when i install a theme , i change it from appearance. but some applications do not follow the same theme. I’ve told that that was because of difference of qt and gtk difference. now is there any way to match this custom theme “orchid” in the kvantum? or is there any theme converter that can help with the situation?
All I want is that tittle bar to change.
For title bar appearance go to window manager tweaks and change it there.
This has been bogging me since 2016. you do NOT know how much I appreciate your answer.
THANK YOU!
