Mod-edit: Formatting and layout
Hi.
My desktop machine can’t suspend via the timer if either option to lock the session is enabled under:
Power - Security
:- “Lock session automatically” ➔ when screen saver is disabled/enabled.
- and “Lock screen when system is going to sleep”.
Instead of suspending, the screen remains in standby and a login screen is shown if the screen is woken up.
If I proceed to login, the ethernet link is now down and if I do sudo reboot now then the machine shuts down instead of rebooting.
The journal then looks like this:
dec 26 12:42:30 sunshine kernel: PM: suspend entry (deep)
dec 26 12:42:30 sunshine kernel: Filesystems sync: 0.007 seconds
dec 26 12:42:30 sunshine rtkit-daemon[1246]: Supervising 3 threads of 2 processes of 1 users.
dec 26 12:42:30 sunshine rtkit-daemon[1246]: Successfully made thread 2734 of process 1218 owned by '1000' RT at priority 5.
dec 26 12:42:30 sunshine rtkit-daemon[1246]: Supervising 4 threads of 2 processes of 1 users.
dec 26 12:42:31 sunshine rtkit-daemon[1246]: Supervising 3 threads of 2 processes of 1 users.
dec 26 12:42:31 sunshine rtkit-daemon[1246]: Successfully made thread 2735 of process 1218 owned by '1000' RT at priority 5.
dec 26 12:42:31 sunshine rtkit-daemon[1246]: Supervising 4 threads of 2 processes of 1 users.
dec 26 12:42:32 sunshine audit[2749]: CRED_ACQ pid=2749 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hos>
dec 26 12:42:32 sunshine lightdm[2749]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=969) by (uid=0)
dec 26 12:42:32 sunshine kernel: audit: type=1103 audit(1608982952.500:105): pid=2749 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="light>
dec 26 12:42:32 sunshine systemd[1]: Created slice User Slice of UID 969.
dec 26 12:42:32 sunshine systemd[1]: Starting User Runtime Directory /run/user/969...
dec 26 12:42:32 sunshine systemd-logind[505]: New session c2 of user lightdm.
dec 26 12:42:32 sunshine systemd[1]: Finished User Runtime Directory /run/user/969.
dec 26 12:42:32 sunshine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? ad>
dec 26 12:42:32 sunshine systemd[1]: Starting User Manager for UID 969...
dec 26 12:42:32 sunshine kernel: audit: type=1130 audit(1608982952.513:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/sy>
dec 26 12:42:32 sunshine dbus-daemon[500]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.157' (uid=0 pid=2753 comm=">
dec 26 12:42:32 sunshine dbus-daemon[500]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
dec 26 12:42:32 sunshine systemd[2753]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
dec 26 12:42:32 sunshine audit[2753]: USER_ACCT pid=2753 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="lightdm" exe="/usr/>
It suspends and wakes fine if I manually select Suspend or if neither “Lock screen” option is enabled under Power - Security
contrasting log:
dec 26 12:17:36 sunshine kernel: r8169 0000:05:00.0 eno1: Link is Down
dec 26 12:17:36 sunshine systemd[1]: Reached target Sleep.
dec 26 12:17:36 sunshine systemd[1]: Starting Suspend...
dec 26 12:17:37 sunshine wpa_supplicant[1004]: nl80211: deinit ifname=p2p-dev-wlp6s0 disabled_11b_rates=0
dec 26 12:17:37 sunshine wpa_supplicant[1004]: nl80211: deinit ifname=wlp6s0 disabled_11b_rates=0
dec 26 12:17:37 sunshine systemd-sleep[1577]: Suspending system...
dec 26 12:17:37 sunshine kernel: PM: suspend entry (deep)
dec 26 12:17:37 sunshine kernel: Filesystems sync: 0.008 seconds
dec 26 12:17:37 sunshine rtkit-daemon[1246]: Supervising 2 threads of 1 processes of 1 users.
dec 26 12:17:37 sunshine rtkit-daemon[1246]: Successfully made thread 1783 of process 1218 owned by '1000' RT at priority 5.
dec 26 12:17:37 sunshine rtkit-daemon[1246]: Supervising 3 threads of 1 processes of 1 users.
dec 26 12:17:37 sunshine rtkit-daemon[1246]: Successfully made thread 1784 of process 1218 owned by '1000' RT at priority 5.
dec 26 12:23:15 sunshine kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
dec 26 12:23:15 sunshine kernel: OOM killer disabled.
dec 26 12:23:15 sunshine kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
dec 26 12:23:15 sunshine kernel: printk: Suspending console(s) (use no_console_suspend to debug)
dec 26 12:23:15 sunshine kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
dec 26 12:23:15 sunshine kernel: sd 0:0:0:0: [sda] Stopping disk
dec 26 12:23:15 sunshine kernel: sd 2:0:0:0: [sdb] Synchronizing SCSI cache
dec 26 12:23:15 sunshine kernel: sd 3:0:0:0: [sdc] Synchronizing SCSI cache
dec 26 12:23:15 sunshine kernel: sd 2:0:0:0: [sdb] Stopping disk
dec 26 12:23:15 sunshine kernel: sd 3:0:0:0: [sdc] Stopping disk
dec 26 12:23:15 sunshine kernel: ACPI: Preparing to enter system sleep state S
Tried running xfce4-power-manager in debug but didn’t get much out of it.
When sleep is about to be triggered it said:
TRACE[xfpm-manager.c:493] xfpm_manager_alarm_timeout_cb(): Alarm inactivity timeout id 3
xfconf-query -c xfce4-power-manager -lv gives:
/xfce4-power-manager/inactivity-on-ac 16
/xfce4-power-manager/power-button-action 1
/xfce4-power-manager/show-tray-icon 1
Saw several thread on waking from suspend but I haven’t seen this problem precisely.
If I missed it; I’m sorry and would appreciate a pointer to the related thread
My sys:
5.9.11-3-MANJARO x86_64
Ryzen 5 3600
B550 motherboard
Nvidia RTX 2060
Connected peripherals are possibly irrelevant since the issue seems account/authentication-based.
Same version of Manjaro but with gnome has no issues going into suspend on a timer.
Thanks for reading.
