Thinkpad T14 can't hibernate with kernel 6.5.1
I installed kernel 6.5.1 a few days ago and noticed that hibernation (aka suspend-to-disk) stopped working. But it continue to work with 6.1 and 6.4 kernels.
With 6.5 I get this:
systemctl hibernate
Call to Hibernate failed: Not enough swap space for hibernation
uname -r
6.5.1-1-MANJARO
free
               total        used        free      shared  buff/cache   available
Mem:           15695        6983        6398        1138        3783        8712
Swap:          16383         139       16244
swapon
NAME           TYPE      SIZE   USED PRIO
/dev/nvme0n1p7 partition  16G 139,3M   -2
inxi -Fza
  Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=1c61cba9-a633-43a2-a05b-7a5fcafbb684 rw quiet splash
    resume=c65d974a-df07-4cdf-8f66-cd9b61ac34fe udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 info: latte-dock
    wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 21AH00BSUS v: ThinkPad T14 Gen 3
  Mobo: LENOVO model: 21AH00BSUS v: SDK0T76538 WIN
    serial: <superuser required> UEFI: LENOVO v: N3MET16W (1.15 )
    date: 06/25/2023
  ID-1: BAT0 charge: 52.9 Wh (99.8%) condition: 53.0/52.5 Wh (101.0%)
    volts: 17.3 min: 15.5 model: Sunwoda 5B10W51867 type: Li-poly
    serial: <filter> status: full cycles: 22
  Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x42C
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
    L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 2232 high: 2500 min/max: 400/4700:3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2500 2: 2500 3: 2500
    4: 2500 5: 1126 6: 2500 7: 1038 8: 2500 9: 2500 10: 1061 11: 2500 12: 2500
    13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79888
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
    conditional, RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 174f:1812
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1920x1200 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.1.6-3 renderer: Mesa Intel Graphics (ADL GT2)
    direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.5.1-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.79 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033 class-ID: e001
  Local Storage: total: 931.51 GiB used: 255.93 GiB (27.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 35.9 C
    scheme: GPT
  ID-1: / raw-size: 70 GiB size: 68.35 GiB (97.64%) used: 39.6 GiB (57.9%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 51.7 MiB (20.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 343.29 GiB size: 336.83 GiB (98.12%)
    used: 216.15 GiB (64.2%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-1: swap-1 type: partition size: 16 GiB used: 139.2 MiB (0.8%)
    priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 2362
  Processes: 375 Uptime: 4h 24m wakeups: 1646 Memory: total: 16 GiB note: est.
  available: 15.33 GiB used: 6.76 GiB (44.1%) Init: systemd v: 253
  Packages: pm: pacman pkgs: 1713 libs: 444 tools: octopi,pamac,yay
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.29
Any ideas on that?
Kernel 6.5 is not quite mature yet. Use 6.4 or (preferably still) the 6.1 LTS kernel. There is nothing to gain from running a bleeding-edge kernel on a production machine.
That what I actually do using older kernel. Just think that someone else has faced the same problem. Or I could help to debug it.
Thanks!
in testing version is 6.5.2
coming version 6.5.3 and version 6.4.16 is EOL
https://www.kernel.org/
The issue happened due to my inattention.
The line for resume in /etc/default/grub must contain the word “UUID” itself:
resume=UUID=“your swap UUID here”.
Mine was: resume=“my swap UUID here”.
On all kernels before 6.5 the system could hibernate, but it couldn’t restore (thats how I guested that during boot the kernel didn’t understand where the image for restoration was).
I don’t know why but starting with kernel 6.5 this missing UUID word even doesn’t let the system to hibernate and make restoration image.
The thread should be marked as SOLVED.
