There is a problem with kernel6.12.x/Wayland/Plasma on Starlabs Starlite 2 in 1
Booting with kernel 6.12, the boot process fails to complete, and unable to SSH into the device.
Dec 03 09:01:55 hilda kernel: Linux version 6.12.1-4-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Mon, 25 Nov 2024 05:36:03 +0000
Dec 03 09:01:55 hilda kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=29705f46-8be2-4ab2-a49e-62fea65f9bd3 rw quiet splash udev.log_priority=3 resume=
Dec 03 09:01:55 hilda kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Dec 03 09:01:55 hilda kernel: BIOS-provided physical RAM map:
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000000fff] reserved
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x0000000000001000-0x000000000009ffff] usable
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x0000000000100000-0x000000007663bfff] usable
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x000000007663c000-0x000000007683bfff] reserved
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x000000007683c000-0x000000007684afff] usable
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x000000007684b000-0x0000000076860fff] ACPI data
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x0000000076861000-0x0000000076861fff] usable
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x0000000076862000-0x00000000803fffff] reserved
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x00000000ff630000-0x00000000ff66ffff] reserved
Dec 03 09:01:55 hilda kernel: BIOS-e820: [mem 0x0000000100000000-0x000000047fbfffff] usable
Dec 03 09:01:55 hilda kernel: NX (Execute Disable) protection: active
Dec 03 09:01:55 hilda kernel: APIC: Static calls initialized
Dec 03 09:01:55 hilda kernel: efi: EFI v2.7 by EDK II
Dec 03 09:01:55 hilda kernel: efi: SMBIOS=0x76823000 SMBIOS 3.0=0x76821000 ACPI=0x76860000 ACPI 2.0=0x76860014 MEMATTR=0x73bd8198 INITRD=0x73bc2a98
Dec 03 09:01:55 hilda kernel: efi: Remove mem87: MMIO range=[0xff630000-0xff66ffff] (0MB) from e820 map
Dec 03 09:01:55 hilda kernel: e820: remove [mem 0xff630000-0xff66ffff] reserved
Dec 03 09:01:55 hilda kernel: SMBIOS 3.0.0 present.
Dec 03 09:01:55 hilda kernel: DMI: Star Labs StarLite/StarLite, BIOS 24.06 07/05/2024
Dec 03 09:01:55 hilda kernel: DMI: Memory slots populated: 4/4
Dec 03 09:01:55 hilda kernel: tsc: Detected 1000.000 MHz processor
Dec 03 09:01:55 hilda kernel: tsc: Detected 998.400 MHz TSC
Dec 03 09:01:55 hilda kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 03 09:01:55 hilda kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 03 09:01:55 hilda kernel: last_pfn = 0x47fc00 max_arch_pfn = 0x400000000
Dec 03 09:01:55 hilda kernel: MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
Dec 03 09:01:55 hilda kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Dec 03 09:01:55 hilda kernel: last_pfn = 0x76862 max_arch_pfn = 0x400000000
Dec 03 09:01:55 hilda kernel: Using GB pages for direct mapping
Dec 03 09:01:55 hilda kernel: Incomplete global flushes, disabling PCID
Dec 03 09:01:55 hilda kernel: Secure boot disabled
Dec 03 09:01:55 hilda kernel: RAMDISK: [mem 0x6d611000-0x6f53efff]
Dec 03 09:01:55 hilda kernel: ACPI: Early table checksum verification disabled
Dec 03 09:01:55 hilda kernel: ACPI: RSDP 0x0000000076860014 000024 (v02 COREv4)
Dec 03 09:01:55 hilda kernel: ACPI: XSDT 0x000000007685F0E8 000074 (v01 COREv4 COREBOOT 00000000      01000013)
Dec 03 09:01:55 hilda kernel: ACPI: FACP 0x000000007685E000 000114 (v06 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: DSDT 0x0000000076858000 005248 (v02 COREv4 COREBOOT 20220930 INTL 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: FACS 0x000000007687A240 000040
Dec 03 09:01:55 hilda kernel: ACPI: SSDT 0x0000000076855000 00229F (v02 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: MCFG 0x0000000076854000 00003C (v01 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: TPM2 0x0000000076853000 00004C (v04 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: LPIT 0x0000000076852000 000094 (v00 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: APIC 0x0000000076851000 000072 (v03 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: DMAR 0x0000000076850000 000088 (v01 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: DBG2 0x000000007684F000 000061 (v00 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: HPET 0x000000007684E000 000038 (v01 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:01:55 hilda kernel: ACPI: BGRT 0x000000007684D000 000038 (v01 INTEL  EDK2     00000002      01000013)
Dec 03 09:01:55 hilda kernel: ACPI: Reserving FACP table memory at [mem 0x7685e000-0x7685e113]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving DSDT table memory at [mem 0x76858000-0x7685d247]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving FACS table memory at [mem 0x7687a240-0x7687a27f]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving SSDT table memory at [mem 0x76855000-0x7685729e]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving MCFG table memory at [mem 0x76854000-0x7685403b]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving TPM2 table memory at [mem 0x76853000-0x7685304b]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving LPIT table memory at [mem 0x76852000-0x76852093]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving APIC table memory at [mem 0x76851000-0x76851071]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving DMAR table memory at [mem 0x76850000-0x76850087]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving DBG2 table memory at [mem 0x7684f000-0x7684f060]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving HPET table memory at [mem 0x7684e000-0x7684e037]
Dec 03 09:01:55 hilda kernel: ACPI: Reserving BGRT table memory at [mem 0x7684d000-0x7684d037]
Dec 03 09:01:55 hilda kernel: No NUMA configuration found
Dec 03 09:01:55 hilda kernel: Faking a node at [mem 0x0000000000000000-0x000000047fbfffff]
Dec 03 09:01:55 hilda kernel: NODE_DATA(0) allocated [mem 0x47fbd52c0-0x47fbfffff]
Dec 03 09:01:55 hilda kernel: Zone ranges:
Dec 03 09:01:55 hilda kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Dec 03 09:01:55 hilda kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Dec 03 09:01:55 hilda kernel:   Normal   [mem 0x0000000100000000-0x000000047fbfffff]
Dec 03 09:01:55 hilda kernel:   Device   empty
Dec 03 09:01:55 hilda kernel: Movable zone start for each node
Dec 03 09:01:55 hilda kernel: Early memory node ranges
Dec 03 09:01:55 hilda kernel:   node   0: [mem 0x0000000000001000-0x000000000009ffff]
Dec 03 09:01:55 hilda kernel:   node   0: [mem 0x0000000000100000-0x000000007663bfff]
Dec 03 09:01:55 hilda kernel:   node   0: [mem 0x000000007683c000-0x000000007684afff]
Dec 03 09:01:55 hilda kernel:   node   0: [mem 0x0000000076861000-0x0000000076861fff]
Dec 03 09:01:55 hilda kernel:   node   0: [mem 0x0000000100000000-0x000000047fbfffff]
Dec 03 09:01:55 hilda kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000047fbfffff]
Dec 03 09:01:55 hilda kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Dec 03 09:01:55 hilda kernel: On node 0, zone DMA: 96 pages in unavailable ranges
Dec 03 09:01:55 hilda kernel: On node 0, zone DMA32: 512 pages in unavailable ranges
Dec 03 09:01:55 hilda kernel: On node 0, zone DMA32: 22 pages in unavailable ranges
Dec 03 09:01:55 hilda kernel: On node 0, zone Normal: 6046 pages in unavailable ranges
Dec 03 09:01:55 hilda kernel: On node 0, zone Normal: 1024 pages in unavailable ranges
Dec 03 09:01:55 hilda kernel: Reserving Intel graphics memory at [mem 0x7c800000-0x803fffff]
Dec 03 09:01:55 hilda kernel: ACPI: PM-Timer IO Port: 0x1808
Dec 03 09:01:55 hilda kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
Dec 03 09:01:55 hilda kernel: IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-119
Dec 03 09:01:55 hilda kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
Dec 03 09:01:55 hilda kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Dec 03 09:01:55 hilda kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Dec 03 09:01:55 hilda kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
Dec 03 09:01:55 hilda kernel: e820: update [mem 0x73614000-0x7363bfff] usable ==> reserved
Dec 03 09:01:55 hilda kernel: TSC deadline timer available
Dec 03 09:01:55 hilda kernel: CPU topo: Max. logical packages:   1
Dec 03 09:01:55 hilda kernel: CPU topo: Max. logical dies:       1
Dec 03 09:01:55 hilda kernel: CPU topo: Max. dies per package:   1
Dec 03 09:01:55 hilda kernel: CPU topo: Max. threads per core:   1
Dec 03 09:01:55 hilda kernel: CPU topo: Num. cores per package:     4
Dec 03 09:01:55 hilda kernel: CPU topo: Num. threads per package:   4
Dec 03 09:01:55 hilda kernel: CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
Dec 03 09:01:55 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Dec 03 09:01:55 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Dec 03 09:01:55 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x73614000-0x7363bfff]
Dec 03 09:01:55 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x7663c000-0x7683bfff]
Dec 03 09:01:55 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x7684b000-0x76860fff]
Dec 03 09:01:55 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x76862000-0x803fffff]
Dec 03 09:01:55 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x80400000-0xffffffff]
Dec 03 09:01:55 hilda kernel: [mem 0x80400000-0xffffffff] available for PCI devices
Dec 03 09:01:55 hilda kernel: Booting paravirtualized kernel on bare hardware
Dec 03 09:01:55 hilda kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Dec 03 09:01:55 hilda kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
Dec 03 09:01:55 hilda kernel: percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
Dec 03 09:01:55 hilda kernel: pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
Dec 03 09:01:55 hilda kernel: pcpu-alloc: [0] 0 1 2 3
Dec 03 09:01:55 hilda kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=29705f46-8be2-4ab2-a49e-62fea65f9bd3 rw quiet splash udev.log_priority=3 resume=
Dec 03 09:01:55 hilda kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64", will be passed to user space.
Dec 03 09:01:55 hilda kernel: random: crng init done
Dec 03 09:01:55 hilda kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Dec 03 09:01:55 hilda kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Dec 03 09:01:55 hilda kernel: Fallback order for Node 0: 0
Dec 03 09:01:55 hilda kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4153835
Dec 03 09:01:55 hilda kernel: Policy zone: Normal
Dec 03 09:01:55 hilda kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Dec 03 09:01:55 hilda kernel: software IO TLB: area num 4.
Dec 03 09:01:55 hilda kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Dec 03 09:01:55 hilda kernel: ftrace: allocating 51311 entries in 201 pages
Dec 03 09:01:55 hilda kernel: ftrace: allocated 201 pages with 4 groups
Dec 03 09:01:55 hilda kernel: Dynamic Preempt: full
Dec 03 09:01:55 hilda kernel: rcu: Preemptible hierarchical RCU implementation.
Dec 03 09:01:55 hilda kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
Dec 03 09:01:55 hilda kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Dec 03 09:01:55 hilda kernel:         Trampoline variant of Tasks RCU enabled.
Dec 03 09:01:55 hilda kernel:         Rude variant of Tasks RCU enabled.
Dec 03 09:01:55 hilda kernel:         Tracing variant of Tasks RCU enabled.
Dec 03 09:01:55 hilda kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Dec 03 09:01:55 hilda kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Dec 03 09:01:55 hilda kernel: RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 03 09:01:55 hilda kernel: RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 03 09:01:55 hilda kernel: RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 03 09:01:55 hilda kernel: NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
Dec 03 09:01:55 hilda kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Dec 03 09:01:55 hilda kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Dec 03 09:01:55 hilda kernel: spurious 8259A interrupt: IRQ7.
Dec 03 09:01:55 hilda kernel: Console: colour dummy device 80x25
Dec 03 09:01:55 hilda kernel: printk: legacy console [tty0] enabled
Dec 03 09:01:55 hilda kernel: ACPI: Core revision 20240827
Dec 03 09:01:55 hilda kernel: hpet: HPET dysfunctional in PC10. Force disabled.
Dec 03 09:01:55 hilda kernel: APIC: Switch to symmetric I/O mode setup
Dec 03 09:01:55 hilda kernel: DMAR: Host address width 39
Dec 03 09:01:55 hilda kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Dec 03 09:01:55 hilda kernel: DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
Dec 03 09:01:55 hilda kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Dec 03 09:01:55 hilda kernel: DMAR: dmar1: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
Dec 03 09:01:55 hilda kernel: DMAR: RMRR base: 0x0000007c000000 end: 0x000000803fffff
Dec 03 09:01:55 hilda kernel: DMAR-IR: IOAPIC id 0 under DRHD base  0xfed91000 IOMMU 1
Dec 03 09:01:55 hilda kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Dec 03 09:01:55 hilda kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Dec 03 09:01:55 hilda kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Dec 03 09:01:55 hilda kernel: x2apic enabled
Dec 03 09:01:55 hilda kernel: APIC: Switched APIC routing to: cluster x2apic
Dec 03 09:01:55 hilda kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1cc85f641a1, max_idle_ns: 881590533829 ns
Dec 03 09:01:55 hilda kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 1997.00 BogoMIPS (lpj=3328000)
Dec 03 09:01:55 hilda kernel: CPU0: Thermal monitoring enabled (TM1)
Dec 03 09:01:55 hilda kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Dec 03 09:01:55 hilda kernel: CET detected: Indirect Branch Tracking enabled
Dec 03 09:01:55 hilda kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Dec 03 09:01:55 hilda kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
Dec 03 09:01:55 hilda kernel: process: using mwait in idle threads
Dec 03 09:01:55 hilda kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Dec 03 09:01:55 hilda kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
Dec 03 09:01:55 hilda kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Dec 03 09:01:55 hilda kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Dec 03 09:01:55 hilda kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Dec 03 09:01:55 hilda kernel: Register File Data Sampling: Mitigation: Clear Register File
Dec 03 09:01:55 hilda kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Dec 03 09:01:55 hilda kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Dec 03 09:01:55 hilda kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Dec 03 09:01:55 hilda kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Dec 03 09:01:55 hilda kernel: x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
Dec 03 09:01:55 hilda kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Dec 03 09:01:55 hilda kernel: x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
Dec 03 09:01:55 hilda kernel: x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
Dec 03 09:01:55 hilda kernel: x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
Dec 03 09:01:55 hilda kernel: Freeing SMP alternatives memory: 40K
Dec 03 09:01:55 hilda kernel: pid_max: default: 32768 minimum: 301
Dec 03 09:01:55 hilda kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
Dec 03 09:01:55 hilda kernel: landlock: Up and running.
Dec 03 09:01:55 hilda kernel: Yama: becoming mindful.
Dec 03 09:01:55 hilda kernel: LSM support for eBPF active
Dec 03 09:01:55 hilda kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec 03 09:01:55 hilda kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec 03 09:01:55 hilda kernel: smpboot: CPU0: Intel(R) N200 (family: 0x6, model: 0xbe, stepping: 0x0)
Dec 03 09:01:55 hilda kernel: Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline, PEBS-via-PT,  AnyThread deprecated, Gracemont events, 32-deep LBR, full-width counters, Intel PMU driver.
Dec 03 09:01:55 hilda kernel: ... version:                5
Dec 03 09:01:55 hilda kernel: ... bit width:              48
Dec 03 09:01:55 hilda kernel: ... generic registers:      6
Dec 03 09:01:55 hilda kernel: ... value mask:             0000ffffffffffff
Dec 03 09:01:55 hilda kernel: ... max period:             00007fffffffffff
Dec 03 09:01:55 hilda kernel: ... fixed-purpose events:   3
Dec 03 09:01:55 hilda kernel: ... event mask:             000000070000003f
Dec 03 09:01:55 hilda kernel: signal: max sigframe size: 3632
Dec 03 09:01:55 hilda kernel: Estimated ratio of average max frequency by base frequency (times 1024): 3276
Dec 03 09:01:55 hilda kernel: rcu: Hierarchical SRCU implementation.
Dec 03 09:01:55 hilda kernel: rcu:         Max phase no-delay instances is 1000.
Dec 03 09:01:55 hilda kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
Dec 03 09:01:55 hilda kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Dec 03 09:01:55 hilda kernel: smp: Bringing up secondary CPUs ...
Dec 03 09:01:55 hilda kernel: smpboot: x86: Booting SMP configuration:
Dec 03 09:01:55 hilda kernel: .... node  #0, CPUs:      #1 #2 #3
Dec 03 09:01:55 hilda kernel: smp: Brought up 1 node, 4 CPUs
Dec 03 09:01:55 hilda kernel: smpboot: Total of 4 processors activated (7990.00 BogoMIPS)
Dec 03 09:01:55 hilda kernel: Memory: 16165936K/16615340K available (18432K kernel code, 2671K rwdata, 14312K rodata, 4260K init, 4040K bss, 436556K reserved, 0K cma-reserved)
Dec 03 09:01:55 hilda kernel: devtmpfs: initialized
Dec 03 09:01:55 hilda kernel: x86/mm: Memory block size: 128MB
Dec 03 09:01:55 hilda kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Dec 03 09:01:55 hilda kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Dec 03 09:01:55 hilda kernel: pinctrl core: initialized pinctrl subsystem
Dec 03 09:01:55 hilda kernel: PM: RTC time: 23:01:52, date: 2024-12-02
Dec 03 09:01:55 hilda kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Dec 03 09:01:55 hilda kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Dec 03 09:01:55 hilda kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec 03 09:01:55 hilda kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Dec 03 09:01:55 hilda kernel: audit: initializing netlink subsys (disabled)
Dec 03 09:01:55 hilda kernel: audit: type=2000 audit(1733180512.013:1): state=initialized audit_enabled=0 res=1
Dec 03 09:01:55 hilda kernel: thermal_sys: Registered thermal governor 'fair_share'
Dec 03 09:01:55 hilda kernel: thermal_sys: Registered thermal governor 'bang_bang'
Dec 03 09:01:55 hilda kernel: thermal_sys: Registered thermal governor 'step_wise'
Dec 03 09:01:55 hilda kernel: thermal_sys: Registered thermal governor 'user_space'
Dec 03 09:01:55 hilda kernel: thermal_sys: Registered thermal governor 'power_allocator'
Dec 03 09:01:55 hilda kernel: cpuidle: using governor ladder
Dec 03 09:01:55 hilda kernel: cpuidle: using governor menu
Dec 03 09:01:55 hilda kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 03 09:01:55 hilda kernel: PCI: ECAM [mem 0xc0000000-0xcfffffff] (base 0xc0000000) for domain 0000 [bus 00-ff]
Dec 03 09:01:55 hilda kernel: PCI: Using configuration type 1 for base access
Dec 03 09:01:55 hilda kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Dec 03 09:01:55 hilda kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Dec 03 09:01:55 hilda kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Dec 03 09:01:55 hilda kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Dec 03 09:01:55 hilda kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Dec 03 09:01:55 hilda kernel: ACPI: Added _OSI(Module Device)
Dec 03 09:01:55 hilda kernel: ACPI: Added _OSI(Processor Device)
Dec 03 09:01:55 hilda kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Dec 03 09:01:55 hilda kernel: ACPI: Added _OSI(Processor Aggregator Device)
Dec 03 09:01:55 hilda kernel: ACPI: 2 ACPI AML tables successfully acquired and loaded
Dec 03 09:01:55 hilda kernel: ACPI: EC: EC started
Dec 03 09:01:55 hilda kernel: ACPI: EC: interrupt blocked
Dec 03 09:01:55 hilda kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Dec 03 09:01:55 hilda kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC used to handle transactions
Dec 03 09:01:55 hilda kernel: ACPI: Interpreter enabled
Dec 03 09:01:55 hilda kernel: ACPI: PM: (supports S0 S3 S4 S5)
Dec 03 09:01:55 hilda kernel: ACPI: Using IOAPIC for interrupt routing
Dec 03 09:01:55 hilda kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Dec 03 09:01:55 hilda kernel: PCI: Ignoring E820 reservations for host bridge windows
Dec 03 09:01:55 hilda kernel: ACPI: Enabled 2 GPEs in block 00 to 7F
Dec 03 09:01:55 hilda kernel: ACPI: \_SB_.PCI0.RP09.RTD3: New power resource
Dec 03 09:01:55 hilda kernel: ACPI: \_SB_.PCI0.TBT0: New power resource
Dec 03 09:01:55 hilda kernel: ACPI: \_SB_.PCI0.TBT1: New power resource
Dec 03 09:01:55 hilda kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Dec 03 09:01:55 hilda kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Dec 03 09:01:55 hilda kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
Dec 03 09:01:55 hilda kernel: PCI host bridge to bus 0000:00
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [mem 0x80400000-0xdfffffff window]
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [mem 0x47fc00000-0x7fffffffff window]
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed47fff window]
Dec 03 09:01:55 hilda kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Dec 03 09:01:55 hilda kernel: pci 0000:00:00.0: [8086:461b] type 00 class 0x060000 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: [8086:46d0] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: BAR 0 [mem 0x81000000-0x81ffffff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: BAR 2 [mem 0x90000000-0x9fffffff 64bit pref]
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: BAR 4 [io  0x1000-0x103f]
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x06ffffff 64bit]: contains BAR 0 for 7 VFs
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0x1fffffff 64bit pref]
Dec 03 09:01:55 hilda kernel: pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0xdfffffff 64bit pref]: contains BAR 2 for 7 VFs
Dec 03 09:01:55 hilda kernel: pci 0000:00:08.0: [8086:467e] type 00 class 0x088000 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:08.0: BAR 0 [mem 0x80624000-0x80624fff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:0a.0: [8086:467d] type 00 class 0x118000 PCIe Root Complex Integrated Endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:0a.0: BAR 0 [mem 0x80610000-0x80617fff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:0a.0: enabling Extended Tags
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.0: [8086:54ed] type 00 class 0x0c0330 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.0: BAR 0 [mem 0x80600000-0x8060ffff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.2: [8086:54ef] type 00 class 0x050000 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.2: BAR 0 [mem 0x80618000-0x8061bfff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.2: BAR 2 [mem 0x80625000-0x80625fff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.3: [8086:54f0] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.3: BAR 0 [mem 0x8061c000-0x8061ffff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
Dec 03 09:01:55 hilda kernel: pci 0000:00:15.0: [8086:54e8] type 00 class 0x0c8000 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:15.0: BAR 0 [mem 0x80626000-0x80626fff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:15.2: [8086:54ea] type 00 class 0x0c8000 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:15.2: BAR 0 [mem 0x80627000-0x80627fff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:1d.0: [8086:54b0] type 01 class 0x060400 PCIe Root Port
Dec 03 09:01:55 hilda kernel: pci 0000:00:1d.0: PCI bridge to [bus 01]
Dec 03 09:01:55 hilda kernel: pci 0000:00:1d.0:   bridge window [mem 0x80400000-0x804fffff]
Dec 03 09:01:55 hilda kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Dec 03 09:01:55 hilda kernel: pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
Dec 03 09:01:55 hilda kernel: pci 0000:00:1e.0: [8086:54a8] type 00 class 0x078000 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:1e.0: BAR 0 [mem 0xfe03e000-0xfe03efff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:1e.0: BAR 2 [mem 0x80629000-0x80629fff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:1f.0: [8086:5481] type 00 class 0x060100 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:1f.3: [8086:54c8] type 00 class 0x040300 conventional PCI endpoint
Dec 03 09:01:55 hilda kernel: pci 0000:00:1f.3: BAR 0 [mem 0x80620000-0x80623fff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:1f.3: BAR 4 [mem 0x80500000-0x805fffff 64bit]
Dec 03 09:01:55 hilda kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Dec 03 09:01:56 hilda kernel: pci 0000:00:1f.4: [8086:54a3] type 00 class 0x0c0500 conventional PCI endpoint
Dec 03 09:01:56 hilda kernel: pci 0000:00:1f.4: BAR 0 [mem 0x8062b000-0x8062b0ff 64bit]
Dec 03 09:01:56 hilda kernel: pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
Dec 03 09:01:56 hilda kernel: pci 0000:00:1f.5: [8086:54a4] type 00 class 0x0c8000 conventional PCI endpoint
Dec 03 09:01:56 hilda kernel: pci 0000:00:1f.5: BAR 0 [mem 0x8062a000-0x8062afff]
Dec 03 09:01:56 hilda kernel: pci 0000:01:00.0: [126f:2263] type 00 class 0x010802 PCIe Endpoint
Dec 03 09:01:56 hilda kernel: pci 0000:01:00.0: BAR 0 [mem 0x80400000-0x80403fff 64bit]
Dec 03 09:01:56 hilda kernel: pci 0000:00:1d.0: PCI bridge to [bus 01]
Dec 03 09:01:56 hilda kernel: ACPI: EC: interrupt unblocked
Dec 03 09:01:56 hilda kernel: ACPI: EC: event unblocked
Dec 03 09:01:56 hilda kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Dec 03 09:01:56 hilda kernel: ACPI: EC: GPE=0x6e
Dec 03 09:01:56 hilda kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC initialization complete
Dec 03 09:01:56 hilda kernel: ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
Dec 03 09:01:56 hilda kernel: iommu: Default domain type: Translated
Dec 03 09:01:56 hilda kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Dec 03 09:01:56 hilda kernel: SCSI subsystem initialized
Dec 03 09:01:56 hilda kernel: libata version 3.00 loaded.
Dec 03 09:01:56 hilda kernel: ACPI: bus type USB registered
Dec 03 09:01:56 hilda kernel: usbcore: registered new interface driver usbfs
Dec 03 09:01:56 hilda kernel: usbcore: registered new interface driver hub
Dec 03 09:01:56 hilda kernel: usbcore: registered new device driver usb
Dec 03 09:01:56 hilda kernel: EDAC MC: Ver: 3.0.0
Dec 03 09:01:56 hilda kernel: efivars: Registered efivars operations
Dec 03 09:01:56 hilda kernel: NetLabel: Initializing
Dec 03 09:01:56 hilda kernel: NetLabel:  domain hash size = 128
Dec 03 09:01:56 hilda kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec 03 09:01:56 hilda kernel: NetLabel:  unlabeled traffic allowed by default
Dec 03 09:01:56 hilda kernel: mctp: management component transport protocol core
Dec 03 09:01:56 hilda kernel: NET: Registered PF_MCTP protocol family
Dec 03 09:01:56 hilda kernel: PCI: Using ACPI for IRQ routing
Dec 03 09:01:56 hilda kernel: PCI: pci_cache_line_size set to 64 bytes
Dec 03 09:01:56 hilda kernel: e820: reserve RAM buffer [mem 0x73614000-0x73ffffff]
Dec 03 09:01:56 hilda kernel: e820: reserve RAM buffer [mem 0x7663c000-0x77ffffff]
Dec 03 09:01:56 hilda kernel: e820: reserve RAM buffer [mem 0x7684b000-0x77ffffff]
Dec 03 09:01:56 hilda kernel: e820: reserve RAM buffer [mem 0x76862000-0x77ffffff]
Dec 03 09:01:56 hilda kernel: e820: reserve RAM buffer [mem 0x47fc00000-0x47fffffff]
Dec 03 09:01:56 hilda kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Dec 03 09:01:56 hilda kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Dec 03 09:01:56 hilda kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Dec 03 09:01:56 hilda kernel: vgaarb: loaded
Dec 03 09:01:56 hilda kernel: clocksource: Switched to clocksource tsc-early
Dec 03 09:01:56 hilda kernel: VFS: Disk quotas dquot_6.6.0
Dec 03 09:01:56 hilda kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec 03 09:01:56 hilda kernel: pnp: PnP ACPI init
Dec 03 09:01:56 hilda kernel: pnp 00:00: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xfedc0000-0xfeddffff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xfeda0000-0xfeda0fff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xfeda1000-0xfeda1fff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xfed90000-0xfed93fff] could not be reserved
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xff000000-0xffffffff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xf8000000-0xf9ffffff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xfee00000-0xfeefffff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:01: [mem 0xfed00000-0xfed003ff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:02: [mem 0xfed00000-0xfed003ff] has been reserved
Dec 03 09:01:56 hilda kernel: system 00:03: [io  0x1800-0x18fe] has been reserved
Dec 03 09:01:56 hilda kernel: pnp: PnP ACPI: found 7 devices
Dec 03 09:01:56 hilda kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Dec 03 09:01:56 hilda kernel: NET: Registered PF_INET protocol family
Dec 03 09:01:56 hilda kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec 03 09:01:56 hilda kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
Dec 03 09:01:56 hilda kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Dec 03 09:01:56 hilda kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Dec 03 09:01:56 hilda kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Dec 03 09:01:56 hilda kernel: TCP: Hash tables configured (established 131072 bind 65536)
Dec 03 09:01:56 hilda kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
Dec 03 09:01:56 hilda kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
Dec 03 09:01:56 hilda kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
Dec 03 09:01:56 hilda kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Dec 03 09:01:56 hilda kernel: NET: Registered PF_XDP protocol family
Dec 03 09:01:56 hilda kernel: pci 0000:00:02.0: VF BAR 2 [mem 0x480000000-0x55fffffff 64bit pref]: assigned
Dec 03 09:01:56 hilda kernel: pci 0000:00:02.0: VF BAR 0 [mem 0x560000000-0x566ffffff 64bit]: assigned
Dec 03 09:01:56 hilda kernel: pci 0000:00:1d.0:   bridge window [mem 0x80400000-0x804fffff]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:00: resource 7 [mem 0x80400000-0xdfffffff window]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:00: resource 8 [mem 0x47fc00000-0x7fffffffff window]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:00: resource 10 [mem 0xfed40000-0xfed47fff window]
Dec 03 09:01:56 hilda kernel: pci_bus 0000:01: resource 1 [mem 0x80400000-0x804fffff]
Dec 03 09:01:56 hilda kernel: PCI: CLS 64 bytes, default 64
Dec 03 09:01:56 hilda kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Dec 03 09:01:56 hilda kernel: software IO TLB: mapped [mem 0x000000006f614000-0x0000000073614000] (64MB)
Dec 03 09:01:56 hilda kernel: Trying to unpack rootfs image as initramfs...
Dec 03 09:01:56 hilda kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1cc85f641a1, max_idle_ns: 881590533829 ns
Dec 03 09:01:56 hilda kernel: Initialise system trusted keyrings
Dec 03 09:01:56 hilda kernel: Key type blacklist registered
Dec 03 09:01:56 hilda kernel: workingset: timestamp_bits=36 max_order=22 bucket_order=0
Dec 03 09:01:56 hilda kernel: fuse: init (API version 7.41)
Dec 03 09:01:56 hilda kernel: integrity: Platform Keyring initialized
Dec 03 09:01:56 hilda kernel: integrity: Machine keyring initialized
Dec 03 09:01:56 hilda kernel: Key type asymmetric registered
Dec 03 09:01:56 hilda kernel: Asymmetric key parser 'x509' registered
Dec 03 09:01:56 hilda kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Dec 03 09:01:56 hilda kernel: io scheduler mq-deadline registered
Dec 03 09:01:56 hilda kernel: io scheduler kyber registered
Dec 03 09:01:56 hilda kernel: io scheduler bfq registered
Dec 03 09:01:56 hilda kernel: ledtrig-cpu: registered to indicate activity on CPUs
Dec 03 09:01:56 hilda kernel: pcieport 0000:00:1d.0: PME: Signaling with IRQ 120
Dec 03 09:01:56 hilda kernel: pcieport 0000:00:1d.0: AER: enabled with IRQ 120
Dec 03 09:01:56 hilda kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Dec 03 09:01:56 hilda kernel: ACPI: AC: AC Adapter [ADP1] (on-line)
Dec 03 09:01:56 hilda kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/PNP0C09:00/PNP0C0D:00/input/input0
Dec 03 09:01:56 hilda kernel: ACPI: button: Lid Switch [LID0]
Dec 03 09:01:56 hilda kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Dec 03 09:01:56 hilda kernel: ACPI: button: Power Button [PWRF]
Dec 03 09:01:56 hilda kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Dec 03 09:01:56 hilda kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 03 09:01:56 hilda kernel: Non-volatile memory driver v1.3
Dec 03 09:01:56 hilda kernel: Linux agpgart interface v0.103
Dec 03 09:01:56 hilda kernel: ACPI: bus type drm_connector registered
Dec 03 09:01:56 hilda kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Dec 03 09:01:56 hilda kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Dec 03 09:01:56 hilda kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000100200009810
Dec 03 09:01:56 hilda kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Dec 03 09:01:56 hilda kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
Dec 03 09:01:56 hilda kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
Dec 03 09:01:56 hilda kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 03 09:01:56 hilda kernel: usb usb1: Product: xHCI Host Controller
Dec 03 09:01:56 hilda kernel: usb usb1: Manufacturer: Linux 6.12.1-4-MANJARO xhci-hcd
Dec 03 09:01:56 hilda kernel: usb usb1: SerialNumber: 0000:00:14.0
Dec 03 09:01:56 hilda kernel: hub 1-0:1.0: USB hub found
Dec 03 09:01:56 hilda kernel: hub 1-0:1.0: 12 ports detected
Dec 03 09:01:56 hilda kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
Dec 03 09:01:56 hilda kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 03 09:01:56 hilda kernel: usb usb2: Product: xHCI Host Controller
Dec 03 09:01:56 hilda kernel: usb usb2: Manufacturer: Linux 6.12.1-4-MANJARO xhci-hcd
Dec 03 09:01:56 hilda kernel: usb usb2: SerialNumber: 0000:00:14.0
Dec 03 09:01:56 hilda kernel: hub 2-0:1.0: USB hub found
Dec 03 09:01:56 hilda kernel: hub 2-0:1.0: 4 ports detected
Dec 03 09:01:56 hilda kernel: usb: port power management may be unreliable
Dec 03 09:01:56 hilda kernel: usbcore: registered new interface driver usbserial_generic
Dec 03 09:01:56 hilda kernel: usbserial: USB Serial support registered for generic
Dec 03 09:01:56 hilda kernel: rtc_cmos 00:04: RTC can wake from S4
Dec 03 09:01:56 hilda kernel: rtc_cmos 00:04: registered as rtc0
Dec 03 09:01:56 hilda kernel: rtc_cmos 00:04: setting system clock to 2024-12-02T23:01:52 UTC (1733180512)
Dec 03 09:01:56 hilda kernel: rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram
Dec 03 09:01:56 hilda kernel: intel_pstate: Intel P-state driver initializing
Dec 03 09:01:56 hilda kernel: intel_pstate: HWP enabled
Dec 03 09:01:56 hilda kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
Dec 03 09:01:56 hilda kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Dec 03 09:01:56 hilda kernel: fbcon: Deferring console take-over
Dec 03 09:01:56 hilda kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Dec 03 09:01:56 hilda kernel: hid: raw HID events driver (C) Jiri Kosina
Dec 03 09:01:56 hilda kernel: drop_monitor: Initializing network drop monitor service
Dec 03 09:01:56 hilda kernel: NET: Registered PF_INET6 protocol family
Dec 03 09:01:56 hilda kernel: Freeing initrd memory: 31928K
Dec 03 09:01:56 hilda kernel: Segment Routing with IPv6
Dec 03 09:01:56 hilda kernel: RPL Segment Routing with IPv6
Dec 03 09:01:56 hilda kernel: In-situ OAM (IOAM) with IPv6
Dec 03 09:01:56 hilda kernel: NET: Registered PF_PACKET protocol family
Dec 03 09:01:56 hilda kernel: microcode: Current revision: 0x0000001a
Dec 03 09:01:56 hilda kernel: microcode: Updated early from: 0x00000017
Dec 03 09:01:56 hilda kernel: resctrl: L2 allocation detected
Dec 03 09:01:56 hilda kernel: IPI shorthand broadcast: enabled
Dec 03 09:01:56 hilda kernel: sched_clock: Marking stable (460002065, 16314029)->(505072245, -28756151)
Dec 03 09:01:56 hilda kernel: registered taskstats version 1
Dec 03 09:01:56 hilda kernel: Loading compiled-in X.509 certificates
Dec 03 09:01:56 hilda kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 2054830c3ef97576fa5ece2df9ad8f0d91245e4f'
Dec 03 09:01:56 hilda kernel: Demotion targets for Node 0: null
Dec 03 09:01:56 hilda kernel: Key type .fscrypt registered
Dec 03 09:01:56 hilda kernel: Key type fscrypt-provisioning registered
Dec 03 09:01:56 hilda kernel: PM:   Magic number: 4:589:48
Dec 03 09:01:56 hilda kernel: memory memory80: hash matches
Dec 03 09:01:56 hilda kernel: RAS: Correctable Errors collector initialized.
Dec 03 09:01:56 hilda kernel: clk: Disabling unused clocks
Dec 03 09:01:56 hilda kernel: PM: genpd: Disabling unused power domains
Dec 03 09:01:56 hilda kernel: ACPI: battery: Slot [BAT0] (battery present)
Dec 03 09:01:56 hilda kernel: Freeing unused decrypted memory: 2028K
Dec 03 09:01:56 hilda kernel: Freeing unused kernel image (initmem) memory: 4260K
Dec 03 09:01:56 hilda kernel: Write protecting the kernel read-only data: 32768k
Dec 03 09:01:56 hilda kernel: Freeing unused kernel image (rodata/data gap) memory: 24K
Dec 03 09:01:56 hilda kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 03 09:01:56 hilda kernel: rodata_test: all tests were successful
Dec 03 09:01:56 hilda kernel: Run /init as init process
Dec 03 09:01:56 hilda kernel:   with arguments:
Dec 03 09:01:56 hilda kernel:     /init
Dec 03 09:01:56 hilda kernel:     splash
Dec 03 09:01:56 hilda kernel:   with environment:
Dec 03 09:01:56 hilda kernel:     HOME=/
Dec 03 09:01:56 hilda kernel:     TERM=linux
Dec 03 09:01:56 hilda kernel:     BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
Dec 03 09:01:56 hilda kernel: usb 1-1: new high-speed USB device number 2 using xhci_hcd
Dec 03 09:01:56 hilda kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Dec 03 09:01:56 hilda kernel: usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
Dec 03 09:01:56 hilda kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 03 09:01:56 hilda kernel: usb 1-1: Product: USB2.1 Hub
Dec 03 09:01:56 hilda kernel: usb 1-1: Manufacturer: GenesysLogic
Dec 03 09:01:56 hilda kernel: hub 1-1:1.0: USB hub found
Dec 03 09:01:56 hilda kernel: hub 1-1:1.0: 4 ports detected
Dec 03 09:01:56 hilda kernel: nvme 0000:01:00.0: platform quirk: setting simple suspend
Dec 03 09:01:56 hilda kernel: nvme nvme0: pci function 0000:01:00.0
Dec 03 09:01:56 hilda kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Dec 03 09:01:56 hilda kernel: nvme nvme0: 4/0/0 default/read/poll queues
Dec 03 09:01:56 hilda kernel: nvme nvme0: Ignoring bogus Namespace Identifiers
Dec 03 09:01:56 hilda kernel: usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
Dec 03 09:01:56 hilda kernel:  nvme0n1: p1 p2
Dec 03 09:01:56 hilda kernel: usb 2-3: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
Dec 03 09:01:56 hilda kernel: usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 03 09:01:56 hilda kernel: usb 2-3: Product: USB3.1 Hub
Dec 03 09:01:56 hilda kernel: usb 2-3: Manufacturer: GenesysLogic
Dec 03 09:01:56 hilda kernel: hub 2-3:1.0: USB hub found
Dec 03 09:01:56 hilda kernel: hub 2-3:1.0: 4 ports detected
Dec 03 09:01:56 hilda kernel: usb 1-3: new high-speed USB device number 3 using xhci_hcd
Dec 03 09:01:56 hilda kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Dec 03 09:01:56 hilda kernel: usb 1-3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
Dec 03 09:01:56 hilda kernel: usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Dec 03 09:01:56 hilda kernel: usb 1-3: Product: USB2.0 Hub
Dec 03 09:01:56 hilda kernel: hub 1-3:1.0: USB hub found
Dec 03 09:01:56 hilda kernel: hub 1-3:1.0: 4 ports detected
Dec 03 09:01:56 hilda kernel: usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
Dec 03 09:01:56 hilda kernel: usb 1-1.2: New USB device found, idVendor=045e, idProduct=00cb, bcdDevice= 1.00
Dec 03 09:01:56 hilda kernel: usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 03 09:01:56 hilda kernel: usb 1-1.2: Product: Microsoft USB Optical Mouse
Dec 03 09:01:56 hilda kernel: usb 1-1.2: Manufacturer: PixArt
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] Found ALDERLAKE_P/ADL-N (device ID 46d0) display version 13.00 stepping D0
Dec 03 09:01:56 hilda kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] Using Transparent Hugepages
Dec 03 09:01:56 hilda kernel: usb 1-6: new high-speed USB device number 5 using xhci_hcd
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc.bin (v2.20)
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.29.2
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
Dec 03 09:01:56 hilda kernel: [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
Dec 03 09:01:56 hilda kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Dec 03 09:01:56 hilda kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
Dec 03 09:01:56 hilda kernel: fbcon: i915drmfb (fb0) is primary device
Dec 03 09:01:56 hilda kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Dec 03 09:01:56 hilda kernel: usb 1-6: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
Dec 03 09:01:56 hilda kernel: usb 1-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Dec 03 09:01:56 hilda kernel: usb 1-6: Product: USB2.0 HUB
Dec 03 09:01:56 hilda kernel: hub 1-6:1.0: USB hub found
Dec 03 09:01:56 hilda kernel: hub 1-6:1.0: 4 ports detected
Dec 03 09:01:56 hilda kernel: usb 1-3.1: new full-speed USB device number 6 using xhci_hcd
Dec 03 09:01:56 hilda kernel: usb 1-3.1: New USB device found, idVendor=1018, idProduct=1006, bcdDevice= 1.03
Dec 03 09:01:56 hilda kernel: usb 1-3.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 03 09:01:56 hilda kernel: usb 1-10: new full-speed USB device number 7 using xhci_hcd
Dec 03 09:01:56 hilda kernel: usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
Dec 03 09:01:56 hilda kernel: usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 03 09:01:56 hilda kernel: usbcore: registered new interface driver usbhid
Dec 03 09:01:56 hilda kernel: usbhid: USB HID core driver
Dec 03 09:01:56 hilda kernel: input: PixArt Microsoft USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:00CB.0001/input/input4
Dec 03 09:01:56 hilda kernel: hid-generic 0003:045E:00CB.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Microsoft USB Optical Mouse] on usb-0000:00:14.0-1.2/input0
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.0/0003:1018:1006.0002/input/input5
Dec 03 09:01:56 hilda kernel: usb 1-3.2: new high-speed USB device number 8 using xhci_hcd
Dec 03 09:01:56 hilda kernel: usb 1-3.2: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
Dec 03 09:01:56 hilda kernel: usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 03 09:01:56 hilda kernel: usb 1-3.2: Product: USB2.0-CRW
Dec 03 09:01:56 hilda kernel: usb 1-3.2: Manufacturer: Generic
Dec 03 09:01:56 hilda kernel: usb 1-3.2: SerialNumber: 20100201396000000
Dec 03 09:01:56 hilda kernel: hid-generic 0003:1018:1006.0002: input,hidraw1: USB HID v1.11 Keyboard [HID 1018:1006] on usb-0000:00:14.0-3.1/input0
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input6
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input7
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input8
Dec 03 09:01:56 hilda kernel: usbcore: registered new interface driver rtsx_usb
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input9
Dec 03 09:01:56 hilda kernel: hid-generic 0003:1018:1006.0003: input,hiddev96,hidraw2: USB HID v1.11 Mouse [HID 1018:1006] on usb-0000:00:14.0-3.1/input1
Dec 03 09:01:56 hilda kernel: usb 1-6.1: new high-speed USB device number 9 using xhci_hcd
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input10
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input11
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input12
Dec 03 09:01:56 hilda kernel: input: HID 1018:1006 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input13
Dec 03 09:01:56 hilda kernel: hid-multitouch 0003:1018:1006.0003: input,hiddev96,hidraw2: USB HID v1.11 Mouse [HID 1018:1006] on usb-0000:00:14.0-3.1/input1
Dec 03 09:01:56 hilda kernel: usb 1-6.1: New USB device found, idVendor=0bda, idProduct=5830, bcdDevice=11.16
Dec 03 09:01:56 hilda kernel: usb 1-6.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 03 09:01:56 hilda kernel: usb 1-6.1: Product: USB2.0 camera
Dec 03 09:01:56 hilda kernel: usb 1-6.1: Manufacturer: SunplusIT Inc
Dec 03 09:01:56 hilda kernel: usb 1-6.1: SerialNumber: J2023111601
Dec 03 09:01:56 hilda kernel: usb 1-6.2: new high-speed USB device number 10 using xhci_hcd
Dec 03 09:01:56 hilda kernel: usb 1-6.2: New USB device found, idVendor=1bcf, idProduct=284d, bcdDevice=11.16
Dec 03 09:01:56 hilda kernel: usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 03 09:01:56 hilda kernel: usb 1-6.2: Product: USB 2.0 Camera
Dec 03 09:01:56 hilda kernel: usb 1-6.2: Manufacturer: SunplusIT Inc
Dec 03 09:01:56 hilda kernel: usb 1-6.2: SerialNumber: J20231116V1
Dec 03 09:01:56 hilda kernel: fbcon: Taking over console
Dec 03 09:01:56 hilda kernel: Console: switching to colour frame buffer device 135x45
Dec 03 09:01:56 hilda kernel: EXT4-fs (nvme0n1p2): mounted filesystem 29705f46-8be2-4ab2-a49e-62fea65f9bd3 r/w with ordered data mode. Quota mode: none.
Dec 03 09:01:56 hilda systemd[1]: systemd 256.8-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
Dec 03 09:01:56 hilda systemd[1]: Detected architecture x86-64.
Dec 03 09:01:56 hilda systemd[1]: Hostname set to <hilda>.
Dec 03 09:01:56 hilda systemd[1]: bpf-restrict-fs: LSM BPF program attached
Dec 03 09:01:56 hilda systemd-ssh-generator[254]: Binding SSH to AF_UNIX socket /run/ssh-unix-local/socket.
Dec 03 09:01:56 hilda systemd-ssh-generator[254]: → connect via 'ssh .host' locally
Dec 03 09:01:56 hilda systemd[1]: Queued start job for default target Graphical Interface.
Dec 03 09:01:56 hilda systemd[1]: Created slice CUPS Slice.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/dirmngr.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/getty.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/gpg-agent.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/gpg-agent-browser.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/gpg-agent-extra.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/keyboxd.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/modprobe.
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/systemd-fsck.
Dec 03 09:01:56 hilda systemd[1]: Created slice User and Session Slice.
Dec 03 09:01:56 hilda systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Dec 03 09:01:56 hilda systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Dec 03 09:01:56 hilda systemd[1]: Expecting device /dev/disk/by-uuid/42A8-45AC...
Dec 03 09:01:56 hilda systemd[1]: Expecting device /dev/tpmrm0...
Dec 03 09:01:56 hilda systemd[1]: Reached target Login Prompts.
Dec 03 09:01:56 hilda systemd[1]: Reached target Local Integrity Protected Volumes.
Dec 03 09:01:56 hilda systemd[1]: Reached target Remote File Systems.
Dec 03 09:01:56 hilda systemd[1]: Reached target Slice Units.
Dec 03 09:01:56 hilda systemd[1]: Reached target Local Verity Protected Volumes.
Dec 03 09:01:56 hilda systemd[1]: Listening on Device-mapper event daemon FIFOs.
Dec 03 09:01:56 hilda systemd[1]: Listening on LVM2 poll daemon socket.
Dec 03 09:01:56 hilda systemd[1]: Listening on Process Core Dump Socket.
Dec 03 09:01:56 hilda systemd[1]: Listening on Credential Encryption/Decryption.
Dec 03 09:01:56 hilda systemd[1]: Listening on Journal Socket (/dev/log).
Dec 03 09:01:56 hilda systemd[1]: Listening on Journal Sockets.
Dec 03 09:01:56 hilda systemd[1]: Listening on udev Control Socket.
Dec 03 09:01:56 hilda systemd[1]: Listening on udev Kernel Socket.
Dec 03 09:01:56 hilda systemd[1]: Listening on User Database Manager Socket.
Dec 03 09:01:56 hilda systemd[1]: Mounting Huge Pages File System...
Dec 03 09:01:56 hilda systemd[1]: Mounting POSIX Message Queue File System...
Dec 03 09:01:56 hilda systemd[1]: Mounting Kernel Debug File System...
Dec 03 09:01:56 hilda systemd[1]: Mounting Kernel Trace File System...
Dec 03 09:01:56 hilda systemd[1]: Starting Create List of Static Device Nodes...
Dec 03 09:01:56 hilda systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Dec 03 09:01:56 hilda systemd[1]: Starting Load Kernel Module configfs...
Dec 03 09:01:56 hilda systemd[1]: Starting Load Kernel Module dm_mod...
Dec 03 09:01:56 hilda systemd[1]: Starting Load Kernel Module drm...
Dec 03 09:01:56 hilda systemd[1]: Starting Load Kernel Module fuse...
Dec 03 09:01:56 hilda systemd[1]: Starting Load Kernel Module loop...
Dec 03 09:01:56 hilda systemd[1]: Starting Mullvad early boot network blocker...
Dec 03 09:01:56 hilda systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Dec 03 09:01:56 hilda systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Dec 03 09:01:56 hilda systemd[1]: Starting Journal Service...
Dec 03 09:01:56 hilda systemd[1]: Starting Load Kernel Modules...
Dec 03 09:01:56 hilda systemd[1]: Starting Remount Root and Kernel File Systems...
Dec 03 09:01:56 hilda systemd[1]: Starting Load udev Rules from Credentials...
Dec 03 09:01:56 hilda kernel: device-mapper: uevent: version 1.0.3
Dec 03 09:01:56 hilda kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
Dec 03 09:01:56 hilda kernel: loop: module loaded
Dec 03 09:01:56 hilda systemd[1]: Starting Coldplug All udev Devices...
Dec 03 09:01:56 hilda systemd[1]: Starting Virtual Console Setup...
Dec 03 09:01:56 hilda systemd[1]: Mounted Huge Pages File System.
Dec 03 09:01:56 hilda systemd[1]: Mounted POSIX Message Queue File System.
Dec 03 09:01:56 hilda systemd[1]: Mounted Kernel Debug File System.
Dec 03 09:01:56 hilda systemd[1]: Mounted Kernel Trace File System.
Dec 03 09:01:56 hilda systemd[1]: Finished Create List of Static Device Nodes.
Dec 03 09:01:56 hilda systemd[1]: modprobe@configfs.service: Deactivated successfully.
Dec 03 09:01:56 hilda systemd[1]: Finished Load Kernel Module configfs.
Dec 03 09:01:56 hilda systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Dec 03 09:01:56 hilda systemd[1]: Finished Load Kernel Module dm_mod.
Dec 03 09:01:56 hilda systemd[1]: modprobe@drm.service: Deactivated successfully.
Dec 03 09:01:56 hilda systemd[1]: Finished Load Kernel Module drm.
Dec 03 09:01:56 hilda systemd[1]: modprobe@fuse.service: Deactivated successfully.
Dec 03 09:01:56 hilda systemd[1]: Finished Load Kernel Module fuse.
Dec 03 09:01:56 hilda systemd[1]: modprobe@loop.service: Deactivated successfully.
Dec 03 09:01:56 hilda systemd[1]: Finished Load Kernel Module loop.
Dec 03 09:01:56 hilda systemd[1]: Finished Load udev Rules from Credentials.
Dec 03 09:01:56 hilda kernel: EXT4-fs (nvme0n1p2): re-mounted 29705f46-8be2-4ab2-a49e-62fea65f9bd3 r/w. Quota mode: none.
Dec 03 09:01:56 hilda systemd-journald[272]: Collecting audit messages is disabled.
Dec 03 09:01:56 hilda kernel: i2c_dev: i2c /dev entries driver
Dec 03 09:01:56 hilda systemd[1]: Mounting FUSE Control File System...
Dec 03 09:01:56 hilda systemd[1]: Mounting Kernel Configuration File System...
Dec 03 09:01:56 hilda systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Dec 03 09:01:56 hilda systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec 03 09:01:56 hilda systemd[1]: Finished Load Kernel Modules.
Dec 03 09:01:56 hilda systemd[1]: Finished Remount Root and Kernel File Systems.
Dec 03 09:01:56 hilda systemd[1]: Finished Virtual Console Setup.
Dec 03 09:01:56 hilda systemd[1]: Mounted FUSE Control File System.
Dec 03 09:01:56 hilda systemd[1]: Activating swap /swapfile...
Dec 03 09:01:56 hilda systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
Dec 03 09:01:56 hilda systemd[1]: Starting Load/Save OS Random Seed...
Dec 03 09:01:56 hilda systemd[1]: Starting Apply Kernel Variables...
Dec 03 09:01:56 hilda systemd[1]: Mounted Kernel Configuration File System.
Dec 03 09:01:56 hilda systemd[1]: Starting User Database Manager...
Dec 03 09:01:56 hilda kernel: Adding 20920316k swap on /swapfile.  Priority:-2 extents:167 across:48857088k SS
Dec 03 09:01:56 hilda systemd[1]: Activated swap /swapfile.
Dec 03 09:01:56 hilda systemd[1]: Reached target Swaps.
Dec 03 09:01:56 hilda systemd-journald[272]: Journal started
Dec 03 09:01:56 hilda systemd-journald[272]: Runtime Journal (/run/log/journal/da9e8f5f671143a3b61e744391317df6) is 8M, max 791.8M, 783.8M free.
Dec 03 09:01:56 hilda systemd[1]: Finished Load/Save OS Random Seed.
Dec 03 09:01:56 hilda systemd[1]: Finished Apply Kernel Variables.
Dec 03 09:01:55 hilda systemd-modules-load[274]: Inserted module 'crypto_user'
Dec 03 09:01:55 hilda systemd-vconsole-setup[281]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Dec 03 09:01:55 hilda systemd-modules-load[274]: Inserted module 'i2c_dev'
Dec 03 09:01:55 hilda systemd-modules-load[274]: Inserted module 'uinput'
Dec 03 09:01:56 hilda systemd[1]: Starting CLI Netfilter Manager...
Dec 03 09:01:56 hilda systemd[1]: Started Journal Service.
Dec 03 09:01:56 hilda mullvad-daemon[271]: [2024-12-03 09:01:55.983][mullvad_daemon::version][INFO] Starting mullvad-daemon - 2024.7 2024-10-30
Dec 03 09:01:56 hilda mullvad-daemon[271]: [2024-12-03 09:01:55.984][mullvad_daemon::settings][INFO] Loading settings from /etc/mullvad-vpn/settings.json
Dec 03 09:01:56 hilda mullvad-daemon[271]: [2024-12-03 09:01:55.998][mullvad_daemon::early_boot_firewall][INFO] Applying firewall policy Blocked. Allowing LAN. Allowing endpoint: none
Dec 03 09:01:56 hilda mullvad-daemon[271]: [2024-12-03 09:01:55.998][talpid_core::firewall][INFO] Applying firewall policy: Blocked. Allowing LAN. Allowing endpoint: none
Dec 03 09:01:56 hilda systemd[1]: Starting Flush Journal to Persistent Storage...
Dec 03 09:01:56 hilda systemd-journald[272]: Time spent on flushing to /var/log/journal/da9e8f5f671143a3b61e744391317df6 is 10.394ms for 711 entries.
Dec 03 09:01:56 hilda systemd-journald[272]: System Journal (/var/log/journal/da9e8f5f671143a3b61e744391317df6) is 44.1M, max 50M, 5.8M free.
Dec 03 09:01:56 hilda systemd-journald[272]: Received client request to flush runtime journal.
Dec 03 09:01:56 hilda systemd[1]: Started User Database Manager.
Dec 03 09:01:56 hilda systemd[1]: Finished Flush Journal to Persistent Storage.
Dec 03 09:01:56 hilda systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
Dec 03 09:01:56 hilda systemd[1]: Starting Create System Users...
Dec 03 09:01:56 hilda systemd[1]: Finished Coldplug All udev Devices.
Dec 03 09:01:56 hilda systemd[1]: Finished Create System Users.
Dec 03 09:01:56 hilda systemd[1]: Starting Create Static Device Nodes in /dev...
Dec 03 09:01:56 hilda systemd[1]: Finished Create Static Device Nodes in /dev.
Dec 03 09:01:56 hilda systemd[1]: Reached target Preparation for Local File Systems.
Dec 03 09:01:56 hilda systemd[1]: Starting Rule-based Manager for Device Events and Files...
Dec 03 09:01:56 hilda systemd[1]: Finished CLI Netfilter Manager.
Dec 03 09:01:56 hilda systemd[1]: mullvad-early-boot-blocking.service: Deactivated successfully.
Dec 03 09:01:56 hilda systemd[1]: Finished Mullvad early boot network blocker.
Dec 03 09:01:56 hilda systemd[1]: Started Rule-based Manager for Device Events and Files.
Dec 03 09:01:56 hilda systemd[1]: Starting Show Plymouth Boot Screen...
Dec 03 09:01:56 hilda systemd[1]: Started Show Plymouth Boot Screen.
Dec 03 09:01:56 hilda systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
Dec 03 09:01:56 hilda systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Dec 03 09:01:56 hilda systemd[1]: Reached target Local Encrypted Volumes.
Dec 03 09:01:56 hilda systemd[1]: Found device NVME 512GB SSD 1.
Dec 03 09:01:56 hilda systemd[1]: Starting File System Check on /dev/disk/by-uuid/42A8-45AC...
Dec 03 09:01:56 hilda mtp-probe[456]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2"
Dec 03 09:01:56 hilda mtp-probe[456]: bus: 1, device: 4 was not an MTP device
Dec 03 09:01:56 hilda mtp-probe[457]: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1"
Dec 03 09:01:56 hilda mtp-probe[457]: bus: 1, device: 6 was not an MTP device
Dec 03 09:01:56 hilda kernel: mousedev: PS/2 mouse device common for all mice
Dec 03 09:01:56 hilda systemd-fsck[460]: fsck.fat 4.2 (2021-01-31)
Dec 03 09:01:56 hilda systemd-fsck[460]: /dev/nvme0n1p1: 5 files, 74/76643 clusters
Dec 03 09:01:56 hilda systemd[1]: Finished File System Check on /dev/disk/by-uuid/42A8-45AC.
Dec 03 09:01:56 hilda kernel: input: Intel HID events as /devices/platform/INTC1051:00/input/input14
Dec 03 09:01:56 hilda kernel: intel_pmc_core INT33A1:00:  initialized
Dec 03 09:01:56 hilda kernel: EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
Dec 03 09:01:56 hilda kernel: EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
Dec 03 09:01:56 hilda kernel: EDAC igen6 MC0: ADDR 0x7fffffffe0
Dec 03 09:01:56 hilda kernel: EDAC igen6: v2.5.1
Dec 03 09:01:56 hilda systemd[1]: Created slice Slice /system/systemd-backlight.
Dec 03 09:01:56 hilda systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Dec 03 09:01:56 hilda mtp-probe[477]: checking bus 1, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6.2"
Dec 03 09:01:56 hilda mtp-probe[476]: checking bus 1, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6.1"
Dec 03 09:01:56 hilda mtp-probe[477]: bus: 1, device: 10 was not an MTP device
Dec 03 09:01:56 hilda mtp-probe[479]: checking bus 1, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2"
Dec 03 09:01:56 hilda mtp-probe[476]: bus: 1, device: 9 was not an MTP device
Dec 03 09:01:56 hilda systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Dec 03 09:01:56 hilda kernel: input: PC Speaker as /devices/platform/pcspkr/input/input15
Dec 03 09:01:56 hilda kernel: mc: Linux media interface: v0.10
Dec 03 09:01:56 hilda kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
Dec 03 09:01:56 hilda kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
Dec 03 09:01:56 hilda kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
Dec 03 09:01:56 hilda kernel: Creating 1 MTD partitions on "0000:00:1f.5":
Dec 03 09:01:56 hilda kernel: 0x000000000000-0x000001000000 : "BIOS"
Dec 03 09:01:56 hilda mtp-probe[479]: bus: 1, device: 8 was not an MTP device
Dec 03 09:01:56 hilda kernel: kxcjk1013 i2c-KIOX000A:00: supply vdd not found, using dummy regulator
Dec 03 09:01:56 hilda kernel: kxcjk1013 i2c-KIOX000A:00: supply vddio not found, using dummy regulator
Dec 03 09:01:56 hilda kernel: Bluetooth: Core ver 2.22
Dec 03 09:01:56 hilda kernel: NET: Registered PF_BLUETOOTH protocol family
Dec 03 09:01:56 hilda kernel: Bluetooth: HCI device and connection manager initialized
Dec 03 09:01:56 hilda kernel: Bluetooth: HCI socket layer initialized
Dec 03 09:01:56 hilda kernel: Bluetooth: L2CAP socket layer initialized
Dec 03 09:01:56 hilda kernel: Bluetooth: SCO socket layer initialized
Dec 03 09:01:56 hilda kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
Dec 03 09:01:56 hilda systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Dec 03 09:01:56 hilda systemd[1]: Stopped Virtual Console Setup.
Dec 03 09:01:56 hilda systemd[1]: Stopping Virtual Console Setup...
Dec 03 09:01:56 hilda kernel: idma64 idma64.2: Found Intel integrated DMA 64-bit
Dec 03 09:01:56 hilda kernel: videodev: Linux video capture interface: v2.00
Dec 03 09:01:56 hilda kernel: simple-framebuffer simple-framebuffer.0: [drm] could not acquire memory region [mem 0x90000000-0x90545fff flags 0x80000200]
Dec 03 09:01:56 hilda kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Dec 03 09:01:56 hilda kernel: simple-framebuffer simple-framebuffer.0: [drm] fb1: simpledrmdrmfb frame buffer device
Dec 03 09:01:56 hilda systemd-vconsole-setup[492]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Dec 03 09:01:56 hilda kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Dec 03 09:01:56 hilda kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Dec 03 09:01:56 hilda kernel: input: GXTP7386:00 27C6:0111 as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input16
Dec 03 09:01:56 hilda kernel: input: GXTP7386:00 27C6:0111 Stylus as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input17
Dec 03 09:01:56 hilda kernel: input: GXTP7386:00 27C6:0111 UNKNOWN as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input18
Dec 03 09:01:56 hilda kernel: input: GXTP7386:00 27C6:0111 Keyboard as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input19
Dec 03 09:01:56 hilda kernel: hid-multitouch 0018:27C6:0111.0004: input,hidraw3: I2C HID v1.00 Keyboard [GXTP7386:00 27C6:0111] on i2c-GXTP7386:00
Dec 03 09:01:56 hilda kernel: RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
Dec 03 09:01:56 hilda kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Dec 03 09:01:56 hilda kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
Dec 03 09:01:56 hilda kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
Dec 03 09:01:56 hilda kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
Dec 03 09:01:56 hilda systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 03 09:01:56 hilda kernel: cryptd: max_cpu_qlen set to 1000
Dec 03 09:01:56 hilda kernel: iTCO_vendor_support: vendor-support=0
Dec 03 09:01:56 hilda kernel: AES CTR mode by8 optimization enabled
Dec 03 09:01:56 hilda kernel: Intel(R) Wireless WiFi driver for Linux
Dec 03 09:01:56 hilda systemd[1]: Mounting /boot/efi...
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Detected crf-id 0x1300202, cnv-id 0x80400 wfpm id 0x80000030
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: PCI dev 54f0/0034, rev=0x370, rfid=0x105110
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-89.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-88.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-87.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-86.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-85.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-84.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-83.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-82.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-81.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-80.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-79.ucode failed with error -2
Dec 03 09:01:56 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-78.ucode failed with error -2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: loaded firmware version 77.f92b5fed.0 so-a0-jf-b0-77.ucode op_mode iwlmvm
Dec 03 09:01:57 hilda kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
Dec 03 09:01:57 hilda kernel: usb 1-6.1: Found UVC 1.00 device USB2.0 camera (0bda:5830)
Dec 03 09:01:57 hilda kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Dec 03 09:01:57 hilda kernel: pps_core: LinuxPPS API ver. 1 registered
Dec 03 09:01:57 hilda kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Dec 03 09:01:57 hilda kernel: PTP clock support registered
Dec 03 09:01:57 hilda kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Dec 03 09:01:57 hilda kernel: dw-apb-uart.2: ttyS4 at MMIO 0xfe03e000 (irq = 20, base_baud = 114825) is a 16550A
Dec 03 09:01:57 hilda kernel: usb 1-6.2: Found UVC 1.00 device USB 2.0 Camera (1bcf:284d)
Dec 03 09:01:57 hilda kernel: usbcore: registered new interface driver btusb
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Device revision is 2
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Secure boot is enabled
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: OTP lock is enabled
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: API lock is enabled
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Debug lock is disabled
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: No support for _PRR ACPI method
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0040-2120.sfi
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Boot Address: 0x100800
Dec 03 09:01:57 hilda kernel: Bluetooth: hci0: Firmware Version: 151-5.24
Dec 03 09:01:57 hilda systemd[1]: Mounting Temporary Directory /tmp...
Dec 03 09:01:57 hilda systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
Dec 03 09:01:57 hilda systemd[1]: Mounted Temporary Directory /tmp.
Dec 03 09:01:57 hilda systemd[1]: Starting Load/Save RF Kill Switch Status...
Dec 03 09:01:57 hilda systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
Dec 03 09:01:57 hilda systemd[1]: Starting Load Kernel Module dm_mod...
Dec 03 09:01:57 hilda systemd[1]: Starting Load Kernel Module loop...
Dec 03 09:01:57 hilda systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Dec 03 09:01:57 hilda systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Dec 03 09:01:57 hilda systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
Dec 03 09:01:57 hilda systemd[1]: Started Load/Save RF Kill Switch Status.
Dec 03 09:01:57 hilda systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Dec 03 09:01:57 hilda systemd[1]: Finished Load Kernel Module dm_mod.
Dec 03 09:01:57 hilda systemd[1]: modprobe@loop.service: Deactivated successfully.
Dec 03 09:01:57 hilda systemd[1]: Finished Load Kernel Module loop.
Dec 03 09:01:57 hilda systemd[1]: Mounted /boot/efi.
Dec 03 09:01:57 hilda systemd[1]: Reached target Local File Systems.
Dec 03 09:01:57 hilda systemd[1]: Listening on Boot Entries Service Socket.
Dec 03 09:01:57 hilda systemd[1]: Listening on System Extension Image Management.
Dec 03 09:01:57 hilda systemd[1]: Starting Rebuild Dynamic Linker Cache...
Dec 03 09:01:57 hilda systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Dec 03 09:01:57 hilda systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
Dec 03 09:01:57 hilda systemd[1]: Update Boot Loader Random Seed was skipped because no trigger condition checks were met.
Dec 03 09:01:57 hilda kernel: usbcore: registered new interface driver uvcvideo
Dec 03 09:01:57 hilda kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=2 (0x14/0x19/0x0/0x0/0x0) type:speaker
Dec 03 09:01:57 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Dec 03 09:01:57 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
Dec 03 09:01:57 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
Dec 03 09:01:57 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
Dec 03 09:01:57 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
Dec 03 09:01:57 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
Dec 03 09:01:57 hilda systemd[1]: Starting Create System Files and Directories...
Dec 03 09:01:57 hilda systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
Dec 03 09:01:57 hilda systemd[1]: Received SIGRTMIN+20 from PID 185 (plymouthd).
Dec 03 09:01:57 hilda kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
Dec 03 09:01:57 hilda kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
Dec 03 09:01:57 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
Dec 03 09:01:57 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
Dec 03 09:01:57 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
Dec 03 09:01:57 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: Detected RF JF, rfid=0x105110
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Dec 03 09:01:57 hilda systemd[1]: Finished Create System Files and Directories.
Dec 03 09:01:57 hilda systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Dec 03 09:01:57 hilda systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Dec 03 09:01:57 hilda systemd[1]: Starting Rebuild Journal Catalog...
Dec 03 09:01:57 hilda systemd[1]: Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
Dec 03 09:01:57 hilda systemd[1]: Starting Network Time Synchronization...
Dec 03 09:01:57 hilda systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: base HW address: 8c:e9:ee:90:fc:2c
Dec 03 09:01:57 hilda systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Dec 03 09:01:57 hilda systemd[1]: Finished Rebuild Journal Catalog.
Dec 03 09:01:57 hilda kernel: intel_tcc_cooling: Programmable TCC Offset detected
Dec 03 09:01:57 hilda systemd[1]: Started Network Time Synchronization.
Dec 03 09:01:57 hilda systemd[1]: Reached target System Time Set.
Dec 03 09:01:57 hilda kernel: intel_rapl_msr: PL4 support detected.
Dec 03 09:01:57 hilda kernel: intel_rapl_common: Found RAPL domain package
Dec 03 09:01:57 hilda kernel: intel_rapl_common: Found RAPL domain core
Dec 03 09:01:57 hilda kernel: intel_rapl_common: Found RAPL domain uncore
Dec 03 09:01:57 hilda kernel: intel_rapl_common: Found RAPL domain psys
Dec 03 09:01:57 hilda systemd[1]: Finished Rebuild Dynamic Linker Cache.
Dec 03 09:01:57 hilda systemd[1]: Starting Update is Completed...
Dec 03 09:01:57 hilda systemd[1]: Finished Update is Completed.
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: timeout waiting for FW reset ACK (inta_hw=0x0)
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-jf-b0-77.ucode
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00A002F0 | trm_hw_status0
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x004D2A06 | branchlink2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | data1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x01000000 | data2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | beacon time
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x0001B7D6 | tsf low
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00026E12 | time gp2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x0000004D | uCode version major
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0xF92B5FED | uCode version minor
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000370 | hw version
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00480002 | board version
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x802DFF00 | hcmd
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00020000 | isr0
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x58F00002 | isr2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00C0000C | isr3
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | wait_event
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000028 | flow_handler
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data2
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac major
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac minor
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | frame pointer
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | stack pointer
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00005032 | IML/ROM data1
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: Fseq Registers:
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x20000000 | FSEQ_ERROR_CODE
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x80330000 | FSEQ_TOP_INIT_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00010009 | FSEQ_CNVIO_INIT_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x131B45E6 | FSEQ_TOP_CONTENT_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_PREV_CNVIO_INIT_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00330000 | FSEQ_WIFI_FSEQ_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x72FCAA6F | FSEQ_BT_FSEQ_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: 0x00000122 | FSEQ_CLASS_TP_VERSION
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x8047e450
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
Dec 03 09:01:57 hilda kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
Dec 03 09:01:57 hilda systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Dec 03 09:01:58 hilda kernel: iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Waiting for firmware download to complete
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Firmware loaded in 1531002 usecs
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Waiting for device to boot
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Device booted in 16887 usecs
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-2120.ddc
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Firmware timestamp 2024.5 buildtype 1 build 151
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Firmware SHA1: 0x00000000
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Fseq status: Success (0x00)
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Fseq executed: 00.00.02.36
Dec 03 09:01:58 hilda kernel: Bluetooth: hci0: Fseq BT Top: 00.00.02.36
Dec 03 09:02:03 hilda systemd[1]: systemd-rfkill.service: Deactivated successfully.
Dec 03 09:03:25 hilda systemd[1]: dev-tpmrm0.device: Job dev-tpmrm0.device/start timed out.
Dec 03 09:03:25 hilda systemd[1]: Timed out waiting for device /dev/tpmrm0.
Dec 03 09:03:25 hilda systemd[1]: dev-tpmrm0.device: Job dev-tpmrm0.device/start failed with result 'timeout'.
Dec 03 09:03:25 hilda systemd[1]: Reached target Trusted Platform Module.
Dec 03 09:03:25 hilda systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:03:25 hilda systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:03:25 hilda systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:03:25 hilda systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:03:25 hilda systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Dec 03 09:03:25 hilda systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:03:25 hilda systemd[1]: Reached target System Initialization.
Dec 03 09:03:25 hilda systemd[1]: Started CUPS Scheduler.
Dec 03 09:03:25 hilda systemd[1]: Started Refresh existing PGP keys of archlinux-keyring regularly.
Dec 03 09:03:25 hilda systemd[1]: Started Daily rotation of log files.
Dec 03 09:03:25 hilda systemd[1]: Started Daily man-db regeneration.
Dec 03 09:03:25 hilda systemd[1]: Started Monthly clean packages cache.
Dec 03 09:03:25 hilda systemd[1]: Started Generate mirrorlist weekly.
Dec 03 09:03:25 hilda systemd[1]: Started Daily verification of password and group files.
Dec 03 09:03:25 hilda systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec 03 09:03:25 hilda systemd[1]: Reached target Path Units.
Dec 03 09:03:25 hilda systemd[1]: Reached target Timer Units.
Dec 03 09:03:25 hilda systemd[1]: Listening on CUPS Scheduler.
Dec 03 09:03:25 hilda systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec 03 09:03:25 hilda systemd[1]: Listening on GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Dec 03 09:03:25 hilda systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Dec 03 09:03:25 hilda systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Dec 03 09:03:25 hilda systemd[1]: Listening on GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Dec 03 09:03:25 hilda systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Dec 03 09:03:25 hilda systemd[1]: Listening on GnuPG public key management service for /etc/pacman.d/gnupg.
Dec 03 09:03:25 hilda systemd[1]: Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Dec 03 09:03:25 hilda systemd[1]: Listening on Hostname Service Socket.
Dec 03 09:03:25 hilda systemd[1]: Reached target Socket Units.
Dec 03 09:03:25 hilda systemd[1]: Starting D-Bus System Message Bus...
Dec 03 09:03:25 hilda systemd[1]: TPM PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:03:26 hilda systemd[1]: Started D-Bus System Message Bus.
Dec 03 09:03:26 hilda systemd[1]: Reached target Basic System.
Dec 03 09:03:26 hilda systemd[1]: Starting Network Manager...
Dec 03 09:03:26 hilda systemd[1]: Starting Save/Restore Sound Card State...
Dec 03 09:03:26 hilda systemd[1]: Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
Dec 03 09:03:26 hilda systemd[1]: Starting Bluetooth service...
Dec 03 09:03:26 hilda dbus-broker-launch[573]: Ready
Dec 03 09:03:26 hilda systemd[1]: Started [Mount SMB Shares].
Dec 03 09:03:26 hilda systemd[1]: Starting Authorization Manager...
Dec 03 09:03:26 hilda systemd[1]: SSH Key Generation was skipped because no trigger condition checks were met.
Dec 03 09:03:26 hilda systemd[1]: Starting User Login Management...
Dec 03 09:03:26 hilda systemd[1]: TPM PCR Barrier (User) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:03:26 hilda systemd[1]: Finished Save/Restore Sound Card State.
Dec 03 09:03:26 hilda systemd[1]: Reached target Sound Card.
Dec 03 09:03:26 hilda mount-smb-shares[582]: ping: connect: Network is unreachable
Dec 03 09:03:26 hilda mount-smb-shares[578]: ..........
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.1364] NetworkManager (version 1.50.0-1) is starting... (boot:bfecab3a-394e-4fc0-b694-3772e147f0e5)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.1365] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Dec 03 09:03:26 hilda bluetoothd[577]: Bluetooth daemon 5.79
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.1500] manager[0x5b3c1d6dbf10]: monitoring kernel firmware directory '/lib/firmware'.
Dec 03 09:03:26 hilda systemd[1]: Started Bluetooth service.
Dec 03 09:03:26 hilda systemd[1]: Reached target Bluetooth Support.
Dec 03 09:03:26 hilda bluetoothd[577]: Starting SDP server
Dec 03 09:03:26 hilda systemd[1]: Starting Hostname Service...
Dec 03 09:03:26 hilda systemd-logind[580]: New seat seat0.
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support bap plugin
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support bass plugin
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support mcp plugin
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support vcp plugin
Dec 03 09:03:26 hilda bluetoothd[577]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support micp plugin
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support ccp plugin
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support csip plugin
Dec 03 09:03:26 hilda bluetoothd[577]: src/plugin.c:init_plugin() System does not support asha plugin
Dec 03 09:03:26 hilda bluetoothd[577]: Bluetooth management interface 1.23 initialized
Dec 03 09:03:26 hilda bluetoothd[577]: Battery Provider Manager created
Dec 03 09:03:26 hilda kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Dec 03 09:03:26 hilda kernel: Bluetooth: BNEP filters: protocol multicast
Dec 03 09:03:26 hilda kernel: Bluetooth: BNEP socket layer initialized
Dec 03 09:03:26 hilda kernel: Bluetooth: MGMT ver 1.23
Dec 03 09:03:26 hilda systemd-logind[580]: Watching system buttons on /dev/input/event1 (Power Button)
Dec 03 09:03:26 hilda kernel: NET: Registered PF_ALG protocol family
Dec 03 09:03:26 hilda systemd-logind[580]: Watching system buttons on /dev/input/event0 (Lid Switch)
Dec 03 09:03:26 hilda systemd-logind[580]: Watching system buttons on /dev/input/event5 (HID 1018:1006)
Dec 03 09:03:26 hilda systemd-logind[580]: Watching system buttons on /dev/input/event8 (HID 1018:1006 System Control)
Dec 03 09:03:26 hilda systemd-logind[580]: Watching system buttons on /dev/input/event9 (HID 1018:1006 Consumer Control)
Dec 03 09:03:26 hilda polkitd[579]: Started polkitd version 125
Dec 03 09:03:26 hilda systemd-logind[580]: Watching system buttons on /dev/input/event10 (Intel HID events)
Dec 03 09:03:26 hilda systemd-logind[580]: Watching system buttons on /dev/input/event2 (AT Translated Set 2 keyboard)
Dec 03 09:03:26 hilda systemd[1]: Started User Login Management.
Dec 03 09:03:26 hilda systemd[1]: Started Authorization Manager.
Dec 03 09:03:26 hilda systemd[1]: Starting Modem Manager...
Dec 03 09:03:26 hilda bluetoothd[577]: Failed to set mode: Failed (0x03)
Dec 03 09:03:26 hilda systemd[1]: Started Hostname Service.
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2236] hostname: hostname: using hostnamed
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2236] hostname: static hostname changed from (none) to "hilda"
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2241] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2252] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/ieee80211/phy0/rfkill1) (driver iwlwifi)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2253] manager[0x5b3c1d6dbf10]: rfkill: Wi-Fi hardware radio set enabled
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2253] manager[0x5b3c1d6dbf10]: rfkill: WWAN hardware radio set enabled
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2381] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-bluetooth.so)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2407] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-ovs.so)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2414] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-adsl.so)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2430] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-wwan.so)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2443] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-wifi.so)
Dec 03 09:03:26 hilda ModemManager[631]: <msg> ModemManager (version 1.22.0-1) starting in system bus...
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2659] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-team.so)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2662] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2662] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2663] manager: Networking is enabled by state file
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2669] settings: Loaded settings plugin: keyfile (internal)
Dec 03 09:03:26 hilda systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2747] dhcp: init: Using DHCP client 'internal'
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2751] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2766] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', managed-type: 'external')
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2774] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', managed-type: 'external')
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2780] device (lo): Activation: starting connection 'lo' (6941216a-3712-4a9a-bf6b-75e82178f08c)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2782] device (wlp0s20f3): driver supports Access Point (AP) mode
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2788] manager: (wlp0s20f3): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/2)
Dec 03 09:03:26 hilda NetworkManager[575]: <info>  [1733180606.2791] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Dec 03 09:03:26 hilda kernel: NET: Registered PF_QIPCRTR protocol family
Dec 03 09:03:26 hilda systemd[1]: Started Modem Manager.
Dec 03 09:03:26 hilda systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: timeout waiting for FW reset ACK (inta_hw=0x0)
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-jf-b0-77.ucode
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x000002F0 | trm_hw_status0
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x004D2A06 | branchlink2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | data1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x01000000 | data2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | beacon time
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x000255CD | tsf low
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x0003092F | time gp2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x0000004D | uCode version major
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0xF92B5FED | uCode version minor
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000370 | hw version
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00480002 | board version
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x8059FF00 | hcmd
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00020000 | isr0
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x48F04002 | isr2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00C3000C | isr3
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x001B0148 | last cmd Id
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | wait_event
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000018 | lmpm_pmg_sel
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00001840 | flow_handler
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data2
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac major
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac minor
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | frame pointer
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | stack pointer
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00004F71 | IML/ROM data1
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: Fseq Registers:
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x80330000 | FSEQ_TOP_INIT_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00010009 | FSEQ_CNVIO_INIT_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x131B45E6 | FSEQ_TOP_CONTENT_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00010009 | FSEQ_PREV_CNVIO_INIT_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00330000 | FSEQ_WIFI_FSEQ_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00330000 | FSEQ_BT_FSEQ_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: 0x00000122 | FSEQ_CLASS_TP_VERSION
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x8047e450
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
Dec 03 09:03:26 hilda kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.1731] device (wlp0s20f3): set-hw-addr: set MAC address to 72:75:63:6D:91:01 (scanning)
Dec 03 09:03:27 hilda kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Dec 03 09:03:27 hilda kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Dec 03 09:03:27 hilda kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Dec 03 09:03:27 hilda kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Dec 03 09:03:27 hilda kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3540] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Dec 03 09:03:27 hilda systemd[1]: Started Network Manager.
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3565] ovsdb: disconnected from ovsdb
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3566] device (lo): state change: disconnected -> prepare (reason 'none', managed-type: 'external')
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3568] device (lo): state change: prepare -> config (reason 'none', managed-type: 'external')
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3571] device (lo): state change: config -> ip-config (reason 'none', managed-type: 'external')
Dec 03 09:03:27 hilda systemd[1]: Started Mullvad VPN daemon.
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3575] device (lo): state change: ip-config -> ip-check (reason 'none', managed-type: 'external')
Dec 03 09:03:27 hilda systemd[1]: Starting WPA supplicant...
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3586] modem-manager: ModemManager available
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3588] device (lo): state change: ip-check -> secondaries (reason 'none', managed-type: 'external')
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3589] device (lo): state change: secondaries -> activated (reason 'none', managed-type: 'external')
Dec 03 09:03:27 hilda NetworkManager[575]: <info>  [1733180607.3592] device (lo): Activation: successful, device activated.
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_daemon::version][INFO] Starting mullvad-daemon - 2024.7 2024-10-30
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_daemon][INFO] Logging to /var/log/mullvad-vpn
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_daemon::management_interface][INFO] Management interface listening on /var/run/mullvad-vpn
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_api::address_cache][DEBUG] Loading API addresses from /var/cache/mullvad-vpn/api-ip-address.txt
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_api::address_cache][DEBUG] Using API address: 45.83.223.196:443
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_api::availability][DEBUG] Suspending API requests
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_daemon::settings][INFO] Loading settings from /etc/mullvad-vpn/settings.json
Dec 03 09:03:27 hilda mullvad-daemon[647]: [mullvad_relay_selector::relay_selector::parsed_relays][DEBUG] Reading relays from /var/cache/mullvad-vpn/relays.json
Dec 03 09:03:27 hilda systemd[1]: Started WPA supplicant.
Dec 03 09:03:27 hilda systemd[1]: Reached target Network.
Dec 03 09:03:27 hilda wpa_supplicant[648]: Successfully initialized wpa_supplicant
-- Boot df8d29c61854485f88c690122da75dcf --
Dec 03 09:05:37 hilda kernel: microcode: updated early: 0x17 -> 0x1a, date = 2024-03-25
First off, clearly with kernel 6.6 the desktop is loading correctly. I’ll have to dod a diff on thesee to see if I can spot the point where it all goes wrong.
I’ll also pass this on to Starlabs.
They both get to this point:
6.6 kernel
6.12 kernel
Dec 03 09:07:08 hilda systemd[1]: Started WPA supplicant.
Dec 03 09:07:08 hilda wpa_supplicant[638]: Successfully initialized wpa_supplicant
Dec 03 09:07:08 hilda systemd[1]: Reached target Network.
After that 6.12 apparently stops:
while 6.6 carries on loading
Does the microcode get loaded also on 6.6 or only with 6.12? You can try this:
sudo pacman -R intel-ucode amd-ucode
sudo mkinitcpio -P
And reboot …
In 6.6 the only reference I see is at Line 447
Dec 03 09:05:37 hilda kernel: microcode: Microcode Update Driver: v2.2.
As soon as I get access to the device, I try your suggestion.
Here’s the 6.6 log up to the point where 6.12 fails
Dec 03 09:05:37 hilda kernel: Linux version 6.6.63-1-MANJARO (builduser@fv-az701-119) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Sat Nov 23 02:15:34 UTC 2024
Dec 03 09:05:37 hilda kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=29705f46-8be2-4ab2-a49e-62fea65f9bd3 rw quiet splash udev.log_priority=3 resume=
Dec 03 09:05:37 hilda kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Dec 03 09:05:37 hilda kernel: BIOS-provided physical RAM map:
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000000fff] reserved
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x0000000000001000-0x000000000009ffff] usable
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x0000000000100000-0x000000007663bfff] usable
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x000000007663c000-0x000000007683bfff] reserved
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x000000007683c000-0x000000007684afff] usable
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x000000007684b000-0x0000000076860fff] ACPI data
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x0000000076861000-0x0000000076861fff] usable
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x0000000076862000-0x00000000803fffff] reserved
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x00000000ff630000-0x00000000ff66ffff] reserved
Dec 03 09:05:37 hilda kernel: BIOS-e820: [mem 0x0000000100000000-0x000000047fbfffff] usable
Dec 03 09:05:37 hilda kernel: NX (Execute Disable) protection: active
Dec 03 09:05:37 hilda kernel: APIC: Static calls initialized
Dec 03 09:05:37 hilda kernel: efi: EFI v2.7 by EDK II
Dec 03 09:05:37 hilda kernel: efi: SMBIOS=0x76823000 SMBIOS 3.0=0x76821000 ACPI=0x76860000 ACPI 2.0=0x76860014 MEMATTR=0x73bd8198 INITRD=0x73bc2a98
Dec 03 09:05:37 hilda kernel: efi: Remove mem87: MMIO range=[0xff630000-0xff66ffff] (0MB) from e820 map
Dec 03 09:05:37 hilda kernel: e820: remove [mem 0xff630000-0xff66ffff] reserved
Dec 03 09:05:37 hilda kernel: SMBIOS 3.0.0 present.
Dec 03 09:05:37 hilda kernel: DMI: Star Labs StarLite/StarLite, BIOS 24.06 07/05/2024
Dec 03 09:05:37 hilda kernel: tsc: Detected 1000.000 MHz processor
Dec 03 09:05:37 hilda kernel: tsc: Detected 998.400 MHz TSC
Dec 03 09:05:37 hilda kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 03 09:05:37 hilda kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 03 09:05:37 hilda kernel: last_pfn = 0x47fc00 max_arch_pfn = 0x400000000
Dec 03 09:05:37 hilda kernel: MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
Dec 03 09:05:37 hilda kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Dec 03 09:05:37 hilda kernel: last_pfn = 0x76862 max_arch_pfn = 0x400000000
Dec 03 09:05:37 hilda kernel: Using GB pages for direct mapping
Dec 03 09:05:37 hilda kernel: Incomplete global flushes, disabling PCID
Dec 03 09:05:37 hilda kernel: Secure boot disabled
Dec 03 09:05:37 hilda kernel: RAMDISK: [mem 0x6dc60000-0x6f7b6fff]
Dec 03 09:05:37 hilda kernel: ACPI: Early table checksum verification disabled
Dec 03 09:05:37 hilda kernel: ACPI: RSDP 0x0000000076860014 000024 (v02 COREv4)
Dec 03 09:05:37 hilda kernel: ACPI: XSDT 0x000000007685F0E8 000074 (v01 COREv4 COREBOOT 00000000      01000013)
Dec 03 09:05:37 hilda kernel: ACPI: FACP 0x000000007685E000 000114 (v06 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: DSDT 0x0000000076858000 005248 (v02 COREv4 COREBOOT 20220930 INTL 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: FACS 0x000000007687A240 000040
Dec 03 09:05:37 hilda kernel: ACPI: SSDT 0x0000000076855000 00229F (v02 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: MCFG 0x0000000076854000 00003C (v01 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: TPM2 0x0000000076853000 00004C (v04 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: LPIT 0x0000000076852000 000094 (v00 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: APIC 0x0000000076851000 000072 (v03 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: DMAR 0x0000000076850000 000088 (v01 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: DBG2 0x000000007684F000 000061 (v00 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: HPET 0x000000007684E000 000038 (v01 COREv4 COREBOOT 00000000 CORE 20230628)
Dec 03 09:05:37 hilda kernel: ACPI: BGRT 0x000000007684D000 000038 (v01 INTEL  EDK2     00000002      01000013)
Dec 03 09:05:37 hilda kernel: ACPI: Reserving FACP table memory at [mem 0x7685e000-0x7685e113]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving DSDT table memory at [mem 0x76858000-0x7685d247]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving FACS table memory at [mem 0x7687a240-0x7687a27f]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving SSDT table memory at [mem 0x76855000-0x7685729e]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving MCFG table memory at [mem 0x76854000-0x7685403b]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving TPM2 table memory at [mem 0x76853000-0x7685304b]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving LPIT table memory at [mem 0x76852000-0x76852093]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving APIC table memory at [mem 0x76851000-0x76851071]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving DMAR table memory at [mem 0x76850000-0x76850087]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving DBG2 table memory at [mem 0x7684f000-0x7684f060]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving HPET table memory at [mem 0x7684e000-0x7684e037]
Dec 03 09:05:37 hilda kernel: ACPI: Reserving BGRT table memory at [mem 0x7684d000-0x7684d037]
Dec 03 09:05:37 hilda kernel: No NUMA configuration found
Dec 03 09:05:37 hilda kernel: Faking a node at [mem 0x0000000000000000-0x000000047fbfffff]
Dec 03 09:05:37 hilda kernel: NODE_DATA(0) allocated [mem 0x47fbfb000-0x47fbfffff]
Dec 03 09:05:37 hilda kernel: Zone ranges:
Dec 03 09:05:37 hilda kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Dec 03 09:05:37 hilda kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Dec 03 09:05:37 hilda kernel:   Normal   [mem 0x0000000100000000-0x000000047fbfffff]
Dec 03 09:05:37 hilda kernel:   Device   empty
Dec 03 09:05:37 hilda kernel: Movable zone start for each node
Dec 03 09:05:37 hilda kernel: Early memory node ranges
Dec 03 09:05:37 hilda kernel:   node   0: [mem 0x0000000000001000-0x000000000009ffff]
Dec 03 09:05:37 hilda kernel:   node   0: [mem 0x0000000000100000-0x000000007663bfff]
Dec 03 09:05:37 hilda kernel:   node   0: [mem 0x000000007683c000-0x000000007684afff]
Dec 03 09:05:37 hilda kernel:   node   0: [mem 0x0000000076861000-0x0000000076861fff]
Dec 03 09:05:37 hilda kernel:   node   0: [mem 0x0000000100000000-0x000000047fbfffff]
Dec 03 09:05:37 hilda kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000047fbfffff]
Dec 03 09:05:37 hilda kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Dec 03 09:05:37 hilda kernel: On node 0, zone DMA: 96 pages in unavailable ranges
Dec 03 09:05:37 hilda kernel: On node 0, zone DMA32: 512 pages in unavailable ranges
Dec 03 09:05:37 hilda kernel: On node 0, zone DMA32: 22 pages in unavailable ranges
Dec 03 09:05:37 hilda kernel: On node 0, zone Normal: 6046 pages in unavailable ranges
Dec 03 09:05:37 hilda kernel: On node 0, zone Normal: 1024 pages in unavailable ranges
Dec 03 09:05:37 hilda kernel: Reserving Intel graphics memory at [mem 0x7c800000-0x803fffff]
Dec 03 09:05:37 hilda kernel: ACPI: PM-Timer IO Port: 0x1808
Dec 03 09:05:37 hilda kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
Dec 03 09:05:37 hilda kernel: IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-119
Dec 03 09:05:37 hilda kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
Dec 03 09:05:37 hilda kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Dec 03 09:05:37 hilda kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Dec 03 09:05:37 hilda kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
Dec 03 09:05:37 hilda kernel: e820: update [mem 0x73614000-0x7363bfff] usable ==> reserved
Dec 03 09:05:37 hilda kernel: TSC deadline timer available
Dec 03 09:05:37 hilda kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
Dec 03 09:05:37 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Dec 03 09:05:37 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Dec 03 09:05:37 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x73614000-0x7363bfff]
Dec 03 09:05:37 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x7663c000-0x7683bfff]
Dec 03 09:05:37 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x7684b000-0x76860fff]
Dec 03 09:05:37 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x76862000-0x803fffff]
Dec 03 09:05:37 hilda kernel: PM: hibernation: Registered nosave memory: [mem 0x80400000-0xffffffff]
Dec 03 09:05:37 hilda kernel: [mem 0x80400000-0xffffffff] available for PCI devices
Dec 03 09:05:37 hilda kernel: Booting paravirtualized kernel on bare hardware
Dec 03 09:05:37 hilda kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Dec 03 09:05:37 hilda kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
Dec 03 09:05:37 hilda kernel: percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
Dec 03 09:05:37 hilda kernel: pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
Dec 03 09:05:37 hilda kernel: pcpu-alloc: [0] 0 1 2 3
Dec 03 09:05:37 hilda kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=29705f46-8be2-4ab2-a49e-62fea65f9bd3 rw quiet splash udev.log_priority=3 resume=
Dec 03 09:05:37 hilda kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64", will be passed to user space.
Dec 03 09:05:37 hilda kernel: random: crng init done
Dec 03 09:05:37 hilda kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Dec 03 09:05:37 hilda kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Dec 03 09:05:37 hilda kernel: Fallback order for Node 0: 0
Dec 03 09:05:37 hilda kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4087346
Dec 03 09:05:37 hilda kernel: Policy zone: Normal
Dec 03 09:05:37 hilda kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Dec 03 09:05:37 hilda kernel: software IO TLB: area num 4.
Dec 03 09:05:37 hilda kernel: Memory: 16126488K/16615340K available (18432K kernel code, 2156K rwdata, 13112K rodata, 3440K init, 3620K bss, 488596K reserved, 0K cma-reserved)
Dec 03 09:05:37 hilda kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Dec 03 09:05:37 hilda kernel: ftrace: allocating 49143 entries in 192 pages
Dec 03 09:05:37 hilda kernel: ftrace: allocated 192 pages with 2 groups
Dec 03 09:05:37 hilda kernel: Dynamic Preempt: full
Dec 03 09:05:37 hilda kernel: rcu: Preemptible hierarchical RCU implementation.
Dec 03 09:05:37 hilda kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
Dec 03 09:05:37 hilda kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Dec 03 09:05:37 hilda kernel:         Trampoline variant of Tasks RCU enabled.
Dec 03 09:05:37 hilda kernel:         Rude variant of Tasks RCU enabled.
Dec 03 09:05:37 hilda kernel:         Tracing variant of Tasks RCU enabled.
Dec 03 09:05:37 hilda kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Dec 03 09:05:37 hilda kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Dec 03 09:05:37 hilda kernel: NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
Dec 03 09:05:37 hilda kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Dec 03 09:05:37 hilda kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Dec 03 09:05:37 hilda kernel: spurious 8259A interrupt: IRQ7.
Dec 03 09:05:37 hilda kernel: Console: colour dummy device 80x25
Dec 03 09:05:37 hilda kernel: printk: console [tty0] enabled
Dec 03 09:05:37 hilda kernel: ACPI: Core revision 20230628
Dec 03 09:05:37 hilda kernel: hpet: HPET dysfunctional in PC10. Force disabled.
Dec 03 09:05:37 hilda kernel: APIC: Switch to symmetric I/O mode setup
Dec 03 09:05:37 hilda kernel: DMAR: Host address width 39
Dec 03 09:05:37 hilda kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Dec 03 09:05:37 hilda kernel: DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
Dec 03 09:05:37 hilda kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Dec 03 09:05:37 hilda kernel: DMAR: dmar1: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
Dec 03 09:05:37 hilda kernel: DMAR: RMRR base: 0x0000007c000000 end: 0x000000803fffff
Dec 03 09:05:37 hilda kernel: DMAR-IR: IOAPIC id 0 under DRHD base  0xfed91000 IOMMU 1
Dec 03 09:05:37 hilda kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Dec 03 09:05:37 hilda kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Dec 03 09:05:37 hilda kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Dec 03 09:05:37 hilda kernel: x2apic enabled
Dec 03 09:05:37 hilda kernel: APIC: Switched APIC routing to: cluster x2apic
Dec 03 09:05:37 hilda kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1cc85f641a1, max_idle_ns: 881590533829 ns
Dec 03 09:05:37 hilda kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 1997.00 BogoMIPS (lpj=3328000)
Dec 03 09:05:37 hilda kernel: CPU0: Thermal monitoring enabled (TM1)
Dec 03 09:05:37 hilda kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Dec 03 09:05:37 hilda kernel: process: using mwait in idle threads
Dec 03 09:05:37 hilda kernel: CET detected: Indirect Branch Tracking enabled
Dec 03 09:05:37 hilda kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Dec 03 09:05:37 hilda kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
Dec 03 09:05:37 hilda kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Dec 03 09:05:37 hilda kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
Dec 03 09:05:37 hilda kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Dec 03 09:05:37 hilda kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Dec 03 09:05:37 hilda kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Dec 03 09:05:37 hilda kernel: Register File Data Sampling: Mitigation: Clear Register File
Dec 03 09:05:37 hilda kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Dec 03 09:05:37 hilda kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Dec 03 09:05:37 hilda kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Dec 03 09:05:37 hilda kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Dec 03 09:05:37 hilda kernel: x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
Dec 03 09:05:37 hilda kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Dec 03 09:05:37 hilda kernel: x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
Dec 03 09:05:37 hilda kernel: x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
Dec 03 09:05:37 hilda kernel: x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
Dec 03 09:05:37 hilda kernel: Freeing SMP alternatives memory: 40K
Dec 03 09:05:37 hilda kernel: pid_max: default: 32768 minimum: 301
Dec 03 09:05:37 hilda kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
Dec 03 09:05:37 hilda kernel: landlock: Up and running.
Dec 03 09:05:37 hilda kernel: Yama: becoming mindful.
Dec 03 09:05:37 hilda kernel: LSM support for eBPF active
Dec 03 09:05:37 hilda kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec 03 09:05:37 hilda kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec 03 09:05:37 hilda kernel: smpboot: CPU0: Intel(R) N200 (family: 0x6, model: 0xbe, stepping: 0x0)
Dec 03 09:05:37 hilda kernel: RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 03 09:05:37 hilda kernel: RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 03 09:05:37 hilda kernel: RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 03 09:05:37 hilda kernel: Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline, PEBS-via-PT,  AnyThread deprecated, Gracemont events, 32-deep LBR, full-width counters, Intel PMU driver.
Dec 03 09:05:37 hilda kernel: ... version:                5
Dec 03 09:05:37 hilda kernel: ... bit width:              48
Dec 03 09:05:37 hilda kernel: ... generic registers:      6
Dec 03 09:05:37 hilda kernel: ... value mask:             0000ffffffffffff
Dec 03 09:05:37 hilda kernel: ... max period:             00007fffffffffff
Dec 03 09:05:37 hilda kernel: ... fixed-purpose events:   3
Dec 03 09:05:37 hilda kernel: ... event mask:             000000070000003f
Dec 03 09:05:37 hilda kernel: signal: max sigframe size: 3632
Dec 03 09:05:37 hilda kernel: Estimated ratio of average max frequency by base frequency (times 1024): 3276
Dec 03 09:05:37 hilda kernel: rcu: Hierarchical SRCU implementation.
Dec 03 09:05:37 hilda kernel: rcu:         Max phase no-delay instances is 1000.
Dec 03 09:05:37 hilda kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Dec 03 09:05:37 hilda kernel: smp: Bringing up secondary CPUs ...
Dec 03 09:05:37 hilda kernel: smpboot: x86: Booting SMP configuration:
Dec 03 09:05:37 hilda kernel: .... node  #0, CPUs:      #1 #2 #3
Dec 03 09:05:37 hilda kernel: smp: Brought up 1 node, 4 CPUs
Dec 03 09:05:37 hilda kernel: smpboot: Max logical packages: 1
Dec 03 09:05:37 hilda kernel: smpboot: Total of 4 processors activated (7990.00 BogoMIPS)
Dec 03 09:05:37 hilda kernel: devtmpfs: initialized
Dec 03 09:05:37 hilda kernel: x86/mm: Memory block size: 128MB
Dec 03 09:05:37 hilda kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Dec 03 09:05:37 hilda kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Dec 03 09:05:37 hilda kernel: pinctrl core: initialized pinctrl subsystem
Dec 03 09:05:37 hilda kernel: PM: RTC time: 23:05:33, date: 2024-12-02
Dec 03 09:05:37 hilda kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Dec 03 09:05:37 hilda kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Dec 03 09:05:37 hilda kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec 03 09:05:37 hilda kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Dec 03 09:05:37 hilda kernel: audit: initializing netlink subsys (disabled)
Dec 03 09:05:37 hilda kernel: audit: type=2000 audit(1733180733.009:1): state=initialized audit_enabled=0 res=1
Dec 03 09:05:37 hilda kernel: thermal_sys: Registered thermal governor 'fair_share'
Dec 03 09:05:37 hilda kernel: thermal_sys: Registered thermal governor 'bang_bang'
Dec 03 09:05:37 hilda kernel: thermal_sys: Registered thermal governor 'step_wise'
Dec 03 09:05:37 hilda kernel: thermal_sys: Registered thermal governor 'user_space'
Dec 03 09:05:37 hilda kernel: thermal_sys: Registered thermal governor 'power_allocator'
Dec 03 09:05:37 hilda kernel: cpuidle: using governor ladder
Dec 03 09:05:37 hilda kernel: cpuidle: using governor menu
Dec 03 09:05:37 hilda kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 03 09:05:37 hilda kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
Dec 03 09:05:37 hilda kernel: PCI: Using configuration type 1 for base access
Dec 03 09:05:37 hilda kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Dec 03 09:05:37 hilda kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Dec 03 09:05:37 hilda kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Dec 03 09:05:37 hilda kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Dec 03 09:05:37 hilda kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Dec 03 09:05:37 hilda kernel: ACPI: Added _OSI(Module Device)
Dec 03 09:05:37 hilda kernel: ACPI: Added _OSI(Processor Device)
Dec 03 09:05:37 hilda kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Dec 03 09:05:37 hilda kernel: ACPI: Added _OSI(Processor Aggregator Device)
Dec 03 09:05:37 hilda kernel: ACPI: 2 ACPI AML tables successfully acquired and loaded
Dec 03 09:05:37 hilda kernel: ACPI: _OSC evaluation for CPUs failed, trying _PDC
Dec 03 09:05:37 hilda kernel: ACPI: EC: EC started
Dec 03 09:05:37 hilda kernel: ACPI: EC: interrupt blocked
Dec 03 09:05:37 hilda kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Dec 03 09:05:37 hilda kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC used to handle transactions
Dec 03 09:05:37 hilda kernel: ACPI: Interpreter enabled
Dec 03 09:05:37 hilda kernel: ACPI: PM: (supports S0 S3 S4 S5)
Dec 03 09:05:37 hilda kernel: ACPI: Using IOAPIC for interrupt routing
Dec 03 09:05:37 hilda kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Dec 03 09:05:37 hilda kernel: PCI: Ignoring E820 reservations for host bridge windows
Dec 03 09:05:37 hilda kernel: ACPI: Enabled 2 GPEs in block 00 to 7F
Dec 03 09:05:37 hilda kernel: ACPI: \_SB_.PCI0.RP09.RTD3: New power resource
Dec 03 09:05:37 hilda kernel: ACPI: \_SB_.PCI0.TBT0: New power resource
Dec 03 09:05:37 hilda kernel: ACPI: \_SB_.PCI0.TBT1: New power resource
Dec 03 09:05:37 hilda kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Dec 03 09:05:37 hilda kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Dec 03 09:05:37 hilda kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
Dec 03 09:05:37 hilda kernel: PCI host bridge to bus 0000:00
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [mem 0x80400000-0xdfffffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [mem 0x47fc00000-0x7fffffffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed47fff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Dec 03 09:05:37 hilda kernel: pci 0000:00:00.0: [8086:461b] type 00 class 0x060000
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: [8086:46d0] type 00 class 0x030000
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: reg 0x10: [mem 0x81000000-0x81ffffff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: reg 0x20: [io  0x1000-0x103f]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
Dec 03 09:05:37 hilda kernel: pci 0000:00:08.0: [8086:467e] type 00 class 0x088000
Dec 03 09:05:37 hilda kernel: pci 0000:00:08.0: reg 0x10: [mem 0x80624000-0x80624fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:0a.0: [8086:467d] type 00 class 0x118000
Dec 03 09:05:37 hilda kernel: pci 0000:00:0a.0: reg 0x10: [mem 0x80610000-0x80617fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:0a.0: enabling Extended Tags
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.0: [8086:54ed] type 00 class 0x0c0330
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.0: reg 0x10: [mem 0x80600000-0x8060ffff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.2: [8086:54ef] type 00 class 0x050000
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.2: reg 0x10: [mem 0x80618000-0x8061bfff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.2: reg 0x18: [mem 0x80625000-0x80625fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.3: [8086:54f0] type 00 class 0x028000
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.3: reg 0x10: [mem 0x8061c000-0x8061ffff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
Dec 03 09:05:37 hilda kernel: pci 0000:00:15.0: [8086:54e8] type 00 class 0x0c8000
Dec 03 09:05:37 hilda kernel: pci 0000:00:15.0: reg 0x10: [mem 0x80626000-0x80626fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:15.2: [8086:54ea] type 00 class 0x0c8000
Dec 03 09:05:37 hilda kernel: pci 0000:00:15.2: reg 0x10: [mem 0x80627000-0x80627fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1d.0: [8086:54b0] type 01 class 0x060400
Dec 03 09:05:37 hilda kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Dec 03 09:05:37 hilda kernel: pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
Dec 03 09:05:37 hilda kernel: pci 0000:00:1e.0: [8086:54a8] type 00 class 0x078000
Dec 03 09:05:37 hilda kernel: pci 0000:00:1e.0: reg 0x10: [mem 0xfe03e000-0xfe03efff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1e.0: reg 0x18: [mem 0x80629000-0x80629fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.0: [8086:5481] type 00 class 0x060100
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.3: [8086:54c8] type 00 class 0x040300
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.3: reg 0x10: [mem 0x80620000-0x80623fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.3: reg 0x20: [mem 0x80500000-0x805fffff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.4: [8086:54a3] type 00 class 0x0c0500
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.4: reg 0x10: [mem 0x8062b000-0x8062b0ff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.5: [8086:54a4] type 00 class 0x0c8000
Dec 03 09:05:37 hilda kernel: pci 0000:00:1f.5: reg 0x10: [mem 0x8062a000-0x8062afff]
Dec 03 09:05:37 hilda kernel: pci 0000:01:00.0: [126f:2263] type 00 class 0x010802
Dec 03 09:05:37 hilda kernel: pci 0000:01:00.0: reg 0x10: [mem 0x80400000-0x80403fff 64bit]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1d.0: PCI bridge to [bus 01]
Dec 03 09:05:37 hilda kernel: pci 0000:00:1d.0:   bridge window [mem 0x80400000-0x804fffff]
Dec 03 09:05:37 hilda kernel: ACPI: EC: interrupt unblocked
Dec 03 09:05:37 hilda kernel: ACPI: EC: event unblocked
Dec 03 09:05:37 hilda kernel: ACPI: EC: GPE=0x6e
Dec 03 09:05:37 hilda kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC initialization complete
Dec 03 09:05:37 hilda kernel: ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
Dec 03 09:05:37 hilda kernel: iommu: Default domain type: Translated
Dec 03 09:05:37 hilda kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Dec 03 09:05:37 hilda kernel: SCSI subsystem initialized
Dec 03 09:05:37 hilda kernel: libata version 3.00 loaded.
Dec 03 09:05:37 hilda kernel: ACPI: bus type USB registered
Dec 03 09:05:37 hilda kernel: usbcore: registered new interface driver usbfs
Dec 03 09:05:37 hilda kernel: usbcore: registered new interface driver hub
Dec 03 09:05:37 hilda kernel: usbcore: registered new device driver usb
Dec 03 09:05:37 hilda kernel: pps_core: LinuxPPS API ver. 1 registered
Dec 03 09:05:37 hilda kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Dec 03 09:05:37 hilda kernel: PTP clock support registered
Dec 03 09:05:37 hilda kernel: EDAC MC: Ver: 3.0.0
Dec 03 09:05:37 hilda kernel: efivars: Registered efivars operations
Dec 03 09:05:37 hilda kernel: NetLabel: Initializing
Dec 03 09:05:37 hilda kernel: NetLabel:  domain hash size = 128
Dec 03 09:05:37 hilda kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec 03 09:05:37 hilda kernel: NetLabel:  unlabeled traffic allowed by default
Dec 03 09:05:37 hilda kernel: mctp: management component transport protocol core
Dec 03 09:05:37 hilda kernel: NET: Registered PF_MCTP protocol family
Dec 03 09:05:37 hilda kernel: PCI: Using ACPI for IRQ routing
Dec 03 09:05:37 hilda kernel: PCI: pci_cache_line_size set to 64 bytes
Dec 03 09:05:37 hilda kernel: e820: reserve RAM buffer [mem 0x73614000-0x73ffffff]
Dec 03 09:05:37 hilda kernel: e820: reserve RAM buffer [mem 0x7663c000-0x77ffffff]
Dec 03 09:05:37 hilda kernel: e820: reserve RAM buffer [mem 0x7684b000-0x77ffffff]
Dec 03 09:05:37 hilda kernel: e820: reserve RAM buffer [mem 0x76862000-0x77ffffff]
Dec 03 09:05:37 hilda kernel: e820: reserve RAM buffer [mem 0x47fc00000-0x47fffffff]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Dec 03 09:05:37 hilda kernel: vgaarb: loaded
Dec 03 09:05:37 hilda kernel: clocksource: Switched to clocksource tsc-early
Dec 03 09:05:37 hilda kernel: VFS: Disk quotas dquot_6.6.0
Dec 03 09:05:37 hilda kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec 03 09:05:37 hilda kernel: pnp: PnP ACPI init
Dec 03 09:05:37 hilda kernel: pnp 00:00: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xfedc0000-0xfeddffff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xfeda0000-0xfeda0fff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xfeda1000-0xfeda1fff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xfed90000-0xfed93fff] could not be reserved
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xff000000-0xffffffff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xf8000000-0xf9ffffff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xfee00000-0xfeefffff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:01: [mem 0xfed00000-0xfed003ff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:02: [mem 0xfed00000-0xfed003ff] has been reserved
Dec 03 09:05:37 hilda kernel: system 00:03: [io  0x1800-0x18fe] has been reserved
Dec 03 09:05:37 hilda kernel: pnp: PnP ACPI: found 7 devices
Dec 03 09:05:37 hilda kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Dec 03 09:05:37 hilda kernel: NET: Registered PF_INET protocol family
Dec 03 09:05:37 hilda kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec 03 09:05:37 hilda kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
Dec 03 09:05:37 hilda kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Dec 03 09:05:37 hilda kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Dec 03 09:05:37 hilda kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Dec 03 09:05:37 hilda kernel: TCP: Hash tables configured (established 131072 bind 65536)
Dec 03 09:05:37 hilda kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
Dec 03 09:05:37 hilda kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
Dec 03 09:05:37 hilda kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
Dec 03 09:05:37 hilda kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Dec 03 09:05:37 hilda kernel: NET: Registered PF_XDP protocol family
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: BAR 9: assigned [mem 0x480000000-0x55fffffff 64bit pref]
Dec 03 09:05:37 hilda kernel: pci 0000:00:02.0: BAR 7: assigned [mem 0x560000000-0x566ffffff 64bit]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: resource 7 [mem 0x80400000-0xdfffffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: resource 8 [mem 0x47fc00000-0x7fffffffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:00: resource 10 [mem 0xfed40000-0xfed47fff window]
Dec 03 09:05:37 hilda kernel: pci_bus 0000:01: resource 1 [mem 0x80400000-0x804fffff]
Dec 03 09:05:37 hilda kernel: PCI: CLS 64 bytes, default 64
Dec 03 09:05:37 hilda kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Dec 03 09:05:37 hilda kernel: software IO TLB: mapped [mem 0x0000000069c60000-0x000000006dc60000] (64MB)
Dec 03 09:05:37 hilda kernel: Trying to unpack rootfs image as initramfs...
Dec 03 09:05:37 hilda kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1cc85f641a1, max_idle_ns: 881590533829 ns
Dec 03 09:05:37 hilda kernel: Initialise system trusted keyrings
Dec 03 09:05:37 hilda kernel: Key type blacklist registered
Dec 03 09:05:37 hilda kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
Dec 03 09:05:37 hilda kernel: zbud: loaded
Dec 03 09:05:37 hilda kernel: integrity: Platform Keyring initialized
Dec 03 09:05:37 hilda kernel: integrity: Machine keyring initialized
Dec 03 09:05:37 hilda kernel: Key type asymmetric registered
Dec 03 09:05:37 hilda kernel: Asymmetric key parser 'x509' registered
Dec 03 09:05:37 hilda kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
Dec 03 09:05:37 hilda kernel: io scheduler mq-deadline registered
Dec 03 09:05:37 hilda kernel: io scheduler kyber registered
Dec 03 09:05:37 hilda kernel: io scheduler bfq registered
Dec 03 09:05:37 hilda kernel: pcieport 0000:00:1d.0: PME: Signaling with IRQ 122
Dec 03 09:05:37 hilda kernel: pcieport 0000:00:1d.0: AER: enabled with IRQ 122
Dec 03 09:05:37 hilda kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Dec 03 09:05:37 hilda kernel: ACPI: AC: AC Adapter [ADP1] (on-line)
Dec 03 09:05:37 hilda kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/PNP0C09:00/PNP0C0D:00/input/input0
Dec 03 09:05:37 hilda kernel: ACPI: button: Lid Switch [LID0]
Dec 03 09:05:37 hilda kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Dec 03 09:05:37 hilda kernel: ACPI: button: Power Button [PWRF]
Dec 03 09:05:37 hilda kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Dec 03 09:05:37 hilda kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 03 09:05:37 hilda kernel: Non-volatile memory driver v1.3
Dec 03 09:05:37 hilda kernel: Linux agpgart interface v0.103
Dec 03 09:05:37 hilda kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
Dec 03 09:05:37 hilda kernel: ACPI: bus type drm_connector registered
Dec 03 09:05:37 hilda kernel: usbcore: registered new interface driver usbserial_generic
Dec 03 09:05:37 hilda kernel: usbserial: USB Serial support registered for generic
Dec 03 09:05:37 hilda kernel: rtc_cmos 00:04: RTC can wake from S4
Dec 03 09:05:37 hilda kernel: rtc_cmos 00:04: registered as rtc0
Dec 03 09:05:37 hilda kernel: rtc_cmos 00:04: setting system clock to 2024-12-02T23:05:33 UTC (1733180733)
Dec 03 09:05:37 hilda kernel: rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram
Dec 03 09:05:37 hilda kernel: intel_pstate: Intel P-state driver initializing
Dec 03 09:05:37 hilda kernel: intel_pstate: HWP enabled
Dec 03 09:05:37 hilda kernel: ledtrig-cpu: registered to indicate activity on CPUs
Dec 03 09:05:37 hilda kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
Dec 03 09:05:37 hilda kernel: fbcon: Deferring console take-over
Dec 03 09:05:37 hilda kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Dec 03 09:05:37 hilda kernel: hid: raw HID events driver (C) Jiri Kosina
Dec 03 09:05:37 hilda kernel: intel_pmc_core INT33A1:00:  initialized
Dec 03 09:05:37 hilda kernel: drop_monitor: Initializing network drop monitor service
Dec 03 09:05:37 hilda kernel: Initializing XFRM netlink socket
Dec 03 09:05:37 hilda kernel: NET: Registered PF_INET6 protocol family
Dec 03 09:05:37 hilda kernel: Freeing initrd memory: 27996K
Dec 03 09:05:37 hilda kernel: Segment Routing with IPv6
Dec 03 09:05:37 hilda kernel: RPL Segment Routing with IPv6
Dec 03 09:05:37 hilda kernel: In-situ OAM (IOAM) with IPv6
Dec 03 09:05:37 hilda kernel: NET: Registered PF_PACKET protocol family
Dec 03 09:05:37 hilda kernel: resctrl: L2 allocation detected
Dec 03 09:05:37 hilda kernel: IPI shorthand broadcast: enabled
Dec 03 09:05:37 hilda kernel: sched_clock: Marking stable (460002666, 16837622)->(499293085, -22452797)
Dec 03 09:05:37 hilda kernel: registered taskstats version 1
Dec 03 09:05:37 hilda kernel: Loading compiled-in X.509 certificates
Dec 03 09:05:37 hilda kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 8e75594863f05fb5a08747433e880ba8c3f201b9'
Dec 03 09:05:37 hilda kernel: zswap: loaded using pool zstd/zsmalloc
Dec 03 09:05:37 hilda kernel: Key type .fscrypt registered
Dec 03 09:05:37 hilda kernel: Key type fscrypt-provisioning registered
Dec 03 09:05:37 hilda kernel: PM:   Magic number: 4:142:99
Dec 03 09:05:37 hilda kernel: RAS: Correctable Errors collector initialized.
Dec 03 09:05:37 hilda kernel: clk: Disabling unused clocks
Dec 03 09:05:37 hilda kernel: ACPI: battery: Slot [BAT0] (battery present)
Dec 03 09:05:37 hilda kernel: Freeing unused decrypted memory: 2028K
Dec 03 09:05:37 hilda kernel: Freeing unused kernel image (initmem) memory: 3440K
Dec 03 09:05:37 hilda kernel: Write protecting the kernel read-only data: 32768k
Dec 03 09:05:37 hilda kernel: Freeing unused kernel image (rodata/data gap) memory: 1224K
Dec 03 09:05:37 hilda kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 03 09:05:37 hilda kernel: rodata_test: all tests were successful
Dec 03 09:05:37 hilda kernel: Run /init as init process
Dec 03 09:05:37 hilda kernel:   with arguments:
Dec 03 09:05:37 hilda kernel:     /init
Dec 03 09:05:37 hilda kernel:     splash
Dec 03 09:05:37 hilda kernel:   with environment:
Dec 03 09:05:37 hilda kernel:     HOME=/
Dec 03 09:05:37 hilda kernel:     TERM=linux
Dec 03 09:05:37 hilda kernel:     BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
Dec 03 09:05:37 hilda kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Dec 03 09:05:37 hilda kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Dec 03 09:05:37 hilda kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Dec 03 09:05:37 hilda kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000100200009810
Dec 03 09:05:37 hilda kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Dec 03 09:05:37 hilda kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
Dec 03 09:05:37 hilda kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
Dec 03 09:05:37 hilda kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 03 09:05:37 hilda kernel: usb usb1: Product: xHCI Host Controller
Dec 03 09:05:37 hilda kernel: usb usb1: Manufacturer: Linux 6.6.63-1-MANJARO xhci-hcd
Dec 03 09:05:37 hilda kernel: usb usb1: SerialNumber: 0000:00:14.0
Dec 03 09:05:37 hilda kernel: hub 1-0:1.0: USB hub found
Dec 03 09:05:37 hilda kernel: hub 1-0:1.0: 12 ports detected
Dec 03 09:05:37 hilda kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
Dec 03 09:05:37 hilda kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 03 09:05:37 hilda kernel: usb usb2: Product: xHCI Host Controller
Dec 03 09:05:37 hilda kernel: usb usb2: Manufacturer: Linux 6.6.63-1-MANJARO xhci-hcd
Dec 03 09:05:37 hilda kernel: usb usb2: SerialNumber: 0000:00:14.0
Dec 03 09:05:37 hilda kernel: hub 2-0:1.0: USB hub found
Dec 03 09:05:37 hilda kernel: hub 2-0:1.0: 4 ports detected
Dec 03 09:05:37 hilda kernel: usb: port power management may be unreliable
Dec 03 09:05:37 hilda kernel: nvme 0000:01:00.0: platform quirk: setting simple suspend
Dec 03 09:05:37 hilda kernel: nvme nvme0: pci function 0000:01:00.0
Dec 03 09:05:37 hilda kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Dec 03 09:05:37 hilda kernel: nvme nvme0: 4/0/0 default/read/poll queues
Dec 03 09:05:37 hilda kernel: nvme nvme0: Ignoring bogus Namespace Identifiers
Dec 03 09:05:37 hilda kernel:  nvme0n1: p1 p2
Dec 03 09:05:37 hilda kernel: usb 1-1: new high-speed USB device number 2 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
Dec 03 09:05:37 hilda kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 03 09:05:37 hilda kernel: usb 1-1: Product: USB2.1 Hub
Dec 03 09:05:37 hilda kernel: usb 1-1: Manufacturer: GenesysLogic
Dec 03 09:05:37 hilda kernel: hub 1-1:1.0: USB hub found
Dec 03 09:05:37 hilda kernel: hub 1-1:1.0: 4 ports detected
Dec 03 09:05:37 hilda kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Dec 03 09:05:37 hilda kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
Dec 03 09:05:37 hilda kernel: usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] Using Transparent Hugepages
Dec 03 09:05:37 hilda kernel: usb 2-3: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
Dec 03 09:05:37 hilda kernel: usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 03 09:05:37 hilda kernel: usb 2-3: Product: USB3.1 Hub
Dec 03 09:05:37 hilda kernel: usb 2-3: Manufacturer: GenesysLogic
Dec 03 09:05:37 hilda kernel: hub 2-3:1.0: USB hub found
Dec 03 09:05:37 hilda kernel: hub 2-3:1.0: 4 ports detected
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc.bin (v2.20)
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.29.2
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
Dec 03 09:05:37 hilda kernel: usb 1-3: new high-speed USB device number 3 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
Dec 03 09:05:37 hilda kernel: usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Dec 03 09:05:37 hilda kernel: usb 1-3: Product: USB2.0 Hub
Dec 03 09:05:37 hilda kernel: hub 1-3:1.0: USB hub found
Dec 03 09:05:37 hilda kernel: hub 1-3:1.0: 4 ports detected
Dec 03 09:05:37 hilda kernel: usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-1.2: New USB device found, idVendor=045e, idProduct=00cb, bcdDevice= 1.00
Dec 03 09:05:37 hilda kernel: usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 03 09:05:37 hilda kernel: usb 1-1.2: Product: Microsoft USB Optical Mouse
Dec 03 09:05:37 hilda kernel: usb 1-1.2: Manufacturer: PixArt
Dec 03 09:05:37 hilda kernel: input: PixArt Microsoft USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:00CB.0001/input/input3
Dec 03 09:05:37 hilda kernel: hid-generic 0003:045E:00CB.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Microsoft USB Optical Mouse] on usb-0000:00:14.0-1.2/input0
Dec 03 09:05:37 hilda kernel: usbcore: registered new interface driver usbhid
Dec 03 09:05:37 hilda kernel: usbhid: USB HID core driver
Dec 03 09:05:37 hilda kernel: usb 1-6: new high-speed USB device number 5 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-6: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
Dec 03 09:05:37 hilda kernel: usb 1-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Dec 03 09:05:37 hilda kernel: usb 1-6: Product: USB2.0 HUB
Dec 03 09:05:37 hilda kernel: hub 1-6:1.0: USB hub found
Dec 03 09:05:37 hilda kernel: hub 1-6:1.0: 4 ports detected
Dec 03 09:05:37 hilda kernel: usb 1-3.1: new full-speed USB device number 6 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-3.1: New USB device found, idVendor=1018, idProduct=1006, bcdDevice= 1.03
Dec 03 09:05:37 hilda kernel: usb 1-3.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.0/0003:1018:1006.0002/input/input4
Dec 03 09:05:37 hilda kernel: hid-generic 0003:1018:1006.0002: input,hidraw1: USB HID v1.11 Keyboard [HID 1018:1006] on usb-0000:00:14.0-3.1/input0
Dec 03 09:05:37 hilda kernel: usb 1-10: new full-speed USB device number 7 using xhci_hcd
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input5
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input6
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input7
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input8
Dec 03 09:05:37 hilda kernel: hid-generic 0003:1018:1006.0003: input,hiddev96,hidraw2: USB HID v1.11 Mouse [HID 1018:1006] on usb-0000:00:14.0-3.1/input1
Dec 03 09:05:37 hilda kernel: usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
Dec 03 09:05:37 hilda kernel: usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input9
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input10
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input11
Dec 03 09:05:37 hilda kernel: input: HID 1018:1006 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.1/0003:1018:1006.0003/input/input12
Dec 03 09:05:37 hilda kernel: hid-multitouch 0003:1018:1006.0003: input,hiddev96,hidraw2: USB HID v1.11 Mouse [HID 1018:1006] on usb-0000:00:14.0-3.1/input1
Dec 03 09:05:37 hilda kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
Dec 03 09:05:37 hilda kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Dec 03 09:05:37 hilda kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
Dec 03 09:05:37 hilda kernel: fbcon: i915drmfb (fb0) is primary device
Dec 03 09:05:37 hilda kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Dec 03 09:05:37 hilda kernel: fbcon: Taking over console
Dec 03 09:05:37 hilda kernel: Console: switching to colour frame buffer device 135x45
Dec 03 09:05:37 hilda kernel: usb 1-6.1: new high-speed USB device number 8 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-6.1: New USB device found, idVendor=0bda, idProduct=5830, bcdDevice=11.16
Dec 03 09:05:37 hilda kernel: usb 1-6.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 03 09:05:37 hilda kernel: usb 1-6.1: Product: USB2.0 camera
Dec 03 09:05:37 hilda kernel: usb 1-6.1: Manufacturer: SunplusIT Inc
Dec 03 09:05:37 hilda kernel: usb 1-6.1: SerialNumber: J2023111601
Dec 03 09:05:37 hilda kernel: usb 1-3.2: new high-speed USB device number 9 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-3.2: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
Dec 03 09:05:37 hilda kernel: usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 03 09:05:37 hilda kernel: usb 1-3.2: Product: USB2.0-CRW
Dec 03 09:05:37 hilda kernel: usb 1-3.2: Manufacturer: Generic
Dec 03 09:05:37 hilda kernel: usb 1-3.2: SerialNumber: 20100201396000000
Dec 03 09:05:37 hilda kernel: usbcore: registered new interface driver rtsx_usb
Dec 03 09:05:37 hilda kernel: EXT4-fs (nvme0n1p2): recovery complete
Dec 03 09:05:37 hilda kernel: EXT4-fs (nvme0n1p2): mounted filesystem 29705f46-8be2-4ab2-a49e-62fea65f9bd3 r/w with ordered data mode. Quota mode: none.
Dec 03 09:05:37 hilda systemd[1]: systemd 256.8-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
Dec 03 09:05:37 hilda systemd[1]: Detected architecture x86-64.
Dec 03 09:05:37 hilda systemd[1]: Hostname set to <hilda>.
Dec 03 09:05:37 hilda kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Dec 03 09:05:37 hilda kernel: usb 1-6.2: new high-speed USB device number 10 using xhci_hcd
Dec 03 09:05:37 hilda kernel: usb 1-6.2: New USB device found, idVendor=1bcf, idProduct=284d, bcdDevice=11.16
Dec 03 09:05:37 hilda kernel: usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 03 09:05:37 hilda kernel: usb 1-6.2: Product: USB 2.0 Camera
Dec 03 09:05:37 hilda kernel: usb 1-6.2: Manufacturer: SunplusIT Inc
Dec 03 09:05:37 hilda kernel: usb 1-6.2: SerialNumber: J20231116V1
Dec 03 09:05:37 hilda systemd[1]: bpf-restrict-fs: LSM BPF program attached
Dec 03 09:05:37 hilda systemd-ssh-generator[254]: Binding SSH to AF_UNIX socket /run/ssh-unix-local/socket.
Dec 03 09:05:37 hilda systemd-ssh-generator[254]: → connect via 'ssh .host' locally
Dec 03 09:05:37 hilda systemd[1]: Queued start job for default target Graphical Interface.
Dec 03 09:05:37 hilda systemd[1]: Created slice CUPS Slice.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/dirmngr.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/getty.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/gpg-agent.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/gpg-agent-browser.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/gpg-agent-extra.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/keyboxd.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/modprobe.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/systemd-fsck.
Dec 03 09:05:37 hilda systemd[1]: Created slice User and Session Slice.
Dec 03 09:05:37 hilda systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Dec 03 09:05:37 hilda systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Dec 03 09:05:37 hilda systemd[1]: Expecting device /dev/disk/by-uuid/42A8-45AC...
Dec 03 09:05:37 hilda systemd[1]: Expecting device /dev/tpmrm0...
Dec 03 09:05:37 hilda systemd[1]: Reached target Login Prompts.
Dec 03 09:05:37 hilda systemd[1]: Reached target Local Integrity Protected Volumes.
Dec 03 09:05:37 hilda systemd[1]: Reached target Remote File Systems.
Dec 03 09:05:37 hilda systemd[1]: Reached target Slice Units.
Dec 03 09:05:37 hilda systemd[1]: Reached target Local Verity Protected Volumes.
Dec 03 09:05:37 hilda systemd[1]: Listening on Device-mapper event daemon FIFOs.
Dec 03 09:05:37 hilda systemd[1]: Listening on LVM2 poll daemon socket.
Dec 03 09:05:37 hilda systemd[1]: Listening on Process Core Dump Socket.
Dec 03 09:05:37 hilda systemd[1]: Listening on Credential Encryption/Decryption.
Dec 03 09:05:37 hilda systemd[1]: Listening on Journal Socket (/dev/log).
Dec 03 09:05:37 hilda systemd[1]: Listening on Journal Sockets.
Dec 03 09:05:37 hilda systemd[1]: Listening on udev Control Socket.
Dec 03 09:05:37 hilda systemd[1]: Listening on udev Kernel Socket.
Dec 03 09:05:37 hilda systemd[1]: Listening on User Database Manager Socket.
Dec 03 09:05:37 hilda systemd[1]: Mounting Huge Pages File System...
Dec 03 09:05:37 hilda systemd[1]: Mounting POSIX Message Queue File System...
Dec 03 09:05:37 hilda systemd[1]: Mounting Kernel Debug File System...
Dec 03 09:05:37 hilda systemd[1]: Mounting Kernel Trace File System...
Dec 03 09:05:37 hilda systemd[1]: Starting Create List of Static Device Nodes...
Dec 03 09:05:37 hilda systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Dec 03 09:05:37 hilda systemd[1]: Starting Load Kernel Module configfs...
Dec 03 09:05:37 hilda systemd[1]: Starting Load Kernel Module dm_mod...
Dec 03 09:05:37 hilda systemd[1]: Starting Load Kernel Module drm...
Dec 03 09:05:37 hilda systemd[1]: Starting Load Kernel Module fuse...
Dec 03 09:05:37 hilda systemd[1]: Starting Load Kernel Module loop...
Dec 03 09:05:37 hilda systemd[1]: Starting Mullvad early boot network blocker...
Dec 03 09:05:37 hilda systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Dec 03 09:05:37 hilda systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Dec 03 09:05:37 hilda systemd[1]: Starting Journal Service...
Dec 03 09:05:37 hilda kernel: device-mapper: uevent: version 1.0.3
Dec 03 09:05:37 hilda systemd[1]: Starting Load Kernel Modules...
Dec 03 09:05:37 hilda kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
Dec 03 09:05:37 hilda systemd[1]: Starting Remount Root and Kernel File Systems...
Dec 03 09:05:37 hilda kernel: fuse: init (API version 7.39)
Dec 03 09:05:37 hilda kernel: loop: module loaded
Dec 03 09:05:37 hilda systemd[1]: Starting Load udev Rules from Credentials...
Dec 03 09:05:37 hilda systemd[1]: Starting Coldplug All udev Devices...
Dec 03 09:05:37 hilda systemd[1]: Starting Virtual Console Setup...
Dec 03 09:05:37 hilda systemd[1]: Mounted Huge Pages File System.
Dec 03 09:05:37 hilda systemd[1]: Mounted POSIX Message Queue File System.
Dec 03 09:05:37 hilda systemd[1]: Mounted Kernel Debug File System.
Dec 03 09:05:37 hilda systemd[1]: Mounted Kernel Trace File System.
Dec 03 09:05:37 hilda systemd-journald[272]: Collecting audit messages is disabled.
Dec 03 09:05:37 hilda kernel: i2c_dev: i2c /dev entries driver
Dec 03 09:05:37 hilda kernel: EXT4-fs (nvme0n1p2): re-mounted 29705f46-8be2-4ab2-a49e-62fea65f9bd3 r/w. Quota mode: none.
Dec 03 09:05:37 hilda systemd[1]: Finished Create List of Static Device Nodes.
Dec 03 09:05:37 hilda systemd[1]: modprobe@configfs.service: Deactivated successfully.
Dec 03 09:05:37 hilda systemd-journald[272]: Journal started
Dec 03 09:05:37 hilda systemd-journald[272]: Runtime Journal (/run/log/journal/da9e8f5f671143a3b61e744391317df6) is 8M, max 791.9M, 783.9M free.
Dec 03 09:05:37 hilda systemd-modules-load[273]: Inserted module 'crypto_user'
Dec 03 09:05:37 hilda systemd-vconsole-setup[280]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Dec 03 09:05:37 hilda systemd-modules-load[273]: Inserted module 'i2c_dev'
Dec 03 09:05:37 hilda systemd-modules-load[273]: Inserted module 'uinput'
Dec 03 09:05:37 hilda mullvad-daemon[271]: [2024-12-03 09:05:37.111][mullvad_daemon::version][INFO] Starting mullvad-daemon - 2024.7 2024-10-30
Dec 03 09:05:37 hilda mullvad-daemon[271]: [2024-12-03 09:05:37.112][mullvad_daemon::settings][INFO] Loading settings from /etc/mullvad-vpn/settings.json
Dec 03 09:05:37 hilda mullvad-daemon[271]: [2024-12-03 09:05:37.116][mullvad_daemon::early_boot_firewall][INFO] Applying firewall policy Blocked. Allowing LAN. Allowing endpoint: none
Dec 03 09:05:37 hilda mullvad-daemon[271]: [2024-12-03 09:05:37.116][talpid_core::firewall][INFO] Applying firewall policy: Blocked. Allowing LAN. Allowing endpoint: none
Dec 03 09:05:37 hilda systemd[1]: Finished Load Kernel Module configfs.
Dec 03 09:05:37 hilda systemd[1]: Started Journal Service.
Dec 03 09:05:37 hilda systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec 03 09:05:37 hilda systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Dec 03 09:05:37 hilda systemd[1]: Finished Load Kernel Module dm_mod.
Dec 03 09:05:37 hilda systemd[1]: modprobe@drm.service: Deactivated successfully.
Dec 03 09:05:37 hilda systemd[1]: Finished Load Kernel Module drm.
Dec 03 09:05:37 hilda systemd[1]: modprobe@fuse.service: Deactivated successfully.
Dec 03 09:05:37 hilda systemd[1]: Finished Load Kernel Module fuse.
Dec 03 09:05:37 hilda systemd[1]: modprobe@loop.service: Deactivated successfully.
Dec 03 09:05:37 hilda systemd[1]: Finished Load Kernel Module loop.
Dec 03 09:05:37 hilda systemd[1]: Finished Load Kernel Modules.
Dec 03 09:05:37 hilda systemd[1]: Finished Remount Root and Kernel File Systems.
Dec 03 09:05:37 hilda systemd[1]: Finished Load udev Rules from Credentials.
Dec 03 09:05:37 hilda systemd[1]: Finished Coldplug All udev Devices.
Dec 03 09:05:37 hilda systemd[1]: Finished Virtual Console Setup.
Dec 03 09:05:37 hilda systemd[1]: Activating swap /swapfile...
Dec 03 09:05:37 hilda systemd[1]: Mounting FUSE Control File System...
Dec 03 09:05:37 hilda systemd[1]: Mounting Kernel Configuration File System...
Dec 03 09:05:37 hilda systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Dec 03 09:05:37 hilda systemd[1]: Starting Flush Journal to Persistent Storage...
Dec 03 09:05:37 hilda systemd[1]: Starting Load/Save OS Random Seed...
Dec 03 09:05:37 hilda systemd[1]: Starting Apply Kernel Variables...
Dec 03 09:05:37 hilda kernel: Adding 20920316k swap on /swapfile.  Priority:-2 extents:167 across:48857088k SS
Dec 03 09:05:37 hilda systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Dec 03 09:05:37 hilda systemd-journald[272]: Time spent on flushing to /var/log/journal/da9e8f5f671143a3b61e744391317df6 is 6.667ms for 703 entries.
Dec 03 09:05:37 hilda systemd-journald[272]: System Journal (/var/log/journal/da9e8f5f671143a3b61e744391317df6) is 40.1M, max 50M, 9.8M free.
Dec 03 09:05:37 hilda systemd-journald[272]: Received client request to flush runtime journal.
Dec 03 09:05:37 hilda systemd-journald[272]: File /var/log/journal/da9e8f5f671143a3b61e744391317df6/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 03 09:05:37 hilda systemd[1]: Activated swap /swapfile.
Dec 03 09:05:37 hilda systemd[1]: Mounted FUSE Control File System.
Dec 03 09:05:37 hilda systemd[1]: Mounted Kernel Configuration File System.
Dec 03 09:05:37 hilda systemd[1]: Reached target Swaps.
Dec 03 09:05:37 hilda systemd[1]: Mounting Temporary Directory /tmp...
Dec 03 09:05:37 hilda systemd[1]: Finished Apply Kernel Variables.
Dec 03 09:05:37 hilda systemd[1]: Finished Flush Journal to Persistent Storage.
Dec 03 09:05:37 hilda systemd[1]: Finished Load/Save OS Random Seed.
Dec 03 09:05:37 hilda systemd[1]: mullvad-early-boot-blocking.service: Deactivated successfully.
Dec 03 09:05:37 hilda systemd[1]: Finished Mullvad early boot network blocker.
Dec 03 09:05:37 hilda systemd[1]: Mounted Temporary Directory /tmp.
Dec 03 09:05:37 hilda systemd[1]: Starting User Database Manager...
Dec 03 09:05:37 hilda systemd[1]: Starting CLI Netfilter Manager...
Dec 03 09:05:37 hilda systemd[1]: Started User Database Manager.
Dec 03 09:05:37 hilda systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
Dec 03 09:05:37 hilda systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Dec 03 09:05:37 hilda systemd[1]: Starting Create Static Device Nodes in /dev...
Dec 03 09:05:37 hilda systemd[1]: Finished Create Static Device Nodes in /dev.
Dec 03 09:05:37 hilda systemd[1]: Finished CLI Netfilter Manager.
Dec 03 09:05:37 hilda systemd[1]: Reached target Preparation for Local File Systems.
Dec 03 09:05:37 hilda systemd[1]: Starting Rule-based Manager for Device Events and Files...
Dec 03 09:05:37 hilda systemd[1]: Started Rule-based Manager for Device Events and Files.
Dec 03 09:05:37 hilda systemd[1]: Starting Show Plymouth Boot Screen...
Dec 03 09:05:37 hilda systemd[1]: Started Show Plymouth Boot Screen.
Dec 03 09:05:37 hilda mtp-probe[452]: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1"
Dec 03 09:05:37 hilda mtp-probe[452]: bus: 1, device: 6 was not an MTP device
Dec 03 09:05:37 hilda mtp-probe[454]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2"
Dec 03 09:05:37 hilda mtp-probe[454]: bus: 1, device: 4 was not an MTP device
Dec 03 09:05:37 hilda systemd[1]: Found device NVME 512GB SSD 1.
Dec 03 09:05:37 hilda systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
Dec 03 09:05:37 hilda systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Dec 03 09:05:37 hilda systemd[1]: Reached target Local Encrypted Volumes.
Dec 03 09:05:37 hilda systemd[1]: Starting File System Check on /dev/disk/by-uuid/42A8-45AC...
Dec 03 09:05:37 hilda kernel: mousedev: PS/2 mouse device common for all mice
Dec 03 09:05:37 hilda systemd-fsck[460]: fsck.fat 4.2 (2021-01-31)
Dec 03 09:05:37 hilda systemd-fsck[460]: There are differences between boot sector and its backup.
Dec 03 09:05:37 hilda systemd-fsck[460]: This is mostly harmless. Differences: (offset:original/backup)
Dec 03 09:05:37 hilda systemd-fsck[460]:   65:01/00
Dec 03 09:05:37 hilda systemd-fsck[460]:   Not automatically fixing this.
Dec 03 09:05:37 hilda systemd-fsck[460]: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Dec 03 09:05:37 hilda systemd-fsck[460]:  Automatically removing dirty bit.
Dec 03 09:05:37 hilda systemd-fsck[460]: *** Filesystem was changed ***
Dec 03 09:05:37 hilda systemd-fsck[460]: Writing changes.
Dec 03 09:05:37 hilda systemd-fsck[460]: /dev/nvme0n1p1: 5 files, 74/76643 clusters
Dec 03 09:05:37 hilda kernel: input: Intel HID events as /devices/platform/INTC1051:00/input/input14
Dec 03 09:05:37 hilda systemd[1]: Finished File System Check on /dev/disk/by-uuid/42A8-45AC.
Dec 03 09:05:37 hilda systemd[1]: Created slice Slice /system/systemd-backlight.
Dec 03 09:05:37 hilda systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Dec 03 09:05:37 hilda mtp-probe[474]: checking bus 1, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2"
Dec 03 09:05:37 hilda kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
Dec 03 09:05:37 hilda mtp-probe[476]: checking bus 1, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6.2"
Dec 03 09:05:37 hilda mtp-probe[476]: bus: 1, device: 10 was not an MTP device
Dec 03 09:05:37 hilda systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Dec 03 09:05:37 hilda kernel: kxcjk1013 i2c-KIOX000A:00: mounting matrix not found: using identity...
Dec 03 09:05:38 hilda kernel: kxcjk1013 i2c-KIOX000A:00: supply vdd not found, using dummy regulator
Dec 03 09:05:38 hilda kernel: kxcjk1013 i2c-KIOX000A:00: supply vddio not found, using dummy regulator
Dec 03 09:05:38 hilda kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
Dec 03 09:05:38 hilda kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
Dec 03 09:05:38 hilda kernel: i2c i2c-13: 4/4 memory slots populated (from DMI)
Dec 03 09:05:38 hilda kernel: i2c i2c-13: Memory type 0x23 not supported yet, not instantiating SPD
Dec 03 09:05:38 hilda kernel: spi-nor spi0.0: spi-nor-generic (16384 Kbytes)
Dec 03 09:05:38 hilda kernel: Creating 1 MTD partitions on "0000:00:1f.5":
Dec 03 09:05:38 hilda kernel: 0x000000000000-0x000001000000 : "BIOS"
Dec 03 09:05:38 hilda kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
Dec 03 09:05:38 hilda mtp-probe[474]: bus: 1, device: 9 was not an MTP device
Dec 03 09:05:38 hilda mtp-probe[479]: checking bus 1, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6.1"
Dec 03 09:05:38 hilda mtp-probe[479]: bus: 1, device: 8 was not an MTP device
Dec 03 09:05:38 hilda kernel: input: PC Speaker as /devices/platform/pcspkr/input/input15
Dec 03 09:05:38 hilda kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Dec 03 09:05:38 hilda kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Dec 03 09:05:38 hilda kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Dec 03 09:05:38 hilda kernel: idma64 idma64.2: Found Intel integrated DMA 64-bit
Dec 03 09:05:38 hilda kernel: mc: Linux media interface: v0.10
Dec 03 09:05:38 hilda kernel: Bluetooth: Core ver 2.22
Dec 03 09:05:38 hilda kernel: NET: Registered PF_BLUETOOTH protocol family
Dec 03 09:05:38 hilda kernel: Bluetooth: HCI device and connection manager initialized
Dec 03 09:05:38 hilda kernel: Bluetooth: HCI socket layer initialized
Dec 03 09:05:38 hilda kernel: Bluetooth: L2CAP socket layer initialized
Dec 03 09:05:38 hilda kernel: Bluetooth: SCO socket layer initialized
Dec 03 09:05:38 hilda kernel: Intel(R) Wireless WiFi driver for Linux
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Detected crf-id 0x1300202, cnv-id 0x80400 wfpm id 0x80000030
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: PCI dev 54f0/0034, rev=0x370, rfid=0x105110
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-83.ucode failed with error -2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-82.ucode failed with error -2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-81.ucode failed with error -2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-80.ucode failed with error -2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-79.ucode failed with error -2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-78.ucode failed with error -2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: loaded firmware version 77.f92b5fed.0 so-a0-jf-b0-77.ucode op_mode iwlmvm
Dec 03 09:05:38 hilda systemd[1]: Mounting /boot/efi...
Dec 03 09:05:38 hilda systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
Dec 03 09:05:38 hilda systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Dec 03 09:05:38 hilda systemd[1]: Stopped Virtual Console Setup.
Dec 03 09:05:38 hilda systemd[1]: Stopping Virtual Console Setup...
Dec 03 09:05:38 hilda systemd[1]: Starting Virtual Console Setup...
Dec 03 09:05:38 hilda systemd[1]: run-credentials-systemd\x2dvconsole\x2dsetup.service.mount: Deactivated successfully.
Dec 03 09:05:38 hilda systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 03 09:05:38 hilda systemd-vconsole-setup[499]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Dec 03 09:05:38 hilda kernel: iTCO_vendor_support: vendor-support=0
Dec 03 09:05:38 hilda systemd[1]: Finished Virtual Console Setup.
Dec 03 09:05:38 hilda kernel: input: GXTP7386:00 27C6:0111 as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input16
Dec 03 09:05:38 hilda kernel: input: GXTP7386:00 27C6:0111 Stylus as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input17
Dec 03 09:05:38 hilda kernel: input: GXTP7386:00 27C6:0111 UNKNOWN as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input18
Dec 03 09:05:38 hilda kernel: input: GXTP7386:00 27C6:0111 Keyboard as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-14/i2c-GXTP7386:00/0018:27C6:0111.0004/input/input19
Dec 03 09:05:38 hilda kernel: hid-multitouch 0018:27C6:0111.0004: input,hidraw3: I2C HID v1.00 Keyboard [GXTP7386:00 27C6:0111] on i2c-GXTP7386:00
Dec 03 09:05:38 hilda systemd[1]: Mounted /boot/efi.
Dec 03 09:05:38 hilda systemd[1]: Reached target Local File Systems.
Dec 03 09:05:38 hilda systemd[1]: Listening on Boot Entries Service Socket.
Dec 03 09:05:38 hilda systemd[1]: Listening on System Extension Image Management.
Dec 03 09:05:38 hilda kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
Dec 03 09:05:38 hilda kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Dec 03 09:05:38 hilda systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
Dec 03 09:05:38 hilda systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Dec 03 09:05:38 hilda systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
Dec 03 09:05:38 hilda systemd[1]: Update Boot Loader Random Seed was skipped because no trigger condition checks were met.
Dec 03 09:05:38 hilda kernel: RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
Dec 03 09:05:38 hilda kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Dec 03 09:05:38 hilda kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
Dec 03 09:05:38 hilda kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
Dec 03 09:05:38 hilda kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
Dec 03 09:05:38 hilda systemd[1]: Starting Create System Files and Directories...
Dec 03 09:05:38 hilda kernel: cryptd: max_cpu_qlen set to 1000
Dec 03 09:05:38 hilda kernel: dw-apb-uart.2: ttyS4 at MMIO 0xfe03e000 (irq = 20, base_baud = 114825) is a 16550A
Dec 03 09:05:38 hilda systemd[1]: Received SIGRTMIN+20 from PID 181 (plymouthd).
Dec 03 09:05:38 hilda systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
Dec 03 09:05:38 hilda kernel: AVX2 version of gcm_enc/dec engaged.
Dec 03 09:05:38 hilda kernel: AES CTR mode by8 optimization enabled
Dec 03 09:05:38 hilda kernel: videodev: Linux video capture interface: v2.00
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x370
Dec 03 09:05:38 hilda kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Dec 03 09:05:38 hilda kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Dec 03 09:05:38 hilda kernel: usb 1-6.1: Found UVC 1.00 device USB2.0 camera (0bda:5830)
Dec 03 09:05:38 hilda kernel: usb 1-6.2: Found UVC 1.00 device USB 2.0 Camera (1bcf:284d)
Dec 03 09:05:38 hilda kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=2 (0x14/0x19/0x0/0x0/0x0) type:speaker
Dec 03 09:05:38 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Dec 03 09:05:38 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
Dec 03 09:05:38 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
Dec 03 09:05:38 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
Dec 03 09:05:38 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
Dec 03 09:05:38 hilda kernel: snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
Dec 03 09:05:38 hilda kernel: usbcore: registered new interface driver btusb
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Device revision is 2
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Secure boot is enabled
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: OTP lock is enabled
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: API lock is enabled
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Debug lock is disabled
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: No support for _PRR ACPI method
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0040-2120.sfi
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Boot Address: 0x100800
Dec 03 09:05:38 hilda kernel: Bluetooth: hci0: Firmware Version: 151-5.24
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Detected RF JF, rfid=0x105110
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Dec 03 09:05:38 hilda kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
Dec 03 09:05:38 hilda kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
Dec 03 09:05:38 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
Dec 03 09:05:38 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
Dec 03 09:05:38 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
Dec 03 09:05:38 hilda kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
Dec 03 09:05:38 hilda kernel: usbcore: registered new interface driver uvcvideo
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: base HW address: 8c:e9:ee:90:fc:2c
Dec 03 09:05:38 hilda systemd[1]: Finished Create System Files and Directories.
Dec 03 09:05:38 hilda systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Dec 03 09:05:38 hilda systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Dec 03 09:05:38 hilda systemd[1]: Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
Dec 03 09:05:38 hilda systemd[1]: Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
Dec 03 09:05:38 hilda systemd[1]: Starting Network Time Synchronization...
Dec 03 09:05:38 hilda systemd[1]: Update is Completed was skipped because no trigger condition checks were met.
Dec 03 09:05:38 hilda systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Dec 03 09:05:38 hilda systemd[1]: Starting Load/Save RF Kill Switch Status...
Dec 03 09:05:38 hilda systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
Dec 03 09:05:38 hilda systemd[1]: Starting Load Kernel Module dm_mod...
Dec 03 09:05:38 hilda systemd[1]: Starting Load Kernel Module loop...
Dec 03 09:05:38 hilda systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Dec 03 09:05:38 hilda systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Dec 03 09:05:38 hilda systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Dec 03 09:05:38 hilda systemd[1]: Started Load/Save RF Kill Switch Status.
Dec 03 09:05:38 hilda systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Dec 03 09:05:38 hilda systemd[1]: Finished Load Kernel Module dm_mod.
Dec 03 09:05:38 hilda systemd[1]: modprobe@loop.service: Deactivated successfully.
Dec 03 09:05:38 hilda systemd[1]: Finished Load Kernel Module loop.
Dec 03 09:05:38 hilda systemd[1]: Started Network Time Synchronization.
Dec 03 09:05:38 hilda systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Dec 03 09:05:38 hilda systemd[1]: Reached target System Time Set.
Dec 03 09:05:38 hilda kernel: intel_tcc_cooling: Programmable TCC Offset detected
Dec 03 09:05:38 hilda kernel: intel_rapl_msr: PL4 support detected.
Dec 03 09:05:38 hilda kernel: intel_rapl_common: Found RAPL domain package
Dec 03 09:05:38 hilda kernel: intel_rapl_common: Found RAPL domain core
Dec 03 09:05:38 hilda kernel: intel_rapl_common: Found RAPL domain uncore
Dec 03 09:05:38 hilda kernel: intel_rapl_common: Found RAPL domain psys
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: timeout waiting for FW reset ACK (inta_hw=0x0)
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-jf-b0-77.ucode
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00A002F0 | trm_hw_status0
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x004D2A06 | branchlink2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | data1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x01000000 | data2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | beacon time
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x0001BC43 | tsf low
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00026A8D | time gp2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x0000004D | uCode version major
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0xF92B5FED | uCode version minor
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000370 | hw version
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00480002 | board version
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x802EFF00 | hcmd
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00020000 | isr0
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x58F00002 | isr2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00C0000C | isr3
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | wait_event
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000028 | flow_handler
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data2
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac major
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac minor
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | frame pointer
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | stack pointer
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00004C29 | IML/ROM data1
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: Fseq Registers:
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x20000000 | FSEQ_ERROR_CODE
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x80330000 | FSEQ_TOP_INIT_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00010009 | FSEQ_CNVIO_INIT_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x071A45A7 | FSEQ_TOP_CONTENT_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_PREV_CNVIO_INIT_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00330000 | FSEQ_WIFI_FSEQ_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x5BFCAA6B | FSEQ_BT_FSEQ_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: 0x00000122 | FSEQ_CLASS_TP_VERSION
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x8047e450
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
Dec 03 09:05:38 hilda kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
Dec 03 09:05:39 hilda systemd[1]: Finished Load Kernel Module dm_mod.
Dec 03 09:05:39 hilda systemd[1]: modprobe@loop.service: Deactivated successfully.
Dec 03 09:05:39 hilda systemd[1]: Finished Load Kernel Module loop.
Dec 03 09:05:39 hilda kernel: iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Waiting for firmware download to complete
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Firmware loaded in 1965722 usecs
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Waiting for device to boot
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Device booted in 16845 usecs
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-2120.ddc
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
Dec 03 09:05:40 hilda kernel: Bluetooth: hci0: Firmware timestamp 2024.5 buildtype 1 build 151
Dec 03 09:05:44 hilda systemd[1]: systemd-rfkill.service: Deactivated successfully.
Dec 03 09:07:07 hilda systemd[1]: dev-tpmrm0.device: Job dev-tpmrm0.device/start timed out.
Dec 03 09:07:07 hilda systemd[1]: Timed out waiting for device /dev/tpmrm0.
Dec 03 09:07:07 hilda systemd[1]: dev-tpmrm0.device: Job dev-tpmrm0.device/start failed with result 'timeout'.
Dec 03 09:07:07 hilda systemd[1]: Reached target Trusted Platform Module.
Dec 03 09:07:07 hilda systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:07:07 hilda systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:07:07 hilda systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:07:07 hilda systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:07:07 hilda systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Dec 03 09:07:07 hilda systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:07:07 hilda systemd[1]: Reached target System Initialization.
Dec 03 09:07:07 hilda systemd[1]: Started CUPS Scheduler.
Dec 03 09:07:07 hilda systemd[1]: Started Refresh existing PGP keys of archlinux-keyring regularly.
Dec 03 09:07:07 hilda systemd[1]: Started Daily rotation of log files.
Dec 03 09:07:07 hilda systemd[1]: Started Daily man-db regeneration.
Dec 03 09:07:07 hilda systemd[1]: Started Monthly clean packages cache.
Dec 03 09:07:07 hilda systemd[1]: Started Generate mirrorlist weekly.
Dec 03 09:07:07 hilda systemd[1]: Started Daily verification of password and group files.
Dec 03 09:07:07 hilda systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec 03 09:07:07 hilda systemd[1]: Reached target Path Units.
Dec 03 09:07:07 hilda systemd[1]: Reached target Timer Units.
Dec 03 09:07:07 hilda systemd[1]: Listening on CUPS Scheduler.
Dec 03 09:07:07 hilda systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec 03 09:07:07 hilda systemd[1]: Listening on GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Dec 03 09:07:07 hilda systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Dec 03 09:07:07 hilda systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Dec 03 09:07:07 hilda systemd[1]: Listening on GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Dec 03 09:07:07 hilda systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Dec 03 09:07:07 hilda systemd[1]: Listening on GnuPG public key management service for /etc/pacman.d/gnupg.
Dec 03 09:07:07 hilda systemd[1]: Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Dec 03 09:07:07 hilda systemd[1]: Listening on Hostname Service Socket.
Dec 03 09:07:07 hilda systemd[1]: Reached target Socket Units.
Dec 03 09:07:07 hilda systemd[1]: Starting D-Bus System Message Bus...
Dec 03 09:07:07 hilda systemd[1]: TPM PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:07:07 hilda systemd[1]: Started D-Bus System Message Bus.
Dec 03 09:07:07 hilda systemd[1]: Reached target Basic System.
Dec 03 09:07:07 hilda systemd[1]: Starting Network Manager...
Dec 03 09:07:07 hilda systemd[1]: Starting Save/Restore Sound Card State...
Dec 03 09:07:07 hilda systemd[1]: Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
Dec 03 09:07:07 hilda systemd[1]: Starting Bluetooth service...
Dec 03 09:07:07 hilda dbus-broker-launch[560]: Ready
Dec 03 09:07:07 hilda systemd[1]: Started [Mount SMB Shares].
Dec 03 09:07:07 hilda systemd[1]: Starting Authorization Manager...
Dec 03 09:07:07 hilda systemd[1]: SSH Key Generation was skipped because no trigger condition checks were met.
Dec 03 09:07:07 hilda systemd[1]: Starting User Login Management...
Dec 03 09:07:07 hilda systemd[1]: TPM PCR Barrier (User) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 03 09:07:07 hilda mount-smb-shares[569]: ping: connect: Network is unreachable
Dec 03 09:07:07 hilda mount-smb-shares[565]: ..........
Dec 03 09:07:07 hilda systemd[1]: Finished Save/Restore Sound Card State.
Dec 03 09:07:07 hilda systemd[1]: Reached target Sound Card.
Dec 03 09:07:07 hilda bluetoothd[564]: Bluetooth daemon 5.79
Dec 03 09:07:07 hilda systemd[1]: Started Bluetooth service.
Dec 03 09:07:07 hilda systemd[1]: Reached target Bluetooth Support.
Dec 03 09:07:07 hilda bluetoothd[564]: Starting SDP server
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.3483] NetworkManager (version 1.50.0-1) is starting... (boot:df8d29c6-1854-485f-88c6-90122da75dcf)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.3488] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Dec 03 09:07:07 hilda systemd[1]: Starting Hostname Service...
Dec 03 09:07:07 hilda kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Dec 03 09:07:07 hilda kernel: Bluetooth: BNEP filters: protocol multicast
Dec 03 09:07:07 hilda kernel: Bluetooth: BNEP socket layer initialized
Dec 03 09:07:07 hilda systemd-logind[567]: New seat seat0.
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support bap plugin
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support bass plugin
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support mcp plugin
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support vcp plugin
Dec 03 09:07:07 hilda bluetoothd[564]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support micp plugin
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support ccp plugin
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support csip plugin
Dec 03 09:07:07 hilda bluetoothd[564]: src/plugin.c:init_plugin() System does not support asha plugin
Dec 03 09:07:07 hilda bluetoothd[564]: Bluetooth management interface 1.22 initialized
Dec 03 09:07:07 hilda bluetoothd[564]: Battery Provider Manager created
Dec 03 09:07:07 hilda kernel: Bluetooth: MGMT ver 1.22
Dec 03 09:07:07 hilda systemd-logind[567]: Watching system buttons on /dev/input/event1 (Power Button)
Dec 03 09:07:07 hilda kernel: NET: Registered PF_ALG protocol family
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.3861] manager[0x558ae4b520c0]: monitoring kernel firmware directory '/lib/firmware'.
Dec 03 09:07:07 hilda systemd-logind[567]: Watching system buttons on /dev/input/event0 (Lid Switch)
Dec 03 09:07:07 hilda systemd-logind[567]: Watching system buttons on /dev/input/event4 (HID 1018:1006)
Dec 03 09:07:07 hilda systemd-logind[567]: Watching system buttons on /dev/input/event7 (HID 1018:1006 System Control)
Dec 03 09:07:07 hilda systemd-logind[567]: Watching system buttons on /dev/input/event8 (HID 1018:1006 Consumer Control)
Dec 03 09:07:07 hilda polkitd[566]: Started polkitd version 125
Dec 03 09:07:07 hilda systemd-logind[567]: Watching system buttons on /dev/input/event10 (Intel HID events)
Dec 03 09:07:07 hilda systemd-logind[567]: Watching system buttons on /dev/input/event2 (AT Translated Set 2 keyboard)
Dec 03 09:07:07 hilda systemd[1]: Started User Login Management.
Dec 03 09:07:07 hilda systemd[1]: Started Authorization Manager.
Dec 03 09:07:07 hilda systemd[1]: Starting Modem Manager...
Dec 03 09:07:07 hilda systemd[1]: Started Hostname Service.
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4201] hostname: hostname: using hostnamed
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4201] hostname: static hostname changed from (none) to "hilda"
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4207] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
Dec 03 09:07:07 hilda bluetoothd[564]: Failed to set mode: Failed (0x03)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4218] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/ieee80211/phy0/rfkill1) (driver iwlwifi)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4219] manager[0x558ae4b520c0]: rfkill: Wi-Fi hardware radio set enabled
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4219] manager[0x558ae4b520c0]: rfkill: WWAN hardware radio set enabled
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4304] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-bluetooth.so)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4316] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-ovs.so)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4321] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-adsl.so)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4325] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-wwan.so)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4333] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-wifi.so)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4521] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-team.so)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4530] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4531] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4532] manager: Networking is enabled by state file
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4546] settings: Loaded settings plugin: keyfile (internal)
Dec 03 09:07:07 hilda ModemManager[625]: <msg> ModemManager (version 1.22.0-1) starting in system bus...
Dec 03 09:07:07 hilda systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4642] dhcp: init: Using DHCP client 'internal'
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4648] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4680] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', managed-type: 'external')
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4691] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', managed-type: 'external')
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4698] device (lo): Activation: starting connection 'lo' (31c499ad-9cc9-4282-b88f-cafa219ed9c1)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4703] device (wlp0s20f3): driver supports Access Point (AP) mode
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4708] manager: (wlp0s20f3): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/2)
Dec 03 09:07:07 hilda NetworkManager[562]: <info>  [1733180827.4710] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Dec 03 09:07:07 hilda systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 03 09:07:07 hilda systemd[1]: Started Modem Manager.
Dec 03 09:07:07 hilda kernel: NET: Registered PF_QIPCRTR protocol family
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: timeout waiting for FW reset ACK (inta_hw=0x0)
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-jf-b0-77.ucode
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x000002F0 | trm_hw_status0
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x004D2A06 | branchlink2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | data1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x01000000 | data2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | beacon time
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x0002352A | tsf low
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x0002E9BB | time gp2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x0000004D | uCode version major
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0xF92B5FED | uCode version minor
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000370 | hw version
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00480002 | board version
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x8074FF00 | hcmd
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00020000 | isr0
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x48F04002 | isr2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00C3000C | isr3
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00210148 | last cmd Id
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00011F5A | wait_event
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000018 | lmpm_pmg_sel
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00002044 | flow_handler
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data2
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac major
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac minor
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | frame pointer
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | stack pointer
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00004F71 | IML/ROM data1
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: Fseq Registers:
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x80330000 | FSEQ_TOP_INIT_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00010009 | FSEQ_CNVIO_INIT_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x071A45A7 | FSEQ_TOP_CONTENT_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00010009 | FSEQ_PREV_CNVIO_INIT_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00330000 | FSEQ_WIFI_FSEQ_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00330000 | FSEQ_BT_FSEQ_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: 0x00000122 | FSEQ_CLASS_TP_VERSION
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x8047e450
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
Dec 03 09:07:07 hilda kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.3806] device (wlp0s20f3): set-hw-addr: set MAC address to C2:87:FC:C8:73:18 (scanning)
Dec 03 09:07:08 hilda kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Dec 03 09:07:08 hilda kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Dec 03 09:07:08 hilda kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Dec 03 09:07:08 hilda kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Dec 03 09:07:08 hilda kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5621] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5642] ovsdb: disconnected from ovsdb
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5644] device (lo): state change: disconnected -> prepare (reason 'none', managed-type: 'external')
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5647] device (lo): state change: prepare -> config (reason 'none', managed-type: 'external')
Dec 03 09:07:08 hilda systemd[1]: Started Network Manager.
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5651] device (lo): state change: config -> ip-config (reason 'none', managed-type: 'external')
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5653] device (lo): state change: ip-config -> ip-check (reason 'none', managed-type: 'external')
Dec 03 09:07:08 hilda systemd[1]: Started Mullvad VPN daemon.
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5675] device (lo): state change: ip-check -> secondaries (reason 'none', managed-type: 'external')
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5678] device (lo): state change: secondaries -> activated (reason 'none', managed-type: 'external')
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5686] device (lo): Activation: successful, device activated.
Dec 03 09:07:08 hilda NetworkManager[562]: <info>  [1733180828.5695] modem-manager: ModemManager available
Dec 03 09:07:08 hilda systemd[1]: Starting WPA supplicant...
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_daemon::version][INFO] Starting mullvad-daemon - 2024.7 2024-10-30
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_daemon][INFO] Logging to /var/log/mullvad-vpn
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_daemon::management_interface][INFO] Management interface listening on /var/run/mullvad-vpn
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_api::address_cache][DEBUG] Loading API addresses from /var/cache/mullvad-vpn/api-ip-address.txt
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_api::address_cache][DEBUG] Using API address: 45.83.223.196:443
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_api::availability][DEBUG] Suspending API requests
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_daemon::settings][INFO] Loading settings from /etc/mullvad-vpn/settings.json
Dec 03 09:07:08 hilda mullvad-daemon[637]: [mullvad_relay_selector::relay_selector::parsed_relays][DEBUG] Reading relays from /var/cache/mullvad-vpn/relays.json
Dec 03 09:07:08 hilda systemd[1]: Started WPA supplicant.
Dec 03 09:07:08 hilda wpa_supplicant[638]: Successfully initialized wpa_supplicant
Dec 03 09:07:08 hilda systemd[1]: Reached target Network.
No boot at all, either kernel.
/boot/intel-ucode.img not found
Right, you should have also updated grub menu. Normally that should have happened automatically. Press ESC to load the grub menu. Then select the entry and press E for edit. There scroll down to the line which states /boot/intel-ucode.img and remove /boot/intel-ucode.img. Start with CTRL+X.
Removing /boot/intel-ucode.img and /boot/amd-ucode.img during the boot up process, allowed me to boot into plasma with the 6.12 kernel, then the computer hung.
After booting into 6.6 and then running update-grub then rebooting to 6.12, the boot failed before loading plasma.
It boots fine with 6.6
This looks like the point at which the 6.12 boot failed:
Dec 03 13:48:25 hilda kwin_wayland[769]: kwin_wayland_drm: Pageflip timed out! This is a kern>
Dec 03 13:48:26 hilda systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.servic>
Dec 03 13:48:26 hilda systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: D>
Dec 03 13:48:26 hilda systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Dea>
Dec 03 13:48:28 hilda firefox[1361]: [GFX1-]: Failed to compile vertex shader: brush_solid_AL>
Dec 03 13:48:28 hilda firefox[1361]: [ERROR webrender::device::gl] Failed to compile vertex s>
Dec 03 13:48:28 hilda firefox[1361]: [GFX1-]: Failed to compile vertex shader: ps_text_run_AL>
-- Boot 326f77e3714647f7813881e01494e887 --
To me that looks like wayland and plasma loaded, but the autoload of Firefox did something to block the process.
Hmm, so I don’t think the microcode is the issue here. Might be something else. What happens if you load the X11 session of Plasma 6.2?
I was about to try that, but I have to now wait until I get access again.
It’s difficult doing fault finding for my partner.
last time I tried, with the RC of 6.12, it worked with x11
Well, or simply use the older kernel for now.
Yeah that’s what I left it with.
I received the following from Starlabs, this morning.
The issue you’ve described is most likely this one
https://github.com/StarLabsLtd/firmware/issues/181. We should have
another firmware update out soon which will help to mitigate this.
So I’ll close this.
Right, I was working with them on such an issue but forgot about the coreboot firmware. You may add initcall_blacklist=simpledrm_platform_driver_init to the kernel boot line in /etc/default/grub and rebuild your menu with update-grub.
Yeah I was planning on doing that,thanks.
I’ll let you know when I’ done it.
3
This work around works. The Device is stable running with kernel 6.12.x
