Hi,
Think or Swim Application does not show window in Wayland and works perfect in Xorg.
Wayland:
When I run the app think or swim, I get the installing updates, initial dialog and shows logon screen, when I enter the login details, it authenticates and launches the screen ( i could see the full black window pop but it is invisible after a sec).
If I right-click on the icon in the dock, I would see the “All window”, and clicking it displays a grey block, no internal details of the window are visible.
Xorg:
No issues, everything works perfect.
System Details:
Kernel: 6.7.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
I have tried to change the java version to 8, but got an error that it was compiled by higher version, so immediately reverted back.
sudo archlinux-java status
[sudo] password for lx:
Available Java environments:
java-11-openjdk (default)
Any suggestions to make this app work in Wayland ?
Thank you!
