Three mouse clicks to maximize the window in some applications
I recently installed manjaro gnome and have a problem that I have never met before.
Any window is maximized if you double click on the title. But not Google Chrome and VSCode. For some reason, they need three clicks (if I use their own window frames instead of gnome frames).
I decided to check, maybe I broke something in the system. I took an bootable USB drive and tried to install google chrome on her. The problem persists.
This is my inxi output:
  Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=7541adb9-2825-47f7-8905-c3f8ce7abb75 rw quiet udev.log_priority=3
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: Dell product: Vostro 15-3568 v: N/A serial: <filter>
  Chassis: type: 9 serial: <filter>
  Mobo: Dell model: N/A serial: <filter> UEFI: Dell v: 3.6.0 date: 06/30/2020
  ID-1: BAT0 charge: 9.5 Wh (100.0%) condition: 9.5/41.4 Wh (23.0%)
  volts: 16.7 min: 14.8 model: SMP DELL VN3N047 type: Li-ion serial: <filter>
  status: Full
  RAM: total: 11.56 GiB used: 2.69 GiB (23.2%)
  Info: Dual Core model: Intel Core i3-6100U bits: 64 type: MT MCP
  arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache:
  L2: 3 MiB bogomips: 18406
  Speed: 800 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 800 2: 1127
  3: 837 4: 1200
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca
  mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
  pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
  rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
  vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: l1tf
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: 0
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.1
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Dell driver: ath10k_pci v: kernel port: f040 bus-ID: 01:00.0
  chip-ID: 168c:0042 class-ID: 0280
  vendor: Dell driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
  chip-ID: 0cf3:e009 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 465.76 GiB used: 75.53 GiB (16.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WD5000LPCX-75VHAT0 size: 465.76 GiB block-size: physical: 4096 B
  logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
  rev: 1A03 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
  dev-links: cdrom
  ID-1: / raw-size: 146.49 GiB size: 143.13 GiB (97.71%)
  used: 75.49 GiB (52.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
  uuid: 7541adb9-2825-47f7-8905-c3f8ce7abb75
  used: 41.2 MiB (42.9%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 34CE-ADBF
  ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: N/A
  uuid: A4E67175E6714896
  ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/sda4 maj-min: 8:4 size: 318.65 GiB fs: ntfs label: N/A
  uuid: 3854D7D154D78FCC
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-1:2 info: A4Tech Optical Mouse Opto 510D / OP-620D type: Mouse
  driver: a4tech,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 100mA
  chip-ID: 09da:000a class-ID: 0301
  Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
  Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  class-ID: ff00 serial: <filter>
  Device-4: 1-8:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 48.0 C mobo: 43.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 229 Uptime: 23h 11m wakeups: 4 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1208
  pacman: 1196 lib: 370 flatpak: 12 Shell: Bash v: 5.1.8 running-in: tilix
  inxi: 3.3.06
Is it just me? How can I fix this?
Welcome to the forum! :wave:
Please post your system info as outlined here:
Ok, I edited my post and pasted inxi output
Please read this:
Especially the section Linux has multiple kernels, then install an LTS kernel and try again.
:crossed_fingers:
I changed the kernel to lts, but the problem persists
uname -r
5.10.60-1-MANJARO
Does this problem also occur when you create a new user and log in there? (E.G. boris-gu2)
:thinking:
Yes, on a new user too. There is also this problem on bootable USB drive
