There is no wifi icon in network settings | WIFI not working after installing manjaro
Hi. I cannot switch on wifi because there is no wifi icon. I have been connecting to the internet using USB and Bluetooth tethering from my phone. Please enable wifi on my system so I can connect to wifi.
    sudo inxi -F
    [sudo] password for katlegomokoena:
    perl: warning: Setting locale failed.
    perl: warning: Please check that your locale settings:
    	LANGUAGE = (unset),
    	LC_ALL = (unset),
    	LC_COLLATE = "C",
    	LANG = "en_US.utf8"
        are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    System:    Host: manjaro Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 Console: tty 0 Distro: Manjaro Linux
    Machine:   Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0 serial: FVFTV67TJ1WK
               Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2 serial: FV972340958J22GAK UEFI: Apple v: 194.0.0.0.0
               date: 04/16/2020
    Battery:   ID-1: BAT0 charge: 23.0 Wh condition: 47.9/54.3 Wh (88%)
    CPU:       Info: Dual Core model: Intel Core i5-5350U bits: 64 type: MT MCP L2 cache: 3 MiB
               Speed: 1756 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 1756 2: 1512 3: 1703 4: 1771
    Graphics:  Device-1: Intel HD Graphics 6000 driver: i915 v: kernel
               Display: server: X.org 1.20.10 driver: loaded: i915 note: n/a (using device driver) resolution: <missing: xdpyinfo>
               OpenGL: renderer: Mesa Intel HD Graphics 6000 (BDW GT3) v: 4.6 Mesa 20.3.4
    Audio:     Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
               Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel
               Device-3: Broadcom 720p FaceTime HD Camera driver: bdc-pci
               Sound Server: ALSA v: k5.9.16-1-MANJARO
    Network:   Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: bcma-pci-bridge
               IF-ID-1: bnep0 state: unknown speed: N/A duplex: N/A mac: d4:61:9d:30:c7:0b
    Bluetooth: Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb
               Message: Required tool hciconfig not installed. Check --recommends
    Drives:    Local Storage: total: 113 GiB used: 16.22 GiB (14.4%)
               ID-1: /dev/sda vendor: Apple model: SSD SM0128G size: 113 GiB
    Partition: ID-1: / size: 44.84 GiB used: 16.21 GiB (36.2%) fs: ext4 dev: /dev/dm-0
               ID-2: /boot/efi size: 196.9 MiB used: 15.5 MiB (7.8%) fs: vfat dev: /dev/sda1
    Swap:      Alert: No Swap data was found.
    Sensors:   System Temperatures: cpu: 61.5 C mobo: N/A
    Info:      Processes: 214 Uptime: 17m Memory: 7.68 GiB used: 2.91 GiB (37.9%) Shell: Zsh inxi: 3.3.00
rfkill list
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
:+1: Welcome to Manjaro! :+1:
Broadcom adapters are… pieces of $hit not the best under Linux, and as kernel 5.9 is EOL, try upgrading your kernel to:
  1. 5.4 LTS (Long Term Support)
  2. 5.10 (LTS candidate)
in that order and then try again.
:crossed_fingers:
P.S. Please read this:
https://archived.forum.manjaro.org/t/how-to-provide-good-information-in-your-posts/37102
and use inxi --admin --verbosity=7 --filter --no-host --width in the future as that gives us the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command whereas in inxi -F will give us PII… :man_shrugging:
Hi, how do I upgrade my kernel?
Please see our wiki article:
https://wiki.manjaro.org/index.php/Manjaro_Kernels
If you would get stuck somewhere, please give the paragraph number and the exaxt instruction and what doesn’t work and we’ll take it from there…
:+1:
