Hello everyone,
my laptop recently had some hardware problems which resulted in manjaro being unable to boot. The following error message appears on boot:
Timed out waiting for device /dev/sdb1.
Dependency failed for /mnt.
Dependency failed for Local File Systems.
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs ....
I know this issue seems similar to others, but I think mine is different.
My system is dual-booting Windows and Manjaro, Windows works fine.
The output in the emergency mode:
blkid
/dev/loop1: TYPE="squashfs"
/dev/nvme0n1p5: BLOCK_SIZE="512" UUID="CE3A753C3A75229F" TYPE="ntfs" PARTUUID="25b8d14-1ca0-4fed-afe3-b4fcca76815a"
/dev/nvme0n1p1: LABEL="Recovery" BLOCK_SIZE="512" UUID="A61244C3124499E7" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="aa3b288d-9381-4650-8e49-f27054530748"
/dev/nvme0n1p6: UUID="0c0f230e-4ee3-4667-b955-7ef76e64bfc9" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="5c759437-b019-8046-a18d-03db5ffdc5b8"
/dev/nvme0n1p4: BLOCK_SIZE="512" UUID="4E5846FA5846E077" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="78a41603-649b-45b9-a8e6-c39499bdea4c"
/dev/ncme0n1p2: UUID="B045-8677" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="f16762a5-55d7-411a-8d31-31d9211014"
/dev/loop0: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/loop8: TYPE="squashfs"
cat /etc/fstab
<file system> <mount point> <type> <options> <dump> <pass>
UUID=B045-8677 /boot/efi vfat umask=0077 0 2
UUID=0c0f230e-4ee3-4667-b955-7ef76e64bfc9 / ext4 noatime 0 1
/dev/sdb1 /mnt ext4 users 0 0
parted -l
Number Start End Size File system Name Flags
1 1049kB 556MB 555MB ntfs Basic data partition hidden, diag
2 556MB 660MB 104MB fat32 EFI system partition boot, esp
3 660MB 676MB 16,8MB Microsoft reserved partition msftres
4 676MB 325GB 325GB ntfs Basic data partition msftdata
5 404GB 405GB 882MB ntfs hidden, diag
6 405GB 512GB 107GB ext4
The hardware defect caused issues with the power supply - in case this might be relevant.
Let me know if I am missing something.
Greetings:)
