hello I am a noob ,
timeshift is not selecting my pendrive to store snapshots it says " selected device does not have a linux partition"
the file system of pendrive is fat32 according to gparted
please help me
Hi,
Iâm not an advanced user, Iâm more of that user who manages almost alone he he.
But I can tell you that the timeshift in manjaro works better with the BTRFS filesystem, however if you are trying to save your backups via Rsync mode, you can read it here with an online translator
Good luck!
T+ = See you later
most pendrives are formatted that way
but, alas, fat32 indeed isnât a linux filesystem
It doesnât support permissions and file ownership - hence the message.
Linux can read it and write to it - but it is not a âLinux filesystemâ because of the above.
simple solution: format the pendrive as ext4 filesystem
(the data thatâs on it now will be lost, of course!)
this helped a lot thank you
I did this and all worked thank you for helping me
One day I needed the forums a lot, as I still need it to this day, and everything Iâve been putting in my notepad that I kindly received from fellows around the world, I do the same out there in the same kind and pleasant way to try be useful to other fellows in using Linux.
For that and with that, I am very grateful for having helped you in some way.
T+ = See you later
The very clearly visible reference to the ext4 format when setting up Timeshift apparently was of no use. That could make teejee sad âŠ
