Hello
on a fresh install on a new Thinkpad e15 wifi is not working.
Ethernet works.
$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=86fb53be-c8f5-4e7e-9dcd-1d24c1ea8dc5 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 21EES00100 v: ThinkPad E15 Gen 4
Mobo: LENOVO model: 21EES00100 v: ThinkPad serial: <superuser required>
UEFI: LENOVO v: R20ET26W (1.06 ) date: 02/18/2022
ID-1: BAT0 charge: 40.9 Wh (69.4%) condition: 58.9/57.0 Wh (103.3%)
volts: 12.0 min: 11.5 model: SMP LNV-5B11C73244 type: Li-poly
serial: <filter> status: discharging cycles: 1
RAM: total: 14.53 GiB used: 2.35 GiB (16.2%)
RAM Report:
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1721 high: 1996 min/max: 400/4546 boost: enabled
scaling: driver: amd-pstate governor: schedutil cores: 1: 1589 2: 1596
3: 1776 4: 1597 5: 1595 6: 1595 7: 1899 8: 1773 9: 1995 10: 1755 11: 1596
12: 1594 13: 1996 14: 1995 15: 1597 16: 1596 bogomips: 63919
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300
Device-2: Acer Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 5986:2146 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x2520 s-dpi: 96 s-size: 677x666mm (26.65x26.22")
s-diag: 950mm (37.39")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-left
model: AOC Q3279WG5B serial: <filter> built: 2018 res: 2560x1440 hz: 60
dpi: 90 gamma: 1.2 size: 725x428mm (28.54x16.85") diag: 842mm (33.1")
ratio: 15:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,bottom-r
model: ChiMei InnoLux 0x151e built: 2019 res: 1920x1080 hz: 60 dpi: 142
gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.6-1-MANJARO)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Lenovo driver: r8168 v: 8.050.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: Lenovo driver: N/A pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 11.3 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ512MGE1QDQ size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 1.3Q0630 temp: 22.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 11.3 GiB (2.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 86fb53be-c8f5-4e7e-9dcd-1d24c1ea8dc5
label: NO_LABEL uuid: BF4B-0245
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Acer Integrated RGB Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: FPC Sensor Controller L:0001 FW:16.26.23.14
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 480 Mb/s
power: 100mA chip-ID: 10a5:9800 class-ID: 0000
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): fan-1: 0
Processes: 319 Uptime: 16m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1216 lib: 334
flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
I was assuming below device-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet is also responsible for wireless.
But it might also be device-2 (or a different one?).
$ inxi -Nazy
class-ID: 0200
so far i tried, assuming device-1 needed a package, following this thread: Wifi is not working on fresh install
Kernel 5.15
trying Kernel 5.17
getting the respective headers each and get rtw89-dkms-git
use r8168 (also trying r8169)
blacklisting r8169
if related to device-2 chip-ID 10ec:b852, i was not able to find which package I would need.
How should I proceed?
Many thanks for your help in advance. Looking forward using Manjaro as daily driver.
Hi @oro , and welcome!
I might be wrong so someone is welcome to correct me if I am. Unfortunately, there doesn’t seem to be Linux drivers for that adapter yet. It might be that it’s simply to new. I don’t know.
Does it work in a Live environment?
Have you tried another distribution’s (Like Ubuntu) live ISO?
a search for vendor and product id of the wifi brings up:
attention: install the linux-headers and the base-devel packages as described first.
And here I thought my Google-fu was good… shakes head
Welp, it’s in the AUR:
$ pamac search 8852
rtw89-dkms-git 1:r148.4dc5371-3 AUR
Driver for Realtek 8852AE, an 802.11ax device
So can be installed using
pamac build rtw89-dkms-git
But make sure the headers for your kernel(s) are installed first:
pamac install $(pamac list --quiet --installed | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
This will install the kernel headers for all installed kernels.
Note:
I just remembered why I didn’t recommend it: it’s because it mentioned it was for the Realtek 8852AE , while yours is, in fact, the Realtek 8852BU from what I was able to see.
I also noticed you tried that already, so this will probably not work.
I have the 8852AE realtek wifi & @oro ’s one is different.
In any case, the rtw89 driver is already included since kernel 5.16, so there is no need to install it on 5.17.
Here is how 8852AE reports
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
The chip ID is the same except 1 digit: 10ec:b 852 & I’m having trouble to locate that online.
i would recommend to try @Mirdarthos tip first and installing the aur-package
banjo
14 May 2022 11:57
7
…if my search is correct, there is no happy end yet.
Realtek Semiconductor Realtek Network controller for b852.
Many thanks for the quick replies.
Mirdarthos:
It did also not work in Manjaro’s Live environment and not in KDE Neon’s live ISO.
I might try an Ubuntu live ISO with newer kernel than Neon in the next days, but i assume that won’t make a difference.
I have installed the kernel headers and aur-package rtw89-dkms-git (in that order).
the Gui Systemsettings - Hardwareconfig show the device “network-r8168” with an unticked checkbox “installed”, not sure if that holds true. I see the package in pamac list --installed | grep rtw89.
So, I guess the temporary solution is: to wait.
I’m fine with Ethernet in 95 % of my use case.
How will I know when a fitting driver is published? Should I just check above hardware-probe’s status for the device regularly?
in this regard, should I stay on the newer Kernel 5.17 or move back to LTS?
thanks!
might you reply the output of the inxi --admin --verbosity=7 --filter --width with the drivers that are installed now ?
banjo
15 May 2022 02:29
10
…yes, and keep both kernels, LTS and current. Good chances you can change your wifi-card to intel. In the gen3-model it’s changeable, but I don’t know from this very new model.
sure:
ID-1: BAT0 charge: 28.4 Wh (48.4%) condition: 58.7/57.0 Wh (103.0%)
volts: 11.4 min: 11.5 model: SMP LNV-5B11C73244 type: Li-poly
RAM: total: 14.53 GiB used: 1.74 GiB (12.0%)
RAM Report:
Speed (MHz): avg: 1758 high: 1995 min/max: 400/4546 boost: enabled
scaling: driver: amd-pstate governor: schedutil cores: 1: 1630 2: 1595
3: 1593 4: 1597 5: 1595 6: 1594 7: 1992 8: 1993 9: 1789 10: 1595 11: 1995
12: 1994 13: 1595 14: 1597 15: 1993 16: 1995 bogomips: 63918
class-ID: 0300
Screen-1: 0 s-res: 2560x2520 s-dpi: 96 s-size: 675x665mm (26.57x26.18")
s-diag: 948mm (37.31")
class-ID: 0403
class-ID: 0200
Local Storage: total: 476.94 GiB used: 11.72 GiB (2.5%)
rev: 1.3Q0630 temp: 15.8 C scheme: GPT
used: 11.72 GiB (2.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 86fb53be-c8f5-4e7e-9dcd-1d24c1ea8dc5
System Temperatures: cpu: 30.0 C mobo: N/A gpu: amdgpu temp: 29.0 C
Processes: 323 Uptime: 3m wakeups: 1 Init: systemd v: 250 tool: systemctl
inxi: 3.3.15
not much of a change compared to above, as I installed them before the post.
One other thing: from trial and error i kept AUR (en) - r8168-dkms on my machine. Should I remove it?
thanks! insightful resource. I should improve my google-foo too
oro
29 June 2022 09:00
14
writing this from wireless: works now.
I saw a working working HW Probe using rtl8852be, so I additionally installed this one: github.com/lwfinger/rtw8852be
now it looks like this
$ inxi -Nazy
vendor: Lenovo driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
class-ID: 0200
Device-2: Realtek vendor: Lenovo driver: rtl8852be v: N/A modules: 8852be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
and it works.
thanks all for your help!
oro
29 June 2022 09:03
15
I marked this as solution, since i guess its a mandatory step. Afterwards I did:
git clone http://github.com/lwfinger/rtw8852BE.git
cd rtw8852be
make
sudo make install
reboot
Just in case anyone’s wondering:
@oro marked this as a solution:
$ pamac search 8852
But make sure the headers for your kernel(s) …
But I don’t really know if it is. Seems the solution was:
cd rtw8852be
make
sudo make install
reboot
But, @oro , remember that you are not using a -dkms driver. Which means it will have to be reinstalled after kernel updates, where the -dms would have been rebuilt/reinstalled automatically.
system
Closed
1 July 2022 23:14
17
