Hi,
I’d like to use the dedicated Nvidia graphics card in my laptop (instead of the integrated CPU one), but I’ve been running into issues.
I have a Thinkpad T520 and a fresh install of Manjaro. Upon installation, I picked free drivers, and I haven’t done anything else driver-related since. Also, the official Nvidia drivers no longer seem to be an option for my (at this point very old) graphics card while using Manjaro.
When go to BIOS and set the graphics to “discrete graphics”, the system doesn’t run - I’m stuck at a black screen. I’m unsure how to start addressing this issue.
All comments very appreciated! (And please let me know if you need more info)
(EDIT: I originally thought my issue was an inadequate PSU since I’m
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=38ab0fd9-55ea-4748-a62a-cca9f3a4d911 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 4243W3Y v: ThinkPad T520
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 4243W3Y serial: <filter> UEFI-[Legacy]: LENOVO
v: 8AET51WW (1.31 ) date: 08/08/2011
ID-1: BAT0 charge: 53.6 Wh (100.0%) condition: 53.6/56.2 Wh (95.4%)
volts: 12.5 min: 10.8 model: LGC 45N1005 type: Li-ion serial: <filter>
status: Full
RAM: total: 15.41 GiB used: 4.98 GiB (32.3%)
Info: Quad Core model: Intel Core i7-2760QM bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 6 MiB bogomips: 38288
Speed: 797 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 797 2: 797 3: 797
4: 797 5: 797 6: 797 7: 797 8: 797
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep smx ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0126
class-ID: 0300
Device-2: Chicony Lenovo Integrated Camera (0.3MP) type: USB
driver: uvcvideo bus-ID: 1-1.6:9 chip-ID: 04f2:b217 class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 116 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
vendor: Lenovo ThinkPad T520 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
Device-3: Huawei E353/E3131 type: USB driver: cdc_ether bus-ID: 2-1.1:8
chip-ID: 12d1:14db class-ID: 0a00
IF: enp0s29u1u1 state: up speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 238.47 GiB used: 59.56 GiB (25.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SB8U-256G-1006
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0006 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT33N rev: LT30
dev-links: cdrom
ID-1: / raw-size: 195.89 GiB size: 191.76 GiB (97.89%)
used: 59.56 GiB (31.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 38ab0fd9-55ea-4748-a62a-cca9f3a4d911
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System Reserved
uuid: B496B9CC96B98F7C
ID-2: /dev/sda2 maj-min: 8:2 size: 42.03 GiB fs: ntfs label: N/A
uuid: 768CBE9C8CBE55F9
ID-3: /dev/sda3 maj-min: 8:3 size: 508 MiB fs: ntfs label: N/A
uuid: DCE2BEB1E2BE8EF0
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:12 info: Corsair Gaming SCIMITAR PRO RGB Mouse
type: Mouse,HID driver: corsair,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 300mA chip-ID: 1b1c:1b3e class-ID: 0300 serial: <filter>
Device-2: 1-1.6:9 info: Chicony Lenovo Integrated Camera (0.3MP) type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:8 info: Huawei E353/E3131 type: Ethernet Network,CDC-Data
driver: cdc_ether interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 2mA
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2440
Processes: 267 Uptime: 6d 18h 36m wakeups: 3 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1372
pacman: 1369 lib: 424 flatpak: 0 snap: 3 Shell: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.06
Screen 0: minimum 8 x 8, current 1600 x 900, maximum 32767 x 32767
LVDS1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 350mm x 190mm
1600x900 59.99*+ 59.82 50.00
1400x900 59.96 59.88
1368x768 60.00 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
800x450 60.00
640x480 59.94
720x405 59.51 60.00 58.99
640x360 59.84 59.32 60.00
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
