Hello
I blacklisted my integrated bluetooth adapter from the USB autosuspend option in TLP by modifying /etc/tlp.conf
. I can see if this change is in effect by issuing sudo tlp-stat
and checking that the power management of the bluetooth adapter is set to “on” (meaning no USB autosuspend) rather than “auto” (meaning USB autosuspend). Or, I can just check directly in /sys/bus/usb/devices/1-3/power/control
The problem is that TLP does not apply this at boot, rather only when I manually issue sudo tlp start
Note that TLP is enabled and working at boot.
My first guess is that TLP actually does apply the right setting but that then it is overwritten by some other program.
The only other power saving tool I have installed is powertop, however I only use it as a power monitor.
14:31:48 ⟩ inxi -Fazy
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=9eb44dd1-1630-4db8-8f51-9542e721051b rw pcie_aspm=force pci=noaer
nmi_watchdog=0 i915.modeset=1 i915.enable_fbc=1 i915.enable_psr=2
i915.enable_dc=2 i915.disable_power_well=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 13 9360 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 05JK94 v: A00 serial: <filter> UEFI: Dell v: 2.13.0
date: 11/14/2019
ID-1: BAT0 charge: 47.4 Wh condition: 47.4/60.0 Wh (79%) volts: 8.4/7.6
model: SMP DELL TP1GT61 type: Li-poly serial: <filter> status: Full
Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 3072 KiB
bogomips: 21607
Speed: 600 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 638 2: 679 3: 635
4: 603
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 0c45:670c
Display: wayland server: X.org 1.20.8 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: f040
bus ID: 3a:00.0 chip ID: 168c:003e
IF: wlp58s0 state: up mac: <filter>
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
bus ID: 1-3:2 chip ID: 0cf3:e300
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 4-1.2:3 chip ID: 0bda:8153 serial: <filter>
IF: enp57s0u1u2 state: down mac: <filter>
IF-ID-1: vpn0 state: up speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 953.87 GiB used: 127.53 GiB (13.4%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 42AZS6AC scheme: GPT
ID-1: / raw size: 128.00 GiB size: 124.99 GiB (97.65%)
used: 29.38 GiB (23.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home raw size: 817.36 GiB size: 803.53 GiB (98.31%)
used: 97.89 GiB (12.2%) fs: ext4 dev: /dev/nvme0n1p3
ID-1: swap-1 type: partition size: 8.00 GiB used: 264.8 MiB (3.2%)
priority: -2 dev: /dev/nvme0n1p1
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 225 Uptime: 3h 02m Memory: 7.50 GiB used: 2.55 GiB (33.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1469
pacman: 1459 lib: 366 flatpak: 10 Shell: Zsh v: 5.8 running in: tilix
inxi: 3.1.05
Some idea?
