is available, EPB is not set
# Default: balance_performance (AC), balance_power (BAT)
#CPU_ENERGY_PERF_POLICY_ON_AC=balance_performance
#CPU_ENERGY_PERF_POLICY_ON_BAT=balance_power
# Set Intel CPU P-state performance: 0..100 (%).
# Limit the max/min P-state to control the power dissipation of the CPU.
# Values are stated as a percentage of the available performance.
# Requires an Intel Core i processor with intel_pstate driver.
# Default: <none>
#CPU_MIN_PERF_ON_AC=0
#CPU_MAX_PERF_ON_AC=100
#CPU_MIN_PERF_ON_BAT=0
#CPU_MAX_PERF_ON_BAT=30
# Set the CPU "turbo boost" feature: 0=disable, 1=allow
# Requires an Intel Core i processor.
# Important:
# - This may conflict with your distribution's governor settings
# - A value of 1 does *not* activate boosting, it just allows it
# Default: <none>
#CPU_BOOST_ON_AC=1
#CPU_BOOST_ON_BAT=0
# Minimize number of used CPU cores/hyper-threads under light load conditions:
# 0=disable, 1=enable.
# Default: 0 (AC), 1 (BAT)
#SCHED_POWERSAVE_ON_AC=0
#SCHED_POWERSAVE_ON_BAT=1
# Kernel NMI Watchdog:
# 0=disable (default, saves power), 1=enable (for kernel debugging only).
# Default: 0
NMI_WATCHDOG=0
# Change CPU voltages aka "undervolting" - Kernel with PHC patch required.
# Frequency voltage pairs are written to:
# /sys/devices/system/cpu/cpu0/cpufreq/phc_controls
# CAUTION: only use this, if you thoroughly understand what you are doing!
# Default: <none>.
#PHC_CONTROLS="F:V F:V F:V F:V"
# Disk devices; separate multiple devices with spaces.
# Devices can be specified by disk ID also (lookup with: tlp diskid).
# Note: DISK parameters below are effective only when this option is configured.
# Default: "nvme0n1 sda"
DISK_DEVICES="nvme0n1"
# Disk advanced power management level: 1..254, 255 (max saving, min, off).
# Levels 1..127 may spin down the disk; 255 allowable on most drives.
# Separate values for multiple disks with spaces. Use the special value 'keep'
# to keep the hardware default for the particular disk.
# Default: 254 (AC), 128 (BAT)
#DISK_APM_LEVEL_ON_AC="254 254"
#DISK_APM_LEVEL_ON_BAT="128 128"
# Hard disk spin down timeout:
# 0: spin down disabled
# 1..240: timeouts from 5s to 20min (in units of 5s)
# 241..251: timeouts from 30min to 5.5 hours (in units of 30min)
# See 'man hdparm' for details.
# Default: <none>
#DISK_SPINDOWN_TIMEOUT_ON_AC="0 0"
#DISK_SPINDOWN_TIMEOUT_ON_BAT="0 0"
# Select I/O scheduler for the disk devices.
# Multi queue (blk-mq) schedulers:
# mq-deadline(*), none, kyber, bfq
# Single queue schedulers:
# deadline(*), cfq, bfq, noop
# (*) recommended.
# to keep the kernel default scheduler for the particular disk.
# Notes:
# - Multi queue (blk-mq) may need kernel boot option 'scsi_mod.use_blk_mq=1'
# and 'modprobe mq-deadline-iosched|kyber|bfq' on kernels < 5.0
# - Single queue schedulers are legacy now and were removed together with
# the old block layer in kernel 5.0
# Default: keep
DISK_IOSCHED="mq-deadline mq-deadline"
# AHCI link power management (ALPM) for disk devices:
# min_power, med_power_with_dipm(*), medium_power, max_performance.
# (*) Kernel >= 4.15 required, then recommended.
# Multiple values separated with spaces are tried sequentially until success.
# Default:
# - "med_power_with_dipm max_performance" (AC)
# - "med_power_with_dipm min_power" (BAT)
SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
# Exclude host devices from AHCI link power management.
# Separate multiple hosts with spaces.
# Default: <none>
#SATA_LINKPWR_BLACKLIST="host1"
# Runtime Power Management for AHCI host and disks devices:
# on=disable, auto=enable.
# EXPERIMENTAL ** WARNING: auto may cause system lockups/data loss.
# Default: <none>
#AHCI_RUNTIME_PM_ON_AC=on
#AHCI_RUNTIME_PM_ON_BAT=on
# Seconds of inactivity before disk is suspended.
# Note: effective only when AHCI_RUNTIME_PM_ON_AC/BAT is activated.
# Default: 15
#AHCI_RUNTIME_PM_TIMEOUT=15
# PCI Express Active State Power Management (PCIe ASPM):
# default(*), performance, powersave, powersupersave.
# (*) keeps BIOS ASPM defaults (recommended)
# Default: <none>
PCIE_ASPM_ON_AC=default
PCIE_ASPM_ON_BAT=default
# Set the min/max/turbo frequency for the Intel GPU.
# Possible values depend on your hardware. For available frequencies see
# the output of tlp-stat -g.
# Default: <none>
#INTEL_GPU_MIN_FREQ_ON_AC=0
#INTEL_GPU_MIN_FREQ_ON_BAT=0
#INTEL_GPU_MAX_FREQ_ON_AC=0
#INTEL_GPU_MAX_FREQ_ON_BAT=0
#INTEL_GPU_BOOST_FREQ_ON_AC=0
#INTEL_GPU_BOOST_FREQ_ON_BAT=0
# Radeon graphics clock speed (profile method): low, mid, high, auto, default;
# auto = mid on BAT, high on AC.
# Default: default
#RADEON_POWER_PROFILE_ON_AC=default
#RADEON_POWER_PROFILE_ON_BAT=default
# Radeon dynamic power management method (DPM): battery, performance.
# Default: <none>
#RADEON_DPM_STATE_ON_AC=performance
#RADEON_DPM_STATE_ON_BAT=battery
# Radeon DPM performance level: auto, low, high; auto is recommended.
# Note: effective only when RADEON_DPM_STATE_ON_AC/BAT is activated.
# Default: auto
#RADEON_DPM_PERF_LEVEL_ON_AC=auto
#RADEON_DPM_PERF_LEVEL_ON_BAT=auto
# WiFi power saving mode: on=enable, off=disable; not supported by all adapters.
# Default: off (AC), on (BAT)
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=on
# Disable wake on LAN: Y/N.
# Default: Y
WOL_DISABLE=Y
# Enable audio power saving for Intel HDA, AC97 devices (timeout in secs).
# A value of 0 disables, >=1 enables power saving (recommended: 1).
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=1
# Disable controller too (HDA only): Y/N.
# Note: effective only when SOUND_POWER_SAVE_ON_AC/BAT is activated.
# Default: Y
SOUND_POWER_SAVE_CONTROLLER=Y
# Power off optical drive in UltraBay/MediaBay: 0=disable, 1=enable.
# Drive can be powered on again by releasing (and reinserting) the eject lever
# or by pressing the disc eject button on newer models.
# Note: an UltraBay/MediaBay hard disk is never powered off.
# Default: 0
#BAY_POWEROFF_ON_AC=0
#BAY_POWEROFF_ON_BAT=0
# Optical drive device to power off
# Default: sr0
#BAY_DEVICE="sr0"
# Runtime Power Management for PCI(e) bus devices: on=disable, auto=enable.
# Default: on (AC), auto (BAT)
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
# Exclude PCI(e) device adresses the following list from Runtime PM
# (separate with spaces). Use lspci to get the adresses (1st column).
# Default: <none>
#RUNTIME_PM_BLACKLIST="bb:dd.f 11:22.3 44:55.6"
# Exclude PCI(e) devices assigned to the listed drivers from Runtime PM.
# Default when unconfigured is "amdgpu nouveau nvidia radeon" which
# prevents accidential power-on of dGPU in hybrid graphics setups.
# Separate multiple drivers with spaces.
# Default: "amdgpu mei_me nouveau nvidia pcieport radeon", use "" to disable
# completely.
#RUNTIME_PM_DRIVER_BLACKLIST="amdgpu mei_me nouveau nvidia pcieport radeon"
# Set to 0 to disable, 1 to enable USB autosuspend feature.
# Default: 1
#USB_AUTOSUSPEND=1
# Exclude listed devices from USB autosuspend (separate with spaces).
# Use lsusb to get the ids.
# Note: input devices (usbhid) are excluded automatically
# Default: <none>
#USB_BLACKLIST="1111:2222 3333:4444"
# Bluetooth devices are excluded from USB autosuspend:
# 0=do not exclude, 1=exclude.
# Default: 0
USB_BLACKLIST_BTUSB=0
# Phone devices are excluded from USB autosuspend:
# 0=do not exclude, 1=exclude (enable charging).
# Default: 0
USB_BLACKLIST_PHONE=0
# Printers are excluded from USB autosuspend:
# Default: 1
USB_BLACKLIST_PRINTER=1
# WWAN devices are excluded from USB autosuspend:
# Default: 0
USB_BLACKLIST_WWAN=0
# Include listed devices into USB autosuspend even if already excluded
# by the blacklists above (separate with spaces). Use lsusb to get the ids.
# Default: <none>
#USB_WHITELIST="1111:2222 3333:4444"
# Set to 1 to disable autosuspend before shutdown, 0 to do nothing
# Note: use as a workaround for USB devices that cause shutdown problems.
# Default: 0
USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=0
# Restore radio device state (Bluetooth, WiFi, WWAN) from previous shutdown
# on system startup: 0=disable, 1=enable.
# Note: the parameters DEVICES_TO_DISABLE/ENABLE_ON_STARTUP/SHUTDOWN below
# are ignored when this is enabled.
# Default: 0
#RESTORE_DEVICE_STATE_ON_STARTUP=0
# Radio devices to disable on startup: bluetooth, wifi, wwan.
# Separate multiple devices with spaces.
# Default: <none>
#DEVICES_TO_DISABLE_ON_STARTUP="bluetooth wifi wwan"
# Radio devices to enable on startup: bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_STARTUP="wifi"
# Radio devices to disable on shutdown: bluetooth, wifi, wwan.
# Note: use as a workaround for devices that are blocking shutdown.
# Default: <none>
#DEVICES_TO_DISABLE_ON_SHUTDOWN="bluetooth wifi wwan"
# Radio devices to enable on shutdown: bluetooth, wifi, wwan.
# (to prevent other operating systems from missing radios).
# Default: <none>
#DEVICES_TO_ENABLE_ON_SHUTDOWN="wwan"
# Radio devices to enable on AC: bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_AC="bluetooth wifi wwan"
# Radio devices to disable on battery: bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT="bluetooth wifi wwan"
# Radio devices to disable on battery when not in use (not connected):
# bluetooth, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth wifi wwan"
# Battery charge thresholds (ThinkPad only).
# May require external kernel module(s), refer to the output of tlp-stat -b.
# Charging starts when the remaining capacity falls below the
# START_CHARGE_THRESH value and stops when exceeding the STOP_CHARGE_THRESH
# value.
# Main / Internal battery (values in %)
# Default: <none>
START_CHARGE_THRESH_BAT0=85
STOP_CHARGE_THRESH_BAT0=90
# Ultrabay / Slice / Replaceable battery (values in %)
# Default: <none>
START_CHARGE_THRESH_BAT1=85
STOP_CHARGE_THRESH_BAT1=90
# Restore charge thresholds when AC is unplugged: 0=disable, 1=enable.
# Default: 0
RESTORE_THRESHOLDS_ON_BAT=1
# Battery feature drivers: 0=disable, 1=enable
# Default: 1 (all)
#NATACPI_ENABLE=1
#TPACPI_ENABLE=1
#TPSMAPI_ENABLE=1
# tlp-rdw - Parameters for the radio device wizard
# Possible devices: bluetooth, wifi, wwan.
# Separate multiple radio devices with spaces.
# Default: <none> (for all parameters below)
# Radio devices to disable on connect.
#DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
#DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
#DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
# Radio devices to enable on disconnect.
#DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
#DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT=""
#DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT=""
# Radio devices to enable/disable when docked.
#DEVICES_TO_ENABLE_ON_DOCK=""
#DEVICES_TO_DISABLE_ON_DOCK=""
# Radio devices to enable/disable when undocked.
#DEVICES_TO_ENABLE_ON_UNDOCK="wifi"
#DEVICES_TO_DISABLE_ON_UNDOCK=""
tlp-stat
--- TLP 1.3.1 --------------------------------------------
+++ Configured Settings:
/etc/tlp.conf L0026: TLP_ENABLE="1"
defaults.conf L0005: TLP_PERSISTENT_DEFAULT="0"
defaults.conf L0006: DISK_IDLE_SECS_ON_AC="0"
defaults.conf L0007: DISK_IDLE_SECS_ON_BAT="2"
defaults.conf L0008: MAX_LOST_WORK_SECS_ON_AC="15"
defaults.conf L0009: MAX_LOST_WORK_SECS_ON_BAT="60"
defaults.conf L0010: CPU_ENERGY_PERF_POLICY_ON_AC="balance_performance"
defaults.conf L0011: CPU_ENERGY_PERF_POLICY_ON_BAT="balance_power"
defaults.conf L0012: SCHED_POWERSAVE_ON_AC="0"
defaults.conf L0013: SCHED_POWERSAVE_ON_BAT="1"
/etc/tlp.conf L0135: NMI_WATCHDOG="0"
/etc/tlp.conf L0150: DISK_DEVICES="nvme0n1"
defaults.conf L0016: DISK_APM_LEVEL_ON_AC="254 254"
defaults.conf L0017: DISK_APM_LEVEL_ON_BAT="128 128"
/etc/tlp.conf L0188: DISK_IOSCHED="mq-deadline mq-deadline"
/etc/tlp.conf L0198: SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
/etc/tlp.conf L0199: SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
defaults.conf L0021: AHCI_RUNTIME_PM_TIMEOUT="15"
/etc/tlp.conf L0226: PCIE_ASPM_ON_AC="default"
/etc/tlp.conf L0227: PCIE_ASPM_ON_BAT="default"
defaults.conf L0024: RADEON_POWER_PROFILE_ON_AC="default"
defaults.conf L0025: RADEON_POWER_PROFILE_ON_BAT="default"
defaults.conf L0026: RADEON_DPM_PERF_LEVEL_ON_AC="auto"
defaults.conf L0027: RADEON_DPM_PERF_LEVEL_ON_BAT="auto"
/etc/tlp.conf L0264: WIFI_PWR_ON_AC="off"
/etc/tlp.conf L0265: WIFI_PWR_ON_BAT="on"
/etc/tlp.conf L0270: WOL_DISABLE="Y"
/etc/tlp.conf L0276: SOUND_POWER_SAVE_ON_AC="0"
/etc/tlp.conf L0277: SOUND_POWER_SAVE_ON_BAT="1"
/etc/tlp.conf L0283: SOUND_POWER_SAVE_CONTROLLER="Y"
defaults.conf L0034: BAY_POWEROFF_ON_AC="0"
defaults.conf L0035: BAY_POWEROFF_ON_BAT="0"
defaults.conf L0036: BAY_DEVICE="sr0"
/etc/tlp.conf L0302: RUNTIME_PM_ON_AC="on"
/etc/tlp.conf L0303: RUNTIME_PM_ON_BAT="auto"
defaults.conf L0039: RUNTIME_PM_DRIVER_BLACKLIST="amdgpu mei_me nouveau nvidia pcieport radeon"
defaults.conf L0040: USB_AUTOSUSPEND="1"
/etc/tlp.conf L0336: USB_BLACKLIST_BTUSB="0"
/etc/tlp.conf L0342: USB_BLACKLIST_PHONE="0"
/etc/tlp.conf L0348: USB_BLACKLIST_PRINTER="1"
/etc/tlp.conf L0354: USB_BLACKLIST_WWAN="0"
/etc/tlp.conf L0366: USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN="0"
defaults.conf L0046: RESTORE_DEVICE_STATE_ON_STARTUP="0"
/etc/tlp.conf L0437: RESTORE_THRESHOLDS_ON_BAT="1"
defaults.conf L0048: NATACPI_ENABLE="1"
defaults.conf L0049: TPACPI_ENABLE="1"
defaults.conf L0050: TPSMAPI_ENABLE="1"
/etc/tlp.conf L0425: START_CHARGE_THRESH_BAT0="85"
/etc/tlp.conf L0426: STOP_CHARGE_THRESH_BAT0="90"
/etc/tlp.conf L0431: START_CHARGE_THRESH_BAT1="85"
/etc/tlp.conf L0432: STOP_CHARGE_THRESH_BAT1="90"
+++ System Info
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = enabled
Mode = AC
+++ Processor
CPU model = Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu1/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu2/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu3/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu4/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu4/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu4/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu4/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu4/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu5/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu5/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu5/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu5/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu5/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu5/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu5/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu6/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu6/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu6/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu6/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu6/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu6/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu6/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu7/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu7/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu7/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu7/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu7/cpufreq/scaling_max_freq = 4600000 [kHz]
/sys/devices/system/cpu/cpu7/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu7/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 8 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 100 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo = 0
/sys/devices/system/cpu/intel_pstate/turbo_pct = 66 [%]
/sys/devices/system/cpu/intel_pstate/num_pstates = 43
/sys/module/workqueue/parameters/power_efficient = Y
/proc/sys/kernel/nmi_watchdog = 0
+++ Temperatures
/proc/acpi/ibm/thermal = 41 -128 0 0 28 0 0 -128 [°C]
/proc/acpi/ibm/fan = 0 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 1500
/proc/sys/vm/dirty_expire_centisecs = 1500
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
+++ Storage Devices
Devices = nvme0n1
/dev/nvme0n1:
Type = NVMe
Model = SKHynix_HFS001TD9TNG-L5B0B
Firmware = 80750C10
Scheduler = [mq-deadline] kyber bfq none (multi queue)
Runtime PM: control = auto, autosuspend_delay_ms = (not available)
SMART info:
Critical Warning: 0x00
Temperature: 33 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 0%
Data Units Written: 8.939.572 [4,57 TB]
Power Cycles: 909
Power On Hours: 1.814
Unsafe Shutdowns: 172
Media and Data Integrity Errors: 0
+++ AHCI Link Power Management (ALPM)
No AHCI-enabled host controller detected.
+++ Intel Graphics
/sys/module/i915/parameters/enable_dc = -1 (use per-chip default)
/sys/module/i915/parameters/enable_fbc = -1 (use per-chip default)
/sys/module/i915/parameters/enable_psr = -1 (use per-chip default)
/sys/module/i915/parameters/modeset = 1 (enabled)
/sys/class/drm/card0/gt_min_freq_mhz = 300 [MHz]
/sys/class/drm/card0/gt_max_freq_mhz = 1150 [MHz]
/sys/class/drm/card0/gt_boost_freq_mhz = 1150 [MHz]
+++ Wireless
bluetooth = on
wifi = on
wwan = on
hci0(btusb) : bluetooth, not connected
wlp0s20f3(iwlwifi) : wifi, not connected, power management = off
wwp0s20f0u7(cdc_mbim) : wwan, connected
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 0
/sys/module/snd_hda_intel/parameters/power_save_controller = N
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = [default] performance powersave powersupersave (using BIOS preferences)
+++ Runtime Power Management
Device blacklist = (not configured)
Driver blacklist = amdgpu mei_me nouveau nvidia pcieport radeon
/sys/bus/pci/devices/0000:00:00.0/power/control = on (0x060000, Host bridge, skl_uncore)
/sys/bus/pci/devices/0000:00:02.0/power/control = on (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:04.0/power/control = on (0x118000, Signal processing controller, proc_thermal)
/sys/bus/pci/devices/0000:00:08.0/power/control = on (0x088000, System peripheral, no driver)
/sys/bus/pci/devices/0000:00:12.0/power/control = on (0x118000, Signal processing controller, intel_pch_thermal)
/sys/bus/pci/devices/0000:00:14.0/power/control = on (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:14.2/power/control = on (0x050000, RAM memory, no driver)
/sys/bus/pci/devices/0000:00:14.3/power/control = on (0x028000, Network controller, iwlwifi)
/sys/bus/pci/devices/0000:00:15.0/power/control = on (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:16.0/power/control = auto (0x078000, Communication controller, mei_me)
/sys/bus/pci/devices/0000:00:1c.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1c.4/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1d.0/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1d.4/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1f.0/power/control = on (0x060100, ISA bridge, no driver)
/sys/bus/pci/devices/0000:00:1f.3/power/control = on (0x040380, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:1f.4/power/control = on (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:00:1f.5/power/control = on (0x0c8000, Serial bus controller [0c80], no driver)
/sys/bus/pci/devices/0000:00:1f.6/power/control = on (0x020000, Ethernet controller, e1000e)
/sys/bus/pci/devices/0000:01:00.0/power/control = on (0x080501, SD Host controller, sdhci-pci)
/sys/bus/pci/devices/0000:02:00.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:03:00.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:03:01.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:03:02.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:04:00.0/power/control = on (0x088000, System peripheral, thunderbolt)
/sys/bus/pci/devices/0000:3a:00.0/power/control = on (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:3d:00.0/power/control = on (0x010802, Non-Volatile memory controller, nvme)
+++ USB
Autosuspend = enabled
Device whitelist = (not configured)
Bluetooth blacklist = disabled
Phone blacklist = disabled
WWAN blacklist = disabled
Bus 004 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 003 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 004 ID 13d3:56bc control = auto, autosuspend_delay_ms = 2000 -- IMC Networks Integrated Camera (uvcvideo)
Bus 001 Device 008 ID 2cb7:0210 control = auto, autosuspend_delay_ms = 2000 -- Fibocom L830-EB-00 LTE WWAN Modem (cdc_mbim, cdc_acm)
Bus 001 Device 010 ID 045e:00cb control = on, autosuspend_delay_ms = 2000 -- Microsoft Corp. Basic Optical Mouse v2.0 (usbhid)
Bus 001 Device 005 ID 8087:0aaa control = auto, autosuspend_delay_ms = 2000 -- Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP) (btusb)
Bus 001 Device 002 ID 058f:9540 control = auto, autosuspend_delay_ms = 2000 -- Alcor Micro Corp. AU9540 Smartcard Reader (no driver)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Features: Charge Thresholds and Recalibrate
natacpi = active (data, thresholds)
tpacpi-bat = active (recalibrate)
tp-smapi = inactive (ThinkPad not supported)
+++ ThinkPad Battery Status: BAT0 (Main / Internal)
/sys/class/power_supply/BAT0/manufacturer = SMP
/sys/class/power_supply/BAT0/model_name = 5B10W13906
/sys/class/power_supply/BAT0/cycle_count = 35
/sys/class/power_supply/BAT0/energy_full_design = 50450 [mWh]
/sys/class/power_supply/BAT0/energy_full = 47530 [mWh]
/sys/class/power_supply/BAT0/energy_now = 41730 [mWh]
/sys/class/power_supply/BAT0/power_now = 7707 [mW]
/sys/class/power_supply/BAT0/status = Discharging
/sys/class/power_supply/BAT0/charge_start_threshold = 85 [%]
/sys/class/power_supply/BAT0/charge_stop_threshold = 90 [%]
tpacpi-bat.BAT0.forceDischarge = 0
Charge = 87.8 [%]
Capacity = 94.2 [%]
