Timed Shutdown/Hibernate during SSH Session
Hi all! I’d run into an oddity, have seen some partially related topics, USB-Ethernet Udev TLP Upowerd, but nothing really included disabling this behavior.
Thought I’d share my progress, if someone runs into something similar:
I run a Manjaro Gnome minimal installation as a workstation for software development. Most of the time I use a lightweight laptop as a thin-client and connect to the workstation via SSH and use NeoVim on my workstation/server. This allows me to work with substantial performance everywhere I go, without having noticeable latency.
The Motherboard that I’m Using for the machine is an Gigabyte Aorus B550m Pro-P rev1. Since there are lots of issues with Gigabyte regarding the RLTK 2.5 gbit Lan controller, I was forced to use an 1gbit USB-Ethernet adapter.
The issue:
When I’m connected to the machine via SSH, at some point the PSU toggles off/on (takes 1 sec). This happens after a certain interval. After that the SSH session still (kinda) lives, the thing you’ll notice is that the terminal freezes on the client machine. It will take approx 2 to 5 minutes to continue what you where doing.
The behavior doesn’t care if there are user processes running. Even during compiling, or other heavy workloads. So it can be a bit annoying :face_with_raised_eyebrow:
The reason I removed TLP: After finding the error message below and reading the TLP documentation, I don’t necessarily need this type of power management on this machine.
/usr/lib/systemd/system-sleep/tlp failed with exit status 1.
This, I thought, disabled the behavior. And didn’t occur for a couple of days. But as I’m writing this, sitting in the room next of the machine, I hear the power supply toggle.
So, I was wondering what triggered this:
journalctl -n 200 --no-pager
mei 17 20:30:51 HVSR gnome-shell[744]: pushModal: invocation of begin_modal failed
mei 17 20:30:51 HVSR gnome-shell[744]: error: Unable to lock: Lock was blocked by an application
// 15 min timed trigger
mei 17 20:45:51 HVSR NetworkManager[573]: <info>   manager: sleep: sleep requested (sleeping: no  enabled: yes)
mei 17 20:45:51 HVSR NetworkManager[573]: <info> device (wlp4s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mei 17 20:45:51 HVSR ModemManager[565]: <info>  system is about to suspend
mei 17 20:45:51 HVSR NetworkManager[573]: <info> device (wlp4s0): set-hw-addr: reset MAC address to xxxx (unmanage)
mei 17 20:45:51 HVSR NetworkManager[573]: <info>  manager: NetworkManager state is now ASLEEP
mei 17 20:45:51 HVSR gnome-shell[744]: pushModal: invocation of begin_modal failed
mei 17 20:45:51 HVSR gnome-shell[744]: error: Unable to lock: Lock was blocked by an application
mei 17 20:45:56 HVSR systemd-logind[531]: Delay lock is active (UID 120/gdm, PID 744/gnome-shell) but inhibitor timeout is reached.
// reached target
mei 17 20:45:56 HVSR systemd[1]: Reached target Sleep.
mei 17 20:45:56 HVSR systemd[1]: Starting Suspend...
mei 17 20:45:56 HVSR systemd-sleep[1442]: Suspending system...
mei 17 20:45:56 HVSR kernel: PM: suspend entry (deep)
mei 17 20:45:56 HVSR kernel: Filesystems sync: 0.005 seconds
// etc
Check status of
systemctl status sleep.target
● sleep.target - Sleep
 Loaded: loaded (/usr/lib/systemd/system/sleep.target; static)
 Active: inactive (dead)
   Docs: man:systemd.special(7)
mei 17 20:25:47 HVSR systemd[1]: Reached target Sleep.
mei 17 20:25:51 HVSR systemd[1]: Stopped target Sleep.
mei 17 20:46:01 HVSR systemd[1]: Stopped target Sleep.
mei 17 21:06:06 HVSR systemd[1]: Reached target Sleep.
mei 17 21:06:11 HVSR systemd[1]: Stopped target Sleep.
mei 17 21:26:16 HVSR systemd[1]: Reached target Sleep.
mei 17 21:26:21 HVSR systemd[1]: Stopped target Sleep.
Eventually masking systemd.sleep* disables this behavior
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
● sleep.target
 Loaded: masked (Reason: Unit sleep.target is masked.)
Still
I’m not sure of if USB Net device registration @ udev causes a kind of innactivity flag to the system. And would it solve the problem if a PCI device is used (or symlink as).
Also, not sure if its a Gnome related, I haven’t tested it on KDE & XFCE.
TLDR, steps how I disabled this behavior:
--super user do
pacman -R tlp   --remove tlp
mkinitcpio -p   --to be certain
update-grub     --ref new images
reboot
--symlink targets to null
--bob is your uncle
Feel free to correct me!
inxi:
   Kernel: 5.11.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
   parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
   root=UUID=XXXX rw udev.log_priority=2
   Console: tty pts/0 DM: GDM 40.0 Distro: Manjaro Linux base: Arch Linux
   Type: Desktop Mobo: Gigabyte model: B550M AORUS PRO-P v: x.x
   serial: <filter> UEFI: American Megatrends LLC. v: F13c date: 02/17/2021
   RAM: total: 31.36 GiB used: 1015.1 MiB (3.2%)
   Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
   family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
   L2: 4 MiB bogomips: 121432
   Speed: 2871 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
   1: 2871 2: 3589 3: 2868 4: 2870 5: 2864 6: 2871 7: 2922 8: 2866 9: 2876
   10: 2870 11: 2871 12: 2867 13: 2870 14: 2868 15: 3274 16: 3588
   cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
   flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
   invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
   movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
   overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
   perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
   rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
   sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
   topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
   vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
   Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
   STIBP: always-on, RSB filling
   Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] driver: nvidia v: 460.73.01
   alternate: nouveau,nvidia_drm bus-ID: 06:00.0 chip-ID: 10de:1b06
   class-ID: 0300
   Display: server: X.org 1.20.11 compositor: gnome-shell driver:
   loaded: nvidia tty: 237x58
   Message: Advanced graphics data unavailable in console. Try -G --display
   Device-1: NVIDIA GP102 HDMI Audio driver: snd_hda_intel v: kernel
   bus-ID: 06:00.1 chip-ID: 10de:10ef class-ID: 0403
   Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
   driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
   class-ID: 0403
   Sound Server-1: ALSA v: k5.11.18-1-MANJARO running: yes
   Sound Server-4: PipeWire v: 0.3.26 running: no
   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
   chip-ID: 8086:2723 class-ID: 0280
   IF: wlp4s0 state: down mac: <filter>
   Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
   type: USB driver: r8152 bus-ID: 4-3:2 chip-ID: 2357:0601 class-ID: 0000
   serial: <filter>
   IF: enp8s0f3u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
   IF-ID-1: virbr0 state: down mac: <filter>
   Device-1: 1-9:2 info: Integrated Express ITE Device type: HID
   driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
   power: 100mA chip-ID: 048d:5702 class-ID: 0300
   Hub-2: 1-10:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
   Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
   Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
   Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
   Device-1: 4-3:2
   info: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
   type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
   power: 256mA chip-ID: 2357:0601 class-ID: 0000 serial: <filter>
   System Temperatures: cpu: 33.4 C mobo: 16.8 C
   Processes: 307 Uptime: 45m wakeups: 0 Init: systemd v: 247 tool: systemctl
   Compilers: gcc: 10.2.0 Packages: pacman: 1100 lib: 307 Shell: Zsh v: 5.8
   running-in: tty pts/0 (SSH) inxi: 3.3.04
Cheers
I’t works, but does it count as an actual solution?
--super user do
reboot
--bob is your uncle
Did you check the energy settings of the desktop environment?
It’s probably configured/deciding to go to sleep after a certain amount of time due to not seeing activity on any (local) input devices.
Thanks for your reply, I did check it indeed. The funny thing is though: if I use the host directly and log in to a Gnome desktop session, lock the desktop and SSH into it via my laptop. I don’t get the timed shutdown behavior.
Power settings:
  no screen dimming
  no auto blank screen
  no auto suspend
  no WiFi + BT override
  -during inactive
Hmm, so this might be a default somewhere which gets overriden by your locked local session but not when only logged in via ssh remotely?
Yes exactly! What I suspect is the USB Ethernet device, which is handled differently by UDev than PCI. Probably its flagged by the kernel as !inactive.
An I340-T4 PCI-E network adapter is in the mail. I will do some testing and report my findings.
Cheers!
