Thinkpad E15 Gen2 - Touchpad & Trackpoint Not Recognized/Not Working
I recently acquired a Thinkpad E15 Gen 2 with Ryzen 7 4000 series CPU and am dual booting Windows 10 with Manjaro + XFCE but noticed the touchpad/touchpoint does not work at all. I have had to use a Logitech USB mouse since first installing the OS. Looking into the issue more and it seems kernel is not even recognizing the touchpad or trackpoint.
Oddly enough I have had 2, maybe 3 occasions, where both the touchpad and trackpoint started working for moments (goes back to not working/not being recognized almost immediately)
Here is the output for inxi --full --admin --verbosity=7 --filter --no-host:
  Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc
  v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=0ed9e587-af57-452c-9757-9280bd655edd rw quiet
  udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel
  wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0
  Type: Laptop System: LENOVO product: 20T8002BUS
  v: ThinkPad E15 Gen 2 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: LENOVO model: 20T8002BUS serial: <filter>
  UEFI: LENOVO v: R1AET37W (1.13 ) date: 04/09/2021
  ID-1: BAT0 charge: 39.7 Wh (98.3%)
  condition: 40.4/45.7 Wh (88.3%) volts: 12.3 min: 11.1
  model: SMP 5B10X026 type: Li-poly serial: <filter>
  status: Unknown cycles: 268
  Device-1: hidpp_battery_1
  model: Logitech Wireless Mouse B330/M330/M331
  serial: <filter> charge: 55% (should be ignored)
  rechargeable: yes status: Discharging
  RAM: total: 14.86 GiB used: 11.39 GiB (76.7%)
  RAM Report: permissions: Unable to run dmidecode. Root
  privileges required.
  Info: 8-Core
  model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96)
  stepping: 1 microcode: 8600103 cache: L2: 4 MiB
  bogomips: 31958
  Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled
  Core speeds (MHz): 1: 1397 2: 2150 3: 1397 4: 1398
  5: 1397 6: 1397 7: 1397 8: 1397
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat
  avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
  clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb
  cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
  cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists
  extapic extd_apicid f16c flushbyasid fma fpu fsgsbase
  fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
  msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
  overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
  rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse
  sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
  syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt
  Type: spec_store_bypass mitigation: Speculative Store
  Bypass disabled via prctl and seccomp
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and
  __user pointer sanitization
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB:
  conditional, IBRS_FW, STIBP: disabled, RSB filling
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu
  v: kernel bus-ID: 04:00.0 chip-ID: 1002:1636
  class-ID: 0300
  Device-2: Luxvisions Innotech Limited Integrated Camera
  type: USB driver: uvcvideo bus-ID: 1-3:3
  chip-ID: 30c9:0014 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4
  v: 4.16.1 driver: loaded: amdgpu,ati
  unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96
  s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142
  size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
  OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.7-2-MANJARO
  LLVM 12.0.1)
  v: 4.6 Mesa 21.2.2 direct render: Yes
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637
  class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio
  Processor
  vendor: Lenovo driver: N/A
  alternate: snd_pci_acp3x, snd_rn_pci_acp3x
  bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus-ID: 04:00.6
  chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.37 running: no
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit
  Ethernet
  vendor: Lenovo driver: r8168 v: 8.049.02-NAPI
  modules: r8169 port: 2000 bus-ID: 02:00.0
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel
  port: 2000 bus-ID: 03:00.0 chip-ID: 8086:2723
  class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb
  v: 0.8 bus-ID: 3-4:2 chip-ID: 8087:0029 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up
  address: see --recommends
  Local Storage: total: 953.87 GiB used: 180.29 GiB (18.9%)
  SMART Message: Required tool smartctl not installed.
  Check --recommends
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent
  model: Rocket nano size: 953.87 GiB block-size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  type: SSD serial: <filter> rev: RKT301.3 temp: 22.9 C
  scheme: GPT
  ID-1: / raw-size: 683.59 GiB size: 671.79 GiB (98.27%)
  used: 180.27 GiB (26.8%) fs: ext4 dev: /dev/nvme0n1p5
  maj-min: 259:5 label: N/A
  uuid: 0ed9e587-af57-452c-9757-9280bd655edd
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 25.9 MiB (10.1%) fs: vfat dev: /dev/nvme0n1p1
  maj-min: 259:1 label: SYSTEM uuid: 6C36-95F1
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB
  fs: <superuser required> label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 269.03 GiB
  fs: bitlocker label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB
  fs: ntfs label: WinRE_DRV uuid: 1EF4398FF4396A63
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4
  rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
  Device-1: 1-2:4 info: Logitech Unifying Receiver
  type: Mouse,HID driver: logitech-djreceiver,usbhid
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA
  chip-ID: 046d:c52f class-ID: 0300
  Device-2: 1-3:3
  info: Luxvisions Innotech Limited Integrated Camera
  type: Video driver: uvcvideo interfaces: 2 rev: 2.0
  speed: 480 Mb/s power: 500mA chip-ID: 30c9:0014
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2
  rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4
  Device-1: 3-4:2 info: Intel AX200 Bluetooth
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 8087:0029
  class-ID: e001
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2
  System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu
  temp: 41.0 C
  Fan Speeds (RPM): fan-1: 2200
  Processes: 338 Uptime: 6d 2h 52m wakeups: 224
  Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 12.0.1 Packages: 1453 pacman: 1449
  lib: 418 snap: 4 Shell: Bash v: 5.1.8 running-in: urxvt
  inxi: 3.3.06
Output of xinput:
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ Logitech B330/M330/M3                   	id=13	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ Power Button                            	id=6	[slave  keyboard (3)]
    ↳ Video Bus                               	id=7	[slave  keyboard (3)]
    ↳ Power Button                            	id=8	[slave  keyboard (3)]
    ↳ Sleep Button                            	id=9	[slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            	id=10	[slave  keyboard (3)]
    ↳ ThinkPad Extra Buttons                  	id=11	[slave  keyboard (3)]
    ↳ Integrated Camera: Integrated C         	id=12	[slave  keyboard (3)]
    ↳ Logitech B330/M330/M3                   	id=14	[slave  keyboard (3)]
Also, the output for sudo libinput list-devices
Device:           Power Button
Kernel:           /dev/input/event3
Group:            1
Seat:             seat0, default
Capabilities:     keyboard
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Middle emulation: n/a
Calibration:      n/a
Scroll methods:   none
Click methods:    none
Disable-w-typing: n/a
Accel profiles:   n/a
Rotation:         n/a
Device:           Video Bus
Kernel:           /dev/input/event5
Group:            2
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Kernel:           /dev/input/event0
Group:            3
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Lid Switch
Kernel:           /dev/input/event1
Group:            4
Capabilities:     switch
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Sleep Button
Kernel:           /dev/input/event2
Group:            5
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Logitech B330/M330/M3
Kernel:           /dev/input/event13
Group:            6
Capabilities:     keyboard pointer
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      disabled
Nat.scrolling:    disabled
Middle emulation: disabled
Calibration:      n/a
Scroll methods:   button
Click methods:    none
Accel profiles:   flat *adaptive
Rotation:         n/a
Device:           Integrated Camera: Integrated C
Kernel:           /dev/input/event15
Group:            7
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           AT Translated Set 2 keyboard
Kernel:           /dev/input/event4
Group:            8
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           ThinkPad Extra Buttons
Kernel:           /dev/input/event9
Group:            9
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Any insight is appreciated and if there is any other information that could be pertinent to debugging the issue I can gladly supply that as well.
Thank you
There is a newer BIOS laptops and netbooks :: thinkpad edge laptops :: thinkpad e15 gen 2 type 20t8 20t9 - Lenovo Support US
Seems you are not the only one with some issues of running linux on that model
I upgraded my BIOS back in September when that upgrade was made available and while that + kernel upgrade did seem to fix the FN keys issue described in your linked post, it did not seem to do anything for the touchpad + trackpoint.
Oddly enough though, I just accessed the Windows 10 partition that I have on this same machine and the touchpad + trackpoint don’t even seem to work there anymore 0.0
I know for a fact the touchpad + trackpoint worked in Windows before because this machine shipped with Windows 10 and I used the original OS to create a bootable drive to install Manjaro.
Edit: To make things even more interesting I am noticing now that detection of the touchpad and trackpoint is an intermittent issue. I restarted my PC 3 times in a row to test a non-related issue and I noticed on the third restart the touchpad and trackpoint were working!
xinput list
⎜   ↳ Logitech B330/M330/M3                   	id=10	[slave  pointer  (2)]
⎜   ↳ ETPS/2 Elantech Touchpad                	id=13	[slave  pointer  (2)]
⎜   ↳ ETPS/2 Elantech TrackPoint              	id=14	[slave  pointer  (2)]
    ↳ Integrated Camera: Integrated C         	id=11	[slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            	id=12	[slave  keyboard (3)]
    ↳ ThinkPad Extra Buttons                  	id=15	[slave  keyboard (3)]
    ↳ Logitech B330/M330/M3                   	id=16	[slave  keyboard (3)]
sudo dmesg | grep Elan
[    6.100285] psmouse serio1: elantech: Elan sample query result 00, 0e, a7
[    6.116038] psmouse serio1: elantech: Elan ic body: 0x11, current fw version: 0x4
[    6.218769] input: ETPS/2 Elantech TrackPoint as /devices/platform/i8042/serio1/input/input26
[    6.235060] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input23
Edit: After an hour or so of usage the touchpad and trackpoint randomly stopped working for 2-3 minutes, during that time the devices appear to be recognized still but no events when attempting to use them.
sudo libinput debug-events
-event3   DEVICE_ADDED            Power Button                      seat0 default group1  cap:k
-event6   DEVICE_ADDED            Video Bus                         seat0 default group2  cap:k
-event0   DEVICE_ADDED            Power Button                      seat0 default group3  cap:k
-event1   DEVICE_ADDED            Lid Switch                        seat0 default group4  cap:S
-event2   DEVICE_ADDED            Sleep Button                      seat0 default group5  cap:k
-event5   DEVICE_ADDED            Logitech B330/M330/M3             seat0 default group6  cap:kp left scroll-nat scroll-button
-event16  DEVICE_ADDED            Integrated Camera: Integrated C   seat0 default group7  cap:k
-event4   DEVICE_ADDED            AT Translated Set 2 keyboard      seat0 default group8  cap:k
-event15  DEVICE_ADDED            ETPS/2 Elantech Touchpad          seat0 default group9  cap:pg  size 99x66mm tap(dl off) left scroll-nat scroll-2fg-edge click-buttonareas-clickfinger dwt-on
-event14  DEVICE_ADDED            ETPS/2 Elantech TrackPoint        seat0 default group9  cap:p left scroll-nat scroll-button
-event7   DEVICE_ADDED            ThinkPad Extra Buttons            seat0 default group10 cap:k
After putting the laptop into suspend touchpad/trackpoint stopped working completely, still being recognized but no response. See updated dmesg output below
sudo dmesg | grep elan
[    6.073784] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x6f3001)
[    6.087004] psmouse serio1: elantech: Synaptics capabilities query result 0x90, 0x18, 0x10.
[    6.189740] psmouse serio1: elantech: Trying to set up SMBus access
[    6.189806] psmouse serio1: elantech: SMbus companion is not ready yet
Rebooting the laptop will result in no detection of the touchpad/trackpoint again as per my OP.
