Hi all!
A few days ago I tried to switch my laptop from kernel 5.10 to 5.15. Unfortunately my Thinkpad doesn’t like this latest version.
The problem seems to be related to this package: linux515-acpi_call, that seems to be outdated. Latest release is v.1.2.2-4 (from Arch repo) but for some reason unknown for me, Manjaro is still using linux515-acpi_call-1.1.x
The bug has already been fixed on v1.2.2 according to this site: Fixing acpi_call kernel oops on Thinkpads · GitHub
Does anyone have any idea when this package will be upgraded to the latest version? can I download this package from any other place? link?
Thanks in advance! I’m just wanting to switch to 5.15 ASAP… ![]()
Inxi:
System: Host: thinkpad1.localdomain Kernel: 5.10.83-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20UES1D600 v: ThinkPad T14 Gen 1 serial: <superuser required>
Mobo: LENOVO model: 20UES1D600 serial: <superuser required> UEFI: LENOVO v: R1BET36W(1.05 ) date: 06/11/2020
Battery: ID-1: BAT0 charge: 27.2 Wh (52.8%) condition: 51.5/50.5 Wh (101.9%) volts: 11.5 min: 11.6
CPU: Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64 type: MT MCP cache: L2: 4 MiB
Speed: 1480 MHz min/max: 1400/1700 MHz Core speeds (MHz): 1: 2425 2: 2653 3: 1396 4: 1397 5: 1397 6: 1397 7: 1398
8: 1397 9: 1683 10: 1398 11: 1397 12: 1397 13: 1483 14: 1397 15: 1397 16: 1397
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
Display: server: X.Org 1.21.1.1 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1: 1920x1080~60Hz
2: 3840x2160~60Hz
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: snd_rn_pci_acp3x
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.10.83-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp2s0f0 state: down mac: 00:2b:67:cd:ff:ea
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlp3s0 state: up mac: a8:7e:ea:ba:a7:3e
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp5s0 state: down mac: 00:2b:67:cd:ff:e9
IF-ID-1: virbr0 state: down mac: 52:54:00:39:37:c7
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled rfk-block: hardware: no software: no
address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 192.53 GiB (40.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L7 size: 476.94 GiB
Partition: ID-1: / size: 24.48 GiB used: 17.73 GiB (72.4%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 511 MiB used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4
ID-3: /home size: 268.18 GiB used: 174.79 GiB (65.2%) fs: ext4 dev: /dev/dm-0
Swap: ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p5
Sensors: System Temperatures: cpu: 50.2 C mobo: 0.0 C gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 382 Uptime: 16m Memory: 30.65 GiB used: 3.96 GiB (12.9%) Shell: Bash inxi: 3.3.09
OOPS
[ 28.552557] [drm] Unknown EDID CEA parser results
[ 28.818670] BUG: kernel NULL pointer dereference, address: 0000000000000000
[ 28.818678] #PF: supervisor instruction fetch in kernel mode
[ 28.818681] #PF: error_code(0x0010) - not-present page
[ 28.818684] PGD 0 P4D 0
[ 28.818688] Oops: 0010 [#1] PREEMPT SMP NOPTI
[ 28.818692] CPU: 6 PID: 1647 Comm: tpacpi-bat Tainted: G OE 5.15.6-2-MANJARO #1 3a19d45d1162f23d4faca02dd20d7e24f26326df
[ 28.818697] Hardware name: LENOVO 20UES1D600/20UES1D600, BIOS R1BET36W(1.05 ) 06/11/2020
[ 28.818700] RIP: 0010:0x0
[ 28.818708] Code: Unable to access opcode bytes at RIP 0xffffffffffffffd6.
[ 28.818709] RSP: 0018:ffffa80c037cfec0 EFLAGS: 00010246
[ 28.818713] RAX: 0000000000000000 RBX: ffff8a18819c55c0 RCX: 0000000000000001
[ 28.818715] RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffff8a1888ce0900
[ 28.818717] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
[ 28.818719] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000001
[ 28.818721] R13: ffffffffffffffea R14: ffff8a1888ce0900 R15: 0000000000000000
[ 28.818723] FS: 00007f31c6b18740(0000) GS:ffff8a1f6f980000(0000) knlGS:0000000000000000
[ 28.818726] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 28.818729] CR2: ffffffffffffffd6 CR3: 000000011561c000 CR4: 0000000000350ee0
[ 28.818732] Call Trace:
[ 28.818734] <TASK>
[ 28.818736] proc_reg_llseek+0x49/0x90
[ 28.818745] ? __fdget_pos+0x13/0x60
[ 28.818749] ksys_lseek+0x83/0xc0
[ 28.818753] do_syscall_64+0x5c/0x90
[ 28.818758] ? exc_page_fault+0x72/0x180
[ 28.818762] entry_SYSCALL_64_after_hwframe+0x44/0xae
[ 28.818768] RIP: 0033:0x7f31c6daf99b
[ 28.818770] Code: ff ff c3 0f 1f 40 00 48 8b 15 d1 04 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb ba 0f 1f 00 f3 0f 1e fa b8 08 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 05 c3 0f 1f 40 00 48 8b 15 a1 04 0d 00 f7 d8
[ 28.818773] RSP: 002b:00007fffc79b5088 EFLAGS: 00000246 ORIG_RAX: 0000000000000008
[ 28.818777] RAX: ffffffffffffffda RBX: 00007f31c7235de0 RCX: 00007f31c6daf99b
[ 28.818779] RDX: 0000000000000001 RSI: 0000000000000000 RDI: 0000000000000003
[ 28.818781] RBP: 0000560e8b09aec0 R08: 00007fffc79b5030 R09: 00000000ffffffff
[ 28.818783] R10: 00007f31c6e80a00 R11: 0000000000000246 R12: 0000560e8b07a2a0
[ 28.818785] R13: 00007fffc79b5290 R14: 0000560e8b07a3e0 R15: 0000560e8b0d9940
[ 28.818790] </TASK>
[ 28.818792] Modules linked in: ccm xt_CHECKSUM xt_MASQUERADE xt_conntrack ipt_REJECT nf_reject_ipv4 xt_tcpudp ip6table_mangle ip6table_nat ip6table_filter ip6_tables iptable_mangle iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c iptable_filter bridge stp llc dm_crypt cbc encrypted_keys trusted asn1_encoder tee hid_logitech_hidpp hid_logitech_dj btusb btrtl btbcm btintel bluetooth usbhid ecdh_generic uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc joydev mousedev snd_soc_dmic snd_acp3x_rn snd_acp3x_pdm_dma intel_rapl_msr snd_soc_core snd_compress ac97_bus think_lmi snd_pcm_dmaengine intel_rapl_common wmi_bmof firmware_attributes_class edac_mce_amd iwlmvm kvm_amd snd_ctl_led amdgpu snd_hda_codec_realtek mac80211 kvm snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi libarc4 irqbypass snd_hda_codec crct10dif_pclmul crc32_pclmul ghash_clmulni_intel tpm_crb iwlwifi aesni_intel snd_hda_core
[ 28.818858] r8169 gpu_sched crypto_simd ucsi_acpi vfat snd_hwdep tpm_tis cryptd realtek snd_pci_acp5x typec_ucsi snd_pcm thinkpad_acpi mdio_devres tpm_tis_core drm_ttm_helper sp5100_tco fat rapl cfg80211 psmouse k10temp snd_rn_pci_acp3x ledtrig_audio dm_mod platform_profile ccp i2c_piix4 ttm snd_timer snd_pci_acp3x tpm typec libphy rfkill roles rng_core wmi snd soundcore video pinctrl_amd mac_hid i2c_scmi acpi_call(OE) acpi_cpufreq ipmi_devintf ipmi_msghandler fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc serio_raw mmc_core atkbd libps2 i8042 crc32c_intel rtsx_pci xhci_pci serio
[ 28.818917] CR2: 0000000000000000
[ 28.818920] ---[ end trace 90d7880e88ad419f ]---
[ 28.818922] RIP: 0010:0x0
[ 28.818925] Code: Unable to access opcode bytes at RIP 0xffffffffffffffd6.
[ 28.818926] RSP: 0018:ffffa80c037cfec0 EFLAGS: 00010246
[ 28.818929] RAX: 0000000000000000 RBX: ffff8a18819c55c0 RCX: 0000000000000001
[ 28.818931] RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffff8a1888ce0900
[ 28.818933] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
[ 28.818935] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000001
[ 28.818936] R13: ffffffffffffffea R14: ffff8a1888ce0900 R15: 0000000000000000
[ 28.818939] FS: 00007f31c6b18740(0000) GS:ffff8a1f6f980000(0000) knlGS:0000000000000000
[ 28.818941] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 28.818943] CR2: ffffffffffffffd6 CR3: 000000011561c000 CR4: 0000000000350ee0
[ 29.352514] [drm] Unknown EDID CEA parser results
[ 29.481593] FS-Cache: Loaded
Arch package should be perfectly compatible, same is applicable to bbswitch btw.
