After the latest update to Thunderbird 137 the printing function for pdf documents no longer works correctly. This is true for the hardware printer and for pdf printing as well. While I have found as solution to change the pdf-viewer in Thunderbird to an other software, the pdf-printer in Thunderbird is still not working. I have no add-ons installed.
PDF printing seems to be working (for me) on Plasma.
Please provide system information as described (below), posted as preformatted text (see links below for instructions).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
I have Manjaro in the current version on two different devices, once with xcfe, once with Plasma. For me, both systems show the same issue.
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=2980b369-962f-40e4-97c8-aaee25322d7b rw quiet splash
resume=UUID=97132b9e-091e-4d2d-93aa-90fb2155f878 udev.log_priority=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop System: LENOVO product: 90B6009WMZ v: Lenovo H50-50
serial: <superuser required>
Mobo: LENOVO model: SHARKBAY v: 31900058 STD serial: <superuser required>
part-nu: LENOVO_PN_90B6009WMZ uuid: <superuser required> UEFI: LENOVO
v: IEKT31AUS date: 03/09/2015
System RAM: total: 16 GiB available: 15.57 GiB used: 2.17 GiB (13.9%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M378B1G73QH0-CK0 serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3400 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 25549
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
disabled
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GM107 [GeForce GTX 745] vendor: Micro-Star MSI
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 2
speed: 5 GT/s lanes: 16 ports: active: none off: HDMI-A-1 empty: VGA-1
bus-ID: 01:00.0 chip-ID: 10de:1382 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: Acer K272HL serial: <filter> built: 2016
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.329 green:
x: 0.314 y: 0.620 blue: x: 0.153 y: 0.063 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1920x1200, 1680x1050, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 745/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.4.309 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 745 driver: N/A device-ID: 10de:1382
surfaces: xcb,xlib
wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.83 TiB used: 711.66 GiB (38.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Silicon Power
model: SPCC Solid State Disk size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1B0
scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08M2NA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 459.52 GiB size: 451.24 GiB (98.20%) used: 26.6 GiB (5.9%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 2980b369-962f-40e4-97c8-aaee25322d7b
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: D7E4-1A9F
ID-3: /run/media/tapis raw-size: 907.1 GiB size: 907.1 GiB (100.00%)
used: 685.05 GiB (75.5%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: Lenovo
uuid: 6CB24CF0B24CC076
ID-1: swap-1 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 97132b9e-091e-4d2d-93aa-90fb2155f878
ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: C6A24194A2418A3F
ID-2: /dev/sda2 maj-min: 8:2 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 3044-C7EA
ID-3: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 417.26 GiB fs: ntfs label: Windows8_OS
uuid: 2C404BEC404BBB7A
ID-5: /dev/sda5 maj-min: 8:5 size: 582 MiB fs: ntfs label: N/A
uuid: 4EB8102CB8101555
ID-6: /dev/sdc2 maj-min: 8:34 size: 24.41 GiB fs: ntfs label: PBR_DRV
uuid: 50B23AF5B23ADEE2
Hub-2: 1-1:2 info: Atmel 4-Port Hub ports: 4 rev: 1.1
chip-ID: 03eb:0902 class-ID: 0900
Device-1: 1-1.2:4 info: Lenovo Black Silk Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 17ef:602d class-ID: 0300
Device-2: 1-2:3 info: C AB CLX.PayPen type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 200mA chip-ID: 0a93:0103 class-ID: ff00 serial: <filter>
Hub-3: 1-3:5 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-3.1:6 info: Logitech Premium Optical Wheel Mouse (M-BT58)
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 046d:c03e class-ID: 0301
Hub-4: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Device-1: 2-1.4:3 info: Genesys Logic SD/MMC card reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 05e3:0722 class-ID: 0806 serial: <filter>
Hub-6: 3-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-7: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-8: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
System Temperatures: cpu: 31.0 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 42%
Packages: pm: pacman pkgs: 1307 libs: 359 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.init7.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 230
1: cpu: 27.6% command: thunderbird pid: 1620 mem: 570.5 MiB (3.5%)
2: cpu: 10.1% command: firefox pid: 1266 mem: 521.6 MiB (3.2%)
3: cpu: 9.9% command: zsh pid: 1891 mem: 9.76 MiB (0.0%)
4: cpu: 8.2% command: konsole pid: 1882 mem: 197.8 MiB (1.2%)
5: cpu: 6.9% command: firefox pid: 1465 mem: 229.2 MiB (1.4%)
Memory top: 5 of 230
1: mem: 570.5 MiB (3.5%) command: thunderbird pid: 1620 cpu: 27.6%
2: mem: 521.6 MiB (3.2%) command: firefox pid: 1266 cpu: 10.1%
3: mem: 473.6 MiB (2.9%) command: plasmashell pid: 750 cpu: 0.9%
4: mem: 229.2 MiB (1.4%) command: firefox pid: 1465 cpu: 6.9%
5: mem: 197.8 MiB (1.2%) command: konsole pid: 1882 cpu: 8.2%
Processes: 230 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.37
Does this also hapen when running Thunderbird in safe mode?
Or, I should say…
Troubleshoot Mode, as they seem to be calling it now;
Unfortunately no change in Troubleshoot Mode. When choosing Okular to display pdf, everything works correctly.
So, for clarity, are you saying that neither system will print to PDF (using Save as PDF) or to the physical printer?
I should mention that Okular is the default PDF viewer on my local machine. There’s nothing to specifically indicate Okular is used when choosing Save as PDF from the Thunderbird print dialog.
The fact that a PDF file is produced suggests (to me) that there isn’t an issue with PDF printing. I have two destination options when printing from Thunderbird - Save as PDF and Canon Printer.
Can you specify what other options you have that I don’t?
Please verify that cups-pdf is installed;
pacman -Qi cups-pdf
I believe it should be available by default on Manjaro systems, but if it isn’t, you can install it manually:
sudo pacman -S cups-pdf
cups-pdf enables the configuration needed to print to PDF.
It’s possible that CUPS isn’t configured properly;
Another possibility is a problem with your physical printer. Are you able to print to your physical printer from other applications?
Thank you for all your help.
The standard settings in both of my two Manjaro-Installations for printing pdf directly (when opening a pdf-attachment in Thunderbird) is as follows:
When I go to Thunderbird → Settings → Searching for “pdf” I find as “Action” for pdf: “Preview in Thunderbird”. Without any change in the settings, when I open a pdf in Thunderbird, it is shown apparently with this Thunderbird preview software (not with Okular). There is a printing dialog, opening as usual, and I used to print pdf by that way. But now the printing process results in white papers (while the printer is “printing”).
My solution:
Within the pdf-Settings (as mentioned above) I can change in Dropdown-Menu “Action” and select Okular, and everything is fine. All pdf from Thunderbird are now shown in Ocular and the printing process is working without a problem.
As for me, I am satisfied with this solution, but I had to find that way to go, because the standard setting in both installations I have was not with Ocular but with Thunderbird preview.
Other people might have the same issue, but the solution is very easy (still you have to make the changes in the settings).
