I got an external ThinkPad Trackpoint Keyboard II and connected it to my Thinkpad T495 via a USB dongle without any issues (the keyboard has a bluetooth mode and a 2.4GHz mode). When I try to pair it in the bluetooth setting, blueman sees the keyboard, but I get the “pairing failed” message. I’m not sure how to diagnose the problem. Could anyone help me or give me suggestions as to how I can further diagnose this? My inxi output is below.
The other issue I have is with special keys - has anyone been successful in getting all of them to work on a Thinkpad Keyboard IIh F1-F3 and F5-F7 equivalents (sound, brightness, etc) work, but F4 or F8-F12 do not. I tried xev and these keys don’t even seem to register anything. I would appreciate any leads or advice as to how to fix that (I was especially hoping to get F4/mic mute and F10/bluetooth toggle to work. I should add that the same keys work on my internal Thinkpad keyboard, where they have the same layout.
My inxi:
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, plank wm: xfwm4
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20NJ0002US v: ThinkPad T495
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20NJ0002US serial: <filter> UEFI-[Legacy]: LENOVO
v: R12ET34W(1.04 ) date: 04/19/2019
ID-1: BAT0 charge: 34.3 Wh (79.6%) condition: 43.1/50.5 Wh (85.5%)
volts: 12.3 min: 11.5 model: SMP 02DL008 type: Li-poly serial: <filter>
status: Unknown cycles: 400
Device-1: hid-0003:17EF:60EE.0009-battery
model: Lenovo TrackPoint Keyboard II serial: N/A charge: N/A status: N/A
RAM: total: 21.14 GiB used: 6.78 GiB (32.1%)
RAM Report:
Info: Quad Core model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L2: 2 MiB
bogomips: 33550
Speed: 1222 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1222 2: 1222 3: 1396 4: 1397 5: 1394 6: 1397 7: 1222 8: 1219
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 06:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 4-2.1:4 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting
alternate: ati,fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.23-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2526 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3400 bus-ID: 03:00.0
IF: enp3s0f0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 4-1:10 chip-ID: 8087:0025 class-ID: e001
Message: No LVM data was found.
Local Storage: total: 476.94 GiB used: 99.01 GiB (20.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L7
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 3L2QEXF7 temp: 37.9 C scheme: MBR
ID-1: / size: 468.45 GiB used: 99.01 GiB (21.1%) fs: ext4
dev: /dev/nvme0n1p1 label: N/A uuid: 3ad07520-f46a-4231-97b3-a1860800622a
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 2-3:5 info: Lenovo TrackPoint Keyboard II
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 17ef:60ee class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 4-1:10 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-5: 4-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 4-2.1:4 info: Chicony Integrated Camera (1280x720@30)
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Device-2: 4-2.4:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1
System Temperatures: cpu: 64.0 C mobo: 0.0 C gpu: amdgpu temp: 64.0 C
Fan Speeds (RPM): cpu: 0
Processes: 322 Uptime: 4d 2h 25m wakeups: 311 Init: systemd v: 247
Compilers: gcc: 10.2.0 Packages: 1624 pacman: 1620 snap: 4 Shell: Bash
v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.03
