Thinkpad T15g suspends only for a moment, and then wakes up
I’m running Manjaro KDE, and this Thinkpad T15g won’t stay suspended. The main screen and second monitor go black, and then wake up shows a login screen.
There’s an NVidia chip, but I’m running on the Nouveau drivers.
$ glxinfo | grep "vendor"
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
OpenGL vendor string: Intel
sudo dmesg gives …
[462900.774989] PM: suspend entry (deep)
[462900.782752] Filesystems sync: 0.007 seconds
[462900.782833] (NULL device *): Direct firmware load for nvidia/575.64.03/gsp_tu10x.bin failed with error -2
[462900.824571] Freezing user space processes
[462901.025949] Freezing user space processes completed (elapsed 0.201 seconds)
[462901.025953] OOM killer disabled.
[462901.025954] Freezing remaining freezable tasks
[462901.027537] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[462901.027590] printk: Suspending console(s) (use no_console_suspend to debug)
[462901.257877] NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
[462901.257975] e1000e: EEE TX LPI TIMER: 00000011
[462901.257920] nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
[462901.258873] nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
[462901.258900] nvidia 0000:01:00.0: PM: failed to suspend async: error -5
[462901.526941] PM: Some devices failed to suspend, or early wake event detected
[462901.537667] nvme nvme0: D3 entry latency set to 8 seconds
[462901.540183] nvme nvme1: 16/0/0 default/read/poll queues
[462901.559160] nvme nvme0: 16/0/0 default/read/poll queues
[462902.248262] psmouse serio1: synaptics: queried max coordinates: x [..5678], y [..4694]
[462902.279921] psmouse serio1: synaptics: queried min coordinates: x [1266..], y [1162..]
[462902.530517] OOM killer enabled.
[462902.530518] Restarting tasks ...
[462902.530664] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[462902.534086] done.
[462902.534099] random: crng reseeded on system resumption
[462902.584126] PM: suspend exit
[462902.584186] PM: suspend entry (s2idle)
[462902.589944] Filesystems sync: 0.005 seconds
[462902.590028] (NULL device *): Direct firmware load for nvidia/575.64.03/gsp_tu10x.bin failed with error -2
[462902.597183] Freezing user space processes
[462902.878227] Freezing user space processes completed (elapsed 0.281 seconds)
[462902.878230] OOM killer disabled.
[462902.878230] Freezing remaining freezable tasks
[462902.880220] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[462902.880224] printk: Suspending console(s) (use no_console_suspend to debug)
[462903.138488] NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
[462903.138496] e1000e: EEE TX LPI TIMER: 00000011
[462903.138504] nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
[462903.139484] nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
[462903.139496] nvidia 0000:01:00.0: PM: failed to suspend async: error -5
[462903.231876] PM: Some devices failed to suspend, or early wake event detected
Here’s some systems information
$ inxi -Farz
  Kernel: 6.15.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
    root=UUID=e336ea36-9445-48dc-875e-ad7a58ebbeac rw apparmor=1
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Laptop System: LENOVO product: 20URS01K00 v: ThinkPad T15g Gen 1
  Mobo: LENOVO model: 20URS01K00 v: SDK0T08861 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20UR_BU_Think_FM_ThinkPad
    T15g Gen 1 uuid: <superuser required> UEFI: LENOVO v: N30ET59W (1.42 )
    date: 05/26/2025
  ID-1: BAT0 charge: 91.8 Wh (100.0%) condition: 91.8/94.0 Wh (97.7%)
    volts: 12.2 min: 11.5 model: Celxpert 5B10W13959 type: Li-poly
    serial: <filter> status: full cycles: 13
  Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
    desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3503 min/max: 800/5300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3503 2: 3503 3: 3503 4: 3503 5: 3503 6: 3503
    7: 3503 8: 3503 9: 3503 10: 3503 11: 3503 12: 3503 13: 3503 14: 3503
    15: 3503 16: 3503 bogomips: 76800
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
    vendor: Lenovo driver: nvidia v: 575.64.03
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-3
    empty: DP-4,DP-5,DP-6 bus-ID: 01:00.0 chip-ID: 10de:1e91 class-ID: 0300
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 5986:9106
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    alternate: fbdev,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
    s-diag: 1052mm (41.43")
  Monitor-1: HDMI-A-3 mapped: HDMI-1-0 note: disabled pos: right
    model: Acer SB220Q serial: <filter> built: 2021 res: mode: 1920x1080 hz: 75
    scale: 100% (1) dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
    diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x150c
    built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 1 drv: iris
    device: 2 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland,device-0
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 14.89 GiB unified: yes
  API: Vulkan v: 1.4.321 layers: 2 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (CML GT2) driver: mesa intel v: 25.1.7-arch1.1
    device-ID: 8086:9bc4 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:06c8 class-ID: 0403
  API: ALSA v: k6.15.7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4c class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 3 state: up address: N/A
  Local Storage: total: 942.7 GiB used: 637.1 GiB (67.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBQNTY-512G-1001 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 11170101 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 87.89 GiB size: 86.21 GiB (98.09%) used: 62.1 GiB (72.0%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
  ID-2: /boot/efi raw-size: 250 MiB size: 246.1 MiB (98.46%)
    used: 6.2 MiB (2.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
  ID-3: /home raw-size: 332.7 GiB size: 326.41 GiB (98.11%)
    used: 142.73 GiB (43.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:9
  ID-1: swap-1 type: partition size: 15.62 GiB used: 10.63 GiB (68.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:10
  System Temperatures: cpu: 54.0 C pch: 57.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 2369 fan-2: 1873
  Packages: 2228 pm: pacman pkgs: 2207 libs: 470 tools: pamac pm: flatpak
    pkgs: 21
    1: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.init7.net/manjaro/stable/$repo/$arch
    4: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    6: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    8: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
  Memory: total: 16 GiB note: est. available: 15.25 GiB
    used: 12.65 GiB (83.0%)
  Processes: 580 Power: uptime: 5d 8h 39m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 fails: 20 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.07 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 257
  Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Bash v: 5.3.3
    running-in: konsole inxi: 3.3.38
Any hints? Do I need to provide more information? Thanks.
The logs tell you the GPU can’t be suspended and searching for it finds for instance Suspend doesn’t work when PreserveVideoMemoryAllocations is enabled
Thanks for confirming the problem @jofi . This remains unresolved on Github.
After reading the whole thread, I decided to experiment with something different. I switched from X11 to Wayland. The Thinkpad now suspends properly.
I had been running Wayland originally, and ran into a problem that had me switching back to X11. I don’t remember why. I guess when I get that problem again, I’ll deal with that.
