Root applications by default have Breath2 theme. If you run any application with sudo (with some exceptions for KDE apps, there run as root is more complicated) you’ll see the same effect. You probably can change it if you run System Settings as root:
What’s the problem?
I’m interested why you’d have Gparted installed for KDE - I suspect some mixing of desktops messing up stuff here, as we have KDE Partition manager and it’s a better option for KDE…
