TigerLake-LP no sound
Hello everyone. I have a TigerLake LP sound card, I have Manjaro Gnome 22.1.3 installed on my machine. I have been struggling with this sound problem since I bought this machine, I could not solve it. When I installed Manjaro, I went a step further. My computer, which used to be marked as “dummy output” and not making any sound at all, now makes a popping sound on startup that makes me feel like the speaker is there. This is not a problem when using Windows 11, but when I start any Linux distro, there is no sound at all. I leave some output of the problem below, if you can help me I would appreciate it.
Here is my sound settings: htt ps://i.imgur com/wdxABhg.png
inxi -Fazy
  Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=8bd241d7-aeb4-41b9-bdf0-c31fb03af672 rw quiet splash apparmor=1
    security=apparmor resume=UUID=efc7207c-a03a-454d-8778-22e2b43ee1e6
    udev.log_priority=3
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: MONSTER product: Huma H5 V3.1 v: V10
    serial: <superuser required> Chassis: Monster type: 10
  Mobo: Monster model: Huma H5 V3.1 v: V20 serial: <superuser required>
    UEFI: INSYDE v: TN1V7.09_Monster date: 12/28/2021
  ID-1: BAT0 charge: 50.9 Wh (100.0%) condition: 50.9/53.6 Wh (94.9%)
    volts: 12.7 min: 11.4 model: Simplo BASE-BAT type: Li-poly serial: N/A
    status: charging
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xAA
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 2400 min/max: 400/2400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2400 2: 2400 3: 2400 4: 2400 5: 2400 6: 2400
    7: 2400 8: 2400 bogomips: 38720
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: IP3 Tech
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2,
    HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: BKX-Usb2.0 2MP Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: b349:b182
    class-ID: 0102
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0a1c built: 2021 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: IP3 Tech
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
    class-ID: 0102
  API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.73 status: off tools: pw-cli
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 1.38 TiB used: 280.51 GiB (19.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR033 temp: 36.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Wilk model: USB DISK 2.0
    size: 14.46 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
    scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04UBF100
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> scheme: MBR
  ID-1: / raw-size: 44.83 GiB size: 43.82 GiB (97.76%) used: 9.17 GiB (20.9%)
    fs: ext4 dev: /dev/sdb3 maj-min: 8:19
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 288 KiB (0.0%)
    fs: vfat dev: /dev/sdb4 maj-min: 8:20
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sdb2 maj-min: 8:18
  System Temperatures: cpu: 46.0 C mobo: N/A
  Processes: 272 Uptime: 15m wakeups: 3587 Memory: total: 16 GiB
  available: 15.43 GiB used: 2.76 GiB (17.9%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1144 libs: 317 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.28
pactl list cards && pactl list sinks
Card #0
	Driver: module-alsa-card.c
	Owner Module: 6
	Properties:
		alsa.card = "0"
		alsa.card_name = "BKX-Usb2.0 2MP Camera"
		alsa.long_card_name = "BKX-Usb2.0 2MP Camera BKX-Usb2.0 2MP Camera at usb-0000:00:14.0-4, high speed"
		alsa.driver_name = "snd_usb_audio"
		device.bus_path = "pci-0000:00:14.0-usb-0:4:1.2"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.2/sound/card0"
		udev.id = "usb-BKX-Usb2.0_2MP_Camera_BKX-Usb2.0_2MP_Camera-02"
		device.bus = "usb"
		device.vendor.id = "b349"
		device.vendor.name = "BKX-Usb2.0 2MP Camera"
		device.product.id = "b182"
		device.product.name = "BKX-Usb2.0 2MP Camera"
		device.serial = "BKX-Usb2.0_2MP_Camera_BKX-Usb2.0_2MP_Camera"
		device.form_factor = "webcam"
		device.string = "0"
		device.description = "BKX-Usb2.0 2MP Camera"
		module-udev-detect.discovered = "1"
		device.icon_name = "camera-web-usb"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
		input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: input:iec958-stereo
	Ports:
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
			Properties:
			Part of profile(s): input:analog-stereo
		iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
			Part of profile(s): input:iec958-stereo
Card #1
	Owner Module: 7
	Properties:
		alsa.card = "1"
		alsa.card_name = "sof-essx8336"
		alsa.long_card_name = "Monster-HumaH5V3.1-V10"
		alsa.driver_name = "snd_soc_sof_es8336"
		device.bus_path = "pci-0000:00:1f.3-platform-sof-essx8336"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sof-essx8336/sound/card1"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "a0c8"
		device.product.name = "Tiger Lake-LP Smart Sound Technology Audio Controller"
		device.string = "1"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller"
		device.icon_name = "audio-card-pci"
	Profiles:
		input:stereo-fallback: Stereo Input (sinks: 0, sources: 1, priority: 51, available: no)
		output:stereo-fallback: Stereo Output (sinks: 1, sources: 0, priority: 37868, available: yes)
		output:stereo-fallback+input:stereo-fallback: Stereo Output + Stereo Input (sinks: 1, sources: 1, priority: 5151, available: yes)
	Active Profile: output:stereo-fallback
	Ports:
		analog-input-headset-mic: Headset Microphone (type: Headset, priority: 8800, latency offset: 0 usec, availability group: Legacy 1, not available)
			Properties:
			Part of profile(s): input:stereo-fallback, output:stereo-fallback+input:stereo-fallback
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
			Properties:
			Part of profile(s): output:stereo-fallback, output:stereo-fallback+input:stereo-fallback
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 1, not available)
			Properties:
Sink #0
	State: SUSPENDED
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller Stereo
	Sample Specification: s16le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 7
	Mute: no
	Volume: front-left: 36987 /  56% / -14,91 dB,   front-right: 36987 /  56% / -14,91 dB
	        balance 0,00
	Base Volume: 65536 / 100% / 0,00 dB
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-sof-essx8336.stereo-fallback.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = ""
		alsa.id = "ES8336 (*)"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "1"
		device.bus = "pci"
		device.string = "hw:1"
		device.buffering.buffer_size = "65536"
		device.buffering.fragment_size = "16384"
		device.access_mode = "mmap+timer"
		device.profile.name = "stereo-fallback"
		device.profile.description = "Stereo"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Stereo"
	Ports:
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability unknown)
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 1, not available)
	Active Port: analog-output-speaker
	Formats:
		pcm
uname -a
Linux ark 6.1.38-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Jul  5 23:49:30 UTC 2023 x86_64 GNU/Linux
options snd-hda-intel dmic_detect=0
options snd-hda-intel index=0
https://bbs.archlinux.org/viewtopic.php?id=286495
OP account is shown as no longer active
Modprobe option snd-hda-intel dmic_detect=0 (to disable internal microphone) was deprecated and replaced by snd-intel-dspcfg.dsp_driver=1 in 2020
but internal microphone should be working on most Tiger Lake systems
