Thumbnails fail to generate
Hello There,
i've been a casual linux user, i switched to manjaro yesterday so the issues i face are:-
the image thumbnails don't seem to load, i did search the forum like the good forum user i am, but i was unable to find a duplicate thread. apologies in advance if i missed it.
in case i mess up here's the imgur post where i uploaded the screenshots
https://imgur.com/a/aWa26dn
Running KDE Plasma 5 on Manjaro latest stable.
Thanks in Advance.
Blockquote
Kernel: 5.4.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: KDE Plasma 5.19.3 tk: Qt 5.15.0 wm: kwin_x11 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: Apple product: iMac16,1 v: 1.0 serial:
Chassis: type: 9 v: Mac-A369DDC4E67F1C45 serial:
Mobo: Apple model: Mac-A369DDC4E67F1C45 v: iMac16,1 serial:
UEFI: Apple v: 234.0.0.0.0 date: 04/16/2020
RAM: total: 7.65 GiB used: 5.27 GiB (68.8%)
RAM Report:
Topology: Dual Core model: Intel Core i5-5250U bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 3072 KiB bogomips: 12805
Speed: 844 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 1171 2: 1207
3: 1212 4: 1163
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1626
Display: x11 server: X.Org 1.20.8 driver: intel compositor: kwin_x11
resolution: 1920x1080~60Hz
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0
Sound Server: ALSA v: k5.4.52-1-MANJARO
Device-1: Broadcom and subsidiaries BCM43602 802.11ac Wireless LAN SoC
vendor: Apple driver: brcmfmac v: kernel port: efa0 bus ID: 02:00.0
chip ID: 14e4:43ba
IF: wlp2s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
Device-2: Broadcom and subsidiaries NetXtreme BCM57766 Gigabit Ethernet
PCIe
driver: tg3 v: 3.137 port: efa0 bus ID: 03:00.0 chip ID: 14e4:1686
IF: enp3s0f0 state: down mac:
WAN IP:
Local Storage: total: 1.85 TiB used: 823.41 GiB (43.5%)
ID-1: /dev/sda vendor: Apple model: HDD HTS541010A9E662 size: 931.51 GiB
speed: 3.0 Gb/s rotation: 5400 rpm serial: rev: B5D0 scheme: GPT
ID-2: /dev/sdb type: USB vendor: SanDisk model: Ultra size: 28.64 GiB
serial: rev: 1.00 scheme: GPT
ID-3: /dev/sdc type: USB vendor: Lenovo model: USB Hard Drive
size: 931.51 GiB serial: rev: 1U scheme: MBR
ID-1: / size: 27.77 GiB used: 16.16 GiB (58.2%) fs: ext4 dev: /dev/sdb2
label: N/A uuid: 10ffde17-fb58-4e74-a57c-0d21d8db1994
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
dev: /dev/sdb1 label: N/A uuid: 2B27-5A73
ID-3: /run/media/oran/Oran HDD size: 868.72 GiB used: 754.35 GiB (86.8%)
fs: exfat dev: /dev/sdc3 label: Oran HDD uuid: 6E3E-BBA8
ID-4: /run/media/oran/Win Live size: 62.50 GiB used: 52.90 GiB (84.6%)
fs: ntfs dev: /dev/sdc2 label: Win Live uuid: 5E067E40067E18EB
ID-5: /var/lib/snapd/snap/core18/1880 raw size: 55.0 MiB
size: used: fs: squashfs dev: /dev/loop0
label: N/A uuid: N/A
ID-6: /var/lib/snapd/snap/snapd/8542 raw size: 29.9 MiB
size: used: fs: squashfs dev: /dev/loop1
ID-7: /var/lib/snapd/snap/spotify/41 raw size: 163.7 MiB
size: used: fs: squashfs dev: /dev/loop2
ID-1: /dev/sda1 size: 200.0 MiB fs: vfat label: EFI uuid: 67E3-17ED
ID-2: /dev/sda2 size: 314.65 GiB fs: ntfs label: New Volume
uuid: A4402B9A402B726A
ID-3: /dev/sda3 size: 244.75 GiB fs: apfs label: N/A
uuid: 4d4f0a5e-e213-48fc-b01b-0d5b0b2b6c04
ID-4: /dev/sda4 size: 371.45 GiB fs: ntfs label: BOOTCAMP
uuid: DEDC9551DC952535
ID-5: /dev/sda5 size: 473.0 MiB fs: ntfs label: N/A uuid: 2494C1CA94C19F24
ID-6: /dev/sdc1 size: 300.0 MiB fs: vfat label: SYSTEM uuid: B689-5C1A
Hub: 1-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:2 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 10c4:8108
Device-2: 1-3:3 info: China Resource Semico USB Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s chip ID: 1a2c:2124
Device-3: 1-5:4 info: Apple FaceTime HD Camera (Built-in) type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s chip ID: 05ac:8511
serial:
Device-4: 1-6:5 info: Apple Bluetooth USB Host Controller
type: Keyboard,Mouse,Bluetooth driver: btusb,hid-generic,usbhid
interfaces: 6 rev: 2.0 speed: 12 Mb/s chip ID: 05ac:8294
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Device-5: 2-1:2 info: SanDisk Ultra Dual type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
chip ID: 0781:5590 serial:
Device-6: 2-4:3 info: Lenovo Lenovo Portable HDD type: Mass Storage
chip ID: 17ef:4533 serial:
System Temperatures: cpu: 43.5 C mobo: N/A
Processes: 226 Uptime: 4h 19m Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: bash v: 5.0.18 running in: xfce4-terminal inxi: 3.0.37
Do you mean "show previews" in Dolphin?
shows preview
where do you find that?
In dolphin (the file manager / folder explorer) setting on the top right corner.
The exact issue i face is thumbnails for things like Desktop wallpapers, widgets and things on panel don't load, the icons in case of panel.
I have no issue with previewing the wallpaper:
I'm sorry, Idk.
yep you got it, thats the exact issue i face :slight_smile:
hope someone knows how to fix it. thanks anyways.
bump up
bump up
still facing the issue
