Hi there,
The recent update was the most devastating I have ever experienced. I managed to fix a problem of my laptop screen not being recognized thanks to some aid in the update post (downgrading optimus-manager
), but now I find a weirder issue.
Everything works fine until I suspend the system; then when I log back in most of the text in Gnome-related stuff (extensions like the dock, the application menu, even the login screen itself, etc) is just gone for good. The applications themselves work fine, it’s just the DE. Here I attach a screenshot:
My specs are:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=cf1293a5-ebc9-4100-b028-d45a8ec4961c rw acpi_osi=Linux
acpi_backlight=0 quiet splash apparmor=1 security=apparmor
resume=UUID=5d201beb-5334-4696-b30d-1118f85957b1 udev.log_priority=3
video.use_native_backlight=1 i915.enable_dpcd_backlight=0
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 81Y6 v: Lenovo Legion 5 15IMH05H
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15IMH05H
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: EFCN51WW date: 05/19/2021
ID-1: BAT0 charge: 59.8 Wh (82.0%) condition: 72.9/80.0 Wh (91.1%)
volts: 17.1 min: 15.4 model: Celxpert L19C4PC1 type: Li-poly
serial: <filter> status: Charging cycles: 176
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 08:00.0
IF: enp8s0 state: down mac: <filter>
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 942.7 GiB used: 130.83 GiB (13.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA PLUS SSD
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFA10.5 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: SK Hynix
model: HFM512GDHTNI-87A0B size: 476.94 GiB block-size: physical: 512 B
rev: 11010C00 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
used: 130.83 GiB (29.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 42.0 C pch: 43.0 C mobo: N/A gpu: nvidia
temp: 42 C
Processes: 326 Uptime: 8h 6m wakeups: 10 Memory: 15.5 GiB
used: 4.3 GiB (27.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1438 pacman: 1428 lib: 330 flatpak: 10 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.11
Thanks for your attention
Edit: added full specs (inxi -Fazy
) as requested
