Hi everyone, hope the holidays has treated you well!
I have this issue, where I’m putting my Timeshift backups on an external USB drive. This works fine but, Timeshift creates its own mount point, so I end up with two mounts on the same /dev/sdd1 partition. This happens because:
In /etc/mtab I have the following from Timeshift and my USB Drive:
The issue is that when I go to /wdusb directory in Dolphin I get /run/timeshift/backup instead. Apparently the Timeshift mount point is taking precedence over /wdusb.
Does anyone have some thoughts on how to avoid this, by chance?
No you end up with the same partition on two mount points.
Yes, pick one.
EDIT:
It seems you want two partitions, mounted to separate mount points, or maybe I’ve misinterpreted.
If you want different files at those mount points, then you need two partitions, if you want it to stop changing the path in dolphin then I don’t know.
I want one partition for my external USB drive, as is the case now. I want said drive to be mounted on /wdusb, as it is now. And I want to store my Timeshift backups on that drive, which it does. But, I don’t want to go to /run/timeshift/backup in Dolphin, when my intention is to go to /wdusb. Does that make sense?
Timeshift is creating its own mount point and in-turn overriding my own in Dolphin (although the drive/partition is the same.)
