Hey guys, I cannot create or delete any snapshot of the timeshift GUI.
When timeshift is creating or deleting half of the snapshot it closes the window all of the sudden.
I’ll appreciate the help!
Thanks for the reply.
I hope it can be fixed.
It already is. Update your system and you will have the newest version, in which the problem has been fixed.
Ah, yes, yes, yes. We can only hope. We can only hope. Perhaps, some day. Hopefully soon…
@Aragorn, stop giving away every secret. It makes life more boring.
As Aragorn said the Timeshift update that addresses the issue is already out there just update. Please make sure to unignore glib2 afterwards if you have it set to be ignored.
Thanks, it worked. Timeshift works normally!
