Timeshift autosnap fails to create subvolume and can't create snapshots
sudo timeshift --create --comments "test"                        1|13:57:50
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/sda5' (subvolid=0) at '/run/timeshift/25512/backup'
Creating new backup...(BTRFS)
Saving to device: /dev/sda5, mounted at path: /run/timeshift/25512/backup
Created directory: /run/timeshift/25512/backup/timeshift-btrfs/snapshots/2025-12-01_13-58-41
E: ERROR: Could not create subvolume: Text file busy
E: btrfs returned an error: 256
E: Failed to create subvolume snapshot: @
Failed to create snapshot
Removing snapshots (incomplete):
Removing snapshot: 2025-12-01_13-58-41
Deleted directory: /run/timeshift/25512/backup/timeshift-btrfs/snapshots/2025-12-01_13-58-41
Removed snapshot: 2025-12-01_13-58-41
my lsblk
lsblk                                                            0|13:58:41
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda      8:0    0 931.5G  0 disk
├─sda1   8:1    0   224G  0 part
├─sda3   8:3    0   500M  0 part /boot/efi
├─sda4   8:4    0     1G  0 part /boot
├─sda5   8:5    0 338.1G  0 part /home
│                                /var/cache
│                                /var/log
└─sda6   8:6    0 367.9G  0 part /mnt/2AB03840B03814B3
zram0  254:0    0   3.8G  0 disk [SWAP]
sudo btrfs subvolume list /                                      0|14:02:09
ID 256 gen 907 top level 5 path @
ID 257 gen 907 top level 5 path @home
ID 258 gen 871 top level 5 path @cache
ID 259 gen 907 top level 5 path @log
ID 260 gen 50 top level 5 path timeshift-btrfs/snapshots/2025-12-01_02-21-05/@
ID 261 gen 51 top level 5 path timeshift-btrfs/snapshots/2025-12-01_02-21-32/@
inxi -zv8                                                        0|14:03:02
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
    root=UUID=7fae08da-fa36-41a8-bb08-c868a242816e rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.5 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: Dell product: Inspiron 5459 v: N/A
  Mobo: Dell model: 0F1J0W v: A00 serial: <superuser required> part-nu: 06B2
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.9.0
    date: 09/07/2020
  ID-1: BAT0 charge: 23.8 Wh (100%) condition: 23.8/32.6 Wh (73%) volts: 16.59
    min: 14.8 model: SMP DELL VN3N047 type: Li-ion serial: <filter> charging:
    status: full control: start: 75% end: 80% type: standard
    avail: custom,standard,trickle cycles: N/A
  System RAM: total: 8 GiB available: 7.59 GiB used: 3.13 GiB (41.3%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM A type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: curr: 1.35 width (bits): data: 64 total: 64
    manufacturer: SK Hynix part-no: HMT451S6BFR8A-PB serial: <filter>
  Device-2: DIMM B type: DDR3 detail: synchronous size: 4 GiB
    manufacturer: Chips and Technologies part-no: N/A serial: <filter>
  Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 500 min/max: 400/3100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 20810
    sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD
    8670A/8670M/8690M / R5 M330 M430 Radeon 520 Mobile] vendor: Dell
    driver: radeon v: kernel alternate: amdgpu arch: GCN-1
    code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 1
    speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380 temp: 52.0 C
  Device-3: Microdia Integrated Webcam HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:6712
    class-ID: 0e02
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x14c3 built: 2016 res: 1366x768
    dpi: 112 gamma: 1.2 chroma: red: x: 0.576 y: 0.333 green: x: 0.325 y: 0.580
    blue: x: 0.157 y: 0.137 white: x: 0.314 y: 0.329
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
    surfaceless: drv: iris wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 7.41 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d70
    class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b3 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:07dc
    class-ID: e001
  Local Storage: total: 931.51 GiB used: 25.96 GiB (2.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST1000LM024 HN-M101MBB
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0003 scheme: GPT
  ID-1: / raw-size: 338.12 GiB size: 338.12 GiB (100.00%)
    used: 18.04 GiB (5.3%) fs: btrfs dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: 7fae08da-fa36-41a8-bb08-c868a242816e
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
    used: 217.8 MiB (22.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: bc6e9cec-bc64-4ad5-9409-e0d804fe91d6
  ID-3: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 8.2 MiB (1.6%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: EFI-SYSTEM
    uuid: 1FFE-471A
  ID-4: /home raw-size: 338.12 GiB size: 338.12 GiB (100.00%)
  ID-5: /mnt/2AB03840B03814B3 raw-size: 367.9 GiB size: 367.9 GiB (100.00%)
    used: 7.71 GiB (2.1%) fs: ntfs dev: /dev/sda6 maj-min: 8:6
    label: Education & Software uuid: 2AB03840B03814B3
  ID-6: /var/cache raw-size: 338.12 GiB size: 338.12 GiB (100.00%)
  ID-7: /var/log raw-size: 338.12 GiB size: 338.12 GiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
    zswap: no
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-2: swap-2 type: zram size: 3.79 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
    dev: /dev/zram0
  ID-1: /dev/sda1 maj-min: 8:1 size: 224 GiB fs: ext4 label: rootMX25
    uuid: 41a863d0-58ab-4a43-84d0-e2a5711d373d
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Microdia Integrated Webcam HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6712 class-ID: 0e02
  Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 54.0 C pch: 44.0 C mobo: 42.0 C sodimm: 40.0 C
    gpu: radeon temp: 52.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1349 libs: 366
    tools: gnome-software,pamac,paru,yay pm: flatpak pkgs: 0
    1: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 270
  1: cpu: 14.1% command: nautilus pid: 26402 mem: 286.8 MiB (3.6%)
  2: cpu: 11.5% command: chrome pid: 24914 mem: 305.4 MiB (3.9%)
  3: cpu: 10.9% command: gnome-shell pid: 1609 mem: 368.7 MiB (4.7%)
  4: cpu: 6.5% command: chrome pid: 16727 mem: 555.9 MiB (7.1%)
  5: cpu: 5.0% command: chrome pid: 26868 mem: 255.3 MiB (3.2%)
  Memory top: 5 of 270
  1: mem: 555.9 MiB (7.1%) command: chrome pid: 16727 cpu: 6.5%
  2: mem: 368.7 MiB (4.7%) command: gnome-shell pid: 1609 cpu: 10.9%
  3: mem: 305.4 MiB (3.9%) command: chrome pid: 24914 cpu: 11.5%
  4: mem: 299.2 MiB (3.8%) command: chrome pid: 18808 cpu: 4.6%
  5: mem: 286.8 MiB (3.6%) command: nautilus pid: 26402 cpu: 14.1%
  Processes: 270 Power: uptime: 34m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.01 GiB services: gsd-power,
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: fish v: 4.0.8 running-in: kgx inxi: 3.3.40
I recently cleanly installed Manjaro 25 on my laptop, dual-booting with MX Linux 25 (for some Debian stability).
I have a near-perfect setup now for my liking. The only thing not working is the timeshift-autosnap.
Can anyone please help me solve this problem?
Please provide system information as described (below). I’m sure someone will help when they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a :crystal_ball: at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
If running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
The problem was with how I created my swapfile. I recreated the swapfile following the guidelines from the Arch wiki.
The /swapfile can not be snapshotted. So needed a /swap subvolume first.
I put the swapfile in /swap/swapfile.
Then edited the /etc/fstab and followed the Arch wiki on Btrfs again.
This solved the problem, and now I get the following.
sudo timeshift --create --comments “test” 0|15:04:39
[sudo] password for md:
Mounted ‘/dev/sda5’ (subvolid=0) at ‘/run/timeshift/40119/backup’
Creating new backup…(BTRFS)
Saving to device: /dev/sda5, mounted at path: /run/timeshift/40119/backup
Created directory: /run/timeshift/40119/backup/timeshift-btrfs/snapshots/2025-12-01_15-04-46
Created subvolume snapshot: /run/timeshift/40119/backup/timeshift-btrfs/snapshots/2025-12-01_15-04-46/@
Created control file: /run/timeshift/40119/backup/timeshift-btrfs/snapshots/2025-12-01_15-04-46/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot ‘2025-12-01_15-04-46’: ondemand
