Hi folks.
Just moved to Manjaro + i3 from Mint, but have a problem I can’t figure out. Whenever I hit the laptop Fn key it completely lock the DE. I can still move the cursor and access the terminal with ctrl+alt+f2. I’ve googled and searched the forums but not found much in the way of where to start let alone what the issue might be.
Any suggestions appreciated.
Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=505a774d-039a-4210-85b1-c60aa274c7c9 rw quiet
resume=UUID=df3dbecd-6e09-4dc6-b82b-81ef8672304d udev.log_priority=3
Desktop: i3 4.19.1 info: i3bar vt: 2 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 20QJ000CUK v: ThinkPad T495s
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20QJ000CUK serial: <filter> UEFI: LENOVO
v: R13ET40W(1.14 ) date: 10/29/2019
ID-1: BAT0 charge: 50.8 Wh (98.3%) condition: 51.7/57.0 Wh (90.7%)
volts: 12.5 min: 11.5 model: Celxpert 5B10W138 type: Li-poly
serial: <filter> status: Discharging cycles: 30
RAM: total: 13.61 GiB used: 1.14 GiB (8.4%)
Info: Quad Core model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108102 cache: L2: 2 MiB
bogomips: 33538
Speed: 1222 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1222 2: 1222 3: 1223 4: 1223 5: 1322 6: 1262 7: 1230 8: 1221
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 4-2.1:4 chip-ID: 04f2:b67c class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.20.11 compositor: picom v: git-dac85 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.34-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2526 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 2400 bus-ID: 03:00.0
IF: enp3s0f0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 4-1:2 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: not found
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 238.47 GiB used: 4.39 GiB (1.8%)
model: PC SN730 SDBQNTY-256G-1001 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 11130101 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%) used: 4.39 GiB (2.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 505a774d-039a-4210-85b1-c60aa274c7c9
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 36EB-EBE9
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: df3dbecd-6e09-4dc6-b82b-81ef8672304d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 4-1:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-5: 4-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 4-2.1:4 info: Chicony Integrated Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 4-2.2:5 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
chip-ID: 058f:9540 class-ID: 0b00
Device-3: 4-2.4:6 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.5 C mobo: 0.0 C gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): cpu: 0
Processes: 206 Uptime: 6m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 779 lib: 228 Shell: Bash v: 5.1.4
running-in: urxvtd inxi: 3.3.04
Has anyone encountered anything similar or have knowledge around what might be the cause?
