Thunderbird compacted folder issue
I have the same problem:
I can´t compress one of my email accounts permantly.
All other work fine.
Filesystem is ext4.
Please see the links @scotty65 has already given.
Link #1: delete the trash and trash.msf.
No success.
What I observed: compacting all folder under the top email account works.
I do notice this warning when using Thunderbird (daily branch) but whether it has any bearing on your issue, I can’t say:
I have personally never experienced any file corruption as described. It might be best to ask for help directly from Thunderbird:
I am using Thunderbird 128.5.2 esr.
Your posts have been moved to a new dedicated topic to increase visibility. Note that adding your own issue to another Member’s topic is generally discouraged.
Please edit your first post in this thread and provide your system information and describe your issue with as much detail as possible.
The following copy/paste information should help remind you of forum guidelines for presentation.
As a new or infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
    root=UUID=86b44fe2-10a4-46cd-a916-50fa4f477973 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Server System: Supermicro product: X10SRA v: 0123456789
    serial: <filter> Chassis: type: 17 v: 0123456789 serial: <filter>
  Mobo: Supermicro model: X10SRA v: 1.01 serial: <filter>
    uuid: 00000000-0000-0000-0000-ac1f6b15f24c UEFI: American Megatrends v: 2.1a
    date: 10/24/2018
  System RAM: total: 32 GiB available: 31.22 GiB used: 2.44 GiB (7.8%)
  Array-1: capacity: 512 GiB note: check slots: 8 modules: 4 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: DIMMA1 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2400 MT/s volts: curr: 0.003 min: 1.14 max: 1.26 width (bits):
    data: 64 total: 64 manufacturer: N/A part-no: KHX2400C12D4/8GX
    serial: <filter>
  Device-2: NO DIMM type: no module installed
  Device-3: DIMMB1 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Device-4: NO DIMM type: no module installed
  Device-5: DIMMC1 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Device-6: NO DIMM type: no module installed
  Device-7: DIMMD1 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Device-8: NO DIMM type: no module installed
  Slot: 1 type: PCIe gen: 3 status: available length: short volts: 3.3
    bus-ID: 01:00.0
  Slot: 2 type: PCIe gen: 3 status: in use length: short volts: 3.3
    bus-ID: 02:00.0
  Slot: 3 type: PCIe gen: 2 status: available length: short volts: 3.3
    bus-ID: 0a:00.0
  Slot: 4 type: PCIe gen: 3 status: available length: long volts: 3.3
    bus-ID: ff:00.0
  Slot: 5 type: PCIe gen: 2 status: available length: short volts: 3.3
    bus-ID: 0b:00.0
  Slot: 6 type: PCIe gen: 3 status: in use length: long volts: 3.3
    bus-ID: 03:00.0
  Info: model: Intel Core i7-6800K socket: LGA2011-3 bits: 64 type: MT MCP
    arch: Broadwell gen: core 6 level: v3 note: check built: 2015-18
    process: Intel 14nm family: 6 model-id: 0x4F (79) stepping: 1
    microcode: 0xB000040
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 15 MiB desc: 1x15 MiB
  Speed (MHz): avg: 1201 min/max: 1200/3800 base/boost: 3400/4000 scaling:
    driver: intel_cpufreq governor: schedutil volts: 1.8 V ext-clock: 100 MHz
    cores: 1: 1201 2: 1201 3: 1201 4: 1201 5: 1201 6: 1201 7: 1201 8: 1201
    9: 1201 10: 1201 11: 1201 12: 1201 bogomips: 81633
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts cat_l3 cdp_l3 clflush cmov constant_tsc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cx16 cx8
    dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_ppin intel_pt
    invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc
    nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt
    pse pse36 pti pts rdrand rdseed rdt_a rdtscp rep_good rtm sdbg sep smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nouveau v: kernel
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 10de:2182
    class-ID: 0300 temp: 27.0 C
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: nouveau gpu: nouveau display-ID: 0
  Monitor-1: DP-1 model: Dell U2713HM serial: <filter> built: 2012 res:
    mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
    x: 0.655 y: 0.337 green: x: 0.294 y: 0.639 blue: x: 0.145 y: 0.039 white:
    x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
    drv: nouveau x11: drv: nouveau
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.8-arch1.1 glx-v: 1.4
    direct-render: yes renderer: NV168 device-ID: 10de:2182 memory: 5.83 GiB
    unified: no display-ID: :1.0
  Device-1: Intel C610/X99 series HD Audio vendor: Super Micro
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
    class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 03:00.1 chip-ID: 10de:1aeb class-ID: 0403
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
    chip-ID: 8086:1533 class-ID: 0200
  Device-2: Intel I210 Gigabit Network vendor: Super Micro driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
  IF: eno2 state: down mac: <filter>
  Info: services: NetworkManager
  Local Storage: total: 1.36 TiB used: 311.19 GiB (22.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 21.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 51d 20h cycles: 17,188
    read-units: 110,376,423 [56.5 TB] written-units: 35,324,904 [18.0 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    family: based SSDs size: 232.89 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 4B6Q temp: 20 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 156d 7h cycles: 33125
    written: 1.12 TiB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 2B6Q temp: 20 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 74d 12h cycles: 12749
    written: 3.57 TiB
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.01
    dev-links: cdrom
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 9.04 GiB (9.2%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
    uuid: 86b44fe2-10a4-46cd-a916-50fa4f477973
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
    used: 231.7 MiB (23.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
    maj-min: 259:6 label: N/A uuid: bab747c4-ac42-4dcb-868b-15b0dddd640e
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
    maj-min: 259:5 label: N/A uuid: 8A29-9547
  ID-4: /data1 raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
    used: 131.45 GiB (57.6%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: N/A uuid: 768ed87d-c01f-413c-8f8c-fc79b9d82187
  ID-5: /data2 raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
    used: 143.56 GiB (62.9%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
    maj-min: 8:17 label: N/A uuid: 452fa532-dfb1-4d36-be75-ec2aa6e67c93
  ID-6: /home raw-size: 300 GiB size: 294.23 GiB (98.08%)
    used: 15.74 GiB (5.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p9
    maj-min: 259:9 label: N/A uuid: 7e496c5b-8cc9-4ada-a53e-31f86c283b22
  ID-7: /var raw-size: 32.46 GiB size: 31.66 GiB (97.51%)
    used: 11.17 GiB (35.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p10
    maj-min: 259:10 label: N/A uuid: 73111fef-a4dd-4ea1-b290-f225a0efee44
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 9bb2d748-0fde-4893-85fe-8c80c8c2533d
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 6661-26CE
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 465.13 GiB fs: ntfs label: N/A
    uuid: 40D863E3D863D626
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 525 MiB fs: ntfs label: N/A
    uuid: 067EE8AD7EE89729
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Hub ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 8087:800a class-ID: 0900
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel 8 channel internal hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8002
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 8-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-11: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 9-1:2 info: Logitech Gaming Mouse G300 type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 046d:c246 class-ID: 0300
  Device-2: 9-2:3 info: CHERRY KC 6000 Slim Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 046a:0113 class-ID: 0300
  Hub-12: 10-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 19.0 C pch: 30.0 C mobo: N/A gpu: nouveau
    temp: 27.0 C
  Fan Speeds (rpm): N/A gpu: nouveau fan: 471
  Packages: pm: pacman pkgs: 1285 libs: 361 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 333
  1: cpu: 100% command: ps pid: 2558 mem: 3.36 MiB (0.0%)
  2: cpu: 16.6% command: firefox pid: 1167 mem: 449.9 MiB (1.4%)
  3: cpu: 8.9% command: [kworker/u24:5-flush-259:0] pid: 147
    mem: 0.00 MiB (0.0%)
  4: cpu: 7.9% command: [kworker/u24:6-events_unbound] pid: 148
  5: cpu: 5.5% command: [kworker/u24:8-events_unbound] pid: 150
  Memory top: 5 of 333
  1: mem: 449.9 MiB (1.4%) command: firefox pid: 1167 cpu: 16.6%
  2: mem: 373.6 MiB (1.1%) command: thunderbird pid: 1169 cpu: 4.4%
  3: mem: 302.2 MiB (0.9%) command: plasmashell pid: 941 cpu: 2.1%
  4: mem: 244.5 MiB (0.7%) command: kwin_wayland pid: 780 cpu: 4.3%
  5: mem: 220.7 MiB (0.6%) command: firefox pid: 2142 cpu: 4.2%
  Processes: 333 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Bash (su) v: 5.2.37 running-in: konsole inxi: 3.3.37
I have three computers: on two computers, the compacting fails on the specific acoount, the laptop works.
