Hi everyone,
I’ve been struggling since days to use latest TigerVNC, i finally get it to work but there is a glitch while using ~/.vnc/config file.
session=xfce
geometry=1920x1080
localhost
alwaysshared
I have remove it to be able to use TigerVNC What can be the issue with it ?
[jeanmarc@zbox .vnc]$ cat /etc/pam.d/tigervnc
#%PAM-1.0
# pam_selinux.so close should be the first session rule
#-session required pam_selinux.so close
session required pam_loginuid.so
#-session required pam_selinux.so open
session required pam_namespace.so
session optional pam_keyinit.so force revoke
session required pam_limits.so
-session optional pam_systemd.so
session required pam_unix.so
-session optional pam_reauthorize.so prepare
[jeanmarc@zbox .vnc]$ sudo systemctl --full edit vncserver@:1
[Unit]
Description=Remote desktop service (VNC)
After=syslog.target network.target
[Service]
Type=forking
ExecStart=/usr/bin/vncsession-start %i
PIDFile=/run/vncsession-%i.pid
[Install]
WantedBy=multi-user.target
[jeanmarc@zbox .vnc]$ cat /etc/tigervnc/vncserver.users
# TigerVNC User assignment
# This file assigns users to specific VNC display numbers.
# The syntax is <display>=<username>. E.g.:
# :2=andrew
# :3=lisa
:1=jeanmarc
:2=jm
